Retrieve files with the most I/O activity
Retrieves a list of files with the highest I/O activity, helping you identify which files are most frequently accessed or modified.
HTTP method and endpoint
GET /storage/volumes/{volume.uuid}/top-metrics/files
Introduced in
ONTAP 9.10
Usage notes
Retrieves a list of files with the most I/O activity.
volume.uuid |
string |
path |
True |
Volume UUID |
top_metric |
string |
query |
False |
I/O activity type
max_records_per_volume |
integer |
query |
False |
Max records per volume. |
volume.name |
string |
query |
False |
Filter by volume.name |
total_throughput.write |
integer |
query |
False |
Filter by total_throughput.write
total_throughput.error.lower_bound |
integer |
query |
False |
Filter by total_throughput.error.lower_bound
total_throughput.error.upper_bound |
integer |
query |
False |
Filter by total_throughput.error.upper_bound
total_throughput.read |
integer |
query |
False |
Filter by total_throughput.read
total_ops.read |
integer |
query |
False |
Filter by total_ops.read
total_ops.error.lower_bound |
integer |
query |
False |
Filter by total_ops.error.lower_bound
total_ops.error.upper_bound |
integer |
query |
False |
Filter by total_ops.error.upper_bound
total_ops.write |
integer |
query |
False |
Filter by total_ops.write
path |
string |
query |
False |
Filter by path |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
iops.write |
integer |
query |
False |
Filter by iops.write |
iops.error.lower_bound |
integer |
query |
False |
Filter by iops.error.lower_bound |
iops.error.upper_bound |
integer |
query |
False |
Filter by iops.error.upper_bound |
iops.read |
integer |
query |
False |
Filter by iops.read |
throughput.write |
integer |
query |
False |
Filter by throughput.write |
integer |
query |
False |
Filter by throughput.error.lower_bound |
integer |
query |
False |
Filter by throughput.error.upper_bound |
throughput.read |
integer |
query |
False |
Filter by throughput.read |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
incomplete_response_reason |
Indicates that the metric report provides incomplete data. |
notice |
Optional field that indicates why no records are returned by the volume activity tracking REST API. |
num_records |
integer |
Number of records. |
observation_window |
The time window over which metrics are aggregated. |
partial_response_reason |
Indicates that the metric report provides partial data. |
records |
array[top_metrics_file] |
"next": {
"href": "/api/resourcelink"
"incomplete_response_reason": {
"code": "111411207",
"message": "Partial data has been returned for this metric report. Reason: The activity tracking report for this volume is not available because the system is busy collecting tracking data."
"notice": {
"message": "No read/write traffic on volume."
"num_records": 1,
"observation_window": {
"duration": 60,
"end": "2026-01-11 01:30:00 +0000",
"start": "2026-01-11 01:29:55 +0000"
"partial_response_reason": {
"code": "124518424",
"message": "The top metrics report contains partial data for read operations because NFSv4 reads using Multi-Processor I/O (MPIO) are not tracked."
"records": [
"metadata": {
"iops": {
"error": {
"lower_bound": 34,
"upper_bound": 54
"read": 5,
"write": 4
"path": "/dir_abc/dir_123/file_1",
"svm": {
"name": "svm1",
"throughput": {
"error": {
"lower_bound": 34,
"upper_bound": 54
"read": 2,
"write": 20
"total_ops": {
"error": {
"lower_bound": 34,
"upper_bound": 54
"read": 1400,
"write": 400
"total_throughput": {
"error": {
"lower_bound": 34,
"upper_bound": 54
"read": 2800,
"write": 600
"volume": {
"name": "volume1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
124518405 |
Volume activity tracking is not supported on volumes that contain LUNs. |
124518407 |
Volume activity tracking is not supported on FlexCache volumes. |
124518408 |
Volume activity tracking is not supported on audit staging volumes. |
124518409 |
Volume activity tracking is not supported on object store server volumes. |
124518410 |
Volume activity tracking is not supported on SnapMirror destination volumes. |
124518411 |
Enabling or disabling volume activity tracking is not supported on individual FlexGroup constituents. |
124518412 |
Volume activity tracking is not supported on SnapLock volumes. |
124518414 |
Volume activity tracking is not supported on volumes that contain NVMe namespaces. |
124518415 |
Failed to get the volume activity tracking report on volume volume.name in SVM svm.name. |
124518416 |
Internal error. Volume activity tracking report timed out for volume volume.name in SVM svm.name. |
124518417 |
Volume wildcard queries are not supported for activity tracking reports. |
124518418 |
The activity tracking report for volume volume.name in SVM svm.name returned zero records. Check whether the volume has read/write traffic. Refer to the REST API documentation for more information. |
124518422 |
Volume activity tracking is not supported on All SAN Array clusters. |
124518423 |
Volume activity tracking is not supported on the volume. |
124519411 |
Volume activity tracking is not enabled on the volume. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
code |
string |
Warning code indicating why partial data was reported. |
message |
string |
A message describing the reason for partial data. |
notice
code |
string |
Warning code indicating why no records are returned. |
message |
string |
Details why no records are returned. |
observation_window
duration |
integer |
Duration of the observation window in seconds. |
end |
string |
End timestamp of the observation window in UTC. |
start |
string |
Start timestamp of the observation window in UTC. |
code |
string |
message |
string |
_links
metadata |
self |
top_metric_value_error_bounds
lower_bound |
integer |
Lower bound of the nominal value of a metric. |
upper_bound |
integer |
Upper bound of the nominal value of a metric. |
iops
error |
read |
integer |
Average number of read operations per second. |
write |
integer |
Average number of write operations per second. |
_links
self |
svm
_links |
name |
string |
uuid |
string |
throughput
error |
read |
integer |
Average number of read bytes received per second. |
write |
integer |
Average number of write bytes received per second. |
total_ops
error |
read |
integer |
Total read operations in the observation window. |
write |
integer |
Total write operations in the observation window. |
total_throughput
error |
read |
integer |
Total bytes read in the observation window. |
write |
integer |
Total bytes written in the observation window. |
volume
_links |
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
top_metrics_file
Information about a file's IO activity.
_links |
iops |
path |
string |
Path of the file. |
svm |
throughput |
total_ops |
total_throughput |
volume |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
