REST API reference
Retrieve volumes
Retrieves information about volumes, helping you to manage and monitor storage resources effectively.
HTTP method and endpoint
GET /storage/volumes
Introduced in
ONTAP 9.6
Usage notes
Retrieves volumes.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • is_svm_root
  • aggressive_readahead_mode
  • analytics.*
  • anti_ransomware.*
  • application.*
  • encryption.*
  • queue_for_encryption
  • convert_unicode
  • clone.parent_snapshot.name
  • clone.parent_snapshot.uuid
  • clone.parent_svm.name
  • clone.parent_svm.uuid
  • clone.parent_volume.name
  • clone.parent_volume.uuid
  • clone.split_complete_percent
  • clone.split_estimate
  • clone.split_initiated
  • efficiency.*
  • error_state.*
  • files.*
  • max_dir_size
  • nas.export_policy.id
  • nas.gid
  • nas.path
  • nas.security_style
  • nas.uid
  • nas.unix_permissions
  • nas.junction_parent.name
  • nas.junction_parent.uuid
  • snaplock.*
  • restore_to.*
  • snapshot_policy.uuid
  • quota.*
  • qos.*
  • flexcache_endpoint_type
  • space.block_storage_inactive_user_data
  • space.capacity_tier_footprint
  • space.performance_tier_footprint
  • space.local_tier_footprint
  • space.footprint
  • space.over_provisioned
  • space.metadata
  • space.total_footprint
  • space.dedupe_metafiles_footprint
  • space.dedupe_metafiles_temporary_footprint
  • space.delayed_free_footprint
  • space.file_operation_metadata
  • space.snapmirror_destination_footprint
  • space.volume_guarantee_footprint
  • space.cross_volume_dedupe_metafiles_footprint
  • space.cross_volume_dedupe_metafiles_temporary_footprint
  • space.snapshot_reserve_unusable
  • space.snapshot_spill
  • space.user_data
  • space.logical_space.*
  • space.snapshot.*
  • space.used_by_afs
  • space.afs_total
  • space.available_percent
  • space.full_threshold_percent
  • space.nearly_full_threshold_percent
  • space.overwrite_reserve
  • space.overwrite_reserve_used
  • space.size_available_for_snapshots
  • space.percent_used
  • space.fractional_reserve
  • space.block_storage_inactive_user_data_percent
  • space.physical_used
  • space.physical_used_percent
  • space.expected_available
  • space.filesystem_size
  • space.filesystem_size_fixed
  • guarantee.*
  • autosize.*
  • movement.*
  • statistics.*
  • constituents.name
  • constituents.space.size
  • constituents.space.available
  • constituents.space.used
  • constituents.space.available_percent
  • constituents.space.used_percent
  • constituents.space.block_storage_inactive_user_data
  • constituents.space.capacity_tier_footprint
  • constituents.space.performance_tier_footprint
  • constituents.space.local_tier_footprint
  • constituents.space.footprint
  • constituents.space.over_provisioned
  • constituents.space.metadata
  • constituents.space.total_footprint
  • constituents.space.logical_space.reporting
  • constituents.space.logical_space.enforcement
  • constituents.space.logical_space.used_by_afs
  • constituents.space.logical_space.available
  • constituents.space.snapshot.used
  • constituents.space.snapshot.reserve_percent
  • constituents.space.snapshot.autodelete_enabled
  • constituents.space.large_size_enabled
  • constituents.space.max_size
  • constituents.space.total_metadata
  • constituents.space.total_metadata_footprint
  • constituents.aggregates.name
  • constituents.aggregates.uuid
  • constituents.movement.destination_aggregate.name
  • constituents.movement.destination_aggregate.uuid
  • constituents.movement.state
  • constituents.movement.percent_complete
  • constituents.movement.cutover_window
  • constituents.movement.tiering_policy
  • asynchronous_directory_delete.*
  • rebalancing.*
  • metric.*
  • cloud_write_enabled
  • volume show
  • volume clone show
  • volume efficiency show
  • volume encryption show
  • volume flexcache show
  • volume flexgroup show
  • volume move show
  • volume quota show
  • volume show-space
  • volume snaplock show
  • volume rebalance show
  • security anti-ransomware volume show
  • security anti-ransomware volume space show
  • volume file async-delete client show
is_constituent
boolean
query
False
When set to false, only FlexVol and FlexGroup volumes are returned. When set to true, only FlexGroup constituent volumes are returned. Default for GET calls is false.
  • Default value:
  • Introduced in: 9.10
error_state.is_inconsistent
boolean
query
False
Filter by error_state.is_inconsistent
error_state.has_bad_blocks
boolean
query
False
Filter by error_state.has_bad_blocks
constituents.name
string
query
False
Filter by constituents.name
  • Introduced in: 9.9
integer
query
False
Filter by constituents.space.available_percent
integer
query
False
Filter by constituents.space.over_provisioned
integer
query
False
Filter by constituents.space.local_tier_footprint
constituents.space.afs_total
integer
query
False
Filter by constituents.space.afs_total
integer
query
False
integer
query
False
Filter by constituents.space.size
integer
query
False
Filter by constituents.space.metadata
integer
query
False
Filter by constituents.space.snapshot.used
integer
query
False
Filter by constituents.space.snapshot.reserve_percent
integer
query
False
Filter by constituents.space.total_footprint
boolean
query
False
Filter by constituents.space.large_size_enabled
  • Introduced in: 9.12
boolean
query
False
Filter by constituents.space.logical_space.reporting
integer
query
False
Filter by constituents.space.logical_space.available
boolean
query
False
Filter by constituents.space.logical_space.enforcement
integer
query
False
Filter by constituents.space.logical_space.used_by_afs
integer
query
False
Filter by constituents.space.block_storage_inactive_user_data
integer
query
False
Filter by constituents.space.used
integer
query
False
Filter by constituents.space.total_metadata_footprint
  • Introduced in: 9.15
integer
query
False
Filter by constituents.space.capacity_tier_footprint
integer
query
False
integer
query
False
Filter by constituents.space.footprint
integer
query
False
Filter by constituents.space.used_percent
integer
query
False
Filter by constituents.space.performance_tier_footprint
constituents.space.used_by_afs
integer
query
False
Filter by constituents.space.used_by_afs
string
query
False
Filter by constituents.space.max_size
  • Introduced in: 9.14
string
query
False
Filter by constituents.movement.destination_aggregate.uuid
string
query
False
Filter by constituents.movement.destination_aggregate.name
integer
query
False
Filter by constituents.movement.percent_complete
string
query
False
Filter by constituents.movement.state
integer
query
False
Filter by constituents.movement.cutover_window
string
query
False
Filter by constituents.aggregates.name
string
query
False
Filter by constituents.aggregates.uuid
convert_unicode
boolean
query
False
Filter by convert_unicode
style
string
query
False
Filter by style
language
string
query
False
Filter by language
cloud_write_enabled
boolean
query
False
Filter by cloud_write_enabled
  • Introduced in: 9.13
rebalancing.state
string
query
False
Filter by rebalancing.state
  • Introduced in: 9.11
rebalancing.stop_time
string
query
False
Filter by rebalancing.stop_time
rebalancing.exclude_snapshots
boolean
query
False
Filter by rebalancing.exclude_snapshots
rebalancing.max_runtime
string
query
False
Filter by rebalancing.max_runtime
rebalancing.engine.movement.most_recent_start_time
string
query
False
Filter by rebalancing.engine.movement.most_recent_start_time
rebalancing.engine.movement.last_error.code
integer
query
False
Filter by rebalancing.engine.movement.last_error.code
rebalancing.engine.movement.last_error.file_id
integer
query
False
Filter by rebalancing.engine.movement.last_error.file_id
rebalancing.engine.movement.last_error.time
string
query
False
Filter by rebalancing.engine.movement.last_error.time
rebalancing.engine.movement.last_error.destination
integer
query
False
Filter by rebalancing.engine.movement.last_error.destination
rebalancing.engine.movement.file_moves_started
integer
query
False
Filter by rebalancing.engine.movement.file_moves_started
rebalancing.engine.scanner.blocks_skipped.in_snapshot
integer
query
False
Filter by rebalancing.engine.scanner.blocks_skipped.in_snapshot
rebalancing.engine.scanner.blocks_skipped.too_large
integer
query
False
Filter by rebalancing.engine.scanner.blocks_skipped.too_large
rebalancing.engine.scanner.blocks_skipped.fast_truncate
integer
query
False
Filter by rebalancing.engine.scanner.blocks_skipped.fast_truncate
rebalancing.engine.scanner.blocks_skipped.footprint_invalid
integer
query
False
Filter by rebalancing.engine.scanner.blocks_skipped.footprint_invalid
rebalancing.engine.scanner.blocks_skipped.incompatible
integer
query
False
Filter by rebalancing.engine.scanner.blocks_skipped.incompatible
rebalancing.engine.scanner.blocks_skipped.efficiency_blocks
integer
query
False
Filter by rebalancing.engine.scanner.blocks_skipped.efficiency_blocks
rebalancing.engine.scanner.blocks_skipped.other
integer
query
False
Filter by rebalancing.engine.scanner.blocks_skipped.other
rebalancing.engine.scanner.blocks_skipped.efficiency_percent
integer
query
False
Filter by rebalancing.engine.scanner.blocks_skipped.efficiency_percent
rebalancing.engine.scanner.blocks_skipped.metadata
integer
query
False
Filter by rebalancing.engine.scanner.blocks_skipped.metadata
rebalancing.engine.scanner.blocks_skipped.on_demand_destination
integer
query
False
Filter by rebalancing.engine.scanner.blocks_skipped.on_demand_destination
rebalancing.engine.scanner.blocks_skipped.write_fenced
integer
query
False
Filter by rebalancing.engine.scanner.blocks_skipped.write_fenced
rebalancing.engine.scanner.blocks_skipped.remote_cache
integer
query
False
Filter by rebalancing.engine.scanner.blocks_skipped.remote_cache
rebalancing.engine.scanner.blocks_skipped.too_small
integer
query
False
Filter by rebalancing.engine.scanner.blocks_skipped.too_small
rebalancing.engine.scanner.files_skipped.in_snapshot
integer
query
False
Filter by rebalancing.engine.scanner.files_skipped.in_snapshot
rebalancing.engine.scanner.files_skipped.fast_truncate
integer
query
False
Filter by rebalancing.engine.scanner.files_skipped.fast_truncate
rebalancing.engine.scanner.files_skipped.footprint_invalid
integer
query
False
Filter by rebalancing.engine.scanner.files_skipped.footprint_invalid
rebalancing.engine.scanner.files_skipped.too_large
integer
query
False
Filter by rebalancing.engine.scanner.files_skipped.too_large
rebalancing.engine.scanner.files_skipped.other
integer
query
False
Filter by rebalancing.engine.scanner.files_skipped.other
rebalancing.engine.scanner.files_skipped.efficiency_percent
integer
query
False
Filter by rebalancing.engine.scanner.files_skipped.efficiency_percent
rebalancing.engine.scanner.files_skipped.incompatible
integer
query
False
Filter by rebalancing.engine.scanner.files_skipped.incompatible
rebalancing.engine.scanner.files_skipped.efficiency_blocks
integer
query
False
Filter by rebalancing.engine.scanner.files_skipped.efficiency_blocks
rebalancing.engine.scanner.files_skipped.write_fenced
integer
query
False
Filter by rebalancing.engine.scanner.files_skipped.write_fenced
rebalancing.engine.scanner.files_skipped.too_small
integer
query
False
Filter by rebalancing.engine.scanner.files_skipped.too_small
rebalancing.engine.scanner.files_skipped.remote_cache
integer
query
False
Filter by rebalancing.engine.scanner.files_skipped.remote_cache
rebalancing.engine.scanner.files_skipped.metadata
integer
query
False
Filter by rebalancing.engine.scanner.files_skipped.metadata
rebalancing.engine.scanner.files_skipped.on_demand_destination
integer
query
False
Filter by rebalancing.engine.scanner.files_skipped.on_demand_destination
rebalancing.engine.scanner.files_scanned
integer
query
False
Filter by rebalancing.engine.scanner.files_scanned
rebalancing.engine.scanner.blocks_scanned
integer
query
False
Filter by rebalancing.engine.scanner.blocks_scanned
rebalancing.start_time
string
query
False
Filter by rebalancing.start_time
rebalancing.imbalance_percent
integer
query
False
Filter by rebalancing.imbalance_percent
rebalancing.runtime
string
query
False
Filter by rebalancing.runtime
rebalancing.max_constituent_imbalance_percent
integer
query
False
Filter by rebalancing.max_constituent_imbalance_percent
rebalancing.max_file_moves
integer
query
False
Filter by rebalancing.max_file_moves
rebalancing.min_file_size
integer
query
False
Filter by rebalancing.min_file_size
rebalancing.used_for_imbalance
integer
query
False
Filter by rebalancing.used_for_imbalance
rebalancing.target_used
integer
query
False
Filter by rebalancing.target_used
rebalancing.imbalance_size
integer
query
False
Filter by rebalancing.imbalance_size
rebalancing.max_threshold
integer
query
False
Filter by rebalancing.max_threshold
rebalancing.min_threshold
integer
query
False
Filter by rebalancing.min_threshold
rebalancing.data_moved
integer
query
False
Filter by rebalancing.data_moved
rebalancing.notices.arguments.code
string
query
False
Filter by rebalancing.notices.arguments.code
rebalancing.notices.arguments.message
string
query
False
Filter by rebalancing.notices.arguments.message
rebalancing.notices.message
string
query
False
Filter by rebalancing.notices.message
rebalancing.notices.code
string
query
False
Filter by rebalancing.notices.code
create_time
string
query
False
Filter by create_time
string
query
False
Filter by aggressive_readahead_mode
status
string
query
False
Filter by status
qos.policy.min_throughput_mbps
integer
query
False
Filter by qos.policy.min_throughput_mbps
  • Introduced in: 9.8
  • Max value: 4194303
  • Min value: 0
qos.policy.max_throughput_mbps
integer
query
False
Filter by qos.policy.max_throughput_mbps
  • Min value: 0
qos.policy.uuid
string
query
False
Filter by qos.policy.uuid
qos.policy.name
string
query
False
Filter by qos.policy.name
qos.policy.min_throughput_iops
integer
query
False
Filter by qos.policy.min_throughput_iops
  • Max value: 2147483647
  • Min value: 0
qos.policy.max_throughput_iops
integer
query
False
Filter by qos.policy.max_throughput_iops
  • Min value: 0
boolean
query
False
Filter by queue_for_encryption
integer
query
False
Filter by space.cross_volume_dedupe_metafiles_footprint
integer
query
False
Filter by space.volume_guarantee_footprint
space.physical_used
integer
query
False
Filter by space.physical_used
space.max_size
string
query
False
Filter by space.max_size
integer
query
False
Filter by space.performance_tier_footprint
integer
query
False
Filter by space.total_metadata
space.footprint
integer
query
False
Filter by space.footprint
integer
query
False
Filter by space.capacity_tier_footprint
integer
query
False
Filter by space.dedupe_metafiles_footprint
integer
query
False
Filter by space.overwrite_reserve
space.used
integer
query
False
Filter by space.used
integer
query
False
Filter by space.fractional_reserve
space.capacity_tier_footprint_data_reduction
integer
query
False
Filter by space.capacity_tier_footprint_data_reduction
space.auto_adaptive_compression_footprint_data_reduction
integer
query
False
Filter by space.auto_adaptive_compression_footprint_data_reduction
space.logical_space.used_percent
integer
query
False
Filter by space.logical_space.used_percent
boolean
query
False
Filter by space.logical_space.reporting
integer
query
False
Filter by space.logical_space.used_by_afs
boolean
query
False
Filter by space.logical_space.enforcement
integer
query
False
Filter by space.logical_space.available
integer
query
False
space.logical_space.used_by_snapshots
integer
query
False
Filter by space.logical_space.used_by_snapshots
boolean
query
False
Filter by space.large_size_enabled
space.is_used_stale
boolean
query
False
Filter by space.is_used_stale
space.snapshot.autodelete_trigger
string
query
False
Filter by space.snapshot.autodelete_trigger
space.snapshot.reserve_size
integer
query
False
Filter by space.snapshot.reserve_size
space.snapshot.space_used_percent
integer
query
False
Filter by space.snapshot.space_used_percent
space.snapshot.autodelete.prefix
string
query
False
Filter by space.snapshot.autodelete.prefix
space.snapshot.autodelete.trigger
string
query
False
Filter by space.snapshot.autodelete.trigger
space.snapshot.autodelete.commitment
string
query
False
Filter by space.snapshot.autodelete.commitment
space.snapshot.autodelete.delete_order
string
query
False
Filter by space.snapshot.autodelete.delete_order
space.snapshot.autodelete.defer_delete
string
query
False
Filter by space.snapshot.autodelete.defer_delete
space.snapshot.autodelete.target_free_space
integer
query
False
Filter by space.snapshot.autodelete.target_free_space
space.snapshot.reserve_available
integer
query
False
Filter by space.snapshot.reserve_available
integer
query
False
Filter by space.snapshot.reserve_percent
space.snapshot.used
integer
query
False
Filter by space.snapshot.used
space.metadata
integer
query
False
Filter by space.metadata
space.available
integer
query
False
Filter by space.available
integer
query
False
Filter by space.file_operation_metadata
integer
query
False
Filter by space.physical_used_percent
space.afs_total
integer
query
False
Filter by space.afs_total
integer
query
False
Filter by space.snapmirror_destination_footprint
integer
query
False
Filter by space.full_threshold_percent
space.compaction_footprint_data_reduction
integer
query
False
Filter by space.compaction_footprint_data_reduction
integer
query
False
Filter by space.local_tier_footprint
integer
query
False
Filter by space.over_provisioned
integer
query
False
Filter by space.snapshot_spill
integer
query
False
Filter by space.block_storage_inactive_user_data_percent
integer
query
False
Filter by space.expected_available
integer
query
False
Filter by space.overwrite_reserve_used
integer
query
False
Filter by space.nearly_full_threshold_percent
space.used_by_afs
integer
query
False
Filter by space.used_by_afs
integer
query
False
Filter by space.delayed_free_footprint
integer
query
False
Filter by space.snapshot_reserve_unusable
integer
query
False
Filter by space.total_metadata_footprint
integer
query
False
integer
query
False
Filter by space.cross_volume_dedupe_metafiles_temporary_footprint
integer
query
False
Filter by space.dedupe_metafiles_temporary_footprint
integer
query
False
Filter by space.total_footprint
space.user_data
integer
query
False
Filter by space.user_data
space.percent_used
integer
query
False
Filter by space.percent_used
space.size
integer
query
False
Filter by space.size
integer
query
False
Filter by space.size_available_for_snapshots
space.effective_total_footprint
integer
query
False
Filter by space.effective_total_footprint
integer
query
False
Filter by space.filesystem_size
boolean
query
False
Filter by space.filesystem_size_fixed
integer
query
False
Filter by space.available_percent
msid
integer
query
False
Filter by msid
type
string
query
False
Filter by type
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
autosize.maximum
integer
query
False
Filter by autosize.maximum
autosize.mode
string
query
False
Filter by autosize.mode
autosize.grow_threshold
integer
query
False
Filter by autosize.grow_threshold
autosize.shrink_threshold
integer
query
False
Filter by autosize.shrink_threshold
autosize.minimum
integer
query
False
Filter by autosize.minimum
boolean
query
False
Filter by clone.split_initiated
integer
query
False
Filter by clone.split_estimate
clone.is_flexclone
boolean
query
False
Filter by clone.is_flexclone
clone.has_flexclone
boolean
query
False
Filter by clone.has_flexclone
  • Introduced in: 9.16
string
query
False
Filter by clone.parent_volume.uuid
string
query
False
Filter by clone.parent_volume.name
string
query
False
Filter by clone.parent_svm.name
string
query
False
Filter by clone.parent_svm.uuid
integer
query
False
Filter by clone.split_complete_percent
clone.inherited_savings
integer
query
False
Filter by clone.inherited_savings
clone.inherited_physical_used
integer
query
False
Filter by clone.inherited_physical_used
string
query
False
Filter by clone.parent_snapshot.uuid
string
query
False
Filter by clone.parent_snapshot.name
nas.uid
integer
query
False
Filter by nas.uid
integer
query
False
Filter by nas.unix_permissions
nas.security_style
string
query
False
Filter by nas.security_style
nas.path
string
query
False
Filter by nas.path
string
query
False
Filter by nas.junction_parent.uuid
string
query
False
Filter by nas.junction_parent.name
nas.export_policy.name
string
query
False
Filter by nas.export_policy.name
integer
query
False
Filter by nas.export_policy.id
nas.gid
integer
query
False
Filter by nas.gid
snaplock.compliance_clock_time
string
query
False
Filter by snaplock.compliance_clock_time
snaplock.autocommit_period
string
query
False
Filter by snaplock.autocommit_period
snaplock.expiry_time
string
query
False
Filter by snaplock.expiry_time
snaplock.is_audit_log
boolean
query
False
Filter by snaplock.is_audit_log
snaplock.append_mode_enabled
boolean
query
False
Filter by snaplock.append_mode_enabled
snaplock.retention.default
string
query
False
Filter by snaplock.retention.default
snaplock.retention.minimum
string
query
False
Filter by snaplock.retention.minimum
snaplock.retention.maximum
string
query
False
Filter by snaplock.retention.maximum
snaplock.type
string
query
False
Filter by snaplock.type
snaplock.litigation_count
integer
query
False
Filter by snaplock.litigation_count
snaplock.privileged_delete
string
query
False
Filter by snaplock.privileged_delete
snaplock.unspecified_retention_file_count
integer
query
False
Filter by snaplock.unspecified_retention_file_count
efficiency.application_io_size
string
query
False
Filter by efficiency.application_io_size
efficiency.progress
string
query
False
Filter by efficiency.progress
efficiency.volume_path
string
query
False
Filter by efficiency.volume_path
efficiency.last_op_err
string
query
False
Filter by efficiency.last_op_err
efficiency.policy.name
string
query
False
Filter by efficiency.policy.name
  • Introduced in: 9.7
efficiency.state
string
query
False
Filter by efficiency.state
efficiency.scanner.state
string
query
False
Filter by efficiency.scanner.state
efficiency.scanner.compression
boolean
query
False
Filter by efficiency.scanner.compression
efficiency.scanner.dedupe
boolean
query
False
Filter by efficiency.scanner.dedupe
efficiency.scanner.scan_old_data
boolean
query
False
Filter by efficiency.scanner.scan_old_data
efficiency.idcs_scanner.operation_state
string
query
False
Filter by efficiency.idcs_scanner.operation_state
efficiency.idcs_scanner.mode
string
query
False
Filter by efficiency.idcs_scanner.mode
efficiency.idcs_scanner.threshold_inactive_time
string
query
False
Filter by efficiency.idcs_scanner.threshold_inactive_time
efficiency.idcs_scanner.enabled
boolean
query
False
Filter by efficiency.idcs_scanner.enabled
efficiency.idcs_scanner.status
string
query
False
Filter by efficiency.idcs_scanner.status
efficiency.auto_state
string
query
False
Filter by efficiency.auto_state
efficiency.type
string
query
False
Filter by efficiency.type
efficiency.cross_volume_dedupe
string
query
False
Filter by efficiency.cross_volume_dedupe
efficiency.last_op_size
integer
query
False
Filter by efficiency.last_op_size
efficiency.has_savings
boolean
query
False
Filter by efficiency.has_savings
efficiency.last_op_end
string
query
False
Filter by efficiency.last_op_end
efficiency.storage_efficiency_mode
string
query
False
Filter by efficiency.storage_efficiency_mode
efficiency.space_savings.dedupe_percent
integer
query
False
Filter by efficiency.space_savings.dedupe_percent
efficiency.space_savings.total
integer
query
False
Filter by efficiency.space_savings.total
integer
query
False
efficiency.space_savings.compression
integer
query
False
Filter by efficiency.space_savings.compression
efficiency.space_savings.compression_percent
integer
query
False
Filter by efficiency.space_savings.compression_percent
efficiency.space_savings.total_percent
integer
query
False
Filter by efficiency.space_savings.total_percent
efficiency.space_savings.dedupe_sharing
integer
query
False
Filter by efficiency.space_savings.dedupe_sharing
efficiency.last_op_begin
string
query
False
Filter by efficiency.last_op_begin
efficiency.compression
string
query
False
Filter by efficiency.compression
efficiency.logging_enabled
boolean
query
False
Filter by efficiency.logging_enabled
efficiency.op_state
string
query
False
Filter by efficiency.op_state
efficiency.last_op_state
string
query
False
Filter by efficiency.last_op_state
efficiency.schedule
string
query
False
Filter by efficiency.schedule
efficiency.compression_type
string
query
False
Filter by efficiency.compression_type
efficiency.dedupe
string
query
False
Filter by efficiency.dedupe
efficiency.compaction
string
query
False
Filter by efficiency.compaction
asynchronous_directory_delete.trash_bin
string
query
False
Filter by asynchronous_directory_delete.trash_bin
asynchronous_directory_delete.enabled
boolean
query
False
Filter by asynchronous_directory_delete.enabled
string
query
False
Filter by movement.destination_aggregate.uuid
string
query
False
Filter by movement.destination_aggregate.name
integer
query
False
Filter by movement.percent_complete
integer
query
False
Filter by movement.cutover_window
movement.state
string
query
False
Filter by movement.state
movement.start_time
string
query
False
Filter by movement.start_time
_tags
string
query
False
Filter by _tags
string
query
False
Filter by flexcache_endpoint_type
size
integer
query
False
Filter by size
snapmirror.is_protected
boolean
query
False
Filter by snapmirror.is_protected
snapmirror.destinations.is_ontap
boolean
query
False
Filter by snapmirror.destinations.is_ontap
snapmirror.destinations.is_cloud
boolean
query
False
Filter by snapmirror.destinations.is_cloud
comment
string
query
False
Filter by comment
  • maxLength: 1023
  • minLength: 0
quota.state
string
query
False
Filter by quota.state
application.uuid
string
query
False
Filter by application.uuid
application.name
string
query
False
Filter by application.name
cloud_retrieval_policy
string
query
False
Filter by cloud_retrieval_policy
tiering.policy
string
query
False
Filter by tiering.policy
tiering.object_tags
string
query
False
Filter by tiering.object_tags
  • maxLength: 257
tiering.min_cooling_days
integer
query
False
Filter by tiering.min_cooling_days
  • Max value: 183
  • Min value: 2
statistics.timestamp
string
query
False
Filter by statistics.timestamp
statistics.latency_raw.write
integer
query
False
Filter by statistics.latency_raw.write
statistics.latency_raw.total
integer
query
False
Filter by statistics.latency_raw.total
statistics.latency_raw.read
integer
query
False
Filter by statistics.latency_raw.read
statistics.latency_raw.other
integer
query
False
Filter by statistics.latency_raw.other
statistics.status
string
query
False
Filter by statistics.status
statistics.iops_raw.write
integer
query
False
Filter by statistics.iops_raw.write
statistics.iops_raw.total
integer
query
False
Filter by statistics.iops_raw.total
statistics.iops_raw.read
integer
query
False
Filter by statistics.iops_raw.read
statistics.iops_raw.other
integer
query
False
Filter by statistics.iops_raw.other
statistics.nfs_ops_raw.watch.count
integer
query
False
Filter by statistics.nfs_ops_raw.watch.count
statistics.nfs_ops_raw.watch.total_time
integer
query
False
Filter by statistics.nfs_ops_raw.watch.total_time
statistics.nfs_ops_raw.readdir.count
integer
query
False
Filter by statistics.nfs_ops_raw.readdir.count
statistics.nfs_ops_raw.readdir.total_time
integer
query
False
Filter by statistics.nfs_ops_raw.readdir.total_time
statistics.nfs_ops_raw.setattr.count
integer
query
False
Filter by statistics.nfs_ops_raw.setattr.count
statistics.nfs_ops_raw.setattr.total_time
integer
query
False
Filter by statistics.nfs_ops_raw.setattr.total_time
statistics.nfs_ops_raw.write.total_time
integer
query
False
Filter by statistics.nfs_ops_raw.write.total_time
statistics.nfs_ops_raw.write.volume_protocol_size_histogram_counts
integer
query
False
Filter by statistics.nfs_ops_raw.write.volume_protocol_size_histogram_counts
statistics.nfs_ops_raw.write.volume_protocol_latency_histogram_counts
integer
query
False
Filter by statistics.nfs_ops_raw.write.volume_protocol_latency_histogram_counts
statistics.nfs_ops_raw.write.count
integer
query
False
Filter by statistics.nfs_ops_raw.write.count
statistics.nfs_ops_raw.write.volume_protocol_size_histogram_labels
string
query
False
Filter by statistics.nfs_ops_raw.write.volume_protocol_size_histogram_labels
statistics.nfs_ops_raw.write.volume_protocol_latency_histogram_labels
string
query
False
Filter by statistics.nfs_ops_raw.write.volume_protocol_latency_histogram_labels
statistics.nfs_ops_raw.create.symlink.count
integer
query
False
Filter by statistics.nfs_ops_raw.create.symlink.count
statistics.nfs_ops_raw.create.symlink.total_time
integer
query
False
Filter by statistics.nfs_ops_raw.create.symlink.total_time
statistics.nfs_ops_raw.create.file.count
integer
query
False
Filter by statistics.nfs_ops_raw.create.file.count
statistics.nfs_ops_raw.create.file.total_time
integer
query
False
Filter by statistics.nfs_ops_raw.create.file.total_time
statistics.nfs_ops_raw.create.other.count
integer
query
False
Filter by statistics.nfs_ops_raw.create.other.count
statistics.nfs_ops_raw.create.other.total_time
integer
query
False
Filter by statistics.nfs_ops_raw.create.other.total_time
statistics.nfs_ops_raw.create.dir.count
integer
query
False
Filter by statistics.nfs_ops_raw.create.dir.count
statistics.nfs_ops_raw.create.dir.total_time
integer
query
False
Filter by statistics.nfs_ops_raw.create.dir.total_time
statistics.nfs_ops_raw.getattr.count
integer
query
False
Filter by statistics.nfs_ops_raw.getattr.count
statistics.nfs_ops_raw.getattr.total_time
integer
query
False
Filter by statistics.nfs_ops_raw.getattr.total_time
statistics.nfs_ops_raw.lock.count
integer
query
False
Filter by statistics.nfs_ops_raw.lock.count
statistics.nfs_ops_raw.lock.total_time
integer
query
False
Filter by statistics.nfs_ops_raw.lock.total_time
statistics.nfs_ops_raw.audit.count
integer
query
False
Filter by statistics.nfs_ops_raw.audit.count
statistics.nfs_ops_raw.audit.total_time
integer
query
False
Filter by statistics.nfs_ops_raw.audit.total_time
statistics.nfs_ops_raw.link.count
integer
query
False
Filter by statistics.nfs_ops_raw.link.count
statistics.nfs_ops_raw.link.total_time
integer
query
False
Filter by statistics.nfs_ops_raw.link.total_time
statistics.nfs_ops_raw.readlink.count
integer
query
False
Filter by statistics.nfs_ops_raw.readlink.count
statistics.nfs_ops_raw.readlink.total_time
integer
query
False
Filter by statistics.nfs_ops_raw.readlink.total_time
statistics.nfs_ops_raw.read.total_time
integer
query
False
Filter by statistics.nfs_ops_raw.read.total_time
statistics.nfs_ops_raw.read.volume_protocol_size_histogram_counts
integer
query
False
Filter by statistics.nfs_ops_raw.read.volume_protocol_size_histogram_counts
statistics.nfs_ops_raw.read.volume_protocol_latency_histogram_counts
integer
query
False
Filter by statistics.nfs_ops_raw.read.volume_protocol_latency_histogram_counts
statistics.nfs_ops_raw.read.count
integer
query
False
Filter by statistics.nfs_ops_raw.read.count
statistics.nfs_ops_raw.read.volume_protocol_size_histogram_labels
string
query
False
Filter by statistics.nfs_ops_raw.read.volume_protocol_size_histogram_labels
statistics.nfs_ops_raw.read.volume_protocol_latency_histogram_labels
string
query
False
Filter by statistics.nfs_ops_raw.read.volume_protocol_latency_histogram_labels
statistics.nfs_ops_raw.open.count
integer
query
False
Filter by statistics.nfs_ops_raw.open.count
statistics.nfs_ops_raw.open.total_time
integer
query
False
Filter by statistics.nfs_ops_raw.open.total_time
statistics.nfs_ops_raw.access.count
integer
query
False
Filter by statistics.nfs_ops_raw.access.count
statistics.nfs_ops_raw.access.total_time
integer
query
False
Filter by statistics.nfs_ops_raw.access.total_time
statistics.nfs_ops_raw.unlink.count
integer
query
False
Filter by statistics.nfs_ops_raw.unlink.count
statistics.nfs_ops_raw.unlink.total_time
integer
query
False
Filter by statistics.nfs_ops_raw.unlink.total_time
statistics.nfs_ops_raw.lookup.count
integer
query
False
Filter by statistics.nfs_ops_raw.lookup.count
statistics.nfs_ops_raw.lookup.total_time
integer
query
False
Filter by statistics.nfs_ops_raw.lookup.total_time
statistics.nfs_ops_raw.rename.count
integer
query
False
Filter by statistics.nfs_ops_raw.rename.count
statistics.nfs_ops_raw.rename.total_time
integer
query
False
Filter by statistics.nfs_ops_raw.rename.total_time
statistics.flexcache_raw.cache_miss_blocks
integer
query
False
Filter by statistics.flexcache_raw.cache_miss_blocks
statistics.flexcache_raw.client_requested_blocks
integer
query
False
Filter by statistics.flexcache_raw.client_requested_blocks
statistics.flexcache_raw.status
string
query
False
Filter by statistics.flexcache_raw.status
statistics.flexcache_raw.timestamp
string
query
False
Filter by statistics.flexcache_raw.timestamp
statistics.throughput_raw.write
integer
query
False
Filter by statistics.throughput_raw.write
statistics.throughput_raw.total
integer
query
False
Filter by statistics.throughput_raw.total
statistics.throughput_raw.read
integer
query
False
Filter by statistics.throughput_raw.read
statistics.throughput_raw.other
integer
query
False
Filter by statistics.throughput_raw.other
statistics.cloud.timestamp
string
query
False
Filter by statistics.cloud.timestamp
statistics.cloud.latency_raw.write
integer
query
False
Filter by statistics.cloud.latency_raw.write
statistics.cloud.latency_raw.total
integer
query
False
Filter by statistics.cloud.latency_raw.total
statistics.cloud.latency_raw.read
integer
query
False
Filter by statistics.cloud.latency_raw.read
statistics.cloud.latency_raw.other
integer
query
False
Filter by statistics.cloud.latency_raw.other
statistics.cloud.status
string
query
False
Filter by statistics.cloud.status
statistics.cloud.iops_raw.write
integer
query
False
Filter by statistics.cloud.iops_raw.write
statistics.cloud.iops_raw.total
integer
query
False
Filter by statistics.cloud.iops_raw.total
statistics.cloud.iops_raw.read
integer
query
False
Filter by statistics.cloud.iops_raw.read
statistics.cloud.iops_raw.other
integer
query
False
Filter by statistics.cloud.iops_raw.other
statistics.cifs_ops_raw.watch.count
integer
query
False
Filter by statistics.cifs_ops_raw.watch.count
statistics.cifs_ops_raw.watch.total_time
integer
query
False
Filter by statistics.cifs_ops_raw.watch.total_time
statistics.cifs_ops_raw.readdir.count
integer
query
False
Filter by statistics.cifs_ops_raw.readdir.count
statistics.cifs_ops_raw.readdir.total_time
integer
query
False
Filter by statistics.cifs_ops_raw.readdir.total_time
statistics.cifs_ops_raw.setattr.count
integer
query
False
Filter by statistics.cifs_ops_raw.setattr.count
statistics.cifs_ops_raw.setattr.total_time
integer
query
False
Filter by statistics.cifs_ops_raw.setattr.total_time
statistics.cifs_ops_raw.write.total_time
integer
query
False
Filter by statistics.cifs_ops_raw.write.total_time
statistics.cifs_ops_raw.write.volume_protocol_size_histogram_counts
integer
query
False
Filter by statistics.cifs_ops_raw.write.volume_protocol_size_histogram_counts
statistics.cifs_ops_raw.write.volume_protocol_latency_histogram_counts
integer
query
False
Filter by statistics.cifs_ops_raw.write.volume_protocol_latency_histogram_counts
statistics.cifs_ops_raw.write.count
integer
query
False
Filter by statistics.cifs_ops_raw.write.count
statistics.cifs_ops_raw.write.volume_protocol_size_histogram_labels
string
query
False
Filter by statistics.cifs_ops_raw.write.volume_protocol_size_histogram_labels
statistics.cifs_ops_raw.write.volume_protocol_latency_histogram_labels
string
query
False
Filter by statistics.cifs_ops_raw.write.volume_protocol_latency_histogram_labels
statistics.cifs_ops_raw.create.symlink.count
integer
query
False
Filter by statistics.cifs_ops_raw.create.symlink.count
statistics.cifs_ops_raw.create.symlink.total_time
integer
query
False
Filter by statistics.cifs_ops_raw.create.symlink.total_time
statistics.cifs_ops_raw.create.file.count
integer
query
False
Filter by statistics.cifs_ops_raw.create.file.count
statistics.cifs_ops_raw.create.file.total_time
integer
query
False
Filter by statistics.cifs_ops_raw.create.file.total_time
statistics.cifs_ops_raw.create.other.count
integer
query
False
Filter by statistics.cifs_ops_raw.create.other.count
statistics.cifs_ops_raw.create.other.total_time
integer
query
False
Filter by statistics.cifs_ops_raw.create.other.total_time
statistics.cifs_ops_raw.create.dir.count
integer
query
False
Filter by statistics.cifs_ops_raw.create.dir.count
statistics.cifs_ops_raw.create.dir.total_time
integer
query
False
Filter by statistics.cifs_ops_raw.create.dir.total_time
statistics.cifs_ops_raw.getattr.count
integer
query
False
Filter by statistics.cifs_ops_raw.getattr.count
statistics.cifs_ops_raw.getattr.total_time
integer
query
False
Filter by statistics.cifs_ops_raw.getattr.total_time
statistics.cifs_ops_raw.lock.count
integer
query
False
Filter by statistics.cifs_ops_raw.lock.count
statistics.cifs_ops_raw.lock.total_time
integer
query
False
Filter by statistics.cifs_ops_raw.lock.total_time
statistics.cifs_ops_raw.audit.count
integer
query
False
Filter by statistics.cifs_ops_raw.audit.count
statistics.cifs_ops_raw.audit.total_time
integer
query
False
Filter by statistics.cifs_ops_raw.audit.total_time
statistics.cifs_ops_raw.link.count
integer
query
False
Filter by statistics.cifs_ops_raw.link.count
statistics.cifs_ops_raw.link.total_time
integer
query
False
Filter by statistics.cifs_ops_raw.link.total_time
statistics.cifs_ops_raw.readlink.count
integer
query
False
Filter by statistics.cifs_ops_raw.readlink.count
statistics.cifs_ops_raw.readlink.total_time
integer
query
False
Filter by statistics.cifs_ops_raw.readlink.total_time
statistics.cifs_ops_raw.read.total_time
integer
query
False
Filter by statistics.cifs_ops_raw.read.total_time
statistics.cifs_ops_raw.read.volume_protocol_size_histogram_counts
integer
query
False
Filter by statistics.cifs_ops_raw.read.volume_protocol_size_histogram_counts
statistics.cifs_ops_raw.read.volume_protocol_latency_histogram_counts
integer
query
False
Filter by statistics.cifs_ops_raw.read.volume_protocol_latency_histogram_counts
statistics.cifs_ops_raw.read.count
integer
query
False
Filter by statistics.cifs_ops_raw.read.count
statistics.cifs_ops_raw.read.volume_protocol_size_histogram_labels
string
query
False
Filter by statistics.cifs_ops_raw.read.volume_protocol_size_histogram_labels
statistics.cifs_ops_raw.read.volume_protocol_latency_histogram_labels
string
query
False
Filter by statistics.cifs_ops_raw.read.volume_protocol_latency_histogram_labels
statistics.cifs_ops_raw.open.count
integer
query
False
Filter by statistics.cifs_ops_raw.open.count
statistics.cifs_ops_raw.open.total_time
integer
query
False
Filter by statistics.cifs_ops_raw.open.total_time
statistics.cifs_ops_raw.access.count
integer
query
False
Filter by statistics.cifs_ops_raw.access.count
statistics.cifs_ops_raw.access.total_time
integer
query
False
Filter by statistics.cifs_ops_raw.access.total_time
statistics.cifs_ops_raw.unlink.count
integer
query
False
Filter by statistics.cifs_ops_raw.unlink.count
statistics.cifs_ops_raw.unlink.total_time
integer
query
False
Filter by statistics.cifs_ops_raw.unlink.total_time
statistics.cifs_ops_raw.lookup.count
integer
query
False
Filter by statistics.cifs_ops_raw.lookup.count
statistics.cifs_ops_raw.lookup.total_time
integer
query
False
Filter by statistics.cifs_ops_raw.lookup.total_time
statistics.cifs_ops_raw.rename.count
integer
query
False
Filter by statistics.cifs_ops_raw.rename.count
statistics.cifs_ops_raw.rename.total_time
integer
query
False
Filter by statistics.cifs_ops_raw.rename.total_time
snapshot_count
integer
query
False
Filter by snapshot_count
  • Max value: 1023
  • Min value: 0
state
string
query
False
Filter by state
guarantee.type
string
query
False
Filter by guarantee.type
guarantee.honored
boolean
query
False
Filter by guarantee.honored
flash_pool.caching_policy
string
query
False
Filter by flash_pool.caching_policy
flash_pool.cache_eligibility
string
query
False
Filter by flash_pool.cache_eligibility
flash_pool.cache_retention_priority
string
query
False
Filter by flash_pool.cache_retention_priority
is_object_store
boolean
query
False
Filter by is_object_store
encryption.key_create_time
string
query
False
Filter by encryption.key_create_time
encryption.type
string
query
False
Filter by encryption.type
encryption.status.code
string
query
False
Filter by encryption.status.code
encryption.status.message
string
query
False
Filter by encryption.status.message
encryption.enabled
boolean
query
False
Filter by encryption.enabled
encryption.state
string
query
False
Filter by encryption.state
encryption.action
string
query
False
Filter by encryption.action
encryption.rekey
boolean
query
False
Filter by encryption.rekey
encryption.key_id
string
query
False
Filter by encryption.key_id
uuid
string
query
False
Filter by uuid
snapshot_locking_enabled
boolean
query
False
Filter by snapshot_locking_enabled
activity_tracking.supported
boolean
query
False
Filter by activity_tracking.supported
activity_tracking.unsupported_reason.message
string
query
False
Filter by activity_tracking.unsupported_reason.message
activity_tracking.unsupported_reason.code
string
query
False
Filter by activity_tracking.unsupported_reason.code
activity_tracking.state
string
query
False
Filter by activity_tracking.state
granular_data
boolean
query
False
Filter by granular_data
flexgroup.name
string
query
False
Filter by flexgroup.name
  • maxLength: 203
  • minLength: 1
flexgroup.uuid
string
query
False
Filter by flexgroup.uuid
metric.flexcache.status
string
query
False
Filter by metric.flexcache.status
metric.flexcache.cache_miss_percent
integer
query
False
Filter by metric.flexcache.cache_miss_percent
metric.flexcache.timestamp
string
query
False
Filter by metric.flexcache.timestamp
metric.flexcache.bandwidth_savings
integer
query
False
Filter by metric.flexcache.bandwidth_savings
metric.flexcache.duration
string
query
False
Filter by metric.flexcache.duration
metric.throughput.write
integer
query
False
Filter by metric.throughput.write
metric.throughput.total
integer
query
False
Filter by metric.throughput.total
metric.throughput.read
integer
query
False
Filter by metric.throughput.read
metric.throughput.other
integer
query
False
Filter by metric.throughput.other
metric.status
string
query
False
Filter by metric.status
metric.timestamp
string
query
False
Filter by metric.timestamp
metric.iops.write
integer
query
False
Filter by metric.iops.write
metric.iops.total
integer
query
False
Filter by metric.iops.total
metric.iops.read
integer
query
False
Filter by metric.iops.read
metric.iops.other
integer
query
False
Filter by metric.iops.other
metric.latency.write
integer
query
False
Filter by metric.latency.write
metric.latency.total
integer
query
False
Filter by metric.latency.total
metric.latency.read
integer
query
False
Filter by metric.latency.read
metric.latency.other
integer
query
False
Filter by metric.latency.other
metric.cloud.latency.write
integer
query
False
Filter by metric.cloud.latency.write
metric.cloud.latency.total
integer
query
False
Filter by metric.cloud.latency.total
metric.cloud.latency.read
integer
query
False
Filter by metric.cloud.latency.read
metric.cloud.latency.other
integer
query
False
Filter by metric.cloud.latency.other
metric.cloud.duration
string
query
False
Filter by metric.cloud.duration
metric.cloud.status
string
query
False
Filter by metric.cloud.status
metric.cloud.iops.write
integer
query
False
Filter by metric.cloud.iops.write
metric.cloud.iops.total
integer
query
False
Filter by metric.cloud.iops.total
metric.cloud.iops.read
integer
query
False
Filter by metric.cloud.iops.read
metric.cloud.iops.other
integer
query
False
Filter by metric.cloud.iops.other
metric.cloud.timestamp
string
query
False
Filter by metric.cloud.timestamp
metric.duration
string
query
False
Filter by metric.duration
name
string
query
False
Filter by name
  • maxLength: 203
  • minLength: 1
access_time_enabled
boolean
query
False
Filter by access_time_enabled
consistency_group.uuid
string
query
False
Filter by consistency_group.uuid
consistency_group.name
string
query
False
Filter by consistency_group.name
snapshot_directory_access_enabled
boolean
query
False
Filter by snapshot_directory_access_enabled
validate_only
boolean
query
False
Filter by validate_only
is_svm_root
boolean
query
False
Filter by is_svm_root
analytics.unsupported_reason.code
string
query
False
Filter by analytics.unsupported_reason.code
analytics.unsupported_reason.message
string
query
False
Filter by analytics.unsupported_reason.message
analytics.initialization.state
string
query
False
Filter by analytics.initialization.state
analytics.supported
boolean
query
False
Filter by analytics.supported
analytics.total_files
integer
query
False
Filter by analytics.total_files
analytics.files_scanned
integer
query
False
Filter by analytics.files_scanned
analytics.state
string
query
False
Filter by analytics.state
analytics.scan_throttle_reason.code
string
query
False
Filter by analytics.scan_throttle_reason.code
analytics.scan_throttle_reason.message
string
query
False
Filter by analytics.scan_throttle_reason.message
analytics.scan_throttle_reason.arguments
string
query
False
Filter by analytics.scan_throttle_reason.arguments
analytics.scan_progress
integer
query
False
Filter by analytics.scan_progress
files.maximum
integer
query
False
Filter by files.maximum
files.used
integer
query
False
Filter by files.used
granular_data_mode
string
query
False
Filter by granular_data_mode
max_dir_size
integer
query
False
Filter by max_dir_size
string
query
False
Filter by snapshot_policy.uuid
snapshot_policy.name
string
query
False
Filter by snapshot_policy.name
anti_ransomware.workload.historical_statistics.high_entropy_data_write_peak_percent
integer
query
False
Filter by anti_ransomware.workload.historical_statistics.high_entropy_data_write_peak_percent
anti_ransomware.workload.historical_statistics.high_entropy_data_write_peak_rate_kb_per_minute
integer
query
False
Filter by anti_ransomware.workload.historical_statistics.high_entropy_data_write_peak_rate_kb_per_minute
anti_ransomware.workload.historical_statistics.file_delete_peak_rate_per_minute
integer
query
False
Filter by anti_ransomware.workload.historical_statistics.file_delete_peak_rate_per_minute
anti_ransomware.workload.historical_statistics.file_rename_peak_rate_per_minute
integer
query
False
Filter by anti_ransomware.workload.historical_statistics.file_rename_peak_rate_per_minute
anti_ransomware.workload.historical_statistics.file_create_peak_rate_per_minute
integer
query
False
Filter by anti_ransomware.workload.historical_statistics.file_create_peak_rate_per_minute
anti_ransomware.workload.surge_statistics.time
string
query
False
Filter by anti_ransomware.workload.surge_statistics.time
anti_ransomware.workload.surge_statistics.file_create_peak_rate_per_minute
integer
query
False
Filter by anti_ransomware.workload.surge_statistics.file_create_peak_rate_per_minute
anti_ransomware.workload.surge_statistics.high_entropy_data_write_peak_percent
integer
query
False
Filter by anti_ransomware.workload.surge_statistics.high_entropy_data_write_peak_percent
anti_ransomware.workload.surge_statistics.high_entropy_data_write_peak_rate_kb_per_minute
integer
query
False
Filter by anti_ransomware.workload.surge_statistics.high_entropy_data_write_peak_rate_kb_per_minute
anti_ransomware.workload.surge_statistics.file_rename_peak_rate_per_minute
integer
query
False
Filter by anti_ransomware.workload.surge_statistics.file_rename_peak_rate_per_minute
anti_ransomware.workload.surge_statistics.file_delete_peak_rate_per_minute
integer
query
False
Filter by anti_ransomware.workload.surge_statistics.file_delete_peak_rate_per_minute
anti_ransomware.workload.newly_observed_file_extensions.count
integer
query
False
Filter by anti_ransomware.workload.newly_observed_file_extensions.count
anti_ransomware.workload.newly_observed_file_extensions.name
string
query
False
Filter by anti_ransomware.workload.newly_observed_file_extensions.name
anti_ransomware.workload.typical_usage.file_rename_peak_rate_per_minute
integer
query
False
Filter by anti_ransomware.workload.typical_usage.file_rename_peak_rate_per_minute
anti_ransomware.workload.typical_usage.file_delete_peak_rate_per_minute
integer
query
False
Filter by anti_ransomware.workload.typical_usage.file_delete_peak_rate_per_minute
anti_ransomware.workload.typical_usage.high_entropy_data_write_peak_rate_kb_per_minute
integer
query
False
Filter by anti_ransomware.workload.typical_usage.high_entropy_data_write_peak_rate_kb_per_minute
anti_ransomware.workload.typical_usage.high_entropy_data_write_peak_percent
integer
query
False
Filter by anti_ransomware.workload.typical_usage.high_entropy_data_write_peak_percent
anti_ransomware.workload.typical_usage.file_create_peak_rate_per_minute
integer
query
False
Filter by anti_ransomware.workload.typical_usage.file_create_peak_rate_per_minute
anti_ransomware.workload.file_extensions_observed
string
query
False
Filter by anti_ransomware.workload.file_extensions_observed
anti_ransomware.workload.file_extension_types_count
integer
query
False
Filter by anti_ransomware.workload.file_extension_types_count
anti_ransomware.workload.surge_usage.file_rename_peak_rate_per_minute
integer
query
False
Filter by anti_ransomware.workload.surge_usage.file_rename_peak_rate_per_minute
anti_ransomware.workload.surge_usage.file_delete_peak_rate_per_minute
integer
query
False
Filter by anti_ransomware.workload.surge_usage.file_delete_peak_rate_per_minute
anti_ransomware.workload.surge_usage.high_entropy_data_write_peak_percent
integer
query
False
Filter by anti_ransomware.workload.surge_usage.high_entropy_data_write_peak_percent
anti_ransomware.workload.surge_usage.high_entropy_data_write_peak_rate_kb_per_minute
integer
query
False
Filter by anti_ransomware.workload.surge_usage.high_entropy_data_write_peak_rate_kb_per_minute
anti_ransomware.workload.surge_usage.file_create_peak_rate_per_minute
integer
query
False
Filter by anti_ransomware.workload.surge_usage.file_create_peak_rate_per_minute
anti_ransomware.workload.surge_usage.time
string
query
False
Filter by anti_ransomware.workload.surge_usage.time
anti_ransomware.workload.surge_usage.newly_observed_file_extensions.name
string
query
False
Filter by anti_ransomware.workload.surge_usage.newly_observed_file_extensions.name
anti_ransomware.workload.surge_usage.newly_observed_file_extensions.count
integer
query
False
Filter by anti_ransomware.workload.surge_usage.newly_observed_file_extensions.count
anti_ransomware.surge_usage.file_create_peak_rate_per_minute
integer
query
False
Filter by anti_ransomware.surge_usage.file_create_peak_rate_per_minute
anti_ransomware.surge_usage.time
string
query
False
Filter by anti_ransomware.surge_usage.time
anti_ransomware.surge_usage.file_rename_peak_rate_per_minute
integer
query
False
Filter by anti_ransomware.surge_usage.file_rename_peak_rate_per_minute
anti_ransomware.surge_usage.file_delete_peak_rate_per_minute
integer
query
False
Filter by anti_ransomware.surge_usage.file_delete_peak_rate_per_minute
anti_ransomware.surge_usage.high_entropy_data_write_peak_rate_kb_per_minute
integer
query
False
Filter by anti_ransomware.surge_usage.high_entropy_data_write_peak_rate_kb_per_minute
anti_ransomware.surge_usage.high_entropy_data_write_peak_percent
integer
query
False
Filter by anti_ransomware.surge_usage.high_entropy_data_write_peak_percent
anti_ransomware.update_baseline_from_surge
boolean
query
False
Filter by anti_ransomware.update_baseline_from_surge
anti_ransomware.space.used
integer
query
False
Filter by anti_ransomware.space.used
anti_ransomware.space.used_by_snapshots
integer
query
False
Filter by anti_ransomware.space.used_by_snapshots
anti_ransomware.space.used_by_logs
integer
query
False
Filter by anti_ransomware.space.used_by_logs
anti_ransomware.space.snapshot_count
integer
query
False
Filter by anti_ransomware.space.snapshot_count
anti_ransomware.surge_as_normal
boolean
query
False
Filter by anti_ransomware.surge_as_normal
anti_ransomware.suspect_files.format
string
query
False
Filter by anti_ransomware.suspect_files.format
anti_ransomware.suspect_files.count
integer
query
False
Filter by anti_ransomware.suspect_files.count
anti_ransomware.suspect_files.entropy
string
query
False
Filter by anti_ransomware.suspect_files.entropy
anti_ransomware.state
string
query
False
Filter by anti_ransomware.state
anti_ransomware.attack_reports.time
string
query
False
Filter by anti_ransomware.attack_reports.time
anti_ransomware.attack_probability
string
query
False
Filter by anti_ransomware.attack_probability
anti_ransomware.attack_detection_parameters.file_rename_op_rate_surge_notify_percent
integer
query
False
Filter by anti_ransomware.attack_detection_parameters.file_rename_op_rate_surge_notify_percent
anti_ransomware.attack_detection_parameters.high_entropy_data_surge_notify_percent
integer
query
False
Filter by anti_ransomware.attack_detection_parameters.high_entropy_data_surge_notify_percent
anti_ransomware.attack_detection_parameters.never_seen_before_file_extension_duration_in_hours
integer
query
False
Filter by anti_ransomware.attack_detection_parameters.never_seen_before_file_extension_duration_in_hours
anti_ransomware.attack_detection_parameters.based_on_never_seen_before_file_extension
boolean
query
False
Filter by anti_ransomware.attack_detection_parameters.based_on_never_seen_before_file_extension
anti_ransomware.attack_detection_parameters.based_on_high_entropy_data_rate
boolean
query
False
Filter by anti_ransomware.attack_detection_parameters.based_on_high_entropy_data_rate
anti_ransomware.attack_detection_parameters.never_seen_before_file_extension_count_notify_threshold
integer
query
False
Filter by anti_ransomware.attack_detection_parameters.never_seen_before_file_extension_count_notify_threshold
anti_ransomware.attack_detection_parameters.file_delete_op_rate_surge_notify_percent
integer
query
False
Filter by anti_ransomware.attack_detection_parameters.file_delete_op_rate_surge_notify_percent
anti_ransomware.attack_detection_parameters.based_on_file_create_op_rate
boolean
query
False
Filter by anti_ransomware.attack_detection_parameters.based_on_file_create_op_rate
anti_ransomware.attack_detection_parameters.relaxing_popular_file_extensions
boolean
query
False
Filter by anti_ransomware.attack_detection_parameters.relaxing_popular_file_extensions
anti_ransomware.attack_detection_parameters.file_create_op_rate_surge_notify_percent
integer
query
False
Filter by anti_ransomware.attack_detection_parameters.file_create_op_rate_surge_notify_percent
anti_ransomware.attack_detection_parameters.based_on_file_delete_op_rate
boolean
query
False
Filter by anti_ransomware.attack_detection_parameters.based_on_file_delete_op_rate
anti_ransomware.attack_detection_parameters.based_on_file_rename_op_rate
boolean
query
False
Filter by anti_ransomware.attack_detection_parameters.based_on_file_rename_op_rate
anti_ransomware.dry_run_start_time
string
query
False
Filter by anti_ransomware.dry_run_start_time
anti_ransomware.event_log.is_enabled_on_snapshot_copy_creation
boolean
query
False
Filter by anti_ransomware.event_log.is_enabled_on_snapshot_copy_creation
anti_ransomware.event_log.is_enabled_on_new_file_extension_seen
boolean
query
False
Filter by anti_ransomware.event_log.is_enabled_on_new_file_extension_seen
anti_ransomware.typical_usage.file_create_peak_rate_per_minute
integer
query
False
Filter by anti_ransomware.typical_usage.file_create_peak_rate_per_minute
anti_ransomware.typical_usage.file_delete_peak_rate_per_minute
integer
query
False
Filter by anti_ransomware.typical_usage.file_delete_peak_rate_per_minute
anti_ransomware.typical_usage.file_rename_peak_rate_per_minute
integer
query
False
Filter by anti_ransomware.typical_usage.file_rename_peak_rate_per_minute
anti_ransomware.typical_usage.high_entropy_data_write_peak_percent
integer
query
False
Filter by anti_ransomware.typical_usage.high_entropy_data_write_peak_percent
anti_ransomware.typical_usage.high_entropy_data_write_peak_rate_kb_per_minute
integer
query
False
Filter by anti_ransomware.typical_usage.high_entropy_data_write_peak_rate_kb_per_minute
aggregates.uuid
string
query
False
Filter by aggregates.uuid
aggregates.name
string
query
False
Filter by aggregates.name
scheduled_snapshot_naming_scheme
string
query
False
Filter by scheduled_snapshot_naming_scheme
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[volume]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "_tags": [
        "team:csi",
        "environment:test"
      "activity_tracking": {
        "state": "string",
        "unsupported_reason": {
          "code": "124518405",
          "message": "Volume activity tracking cannot be enabled on volumes that contain LUNs."
      "aggregates": [
          "name": "aggr1",
      "aggressive_readahead_mode": "string",
      "analytics": {
        "files_scanned": 43002,
        "initialization": {
          "state": "string"
        "scan_progress": 17,
        "scan_throttle_reason": {
          "arguments": [
            "string"
          "code": "6739881",
          "message": "The file system analytics scan running on volume \"fsavol2\" in SVM \"vs2\" has slowed down on node \"my_node\". Reason: Computing resources are being used by higher priority workloads."
        "state": "string",
        "total_files": 101890,
          "code": "111411207",
          "message": "File system analytics cannot be enabled on volumes that contain LUNs."
      "anti_ransomware": {
        "attack_detection_parameters": {
          "file_create_op_rate_surge_notify_percent": 100
        "attack_probability": "string",
        "attack_reports": [
              "suspects": {
            "time": "2021-06-01 11:06:41 -0400"
        "dry_run_start_time": "string",
        "space": {
          "snapshot_count": 0,
          "used": 0,
          "used_by_logs": 0,
          "used_by_snapshots": 0
        "state": "string",
        "surge_usage": {
          "file_create_peak_rate_per_minute": 10,
          "file_delete_peak_rate_per_minute": 50,
          "file_rename_peak_rate_per_minute": 30,
          "high_entropy_data_write_peak_percent": 30,
          "high_entropy_data_write_peak_rate_kb_per_minute": 2500,
          "time": "2021-12-01 12:46:20 -0500"
        "suspect_files": [
            "count": 0,
            "entropy": "string",
            "format": "string"
        "typical_usage": {
          "file_create_peak_rate_per_minute": 50,
          "file_delete_peak_rate_per_minute": 10,
          "file_rename_peak_rate_per_minute": 5,
          "high_entropy_data_write_peak_percent": 10,
          "high_entropy_data_write_peak_rate_kb_per_minute": 1200
        "workload": {
          "file_extension_types_count": 3,
          "file_extensions_observed": [
            "pdf",
            "jpeg",
            "txt"
          "historical_statistics": {
          "newly_observed_file_extensions": [
              "count": [
                20
              "name": [
                "lockile"
          "surge_statistics": {
          "surge_usage": {
                "count": [
                  20
                "name": [
                  "lockile"
          "typical_usage": {
      "application": {
        "name": "string",
        "uuid": "1cd8a442-86d1-11e0-ae1d-123478563412"
      "asynchronous_directory_delete": {
        "trash_bin": "string"
      "autosize": {
        "mode": "string"
      "clone": {
        "inherited_physical_used": 0,
        "inherited_savings": 0,
        "parent_snapshot": {
          "name": "this_snapshot",
        "parent_svm": {
          "name": "svm1",
        "parent_volume": {
          "name": "volume1",
        "split_complete_percent": 0,
        "split_estimate": 0
      "cloud_retrieval_policy": "string",
      "comment": "string",
      "consistency_group": {
        "name": "consistency_group_1",
      "constituents": [
          "aggregates": {
            "name": "string",
          "movement": {
            "cutover_window": 30,
            "destination_aggregate": {
              "name": "aggr1",
            "percent_complete": 0,
            "state": "replicating",
            "tiering_policy": "string"
          "name": "string",
          "space": {
            "available": 0,
            "block_storage_inactive_user_data": 0,
            "capacity_tier_footprint": 0,
            "footprint": 0,
            "local_tier_footprint": 0,
            "logical_space": {
              "available": 0,
              "used_by_afs": 0
            "max_size": "string",
            "metadata": 0,
            "over_provisioned": 0,
            "performance_tier_footprint": 0,
            "snapshot": {
              "used": 0
            "total_footprint": 0,
            "total_metadata": 0,
            "total_metadata_footprint": 0,
            "used": 0
      "create_time": "2018-06-04 15:00:00 -0400",
      "efficiency": {
        "application_io_size": "string",
        "auto_state": "string",
        "compaction": "string",
        "compression": "string",
        "compression_type": "string",
        "cross_volume_dedupe": "string",
        "dedupe": "string",
        "idcs_scanner": {
          "mode": "string",
          "operation_state": "string",
          "status": "string",
          "threshold_inactive_time": "P14D"
        "last_op_begin": "string",
        "last_op_end": "string",
        "last_op_err": "string",
        "last_op_size": 0,
        "last_op_state": "string",
        "op_state": "string",
        "policy": {
          "name": "string"
        "progress": "string",
        "scanner": {
          "state": "string"
        "schedule": "string",
        "space_savings": {
          "compression": 0,
          "compression_percent": 0,
          "dedupe": 0,
          "dedupe_percent": 0,
          "dedupe_sharing": 0,
          "total": 0,
          "total_percent": 0
        "state": "string",
        "storage_efficiency_mode": "string",
        "type": "string",
        "volume_path": "string"
      "encryption": {
        "action": "string",
        "key_create_time": "2022-01-01 14:00:00 -0500",
        "key_id": "string",
        "state": "string",
        "status": {
          "code": "string",
          "message": "string"
        "type": "string"
      "files": {
        "used": 0
      "flash_pool": {
        "cache_eligibility": "string",
        "cache_retention_priority": "string",
        "caching_policy": "string"
      "flexcache_endpoint_type": "string",
      "flexgroup": {
        "name": "my_flexgroup",
        "uuid": "75c9cfb0-3eb4-11eb-9fb4-005056bb088a"
      "granular_data_mode": "string",
      "guarantee": {
        "type": "string"
      "language": "string",
      "metric": {
        "cloud": {
          "duration": "PT15S",
          "iops": {
            "read": 200,
            "total": 1000,
            "write": 100
          "latency": {
            "read": 200,
            "total": 1000,
            "write": 100
          "status": "ok",
          "timestamp": "2017-01-25 06:20:13 -0500"
        "flexcache": {
          "bandwidth_savings": 4096,
          "cache_miss_percent": 20,
          "duration": "PT1D",
          "status": "ok",
        "iops": {
          "read": 200,
          "total": 1000,
          "write": 100
        "latency": {
          "read": 200,
          "total": 1000,
          "write": 100
        "status": "ok",
        "throughput": {
          "read": 200,
          "total": 1000,
          "write": 100
      "movement": {
        "capacity_tier_optimized": true,
          "name": "aggr1",
        "start_time": "2020-12-07 03:45:12 -0500",
      "name": "vol_cs_dept",
      "nas": {
        "export_policy": {
          "id": 100,
          "name": "default"
        "junction_parent": {
          "name": "vs1_root",
        "path": "/user/my_volume",
        "security_style": "string",
        "unix_permissions": 493
      "optimize_aggregates": true,
      "qos": {
        "policy": {
          "max_throughput_iops": 10000,
          "max_throughput_mbps": 500,
          "min_throughput_iops": 2000,
          "min_throughput_mbps": 500,
          "name": "performance",
      "quota": {
        "state": "string"
      "rebalancing": {
        "data_moved": 0,
        "engine": {
          "movement": {
            "file_moves_started": 0,
            "last_error": {
              "code": 0,
              "destination": 0,
              "file_id": 0,
              "time": "2018-06-04 15:00:00 -0400"
            "most_recent_start_time": "2018-06-04 15:00:00 -0400"
          "scanner": {
            "blocks_scanned": 0,
            "blocks_skipped": {
              "efficiency_blocks": 0,
              "efficiency_percent": 0,
              "fast_truncate": 0,
              "footprint_invalid": 0,
              "in_snapshot": 0,
              "incompatible": 0,
              "metadata": 0,
              "on_demand_destination": 0,
              "other": 0,
              "remote_cache": 0,
              "too_large": 0,
              "too_small": 0,
              "write_fenced": 0
            "files_scanned": 0,
            "files_skipped": {
              "fast_truncate": 0,
              "in_snapshot": 0,
              "incompatible": 0,
              "metadata": 0,
              "other": 0,
              "remote_cache": 0,
              "too_large": 0,
              "too_small": 0,
              "write_fenced": 0
        "imbalance_percent": 0,
        "imbalance_size": 0,
        "max_constituent_imbalance_percent": 0,
        "max_runtime": "string",
        "notices": [
            "arguments": [
                "code": "string",
                "message": "string"
            "code": "4",
            "message": "entry doesn't exist"
        "runtime": "string",
        "start_time": "string",
        "state": "rebalancing",
        "stop_time": "string",
        "target_used": 0,
        "used_for_imbalance": 0
      "scheduled_snapshot_naming_scheme": "string",
      "snaplock": {
        "append_mode_enabled": "",
        "autocommit_period": "P30M",
        "compliance_clock_time": "2018-06-04 15:00:00 -0400",
        "expiry_time": "Wed Sep  5 11:02:42 GMT 2018",
        "is_audit_log": 1,
        "litigation_count": 10,
        "privileged_delete": "enabled",
        "retention": {
          "default": "P30Y",
          "maximum": "P30Y",
          "minimum": "P30Y"
        "type": "enterprise",
        "unspecified_retention_file_count": 10
      "snapshot_policy": {
        "name": "default",
      "space": {
        "auto_adaptive_compression_footprint_data_reduction": 0,
        "available": 0,
        "block_storage_inactive_user_data_percent": 0,
        "capacity_tier_footprint_data_reduction": 0,
        "compaction_footprint_data_reduction": 0,
        "cross_volume_dedupe_metafiles_footprint": 0,
        "cross_volume_dedupe_metafiles_temporary_footprint": 0,
        "dedupe_metafiles_footprint": 0,
        "dedupe_metafiles_temporary_footprint": 0,
        "delayed_free_footprint": 0,
        "effective_total_footprint": 0,
        "file_operation_metadata": 0,
        "filesystem_size": 0,
        "footprint": 0,
        "logical_space": {
          "available": 0,
          "used": 0,
          "used_by_afs": 0,
          "used_by_snapshots": 0,
          "used_percent": 0
        "metadata": 0,
        "overwrite_reserve": 0,
        "overwrite_reserve_used": 0,
        "percent_used": 0,
        "size_available_for_snapshots": 0,
        "snapmirror_destination_footprint": 0,
        "snapshot": {
          "autodelete": {
            "commitment": "string",
            "defer_delete": "string",
            "delete_order": "string",
            "prefix": "string",
            "trigger": "string"
          "autodelete_trigger": "string",
          "reserve_available": 0,
          "reserve_size": 0,
          "space_used_percent": 0,
          "used": 0
        "snapshot_reserve_unusable": 0,
        "snapshot_spill": 0,
        "used": 0,
        "user_data": 0,
        "volume_guarantee_footprint": 0
      "state": "string",
      "statistics": {
        "cifs_ops_raw": {
          "access": {
            "count": 1000,
            "total_time": 200
          "audit": {
            "count": 1000,
            "total_time": 200
          "create": {
            "dir": {
              "count": 1000,
              "total_time": 200
            "file": {
              "count": 1000,
              "total_time": 200
            "other": {
              "count": 1000,
              "total_time": 200
            "symlink": {
              "count": 1000,
              "total_time": 200
          "getattr": {
            "count": 1000,
            "total_time": 200
          "link": {
            "count": 1000,
            "total_time": 200
          "lock": {
            "count": 1000,
            "total_time": 200
          "lookup": {
            "count": 1000,
            "total_time": 200
          "open": {
            "count": 1000,
            "total_time": 200
          "read": {
            "count": 1000,
            "total_time": 200,
            "volume_protocol_latency_histogram_counts": [
              0,
              0,
              0,
              0,
              0,
              15,
              35,
              100,
              200,
              200,
              300,
              500,
              500,
              500,
              1000,
              1000,
              800,
              500,
              500,
              300,
              200,
              50,
              40,
              15,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0
            "volume_protocol_latency_histogram_labels": [
              "<2us",
              "<6us",
              "<10us",
              "<14us",
              "<20us",
              "<40us",
              "<60us",
              "<80us",
              "<100us",
              "<200us",
              "<400us",
              "<600us",
              "<800us",
              "<1ms",
              "<2ms",
              "<4ms",
              "<6ms",
              "<8ms",
              "<10ms",
              "<12ms",
              "<14ms",
              "<16ms",
              "<18ms",
              "<20ms",
              "<40ms",
              "<60ms",
              "<80ms",
              "<100ms",
              "<200ms",
              "<400ms",
              "<600ms",
              "<800ms",
              "<1s",
              "<2s",
              "<4s",
              "<6s",
              "<8s",
              "<10s",
              "<20s",
              ">20s"
            "volume_protocol_size_histogram_counts": [
              2400,
              1055,
              1100,
              700,
              500,
              300,
              200,
              100,
              100,
              50,
              50,
              75,
              25,
              0,
              0
            "volume_protocol_size_histogram_labels": [
              "<    4KB",
              "=    4KB",
              "<    8KB",
              "=    8KB",
              "<   16KB",
              "=   16KB",
              "<   32KB",
              "=   32KB",
              "<   64KB",
              "=   64KB",
              "<  256KB",
              "=  256KB",
              "< 1024KB",
              "= 1024KB",
              "> 1024KB"
          "readdir": {
            "count": 1000,
            "total_time": 200
          "readlink": {
            "count": 1000,
            "total_time": 200
          "rename": {
            "count": 1000,
            "total_time": 200
          "setattr": {
            "count": 1000,
            "total_time": 200
          "unlink": {
            "count": 1000,
            "total_time": 200
          "watch": {
            "count": 1000,
            "total_time": 200
          "write": {
            "count": 1000,
            "total_time": 200,
              0,
              0,
              0,
              0,
              0,
              15,
              35,
              100,
              200,
              200,
              300,
              500,
              500,
              500,
              1000,
              1000,
              800,
              500,
              500,
              300,
              200,
              50,
              40,
              15,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0
              "<2us",
              "<6us",
              "<10us",
              "<14us",
              "<20us",
              "<40us",
              "<60us",
              "<80us",
              "<100us",
              "<200us",
              "<400us",
              "<600us",
              "<800us",
              "<1ms",
              "<2ms",
              "<4ms",
              "<6ms",
              "<8ms",
              "<10ms",
              "<12ms",
              "<14ms",
              "<16ms",
              "<18ms",
              "<20ms",
              "<40ms",
              "<60ms",
              "<80ms",
              "<100ms",
              "<200ms",
              "<400ms",
              "<600ms",
              "<800ms",
              "<1s",
              "<2s",
              "<4s",
              "<6s",
              "<8s",
              "<10s",
              "<20s",
              ">20s"
              2400,
              1055,
              1100,
              700,
              500,
              300,
              200,
              100,
              100,
              50,
              50,
              75,
              25,
              0,
              0
              "<    4KB",
              "=    4KB",
              "<    8KB",
              "=    8KB",
              "<   16KB",
              "=   16KB",
              "<   32KB",
              "=   32KB",
              "<   64KB",
              "=   64KB",
              "<  256KB",
              "=  256KB",
              "< 1024KB",
              "= 1024KB",
              "> 1024KB"
        "cloud": {
          "iops_raw": {
            "read": 200,
            "total": 1000,
            "write": 100
          "latency_raw": {
            "read": 200,
            "total": 1000,
            "write": 100
          "status": "ok",
        "flexcache_raw": {
          "cache_miss_blocks": 10,
          "client_requested_blocks": 500,
          "status": "ok",
        "iops_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
        "latency_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
        "nfs_ops_raw": {
          "access": {
            "count": 1000,
            "total_time": 200
          "audit": {
            "count": 1000,
            "total_time": 200
          "create": {
            "dir": {
              "count": 1000,
              "total_time": 200
            "file": {
              "count": 1000,
              "total_time": 200
            "other": {
              "count": 1000,
              "total_time": 200
            "symlink": {
              "count": 1000,
              "total_time": 200
          "getattr": {
            "count": 1000,
            "total_time": 200
          "link": {
            "count": 1000,
            "total_time": 200
          "lock": {
            "count": 1000,
            "total_time": 200
          "lookup": {
            "count": 1000,
            "total_time": 200
          "open": {
            "count": 1000,
            "total_time": 200
          "read": {
            "count": 1000,
            "total_time": 200,
              0,
              0,
              0,
              0,
              0,
              15,
              35,
              100,
              200,
              200,
              300,
              500,
              500,
              500,
              1000,
              1000,
              800,
              500,
              500,
              300,
              200,
              50,
              40,
              15,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0
              "<2us",
              "<6us",
              "<10us",
              "<14us",
              "<20us",
              "<40us",
              "<60us",
              "<80us",
              "<100us",
              "<200us",
              "<400us",
              "<600us",
              "<800us",
              "<1ms",
              "<2ms",
              "<4ms",
              "<6ms",
              "<8ms",
              "<10ms",
              "<12ms",
              "<14ms",
              "<16ms",
              "<18ms",
              "<20ms",
              "<40ms",
              "<60ms",
              "<80ms",
              "<100ms",
              "<200ms",
              "<400ms",
              "<600ms",
              "<800ms",
              "<1s",
              "<2s",
              "<4s",
              "<6s",
              "<8s",
              "<10s",
              "<20s",
              ">20s"
              2400,
              1055,
              1100,
              700,
              500,
              300,
              200,
              100,
              100,
              50,
              50,
              75,
              25,
              0,
              0
              "<    4KB",
              "=    4KB",
              "<    8KB",
              "=    8KB",
              "<   16KB",
              "=   16KB",
              "<   32KB",
              "=   32KB",
              "<   64KB",
              "=   64KB",
              "<  256KB",
              "=  256KB",
              "< 1024KB",
              "= 1024KB",
              "> 1024KB"
          "readdir": {
            "count": 1000,
            "total_time": 200
          "readlink": {
            "count": 1000,
            "total_time": 200
          "rename": {
            "count": 1000,
            "total_time": 200
          "setattr": {
            "count": 1000,
            "total_time": 200
          "unlink": {
            "count": 1000,
            "total_time": 200
          "watch": {
            "count": 1000,
            "total_time": 200
          "write": {
            "count": 1000,
            "total_time": 200,
              0,
              0,
              0,
              0,
              0,
              15,
              35,
              100,
              200,
              200,
              300,
              500,
              500,
              500,
              1000,
              1000,
              800,
              500,
              500,
              300,
              200,
              50,
              40,
              15,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0,
              0
              "<2us",
              "<6us",
              "<10us",
              "<14us",
              "<20us",
              "<40us",
              "<60us",
              "<80us",
              "<100us",
              "<200us",
              "<400us",
              "<600us",
              "<800us",
              "<1ms",
              "<2ms",
              "<4ms",
              "<6ms",
              "<8ms",
              "<10ms",
              "<12ms",
              "<14ms",
              "<16ms",
              "<18ms",
              "<20ms",
              "<40ms",
              "<60ms",
              "<80ms",
              "<100ms",
              "<200ms",
              "<400ms",
              "<600ms",
              "<800ms",
              "<1s",
              "<2s",
              "<4s",
              "<6s",
              "<8s",
              "<10s",
              "<20s",
              ">20s"
              2400,
              1055,
              1100,
              700,
              500,
              300,
              200,
              100,
              100,
              50,
              50,
              75,
              25,
              0,
              0
              "<    4KB",
              "=    4KB",
              "<    8KB",
              "=    8KB",
              "<   16KB",
              "=   16KB",
              "<   32KB",
              "=   32KB",
              "<   64KB",
              "=   64KB",
              "<  256KB",
              "=  256KB",
              "< 1024KB",
              "= 1024KB",
              "> 1024KB"
        "status": "ok",
        "throughput_raw": {
          "read": 200,
          "total": 1000,
          "write": 100
      "status": [
        "string"
      "style": "string",
      "svm": {
        "name": "svm1",
      "tiering": {
        "object_tags": [
          "string"
        "policy": "string",
        "supported": true
      "type": "string",
      "use_mirrored_aggregates": true,
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
unsupported_reason
code
string
If volume activity tracking is not supported on the volume, this field provides an appropriate error code.
message
string
If volume activity tracking is not supported on the volume, this field provides an error message detailing why this is the case.
activity_tracking
state
string
Activity tracking state of the volume. If this value is "on", ONTAP collects top metrics information for the volume in real time. There is a slight impact to I/O performance in order to collect this information. If this value is "off", no activity tracking information is collected or available to view.
  • enum: ["off", "on"]
  • Introduced in: 9.10
  • x-nullable: true
supported
boolean
This field indicates whether or not volume activity tracking is supported on the volume. If volume activity tracking is not supported, the reason why is provided in the "activity_tracking.unsupported_reason" field.
unsupported_reason
unsupported_reason
aggregates
Aggregate
_links
_links
name
string
uuid
string
initialization
state
string
State of the analytics file system scan.
arguments
array[string]
Arguments present in the warning message encountered.
code
string
Warning code indicating why scanner throttling is reported.
message
string
A message that provides details for scan throttling.
unsupported_reason
code
string
If file system analytics is not supported on the volume, this field provides the error code explaining why.
message
string
If file system analytics is not supported on the volume, this field provides the error message explaining why.
analytics
files_scanned
integer
Number of files in the volume that the file system analytics initialization scan has processed. Only returned when the state is initializing.
initialization
initialization
scan_progress
integer
Percentage of files in the volume that the file system analytics initialization scan has processed. Only returned when the state is initializing.
state
string
File system analytics state of the volume. If this value is "on", ONTAP collects extra file system analytics information for all directories on the volume. There will be a slight impact to I/O performance to collect this information. If this value is "off", file system analytics information is not collected and not available to be viewed. If this value is "initializing", that means file system analytics was recently turned on, and the initialization scan to gather information for all existing files and directories is currently running. If this value is "initialization_paused", this means that the initialization scan is currently paused. If this value is 'unknown', this means that there was an internal error when determining the file system analytics state for the volume.
  • enum: ["unknown", "initializing", "initialization_paused", "off", "on"]
  • Introduced in: 9.8
  • x-nullable: true
supported
boolean
This field indicates whether or not file system analytics is supported on the volume. If file system analytics is not supported, the reason will be specified in the "analytics.unsupported_reason" field.
total_files
integer
Total number of files in the volume that the file system analytics initialization scan will process. Only returned when the state is initializing.
unsupported_reason
unsupported_reason
anti_ransomware_volume_attack_detection_parameters
boolean
Specifies whether attack detection is based on the file create operations rate. This parameter is valid only for NAS volumes.
boolean
Specifies whether attack detection is based on the file delete operations rate. This parameter is valid only for NAS volumes.
boolean
Specifies whether attack detection is based on the file rename operations rate. This parameter is valid only for NAS volumes.
boolean
Specifies whether a high entropy data rate should be considered for attack detection.
boolean
Specifies whether file extensions never seen before should be considered for attack detection.
integer
Specifies the percentage of surge in the file create rate up to which it is considered normal behavior.
integer
Specifies the percentage of surge in the file delete rate up to which it is considered normal behavior.
integer
Specifies the percent of surge in the file rename rate up to which it is considered normal behavior.
integer
Specifies the percentage of surge in high entropy data up to which it is considered as normal behavior. For example, if the usual high entropy data rate in the volume is 5% and if this parameter is set to 100%, it will be considered as an unusual surge if the high entropy data rate of the volume exceeds 10% at any time. Similarly, if this parameter is set to 400%, it will be considered as an unusual surge if the high entropy data rate of the volume exceeds 25%, and so on.
integer
Specifies the number of files found with a never seen before file extension up to which it is considered normal behavior.
integer
Specifies the duration within which the specified number of files found with never seen before file extensions is considered normal behavior.
boolean
Specifies whether popular file extensions should be relaxed from being treated as a suspect for the attack. Some popular file extensions are .txt, .pdf, and so on.
suspects
anti_ransomware_attack_report
_links
_links
time
string
Timestamp at which ransomware attack is observed.
event_log
boolean
Specifies whether to send an EMS when a new file extension is discovered.
boolean
Specifies whether to send an EMS when a snapshot is created.
space
snapshot_count
integer
Total number of Anti-ransomware backup snapshots.
used
integer
Total space in bytes used by the Anti-ransomware feature.
used_by_logs
integer
Space in bytes used by the Anti-ransomware analytics logs.
used_by_snapshots
integer
Space in bytes used by the Anti-ransomware backup snapshots.
surge_usage
Usage values of the volume's workload during surge. This object is no longer supported use surge_statistics instead.
integer
Peak rate of file creates per minute in the workload of the volume during surge.
integer
Peak rate of file deletes per minute in the workload of the volume during surge.
integer
Peak rate of file renames per minute in the workload of the volume during surge.
integer
Peak percentage of high entropy data writes in the volume during surge.
integer
Peak high entropy data write rate in the volume during surge, in KBs per minute.
time
string
Timestamp at which the first surge in the volume's workload is observed.
suspect_files
count
integer
Total number of suspect_files.format files observed by the Anti-ransomware analytics engine on the volume.
entropy
string
Indicates the entropy level of this file type.
format
string
File formats observed by the Anti-ransomware analytics engine on the volume.
typical_usage
Typical usage values of volume workload. This object is no longer supported use historical_statistics instead.
integer
Typical peak rate of file creates per minute in the workload of the volume.
integer
Typical peak rate of file deletes per minute in the workload of the volume.
integer
Typical peak rate of file renames per minute in the workload of the volume.
integer
Typical peak percentage of high entropy data writes in the volume.
integer
Typical peak high entropy data write rate in the volume, in KBs per minute.
integer
integer
integer
integer
integer
count
integer
Count of newly observed file extensions.
name
string
Name of the newly observed file extension.
surge_statistics
integer
integer
integer
integer
integer
time
string
surge_usage
integer
integer
integer
integer
integer
array[newly_observed_file_extensions]
New file extensions observed in the volume during surge.
time
string
anti_ransomware_volume_workload
integer
Count of types of file extensions observed in the volume.
array[string]
File extensions observed in the volume.
surge_statistics
surge_statistics
surge_usage
surge_usage
typical_usage
typical_usage
anti_ransomware
Anti-ransomware related information of the volume.
attack_probability
string
Probability of a ransomware attack. none No files are suspected of ransomware activity. low A number of files are suspected of ransomware activity. moderate A moderate number of files are suspected of ransomware activity. high A large number of files are suspected of ransomware activity.
attack_reports
array[anti_ransomware_attack_report]
dry_run_start_time
string
Time when Anti-ransomware monitoring state is set to dry-run value for starting evaluation mode.
event_log
event_log
space
space
state
string
Anti-ransomware state. disabled Anti-ransomware monitoring is disabled on the volume. This is the default state in a POST operation. disable_in_progress Anti-ransomware monitoring is being disabled and a cleanup operation is in effect. Valid in GET operation. dry_run Anti-ransomware monitoring is enabled in the evaluation mode. enabled Anti-ransomware monitoring is active on the volume. paused Anti-ransomware monitoring is paused on the volume. enable_paused Anti-ransomware monitoring is paused on the volume from its earlier enabled state. Valid in GET operation. dry_run_paused Anti-ransomware monitoring is paused on the volume from its earlier dry_run state. Valid in GET operation. For POST, the valid Anti-ransomware states are only disabled, enabled and dry_run, whereas for PATCH, paused is also valid along with the three valid states for POST.
surge_as_normal
boolean
Indicates whether or not to set the surge values as historical values. This field is no longer supported. Use update_baseline_from_surge instead.
surge_usage
surge_usage
suspect_files
array[suspect_files]
typical_usage
typical_usage
boolean
Sets the observed surge value as the new baseline on a volume.
workload
application
name
string
Name of the application to which the volume belongs. Available only when the volume is part of an application.
uuid
string
UUID of the application to which the volume belongs. Available only when the volume is part of an application.
Configuration for asynchronous directory delete from the client. This is only supported on Flexible volumes and FlexGroup volumes.
enabled
boolean
Specifies whether asynchronous directory delete from the client is enabled on the volume.
trash_bin
string
Name of the trash bin directory. If no "trash_bin" property is specified when enabling, the default trash bin name, "._ontaptrashbin", is used.
autosize
grow_threshold
integer
Used space threshold size, in percentage, for the automatic growth of the volume. When the amount of used space in the volume becomes greater than this threshold, the volume automatically grows unless it has reached the maximum size. The volume grows when 'space.used' is greater than this percent of 'space.size'. The 'grow_threshold' size cannot be less than or equal to the 'shrink_threshold' size..
maximum
integer
Maximum size in bytes up to which a volume grows automatically. This size cannot be less than the current volume size, or less than or equal to the minimum size of volume.
minimum
integer
Minimum size in bytes up to which the volume shrinks automatically. This size cannot be greater than or equal to the maximum size of volume.
mode
string
Autosize mode for the volume. grow ‐ Volume automatically grows when the amount of used space is above the 'grow_threshold' value. grow_shrink ‐ Volume grows or shrinks in response to the amount of space used. off ‐ Autosizing of the volume is disabled.
shrink_threshold
integer
Used space threshold size, in percentage, for the automatic shrinkage of the volume. When the amount of used space in the volume drops below this threshold, the volume automatically shrinks unless it has reached the minimum size. The volume shrinks when the 'space.used' is less than the 'shrink_threshold' percent of 'space.size'. The 'shrink_threshold' size cannot be greater than or equal to the 'grow_threshold' size.
snapshot_reference
_links
_links
name
string
uuid
string
parent_svm
_links
_links
name
string
uuid
string
parent_volume
_links
_links
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
clone
has_flexclone
boolean
Specifies whether this volume is a parent of any FlexClone volume.
integer
Inherited physical used from the clone's base snapshot.
inherited_savings
integer
Inherited savings from the clone's base snapshot.
is_flexclone
boolean
Specifies if this volume is a normal FlexVol volume or FlexClone volume. This field needs to be set when creating a FlexClone volume. Valid in POST.
parent_snapshot
snapshot_reference
parent_svm
parent_svm
parent_volume
parent_volume
integer
Percentage of FlexClone volume blocks split from its parent volume.
split_estimate
integer
Space required by the containing-aggregate to split the FlexClone volume.
split_initiated
boolean
This field is set when a split is executed on any FlexClone volume, that is when the FlexClone volume is split from its parent FlexVol volume. Setting this field initiates a split of a FlexClone volume from a FlexVol volume. Valid in PATCH.
consistency_group
Consistency group the volume is part of.
name
string
The name of the consistency group to which the volume belongs. Available only when the volume is part of a consistency group. If this volume belongs to a child consistency group, then this will be the UUID of the parent consistency group.
uuid
string
The UUID of the consistency group to which the volume belongs. Available only when the volume is part of a consistency group. If this volume belongs to a child consistency group, then this will be the UUID of the parent consistency group.
aggregates
name
string
Name of the aggregate hosting the FlexGroup volume constituent.
uuid
string
Unique identifier for the aggregate.
Aggregate
_links
_links
name
string
uuid
string
movement
Volume movement. All attributes are modify, that is, not writable through POST. Set PATCH state to destination_aggregate to initiate a volume move operation. Volume movement on FlexGroup volume constituents is not supported.
cutover_window
integer
Time window in seconds for cutover. The allowed range is between 30 to 300 seconds.
Aggregate
percent_complete
integer
Completion percentage
state
string
State of volume move operation. PATCH the state to "aborted" to abort the move operation. PATCH the state to "cutover" to trigger cutover. PATCH the state to "paused" to pause the volume move operation in progress. PATCH the state to "replicating" to resume the paused volume move operation. PATCH the state to "cutover_wait" to go into cutover manually. When volume move operation is waiting to go into "cutover" state, this is indicated by the "cutover_pending" state. A change of state is only supported if volume movement is in progress.
tiering_policy
string
Tiering policy for FabricPool
logical_space
available
integer
The amount of space available in this volume with storage efficiency space considered used, in bytes.
enforcement
boolean
Specifies whether space accounting for operations on the volume is done along with storage efficiency.
reporting
boolean
Specifies whether space reporting on the volume is done along with storage efficiency.
used_by_afs
integer
The virtual space used by AFS alone (includes volume reserves) and along with storage efficiency, in bytes.
snapshot
autodelete_enabled
boolean
Specifies whether snapshot autodelete is currently enabled on this volume.
reserve_percent
integer
The space that has been set aside as a reserve for snapshot usage, in percent.
used
integer
The total space used by snapshots in the volume, in bytes.
space
afs_total
integer
Total size of AFS, excluding snap-reserve, in bytes.
available
integer
The available space, in bytes.
available_percent
integer
The space available, as a percent.
integer
The size that is physically used in the block storage of the volume and has a cold temperature. In bytes. This parameter is only supported if the volume is in an aggregate that is either attached to a cloud store or could be attached to a cloud store.
integer
Space used by capacity tier for this volume in the FabricPool aggregate, in bytes.
footprint
integer
Data used for this volume in the aggregate, in bytes.
large_size_enabled
boolean
Specifies whether the support for large volumes and large files is enabled on the volume.
integer
Space used by the local tier for this volume in the aggregate, in bytes.
logical_space
logical_space
max_size
string
Indicates the maximum size supported for each constituent of the FlexGroup volume.
metadata
integer
Space used by the volume metadata in the aggregate, in bytes.
over_provisioned
integer
The amount of space not available for this volume in the aggregate, in bytes.
integer
Space used by the performance tier for this volume in the FabricPool aggregate, in bytes.
size
integer
Total provisioned size. The default size is equal to the minimum size of 20MB, in bytes.
snapshot
snapshot
total_footprint
integer
Data and metadata used for this volume in the aggregate, in bytes.
total_metadata
integer
Space used by the total metadata in the volume, in bytes.
integer
Space used by the volume metadata footprint in the aggregate, in bytes.
used
integer
The virtual space used (includes volume reserves) before storage efficiency, in bytes.
used_by_afs
integer
The space used by Active Filesystem, in bytes.
used_percent
integer
The virtual space used (includes volume reserves) before storage efficiency, as a percent.
constituents
aggregates
aggregates
movement
movement
name
string
FlexGroup volume constituent name.
space
space
idcs_scanner
Inactive data compression scan looks and picks up blocks that have not been read for a certain amount of time(threshold_inactive_days). These blocks are then compressed in 32K chunks. All attributes are valid for GET only, except for 'operation_state' which is valid for PATCH and GET, and is used to start/stop the scanner.
enabled
boolean
Specifies the administrative state of the inactive data compression scanner. Disabling inactive data compression is not allowed on Capacity optimized Flash with QAT supported platforms.
inactive_days
integer
Data blocks older than, or equal to, 'inactive_days' are picked up by the inactive data compression scanner. Valid for PATCH only. Only applicable when 'operation_state' set to 'active'.
mode
string
Specifies the mode of inactive data compression scanner. Valid for PATCH and GET.
operation_state
string
Specifies the operational state of the inactive data compression scanner. VALID for PATCH and GET. Valid options for PATCH are "idle" and "active".
status
string
Status of last inactive data compression scan on the volume.
string
Time interval after which inactive data compression is automatically triggered. The value is in days and is represented in the ISO-8601 format "PD", for example "P3D" represents a duration of 3 days. This field is not supported on QAT supported platforms.
policy
name
string
Specifies the name of the efficiency policy. The "inline-only" and "none" policies are not supported on Capacity optimized Flash with QAT supported platform.
scanner
compression
boolean
Start compression if scanning old data. Valid for PATCH and GET. This option is not supported for FSX/CVO platforms.
dedupe
boolean
Start deduplication if scanning old data. Valid for PATCH and GET.
scan_old_data
boolean
Indicates whether or not to scan old data. Valid for PATCH and GET.
state
string
State of the volume efficiency scanner. Valid for PATCH and GET. Valid options for PATCH are "idle" and "active".
space_savings
compression
integer
Total disk space that is saved by compressing blocks on the referenced file system, in bytes.
compression_percent
integer
Percentage of total disk space that is saved by compressing blocks on the referenced file system.
dedupe
integer
Total disk space that is saved by deduplication and file cloning, in bytes.
dedupe_percent
integer
Percentage of total disk space that is saved by deduplication and file cloning.
dedupe_sharing
integer
Total disk space that is shared due to deduplication and file cloning.
total
integer
Total disk space saved in the volume due to deduplication, compression and file cloning, in bytes.
total_percent
integer
Percentage of total disk space saved in the volume due to deduplication, compression and file cloning.
efficiency
application_io_size
string
Block size to use by compression. 8k and auto are only allowed for POST. Only auto is supported on QAT supported platforms.
auto_state
string
Automatic deduplication schedule volume state. auto ‐ Volumes with auto_state set to auto start post-process deduplication automatically. deprioritized ‐ Volumes with auto_state set to deprioritized do not start post-process deduplication automatically.
compaction
string
The system can be enabled/disabled compaction. inline ‐ Data will be compacted first and written to the volume. none ‐ None mixed ‐ Read only field for FlexGroup volumes, where some of the constituent volumes are compaction enabled and some are disabled.
compression
string
The system can be enabled/disabled compression. Disabling compression is not allowed on Capacity optimized Flash with QAT supported platforms. inline ‐ Data will be compressed first and written to the volume. background ‐ Data will be written to the volume and compressed later. both ‐ Inline compression compresses the data and write to the volume, background compression compresses only the blocks on which inline compression is not run. none ‐ None mixed ‐ Read only field for FlexGroup volumes, where some of the constituent volumes are compression enabled and some are disabled.
Note that On volumes with container compression enabled, background compression refers to inactive data compression scan enabled on the volume.
compression_type
string
Compression type to use by compression. Valid for PATCH and GET.
cross_volume_dedupe
string
The system can be enabled/disabled cross volume dedupe. it can be enabled only when dedupe is enabled. Disabling cross volume dedupe is not allowed on Capacity optimized Flash with QAT supported platforms. inline ‐ Data will be cross volume deduped first and written to the volume. background ‐ Data will be written to the volume and cross volume deduped later. both ‐ Inline cross volume dedupe dedupes the data and write to the volume, background cross volume dedupe dedupes only the blocks on which inline dedupe is not run. none ‐ None mixed ‐ Read only field for FlexGroup volumes, where some of the constituent volumes are cross volume dedupe enabled and some are disabled.
dedupe
string
The system can be enabled/disabled dedupe. Disabling dedupe is not allowed on Capacity optimized Flash with QAT supported platforms. inline ‐ Data will be deduped first and written to the volume. background ‐ Data will be written to the volume and deduped later. both ‐ Inline dedupe dedupes the data and write to the volume, background dedupe dedupes only the blocks on which inline dedupe is not run. none ‐ None mixed ‐ Read only field for FlexGroup volumes, where some of the constituent volumes are dedupe enabled and some are disabled.
has_savings
boolean
When true, indicates that the volume contains shared(deduplication, file clones) or compressed data.
idcs_scanner
idcs_scanner
last_op_begin
string
Last sis operation begin timestamp.
last_op_end
string
Last sis operation end timestamp.
last_op_err
string
Last sis operation error text.
last_op_size
integer
Last sis operation size.
last_op_state
string
Last sis operation state.
logging_enabled
boolean
When true, indicates that space savings for any newly-written data are being logged.
op_state
string
Sis status of the volume.
policy
policy
progress
string
Sis progress of the volume.
scanner
scanner
schedule
string
Schedule associated with volume.
space_savings
space_savings
state
string
Storage efficiency state of the volume. Currently, this field supports POST/PATCH only for RW (Read-Write) volumes on FSx for ONTAP and Cloud Volumes ONTAP. disabled ‐ All storage efficiency features are disabled. mixed ‐ Read-only field for FlexGroup volumes, storage efficiency is enabled on certain constituents and disabled on others. On FSx for ONTAP and Cloud Volumes ONTAP ‐   enabled ‐ All supported storage efficiency features for the volume are enabled.   custom ‐ Read-only field currently only supported for the FSx for ONTAP and Cloud Volumes ONTAP, user-defined storage efficiency features are enabled. For other platforms ‐   enabled ‐ At least one storage efficiency feature for the volume is enabled.
  • enum: ["disabled", "enabled", "mixed", "custom"]
  • Introduced in: 9.9
  • x-nullable: true
string
Storage efficiency mode used by volume. This parameter is supported only on AFF platforms. There is no difference between default and efficient modes on QAT supported platforms and auto adaptive compression is set irrespective of the modes.
type
string
Sis Type of the volume.
volume_path
string
Absolute volume path of the volume.
status
code
string
Encryption progress message code.
message
string
Encryption progress message.
encryption
action
string
This field can be used to pause an ongoing rekey or conversion operation or resume a paused rekey or conversion operation. Valid in PATCH. The following actions are supported for this field: conversion_pause ‐ Pause an encryption conversion operation currently in progress. conversion_resume ‐ Resume a paused encryption conversion operation. rekey_pause ‐ Pause an encryption rekey operation currently in progress. rekey_resume ‐ Resume a paused encryption rekey operation.
enabled
boolean
Creates an encrypted or an unencrypted volume. For POST, when set to 'true', a new key is generated and used to encrypt the given volume. In that case, the underlying SVM must be configured with the key manager. When set to 'false', the volume created will be unencrypted. For PATCH, when set to 'true', it encrypts an unencrypted volume. Specifying the parameter as 'false' in a PATCH operation for an encrypted volume is only supported when moving the volume to another aggregate.
key_create_time
string
Encryption key creation time of the volume.
key_id
string
The key ID used for creating encrypted volume. A new key-id is generated for creating an encrypted volume. This key-id is associated with the generated key.
rekey
boolean
If set to 'true', re-encrypts the volume with a new key. Valid in PATCH.
state
string
Volume encryption state. encrypted ‐ The volume is completely encrypted. encrypting ‐ Encryption operation is in progress. partial ‐ Some constituents are encrypted and some are not. Applicable only for FlexGroup volume. rekeying. Encryption of volume with a new key is in progress. unencrypted ‐ The volume is a plain-text one.
status
status
type
string
Volume encryption type. none ‐ The volume is a plain-text one. volume ‐ The volume is encrypted with NVE (NetApp Volume Encryption). aggregate ‐ The volume is encrypted with NAE (NetApp Aggregate Encryption).
error_state
has_bad_blocks
boolean
Indicates whether the volume has any corrupt data blocks. If the damaged data block is accessed, an IO error, such as EIO for NFS or STATUS_FILE_CORRUPT for CIFS, is returned.
is_inconsistent
boolean
Indicates whether the file system has any inconsistencies. true ‐ File system is inconsistent. false ‐ File system in not inconsistent.
files
maximum
integer
The maximum number of files (inodes) for user-visible data allowed on the volume. This value can be increased or decreased. Increasing the maximum number of files does not immediately cause additional disk space to be used to track files. Instead, as more files are created on the volume, the system dynamically increases the number of disk blocks that are used to track files. The space assigned to track files is never freed, and this value cannot be decreased below the current number of files that can be tracked within the assigned space for the volume. Valid in PATCH.
used
integer
Number of files (inodes) used for user-visible data permitted on the volume. This field is valid only when the volume is online.
flash_pool
cache_eligibility
string
If this parameter is specified, the command displays information only about the volume or volumes with the specified Flash Pool caching attributes.
string
If this parameter is specified, the command displays the volumes that match the specified cache retention priority policy. A cache retention priority defines how long the blocks of a volume will be cached in the Flash Pool once they become cold.
caching_policy
string
This optionally specifies the caching policy to apply to the volume. A caching policy defines how the system caches a volume's data in Flash Cache modules. If a caching policy is not assigned to a volume, the system uses the caching policy that is assigned to the containing SVM. If a caching policy is not assigned to the containing SVM, the system uses the default cluster-wide policy.
flexgroup
name
string
Name of the FlexGroup volume that the constituent is part of.
uuid
string
Unique identifier for the FlexGroup volume that the constituent is part of.
guarantee
honored
boolean
Is the space guarantee of this volume honored in the aggregate?
type
string
The type of space guarantee of this volume in the aggregate.
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Performance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
cloud
Performance numbers (IOPS and latency) for cloud store. These numbers are relevant only for volumes hosted on FabricPools.
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
timestamp
string
The timestamp of the performance data.
flexcache
Performance number for FlexCache used to measure cache effectiveness.
bandwidth_savings
integer
Bandwidth savings denoting the amount of data served locally by the cache, in bytes.
cache_miss_percent
integer
Cache miss percentage.
duration
string
status
string
timestamp
string
throughput
other
integer
read
integer
total
integer
write
integer
metric
Performance numbers, such as IOPS, latency and throughput.
_links
_links
cloud
cloud
duration
string
flexcache
flexcache
iops
iops
latency
latency
status
string
throughput
throughput
timestamp
string
movement
Volume movement. All attributes are modify, that is, not writable through POST. Set PATCH state to destination_aggregate to initiate a volume move operation. Volume movement on FlexGroup volume constituents are not supported.
cutover_window
integer
Aggregate
percent_complete
integer
start_time
string
Start time of volume move.
state
string
tiering_policy
string
export_policy
Export Policy
_links
_links
id
integer
name
string
junction_parent
_links
_links
name
string
The name of the parent volume that contains the junction inode of this volume. The junction parent volume must belong to the same SVM that owns this volume.
uuid
string
Unique identifier for the parent volume.
nas
export_policy
export_policy
Export Policy
gid
integer
The UNIX group ID of the volume. Valid in POST or PATCH.
junction_parent
junction_parent
path
string
The fully-qualified path in the owning SVM's namespace at which the volume is mounted. The path is case insensitive and must be unique within a SVM's namespace. Path must begin with '/' and must not end with '/'. Only one volume can be mounted at any given junction path. An empty path in POST creates an unmounted volume. An empty path in PATCH deactivates and unmounts the volume. Taking a volume offline or restricted state removes its junction path. This attribute is reported in GET only when the volume is mounted.
security_style
string
Security style associated with the volume. Valid in POST or PATCH. mixed ‐ Mixed-style security ntfs ‐ NTFS/WIndows-style security unified ‐ Unified-style security, unified UNIX, NFS and CIFS permissions unix ‐ Unix-style security.
uid
integer
The UNIX user ID of the volume. Valid in POST or PATCH.
unix_permissions
integer
UNIX permissions to be viewed as an octal number. It consists of 4 digits derived by adding up bits 4 (read), 2 (write) and 1 (execute). First digit selects the set user ID(4), set group ID (2) and sticky (1) attributes. The second digit selects permission for the owner of the file; the third selects permissions for other users in the same group; the fourth for other users not in the group. Valid in POST or PATCH. For security style "mixed" or "unix", the default setting is 0755 in octal (493 in decimal) and for security style "ntfs", the default setting is 0000. In cases where only owner, group and other permissions are given (as in 755, representing the second, third and fourth dight), first digit is assumed to be zero.
policy
When "min_throughput_iops", "min_throughput_mbps", "max_throughput_iops" or "max_throughput_mbps" attributes are specified, the storage object is assigned to an auto-generated QoS policy group. If the attributes are later modified, the auto-generated QoS policy-group attributes are modified. Attributes can be removed by specifying "0" and policy group by specifying "none". Upon deletion of the storage object or if the attributes are removed, then the QoS policy-group is also removed.
_links
_links
max_throughput_iops
integer
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
max_throughput_mbps
integer
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_iops
integer
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH.
min_throughput_mbps
integer
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.
name
string
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH.
uuid
string
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH.
qos
QoS information
policy
policy
quota
Quotas track the space or file usage of a user, group, or qtree in a FlexVol volume or a FlexGroup volume.
enabled
boolean
This option is used to enable or disable the quota for the volume. This option is valid only in PATCH. Quotas are enabled for FlexVol volumes or FlexGroup volumes when the quota state is "on". Quotas are disabled for FlexVol volumes or FlexGroup volumes when the quota state is "off".
state
string
Quota state of the volume
last_error
Error information for the last failed file move on the constituent.
code
integer
Error code of the last file move error on the constituent.
destination
integer
DSID of the destination constituent of the last file move error on the constituent.
file_id
integer
File ID of the last file move error on the constituent.
time
string
Time of the last file move error on the constituent.
movement
Properties on this constituent related to file movement.
file_moves_started
integer
Number of file moves started on this constituent.
last_error
last_error
string
Start time of the most recent file move on the constituent.
blocks_skipped
Number of blocks skipped by the scanner on this constituent due to various reasons.
efficiency_blocks
integer
Number of blocks skipped by the scanner on this constituent because storage efficiency lost, in blocks, would be too high.
efficiency_percent
integer
Number of blocks skipped by the scanner on this constituent because storage efficiency lost, in percent, would be too high.
fast_truncate
integer
Number of blocks skipped by the scanner on this constituent because fast truncate is currently running on files.
footprint_invalid
integer
Number of blocks skipped by the scanner on this constituent because of files with invalid space footprints.
in_snapshot
integer
Number of blocks skipped by the scanner on this constituent because of files in snapshots.
incompatible
integer
Number of blocks skipped by the scanner on this constituent because of incompatible files.
metadata
integer
Number of blocks skipped by the scanner on this constituent because of metadata files.
integer
Number of blocks skipped by the scanner on this constituent because of on demand destination files.
other
integer
Number of blocks skipped by the scanner on this constituent for all other reasons.
remote_cache
integer
Number of blocks skipped by the scanner on this constituent because of remote caches.
too_large
integer
Number of blocks skipped by the scanner on this constituent because of files that are larger than rebalancing.max_file_size.
too_small
integer
Number of blocks skipped by the scanner on this constituent because of files that are smaller than rebalancing.min_file_size.
write_fenced
integer
Number of blocks skipped by the scanner on this constituent because of files fenced for write operations.
files_skipped
Number of files skipped by the scanner on this constituent due to various reasons.
efficiency_blocks
integer
Number of files skipped by the scanner on this constituent because storage efficiency lost, in blocks, would be too high.
efficiency_percent
integer
Number of files skipped by the scanner on this constituent because storage efficiency lost, in percent, would be too high.
fast_truncate
integer
Number of files skipped by the scanner on this constituent because fast truncate is currently running on the file.
footprint_invalid
integer
Number of files skipped by the scanner on this constituent because their space footprints are invalid.
in_snapshot
integer
Number of files skipped by the scanner on this constituent because they are trapped in snapshots.
incompatible
integer
Number of files skipped by the scanner on this constituent because they are incompatible.
metadata
integer
Number of files skipped by the scanner on this constituent because they metadata files.
integer
Number of files skipped by the scanner on this constituent because they are on demand destinations.
other
integer
Number of files skipped by the scanner on this constituent for all other reasons.
remote_cache
integer
Number of files skipped by the scanner on this constituent because they are remote caches.
too_large
integer
Number of files skipped by the scanner on this constituent because they are larger than rebalancing.max_file_size.
too_small
integer
Number of files skipped by the scanner on this constituent because they are smaller than rebalancing.min_file_size.
write_fenced
integer
Number of files skipped by the scanner on this constituent because they are fenced for write operations.
scanner
Properties related to determining which files to move and where to move them to.
blocks_scanned
integer
Number of blocks scanned on this constituent.
blocks_skipped
blocks_skipped
files_scanned
integer
Number of files scanned on this constituent.
files_skipped
files_skipped
engine
Each constituent has one rebalancing engine that co-ordinates scanning constituents for free space and files to move, as well as moving files between constituents. The engine properties must be explicitly requested, are meant for helping diagnose why the volume rebalancer is making decisions.
movement
movement
scanner
scanner
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
rebalancing
Configuration and runtime properties involving non-disruptive volume capacity rebalancing for a FlexGroup volume.
_links
_links
data_moved
integer
The amount of data that has been moved in or out of a constituent. A positive value represents data moving into the constituent while a negative value is data moving out of the constituent.
engine
engine
exclude_snapshots
boolean
Specifies whether or not to exclude files that are stuck in snapshots during rebalancing operation. When a new capacity rebalancing operation is started on a FlexGroup volume, it uses the current "exclude_snapshots" value. Once the operation is started, any changes to the "exclude_snapshots" value do not affect the currently running capacity rebalancing operation. Only future capacity rebalancing operations will use the new "exclude_snapshots" value.
imbalance_percent
integer
Represents the percentage the volume is out of balance.
imbalance_size
integer
Represents how much the volume is out of balance, in bytes.
integer
Absolute percentage of the constituent that is most out of balance. This value will update every 30 seconds when rebalancing is not active and every 10 seconds when rebalancing is active.
max_file_moves
integer
Specifies the maximum number of concurrent file moves in a volume capacity rebalancing operation on a constituent of the FlexGroup volume. When a new capacity rebalancing operation is started on a FlexGroup volume, it uses the current "max_file_moves" value. Once the operation is started, any changes to the "max_file_moves" value do not affect the currently running capacity rebalancing operation. Only future capacity rebalancing operations will use the new "max_file_moves" value.
max_runtime
string
This optional field specifies the maximum time a capacity rebalancing operation runs for. Once the maximum runtime has passed, the capacity rebalancing operation stops. If it is not set, the default value is 6 hours. This value cannot be updated while a capacity rebalancing operation is running. The maximum runtime can be in years, months, days, hours, and minutes. A period specified for years, months, and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively, for example "P3D" represents a duration of 3 days. A duration in hours and minutes is represented by "PTH" and "PTM" respectively.
max_threshold
integer
Specifies the maximum imbalance percentage for FlexGroup volume constituents. When a constituent's imbalance percentage is larger than this value, files are moved from the constituent. When a new capacity rebalancing operation is started on a FlexGroup volume, it uses the current "max_threshold" value. Once the operation is started, any changes to the "max_threshold" value do not affect the currently running capacity rebalancing operation. Only future capacity rebalancing operations will use the new "max_threshold" value.
min_file_size
integer
Specifies the minimum file size to consider for a volume capacity rebalancing operation. When a new capacity rebalancing operation is started on a FlexGroup volume, it uses the current "min_file_size" value. Once the operation is started, any changes to the "min_file_size" value do not affect the currently running capacity rebalancing operation. Only future capacity rebalancing operations will use the new "min_file_size" value. The value must be a multiple of 4KB. If it is not set, the default value is 100MB. Setting "min-file-size" to less than the default value leads to more files being moved. Moved files use granular data, which may impact read/write I/O performance.
min_threshold
integer
Specifies the minimum imbalance percentage for FlexGroup volume constituents. When a constituent's imbalance percentage is smaller than this value, files are not moved from the constituent. When a new capacity rebalancing operation is started on a FlexGroup volume, it will use the current "min_threshold" value. Once the operation is started, any changes to the "min_threshold" value do not affect the currently running capacity rebalancing operation. Only future capacity rebalancing operations will use the new "min_threshold" value.
notices
array[error]
Capacity rebalancing notice messages.
runtime
string
Duration the capacity rebalancing operation has been running.
start_time
string
Time when the current capacity rebalancing operation started, or when a future scheduled rebalancing operation begins.
state
string
State of the volume capacity rebalancing operation. PATCH the state to "starting" to trigger the capacity rebalance operation, and include start_time to schedule rebalancing. PATCH the state to "stopping" to stop the capacity rebalance operation, or cancel a scheduled rebalancing operation. PATCH without the state with a valid start_time to modify the start_time of an existing scheduled rebalance operation.
While a FlexGroup volume is rebalancing, every constituent will have a rebalancing engine that can either be scanning the filesystem for space usage and files to move, actively moving files or temporarily doing neither.
If one or more constituents has a state of "rebalancing_source" or "rebalancing_dest", then files are being moved to rebalance the FlexGroup volume.
If no files are being moved, more information about what the rebalancing engine is doing for each constituent is available using the "rebalancing.engine" property.
The following values apply to FlexGroup volumes. not_running ‐ capacity rebalancing is not running on the volume. starting ‐ used in a PATCH operation to start a capacity rebalancing operation. rebalancing ‐ capacity rebalancing is running on the volume. paused ‐ volume capacity rebalancing is paused on the volume. stopping ‐ used in a PATCH operation to stop a capacity rebalancing operation. unknown ‐ the system was unable to determine the rebalancing state for the volume.
The following values apply to FlexGroup volume constituents. idle ‐ capacity rebalancing is running on the constituent, however, no active scanning or file movement is currently occurring. scanning ‐ the constituent's file system is being scanned to find files to move and determine free space. rebalancing_source ‐ a file is being moved off of the constituent. rebalancing_dest ‐ a file is being moved to the constituent. not_running ‐ capacity rebalancing is not running on the constituent. unknown ‐ the system was unable to determine the rebalancing state for the constituent.
stop_time
string
Time when the capacity rebalancing operation stopped.
target_used
integer
Represents the ideal used size of each constituent. Calculated by dividing the total FlexGroup volume used size by the number of constituents.
used_for_imbalance
integer
Represents the used size of each constituent, as determined by the rebalancing engine. Calculated by subtracting the size used by snapshots, the size of files pending deletion and the size of filesystem metadata from the volume used size.
retention
Name Type Description
default
string
Specifies the default retention period that is applied to files while committing them to the WORM state without an associated retention period. The retention value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A duration specified for years, months, and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively, for example "P10Y" represents a duration of 10 years. A duration in hours and minutes is represented by "PTH" and "PTM" respectively. The retention string must contain only a single time element that is, either years, months, days, hours, or minutes. A duration which combines different periods is not supported, for example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the duration field also accepts the string "infinite" to set an infinite retention period and the string "unspecified" to set an unspecified retention period.
maximum
string
Specifies the maximum allowed retention period for files committed to the WORM state on the volume. The retention value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A duration specified for years, months, and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively, for example "P10Y" represents a duration of 10 years. A duration in hours and minutes is represented by "PTH" and "PTM" respectively. The retention string must contain only a single time element that is, either years, months, days, hours, or minutes. A duration which combines different periods is not supported, for example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the duration field also accepts the string "infinite" to set an infinite retention period.
minimum
string
Specifies the minimum allowed retention period for files committed to the WORM state on the volume. The retention value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A duration specified for years, month,s and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively, for example "P10Y" represents a duration of 10 years. A duration in hours and minutes is represented by "PTH" and "PTM" respectively. The retention string must contain only a single time element that is, either years, months, days, hours, or minutes. A duration which combines different periods is not supported, for example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the duration field also accepts the string "infinite" to set an infinite retention period.
snaplock
append_mode_enabled
boolean
Specifies if the volume append mode is enabled or disabled. When it is enabled, all the files created with write permissions on the volume are, by default, WORM appendable files. The user can append the data to a WORM appendable file but cannot modify the existing contents of the file nor delete the file until it expires.
autocommit_period
string
Specifies the autocommit period for SnapLock volume. All files which are not modified for a period greater than the autocommit period of the volume are committed to the WORM state. The autocommit period value represents a duration and must be specified in the ISO-8601 duration format. The autocommit period can be in years, months, days, hours, and minutes. A period specified for years, months, and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively, for example "P10Y" represents a duration of 10 years. A duration in hours and minutes is represented by "PTH" and "PTM" respectively. The period string must contain only a single time element that is, either years, months, days, hours, or minutes. A duration which combines different periods is not supported, for example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the autocommit field also accepts the string "none".
string
This is the volume compliance clock time which is used to manage the SnapLock objects in the volume.
expiry_time
string
Expiry time of the volume. For volumes with an infinite, indefinite or unspecified SnapLock expiry time, "9999-12-31T23:59:59" is used to denote the time.
is_audit_log
boolean
Indicates if this volume has been configured as SnapLock audit log volume for the SVM .
litigation_count
integer
Litigation count indicates the number of active legal-holds on the volume.
privileged_delete
string
Specifies the privileged-delete attribute of a SnapLock volume. On a SnapLock Enterprise (SLE) volume, a designated privileged user can selectively delete files irrespective of the retention time of the file. SLE volumes can have privileged delete as disabled, enabled or permanently_disabled and for SnapLock Compliance (SLC) volumes it is always permanently_disabled.
retention
retention
type
string
The SnapLock type of the volume. compliance ‐ A SnapLock Compliance(SLC) volume provides the highest level of WORM protection and an administrator cannot destroy a SLC volume if it contains unexpired WORM files. enterprise ‐ An administrator can delete a SnapLock Enterprise(SLE) volume. non_snaplock ‐ Indicates the volume is non-snaplock.
unspecified_retention_file_count
integer
Indicates the number of files with an unspecified retention time in the volume.
destinations
is_cloud
boolean
Specifies whether a volume is a SnapMirror source volume, using SnapMirror to protect its data to a cloud destination.
is_ontap
boolean
Specifies whether a volume is a SnapMirror source volume, using SnapMirror to protect its data to an ONTAP destination.
  • readOnly: 1
  • x-nullable: true
snapmirror
Specifies attributes for SnapMirror protection.
destinations
destinations
is_protected
boolean
Specifies whether a volume is a SnapMirror source volume, using SnapMirror to protect its data.
snapshot_policy
This is a reference to the snapshot policy.
_links
_links
name
string
uuid
string
logical_space
available
integer
enforcement
boolean
reporting
boolean
used
integer
SUM of (physical-used, shared_refs, compression_saved_in_plane0, vbn_zero, future_blk_cnt), in bytes.
used_by_afs
integer
used_by_snapshots
integer
Size that is logically used across all snapshots in the volume, in bytes.
used_percent
integer
SUM of (physical-used, shared_refs, compression_saved_in_plane0, vbn_zero, future_blk_cnt), as a percentage.
autodelete
commitment
string
By default, snapshot autodelete does not delete snapshots locked by Snapmirror, clones of a volume, a LUN, an NVMe namespace, or a file. Deletion of snapshots locked by these applications is specified using this option. The default value is try.
defer_delete
string
Allows the user to inform snapshot autodelete to defer the deletion of a specified snapshot until the end. The default value is user_created.
delete_order
string
Specifies the order in which snapshot autodelete occurs. Ordering is done using the date and time the snapshot is created. The default value is oldest_first.
enabled
boolean
prefix
string
Specifies the prefix of the snapshot which if matched, is deleted last. Used with autodelete_defer_delete when used with a prefix value.
target_free_space
integer
Snapshots are deleted, one at a time, until the used volume space reaches the value specified. The default is 20% free space or 80% utilized.
trigger
string
Specifies when the system should trigger an autodelete of snapshots. When set to volume, autodelete is triggered based on volume fullness. When set to snap_reserve, autodelete is triggered based on snapshot reserve fullness. The default value is volume.
snapshot
autodelete
autodelete
autodelete_enabled
boolean
Specifies whether snapshot autodelete is currently enabled on this volume. This field will no longer be supported in a future release. Use autodelete.enabled instead.
autodelete_trigger
string
Specifies when the system should trigger an autodelete of snapshots. When set to volume, autodelete is triggered based on volume fullness. When set to snap_reserve, autodelete is triggered based on snapshot reserve fullness. The default value is volume. This field will no longer be supported in a future release. Use autodelete.trigger instead.
reserve_available
integer
Size available for snapshots within the snapshot reserve, in bytes.
reserve_percent
integer
reserve_size
integer
Size in the volume that has been set aside as a reserve for snapshot usage, in bytes.
space_used_percent
integer
Percentage of snapshot reserve size that has been used.
used
integer
space
afs_total
integer
auto_adaptive_compression_footprint_data_reduction
integer
Savings achieved due to Auto Adaptive Compression, in bytes.
available
integer
available_percent
integer
block_storage_inactive_user_data
integer
block_storage_inactive_user_data_percent
integer
Percentage of size that is physically used in the performance tier of the volume.
capacity_tier_footprint
integer
capacity_tier_footprint_data_reduction
integer
Savings achieved in the space used by the capacity tier for this volume in the FabricPool aggregate, in bytes.
compaction_footprint_data_reduction
integer
Savings achieved due to Data Compaction, in bytes.
cross_volume_dedupe_metafiles_footprint
integer
Cross volume deduplication metadata footprint, in bytes.
cross_volume_dedupe_metafiles_temporary_footprint
integer
Cross volume temporary deduplication metadata footprint, in bytes.
integer
Deduplication metadata footprint, in bytes.
integer
Temporary deduplication metadata footprint, in bytes.
delayed_free_footprint
integer
Delayed free blocks footprint, in bytes.
effective_total_footprint
integer
Volume footprint after efficiency savings, in bytes. effective total footprint represents total footprint after deducting auto adaptive compression and compaction savings. effective-footprint includes aggregate metadata used by volume.
expected_available
integer
Size that should be available for the volume, irrespective of available size in the aggregate, in bytes.
file_operation_metadata
integer
File operation metadata footprint, in bytes.
filesystem_size
integer
Total usable size of the volume, in bytes.
filesystem_size_fixed
boolean
Specifies whether the file system is to remain of the same size when set to true or to grow when set to false. This option is automatically set to true when a volume becomes SnapMirrored.
footprint
integer
fractional_reserve
integer
Used to change the amount of space reserved for overwrites of reserved objects in a volume.
full_threshold_percent
integer
Volume full threshold percentage at which EMS warnings can be sent.
is_used_stale
boolean
Specifies if the virtual space used is stale.
large_size_enabled
boolean
Indicates if the support for large FlexVol volumes and large files is enabled on this volume. When configured to true, FlexVol volume size can reach up to 300TB and single file size can reach 128TB.
local_tier_footprint
integer
logical_space
logical_space
max_size
string
Indicates the maximum size supported for the FlexVol volume or for each constituent of the FlexGroup volume.
metadata
integer
nearly_full_threshold_percent
integer
Volume nearly full threshold percentage at which EMS warnings can be sent.
over_provisioned
integer
overwrite_reserve
integer
Reserved space for overwrites, in bytes.
overwrite_reserve_used
integer
Overwrite logical reserve space used, in bytes.
percent_used
integer
Percentage of the volume size that is used.
performance_tier_footprint
integer
physical_used
integer
Size that is physically used in the volume, in bytes. Physical used is effective total footprint which is equivalent to total footprint after deducting auto adaptive compression and compaction savings. Physical-used also includes aggregate metadata used by volume.
physical_used_percent
integer
Size that is physically used in the volume, as a percentage.
size
integer
size_available_for_snapshots
integer
Available space for snapshots from snap-reserve, in bytes.
snapmirror_destination_footprint
integer
SnapMirror destination footprint, in bytes.
snapshot
snapshot
snapshot_reserve_unusable
integer
Snapshot reserve that is not available for snapshot creation, in bytes.
snapshot_spill
integer
Space used by the snapshot copies beyond the snap-reserve, in bytes.
total_footprint
integer
total_metadata
integer
total_metadata_footprint
integer
used
integer
used_by_afs
integer
user_data
integer
User data, in bytes.
volume_guarantee_footprint
integer
Space reserved for future writes in the volume, in bytes.
access
Raw count and latency data for access operations.
count
integer
Number of operations of the given type performed on this volume.
total_time
integer
The raw data component latency in microseconds measured within ONTAP for all operations of the given type.
  • example: 200
  • Introduced in: 9.11
  • x-nullable: true
audit
Raw count and latency data for audit operations. These statistics are only applicable for CIFS protocol operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
dir
Raw count and latency data for directory-create operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
file
Raw count and latency data for file-create operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
other
Raw count and latency data for create operations on objects other than files, directories and symlinks.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
Raw count and latency data for symlink-create operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
create
Raw count and latency data for create operations.
dir
dir
file
file
other
other
symlink
symlink
getattr
Raw count and latency data for getattr operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
Raw count and latency data for link operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
lock
Raw count and latency data for lock operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
lookup
Raw count and latency data for lookup operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
open
Raw count and latency data for open operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
read
Raw count and latency data for read operations, including histograms categorizing operations by size and latency.
count
integer
total_time
integer
  • example: 200
  • readOnly: 1
  • x-ntap-advanced: true
  • x-nullable: true
volume_protocol_latency_histogram_counts
array[integer]
volume_protocol_latency_histogram_labels
array[string]
Labels for the latency histogram, ranging from <2us to >20s.
volume_protocol_size_histogram_counts
array[integer]
volume_protocol_size_histogram_labels
array[string]
Labels for the size histogram, ranging from <4KB to >1024KB.
readdir
Raw count and latency data for readdir operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
Raw count and latency data for readlink operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
rename
Raw count and latency data for rename operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
setattr
Raw count and latency data for setattr operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
Raw count and latency data for unlink operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
watch
Raw count and latency data for watch operations. These statistics are only applicable for CIFS protocol operations.
count
integer
total_time
integer
  • example: 200
  • x-nullable: true
write
Raw count and latency data for write operations, including histograms categorizing operations by size and latency.
count
integer
total_time
integer
  • example: 200
  • readOnly: 1
  • x-nullable: true
array[integer]
array[string]
array[integer]
array[string]
cifs_ops_raw
Raw data component performance values for CIFS operations on this volume, including number of operations and raw latency, in microseconds for each operation. The values are cumulative and increase while the volume is online.
access
access
audit
audit
create
create
getattr
getattr
link
link
lock
lock
lookup
lookup
open
open
read
read
readdir
readdir
readlink
readlink
rename
rename
setattr
setattr
unlink
unlink
watch
watch
write
write
iops_raw
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
cloud
These are raw performance numbers (IOPS and latency) for the cloud store. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster. These numbers are relevant only for volumes hosted on FabricPools.
iops_raw
iops_raw
latency_raw
latency_raw
status
string
timestamp
string
flexcache_raw
Performance numbers for FlexCache used to measure cache effectiveness.
cache_miss_blocks
integer
Blocks retrieved from origin in case of a cache miss. This can be divided by the raw client_requested_blocks and multiplied by 100 to calculate the cache miss percentage.
integer
Total blocks requested by the client.
status
string
timestamp
string
nfs_ops_raw
Raw data component performance values for NFS operations on this volume, including number of operations and raw latency, in microseconds for each operation. The values are cumulative and increase while the volume is online.
access
access
audit
audit
create
create
getattr
getattr
link
link
lock
lock
lookup
lookup
open
open
read
read
readdir
readdir
readlink
readlink
rename
rename
setattr
setattr
unlink
unlink
watch
watch
write
write
throughput_raw
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
other
integer
read
integer
total
integer
write
integer
statistics
These are raw performance numbers, such as IOPS latency and throughput. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
cifs_ops_raw
cifs_ops_raw
cloud
cloud
flexcache_raw
flexcache_raw
iops_raw
iops_raw
latency_raw
latency_raw
nfs_ops_raw
nfs_ops_raw
status
string
throughput_raw
throughput_raw
timestamp
string
svm
SVM containing the volume. Required on POST.
_links
_links
name
string
uuid
string
tiering
min_cooling_days
integer
This parameter specifies the minimum number of days that user data blocks of the volume must be cooled before they can be considered cold and tiered out to the cloud tier. Note that this parameter is only used for tiering purposes and does not affect the reporting of inactive data. The value specified should be greater than the frequency with which applications in the volume shift between different sets of data. This parameter cannot be set when volume tiering policy is either "none" or "all". The default value of this parameter depends on the volume's tiering policy. See the tiering policy section of this documentation for corresponding default values. If the tiering policy on the volume gets changed, then this parameter will be reset to the default value corresponding to the new tiering policy.
object_tags
array[string]
This parameter specifies tags of a volume for objects stored on a FabricPool-enabled aggregate. Each tag is a key,value pair and should be in the format "key=value".
policy
string
Policy that determines whether the user data blocks of a volume in a FabricPool will be tiered to the cloud store when they become cold. FabricPool combines flash (performance tier) with a cloud store into a single aggregate. Temperature of a volume block increases if it is accessed frequently and decreases when it is not. Valid in POST or PATCH. all ‐ This policy allows tiering of both snapshots and active file system user data to the cloud store as soon as possible by ignoring the temperature on the volume blocks. auto ‐ This policy allows tiering of both snapshot and active file system user data to the cloud store none ‐ Volume blocks will not be tiered to the cloud store. snapshot_only ‐ This policy allows tiering of only the volume snapshots not associated with the active file system. The default tiering policy is "snapshot-only" for a FlexVol volume and "none" for a FlexGroup volume. The default minimum cooling period for the "snapshot-only" tiering policy is 2 days and for the "auto" tiering policy is 31 days.
volume
_links
_links
_tags
array[string]
Tags are an optional way to track the uses of a resource. Tag values must be formatted as key:value strings.
access_time_enabled
boolean
Indicates whether or not access time updates are enabled on the volume.
activity_tracking
activity_tracking
aggregates
array[aggregates]
Aggregate hosting the volume. Required on POST.
aggressive_readahead_mode
string
Specifies the aggressive_readahead_mode enabled on the volume. When set to file_prefetch, on a file read, the system aggressively issues readaheads for all of the blocks in the file and retains those blocks in a cache for a finite period of time. When the option is set to sequential_read, the system aggressively prefetches the file completely, or to a certain length based on the file size limit, and continues as the read makes progress. If the option is set to cross_file_sequential_read, then the system aggressively prefetches multiple files completely, or to a certain length, and continues as the read makes progress.
analytics
analytics
anti_ransomware
anti_ransomware
Anti-ransomware related information of the volume.
application
application
asynchronous_directory_delete
Configuration for asynchronous directory delete from the client. This is only supported on Flexible volumes and FlexGroup volumes.
autosize
autosize
clone
clone
cloud_retrieval_policy
string
This parameter specifies the cloud retrieval policy for the volume. This policy determines which tiered out blocks to retrieve from the capacity tier to the performance tier. The available cloud retrieval policies are "default" policy retrieves tiered data based on the underlying tiering policy. If the tiering policy is 'auto', tiered data is retrieved only for random client driven data reads. If the tiering policy is 'none' or 'snapshot_only', tiered data is retrieved for random and sequential client driven data reads. If the tiering policy is 'all', tiered data is not retrieved. "on_read" policy retrieves tiered data for all client driven data reads. "never" policy never retrieves tiered data. "promote" policy retrieves all eligible tiered data automatically during the next scheduled scan. It is only supported when the tiering policy is 'none' or 'snapshot_only'. If the tiering policy is 'snapshot_only', the only data brought back is the data in the AFS. Data that is only in a snapshot copy stays in the cloud and if tiering policy is 'none' then all data is retrieved.
cloud_write_enabled
boolean
Indicates whether or not cloud writes are enabled on the volume. NFS writes to this volume are sent to the cloud directly instead of the local performance tier. This feature is only available on volumes in FabricPools.
comment
string
A comment for the volume. Valid in POST or PATCH.
consistency_group
consistency_group
constituents
array[constituents]
FlexGroup volume constituents. FlexGroup volume constituents can be retrieved more efficiently by specifying "is_constituent=true" or "is_constituent=true&flexgroup.uuid=" as query parameters.
convert_unicode
boolean
Specifies whether directory Unicode format conversion is enabled when directories are accessed by NFS clients.
create_time
string
Creation time of the volume. This field is generated when the volume is created.
efficiency
efficiency
encryption
encryption
error_state
error_state
files
files
flash_pool
flash_pool
flexcache_endpoint_type
string
FlexCache endpoint type. none ‐ The volume is neither a FlexCache nor origin of any FlexCache. cache ‐ The volume is a FlexCache volume. origin ‐ The volume is origin of a FlexCache volume.
flexgroup
flexgroup
granular_data
boolean
State of granular data on the volume. This setting is true by default when creating an AWS S3 FlexGroup volume via a POST request and false by default for creating any other type of FlexGroup volume via a POST request. On FlexVol volumes, the setting is always false, as only FlexGroup volumes support this feature. Once enabled, this setting can only be disabled by restoring a snapshot. Earlier versions of ONTAP (pre 9.12) are not compatible with this feature. Therefore, reverting to an earlier version of ONTAP is not possible unless this volume is deleted or restored to a snapshot that was taken before the setting was enabled.
  • Introduced in: 9.12
  • x-nullable: true
granular_data_mode
string
Mode of granular data on the volume. This setting defaults to basic when the granular_data parameter is set to true, but can be specified at the time of creation via a POST request. Earlier versions of ONTAP (pre 9.12) are not compatible with the basic setting. Therefore, when set to basic, reverting to an earlier version of ONTAP is not possible unless this volume is deleted or restored to a snapshot that was taken before the basic mode was enabled. Earlier versions of ONTAP (pre 9.16) are not compatible with the advanced setting. Therefore, when set to advanced, reverting to an earlier version of ONTAP is not possible unless this volume is deleted or restored to a snapshot that was taken before the advanced mode was enabled.
  • enum: ["disabled", "basic", "advanced"]
  • Introduced in: 9.16
  • x-nullable: true
guarantee
guarantee
is_object_store
boolean
Specifies whether the volume is provisioned for an object store server.
is_svm_root
boolean
Specifies whether the volume is a root volume of the SVM it belongs to.
language
string
Language encoding setting for volume. If no language is specified, the volume inherits its SVM language encoding setting.
max_dir_size
integer
Maximum directory size. This value sets maximum size, in bytes, to which a directory can grow. The default maximum directory size for FlexVol volumes is model-dependent, and optimized for the size of system memory. Before increasing the maximum directory size, involve technical support.
metric
metric
movement
movement
msid
integer
The volume's Master Set ID.
name
string
Volume name. The name of volume must start with an alphabetic character (a to z or A to Z) or an underscore (_). The name must be 197 or fewer characters in length for FlexGroup volumes, and 203 or fewer characters in length for all other types of volumes. Volume names must be unique within an SVM. Required on POST.
nas
nas
qos
qos
QoS information
queue_for_encryption
boolean
Specifies whether the volume is queued for encryption.
quota
quota
rebalancing
rebalancing
scheduled_snapshot_naming_scheme
string
Naming Scheme for automatic snapshots:
  • create_time - Automatic snapshots are saved as per the start of their current date and time.
  • ordinal - Latest automatic snapshot copy is saved as .0 and subsequent copies will follow the create_time naming convention.
size
integer
Physical size of the volume, in bytes. The minimum size for a FlexVol volume is 20MB and the minimum size for a FlexGroup volume is 200MB per constituent. The recommended size for a FlexGroup volume is a minimum of 100GB per constituent. For all volumes, the default size is equal to the minimum size.
snaplock
snaplock
snapmirror
snapmirror
snapshot_count
integer
Number of snapshots in the volume.
snapshot_directory_access_enabled
boolean
This field, if true, enables the visible ".snapshot" directory from the client. The ".snapshot" directory will be available in every directory on the volume.
snapshot_locking_enabled
boolean
Specifies whether or not snapshot copy locking is enabled on the volume.
snapshot_policy
snapshot_policy
space
space
state
string
Volume state. Client access is supported only when volume is online and junctioned. Taking volume to offline or restricted state removes its junction path and blocks client access. When volume is in restricted state some operations like parity reconstruction and iron on commit are allowed. The 'mixed' state applies to FlexGroup volumes only and cannot be specified as a target state. An 'error' state implies that the volume is not in a state to serve data.
statistics
statistics
status
array[string]
Describes the current status of a volume.
style
string
The style of the volume. If "style" is not specified, the volume type is determined based on the specified aggregates or license. Specifying a single aggregate, without "constituents_per_aggregate", creates a flexible volume. Specifying multiple aggregates, or a single aggregate with "constituents_per_aggregate", creates a FlexGroup volume. When the UDO License is installed, and no aggregates are specified, the system automatically provisions a FlexGroup volume on system selected aggregates. Specifying a volume "style" creates a volume of that type. For example, if the style is "flexvol", you must specify a single aggregate. If the style is "flexgroup", the system either uses the specified aggregates or automatically provisions aggregates if there are no specified aggregates. The style "flexgroup_constituent" is not supported when creating a volume. flexvol ‐ flexible volumes and FlexClone volumes flexgroup ‐ FlexGroup volumes flexgroup_constituent ‐ FlexGroup volume constituents.
svm
svm
tiering
tiering
type
string
Type of the volume. rw ‐ read-write volume. dp ‐ data-protection volume. ls ‐ load-sharing dp volume. Valid in GET.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • readOnly: 1
  • Introduced in: 9.6
  • x-nullable: true
validate_only
boolean
Validate the volume move or volume conversion operations and their parameters, without actually performing the operation.
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
