Retrieve volumes
Retrieves information about volumes, helping you understand their current configurations and status.
HTTP method and endpoint
GET /storage/volumes
Introduced in
ONTAP 9.6
Usage notes
Retrieves volumes.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
is_svm_root -
aggressive_readahead_mode -
analytics.by_accessed_time.bytes_used -
analytics.by_modified_time.bytes_used -
analytics.bytes_used -
analytics.file_count -
analytics.histogram_by_time_labels -
analytics.incomplete_data -
analytics.report_time -
analytics.subdir_count -
analytics.supported -
analytics.unsupported_reason -
anti_ransomware.* -
application.* -
encryption.* -
queue_for_encryption -
convert_unicode -
clone.parent_snapshot.name -
clone.parent_snapshot.uuid -
clone.parent_svm.name -
clone.parent_svm.uuid -
clone.parent_volume.name -
clone.parent_volume.uuid -
clone.split_complete_percent -
clone.split_estimate -
clone.split_initiated -
efficiency.* -
error_state.* -
files.* -
max_dir_size -
nas.export_policy.id -
nas.gid -
nas.path -
nas.security_style -
nas.uid -
nas.unix_permissions -
nas.junction_parent.name -
nas.junction_parent.uuid -
snaplock.* -
restore_to.* -
quota.* -
qos.* -
flexcache_endpoint_type -
space.block_storage_inactive_user_data -
space.capacity_tier_footprint -
space.performance_tier_footprint -
space.local_tier_footprint -
space.footprint -
space.over_provisioned -
space.metadata -
space.total_footprint -
space.dedupe_metafiles_footprint -
space.dedupe_metafiles_temporary_footprint -
space.delayed_free_footprint -
space.file_operation_metadata -
space.snapmirror_destination_footprint -
space.volume_guarantee_footprint -
space.cross_volume_dedupe_metafiles_footprint -
space.cross_volume_dedupe_metafiles_temporary_footprint -
space.snapshot_reserve_unusable -
space.snapshot_spill -
space.user_data -
space.logical_space.* -
space.snapshot.* -
space.used_by_afs -
space.afs_total -
space.available_percent -
space.full_threshold_percent -
space.nearly_full_threshold_percent -
space.overwrite_reserve -
space.overwrite_reserve_used -
space.size_available_for_snapshots -
space.percent_used -
space.fractional_reserve -
space.block_storage_inactive_user_data_percent -
space.physical_used -
space.physical_used_percent -
space.expected_available -
space.filesystem_size -
space.filesystem_size_fixed -
guarantee.* -
autosize.* -
movement.* -
statistics.* -
constituents.name -
constituents.node.name -
constituents.node.uuid -
constituents.space.size -
constituents.space.available -
constituents.space.used -
constituents.space.available_percent -
constituents.space.used_percent -
constituents.space.block_storage_inactive_user_data -
constituents.space.capacity_tier_footprint -
constituents.space.performance_tier_footprint -
constituents.space.local_tier_footprint -
constituents.space.footprint -
constituents.space.over_provisioned -
constituents.space.metadata -
constituents.space.total_footprint -
constituents.space.logical_space.reporting -
constituents.space.logical_space.enforcement -
constituents.space.logical_space.used_by_afs -
constituents.space.logical_space.available -
constituents.space.snapshot.used -
constituents.space.snapshot.reserve_percent -
constituents.space.snapshot.autodelete_enabled -
constituents.space.large_size_enabled -
constituents.space.max_size -
constituents.space.total_metadata -
constituents.space.total_metadata_footprint -
constituents.aggregates.name -
constituents.aggregates.uuid -
constituents.movement.destination_aggregate.name -
constituents.movement.destination_aggregate.uuid -
constituents.movement.state -
constituents.movement.percent_complete -
constituents.movement.cutover_window -
constituents.movement.tiering_policy -
asynchronous_directory_delete.* -
rebalancing.* -
metric.* -
cloud_write_enabled
Related ONTAP commands
volume show -
volume clone show -
volume efficiency show -
volume encryption show -
volume flexcache show -
volume flexgroup show -
volume move show -
volume quota show -
volume show-space -
volume snaplock show -
volume rebalance show -
security anti-ransomware volume show -
security anti-ransomware volume space show -
volume file async-delete client show
is_constituent |
boolean |
query |
False |
When set to false, only FlexVol and FlexGroup volumes are returned. When set to true, only FlexGroup constituent volumes are returned. Default for GET calls is false.
_tags |
string |
query |
False |
Filter by _tags
nas.gid |
integer |
query |
False |
Filter by nas.gid |
nas.export_policy.name |
string |
query |
False |
Filter by nas.export_policy.name |
nas.export_policy.id |
integer |
query |
False |
Filter by nas.export_policy.id |
nas.unix_permissions |
integer |
query |
False |
Filter by nas.unix_permissions |
nas.junction_parent.name |
string |
query |
False |
Filter by nas.junction_parent.name
nas.junction_parent.uuid |
string |
query |
False |
Filter by nas.junction_parent.uuid
nas.path |
string |
query |
False |
Filter by nas.path |
nas.security_style |
string |
query |
False |
Filter by nas.security_style |
nas.uid |
integer |
query |
False |
Filter by nas.uid |
statistics.iops_raw.read |
integer |
query |
False |
Filter by statistics.iops_raw.read |
statistics.iops_raw.other |
integer |
query |
False |
Filter by statistics.iops_raw.other |
statistics.iops_raw.total |
integer |
query |
False |
Filter by statistics.iops_raw.total |
statistics.iops_raw.write |
integer |
query |
False |
Filter by statistics.iops_raw.write |
statistics.flexcache_raw.client_requested_blocks |
integer |
query |
False |
Filter by statistics.flexcache_raw.client_requested_blocks
statistics.flexcache_raw.cache_miss_blocks |
integer |
query |
False |
Filter by statistics.flexcache_raw.cache_miss_blocks
statistics.flexcache_raw.timestamp |
string |
query |
False |
Filter by statistics.flexcache_raw.timestamp
statistics.flexcache_raw.status |
string |
query |
False |
Filter by statistics.flexcache_raw.status
statistics.timestamp |
string |
query |
False |
Filter by statistics.timestamp |
statistics.nfs_ops_raw.write.count |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.write.count
statistics.nfs_ops_raw.write.volume_protocol_latency_histogram_counts |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.write.volume_protocol_latency_histogram_counts
statistics.nfs_ops_raw.write.volume_protocol_size_histogram_labels |
string |
query |
False |
Filter by statistics.nfs_ops_raw.write.volume_protocol_size_histogram_labels
statistics.nfs_ops_raw.write.volume_protocol_latency_histogram_labels |
string |
query |
False |
Filter by statistics.nfs_ops_raw.write.volume_protocol_latency_histogram_labels
statistics.nfs_ops_raw.write.total_time |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.write.total_time
statistics.nfs_ops_raw.write.volume_protocol_size_histogram_counts |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.write.volume_protocol_size_histogram_counts
statistics.nfs_ops_raw.getattr.total_time |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.getattr.total_time
statistics.nfs_ops_raw.getattr.count |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.getattr.count
statistics.nfs_ops_raw.create.symlink.total_time |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.create.symlink.total_time
statistics.nfs_ops_raw.create.symlink.count |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.create.symlink.count
statistics.nfs_ops_raw.create.dir.total_time |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.create.dir.total_time
statistics.nfs_ops_raw.create.dir.count |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.create.dir.count
statistics.nfs_ops_raw.create.file.total_time |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.create.file.total_time
statistics.nfs_ops_raw.create.file.count |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.create.file.count
statistics.nfs_ops_raw.create.other.total_time |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.create.other.total_time
statistics.nfs_ops_raw.create.other.count |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.create.other.count
statistics.nfs_ops_raw.unlink.total_time |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.unlink.total_time
statistics.nfs_ops_raw.unlink.count |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.unlink.count
statistics.nfs_ops_raw.access.total_time |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.access.total_time
statistics.nfs_ops_raw.access.count |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.access.count
statistics.nfs_ops_raw.rename.total_time |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.rename.total_time
statistics.nfs_ops_raw.rename.count |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.rename.count
statistics.nfs_ops_raw.audit.total_time |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.audit.total_time
statistics.nfs_ops_raw.audit.count |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.audit.count
statistics.nfs_ops_raw.open.total_time |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.open.total_time
statistics.nfs_ops_raw.open.count |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.open.count
statistics.nfs_ops_raw.watch.total_time |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.watch.total_time
statistics.nfs_ops_raw.watch.count |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.watch.count
statistics.nfs_ops_raw.readlink.total_time |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.readlink.total_time
statistics.nfs_ops_raw.readlink.count |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.readlink.count
statistics.nfs_ops_raw.lookup.total_time |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.lookup.total_time
statistics.nfs_ops_raw.lookup.count |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.lookup.count
statistics.nfs_ops_raw.read.count |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.read.count
statistics.nfs_ops_raw.read.volume_protocol_latency_histogram_counts |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.read.volume_protocol_latency_histogram_counts
statistics.nfs_ops_raw.read.volume_protocol_size_histogram_labels |
string |
query |
False |
Filter by statistics.nfs_ops_raw.read.volume_protocol_size_histogram_labels
statistics.nfs_ops_raw.read.volume_protocol_latency_histogram_labels |
string |
query |
False |
Filter by statistics.nfs_ops_raw.read.volume_protocol_latency_histogram_labels
statistics.nfs_ops_raw.read.total_time |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.read.total_time
statistics.nfs_ops_raw.read.volume_protocol_size_histogram_counts |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.read.volume_protocol_size_histogram_counts
statistics.nfs_ops_raw.readdir.total_time |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.readdir.total_time
statistics.nfs_ops_raw.readdir.count |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.readdir.count
statistics.nfs_ops_raw.lock.total_time |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.lock.total_time
statistics.nfs_ops_raw.lock.count |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.lock.count
statistics.nfs_ops_raw.setattr.total_time |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.setattr.total_time
statistics.nfs_ops_raw.setattr.count |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.setattr.count
statistics.nfs_ops_raw.link.total_time |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.link.total_time
statistics.nfs_ops_raw.link.count |
integer |
query |
False |
Filter by statistics.nfs_ops_raw.link.count
statistics.throughput_raw.read |
integer |
query |
False |
Filter by statistics.throughput_raw.read |
statistics.throughput_raw.other |
integer |
query |
False |
Filter by statistics.throughput_raw.other |
statistics.throughput_raw.total |
integer |
query |
False |
Filter by statistics.throughput_raw.total |
statistics.throughput_raw.write |
integer |
query |
False |
Filter by statistics.throughput_raw.write |
statistics.cloud.latency_raw.read |
integer |
query |
False |
Filter by statistics.cloud.latency_raw.read
statistics.cloud.latency_raw.other |
integer |
query |
False |
Filter by statistics.cloud.latency_raw.other
statistics.cloud.latency_raw.total |
integer |
query |
False |
Filter by statistics.cloud.latency_raw.total
statistics.cloud.latency_raw.write |
integer |
query |
False |
Filter by statistics.cloud.latency_raw.write
statistics.cloud.iops_raw.read |
integer |
query |
False |
Filter by statistics.cloud.iops_raw.read
statistics.cloud.iops_raw.other |
integer |
query |
False |
Filter by statistics.cloud.iops_raw.other
statistics.cloud.iops_raw.total |
integer |
query |
False |
Filter by statistics.cloud.iops_raw.total
statistics.cloud.iops_raw.write |
integer |
query |
False |
Filter by statistics.cloud.iops_raw.write
statistics.cloud.status |
string |
query |
False |
Filter by statistics.cloud.status
statistics.cloud.timestamp |
string |
query |
False |
Filter by statistics.cloud.timestamp
statistics.cifs_ops_raw.write.count |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.write.count
statistics.cifs_ops_raw.write.volume_protocol_latency_histogram_counts |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.write.volume_protocol_latency_histogram_counts
statistics.cifs_ops_raw.write.volume_protocol_size_histogram_labels |
string |
query |
False |
Filter by statistics.cifs_ops_raw.write.volume_protocol_size_histogram_labels
statistics.cifs_ops_raw.write.volume_protocol_latency_histogram_labels |
string |
query |
False |
Filter by statistics.cifs_ops_raw.write.volume_protocol_latency_histogram_labels
statistics.cifs_ops_raw.write.total_time |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.write.total_time
statistics.cifs_ops_raw.write.volume_protocol_size_histogram_counts |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.write.volume_protocol_size_histogram_counts
statistics.cifs_ops_raw.getattr.total_time |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.getattr.total_time
statistics.cifs_ops_raw.getattr.count |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.getattr.count
statistics.cifs_ops_raw.create.symlink.total_time |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.create.symlink.total_time
statistics.cifs_ops_raw.create.symlink.count |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.create.symlink.count
statistics.cifs_ops_raw.create.dir.total_time |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.create.dir.total_time
statistics.cifs_ops_raw.create.dir.count |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.create.dir.count
statistics.cifs_ops_raw.create.file.total_time |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.create.file.total_time
statistics.cifs_ops_raw.create.file.count |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.create.file.count
statistics.cifs_ops_raw.create.other.total_time |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.create.other.total_time
statistics.cifs_ops_raw.create.other.count |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.create.other.count
statistics.cifs_ops_raw.unlink.total_time |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.unlink.total_time
statistics.cifs_ops_raw.unlink.count |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.unlink.count
statistics.cifs_ops_raw.access.total_time |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.access.total_time
statistics.cifs_ops_raw.access.count |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.access.count
statistics.cifs_ops_raw.rename.total_time |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.rename.total_time
statistics.cifs_ops_raw.rename.count |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.rename.count
statistics.cifs_ops_raw.audit.total_time |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.audit.total_time
statistics.cifs_ops_raw.audit.count |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.audit.count
statistics.cifs_ops_raw.open.total_time |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.open.total_time
statistics.cifs_ops_raw.open.count |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.open.count
statistics.cifs_ops_raw.watch.total_time |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.watch.total_time
statistics.cifs_ops_raw.watch.count |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.watch.count
statistics.cifs_ops_raw.readlink.total_time |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.readlink.total_time
statistics.cifs_ops_raw.readlink.count |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.readlink.count
statistics.cifs_ops_raw.lookup.total_time |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.lookup.total_time
statistics.cifs_ops_raw.lookup.count |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.lookup.count
statistics.cifs_ops_raw.read.count |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.read.count
statistics.cifs_ops_raw.read.volume_protocol_latency_histogram_counts |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.read.volume_protocol_latency_histogram_counts
statistics.cifs_ops_raw.read.volume_protocol_size_histogram_labels |
string |
query |
False |
Filter by statistics.cifs_ops_raw.read.volume_protocol_size_histogram_labels
statistics.cifs_ops_raw.read.volume_protocol_latency_histogram_labels |
string |
query |
False |
Filter by statistics.cifs_ops_raw.read.volume_protocol_latency_histogram_labels
statistics.cifs_ops_raw.read.total_time |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.read.total_time
statistics.cifs_ops_raw.read.volume_protocol_size_histogram_counts |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.read.volume_protocol_size_histogram_counts
statistics.cifs_ops_raw.readdir.total_time |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.readdir.total_time
statistics.cifs_ops_raw.readdir.count |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.readdir.count
statistics.cifs_ops_raw.lock.total_time |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.lock.total_time
statistics.cifs_ops_raw.lock.count |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.lock.count
statistics.cifs_ops_raw.setattr.total_time |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.setattr.total_time
statistics.cifs_ops_raw.setattr.count |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.setattr.count
statistics.cifs_ops_raw.link.total_time |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.link.total_time
statistics.cifs_ops_raw.link.count |
integer |
query |
False |
Filter by statistics.cifs_ops_raw.link.count
statistics.latency_raw.read |
integer |
query |
False |
Filter by statistics.latency_raw.read |
statistics.latency_raw.other |
integer |
query |
False |
Filter by statistics.latency_raw.other |
statistics.latency_raw.total |
integer |
query |
False |
Filter by statistics.latency_raw.total |
statistics.latency_raw.write |
integer |
query |
False |
Filter by statistics.latency_raw.write |
statistics.status |
string |
query |
False |
Filter by statistics.status |
granular_data_mode |
string |
query |
False |
Filter by granular_data_mode
convert_unicode |
boolean |
query |
False |
Filter by convert_unicode
is_s3_arbitrary_part_size_enabled |
boolean |
query |
False |
Filter by is_s3_arbitrary_part_size_enabled
comment |
string |
query |
False |
Filter by comment
cloud_retrieval_policy |
string |
query |
False |
Filter by cloud_retrieval_policy
snapshot_policy.name |
string |
query |
False |
Filter by snapshot_policy.name |
snapshot_policy.uuid |
string |
query |
False |
Filter by snapshot_policy.uuid |
name |
string |
query |
False |
Filter by name
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
max_dir_size |
integer |
query |
False |
Filter by max_dir_size
quota.state |
string |
query |
False |
Filter by quota.state |
is_svm_root |
boolean |
query |
False |
Filter by is_svm_root
uuid |
string |
query |
False |
Filter by uuid |
create_time |
string |
query |
False |
Filter by create_time |
flash_pool.caching_policy |
string |
query |
False |
Filter by flash_pool.caching_policy
flash_pool.cache_retention_priority |
string |
query |
False |
Filter by flash_pool.cache_retention_priority
flash_pool.cache_eligibility |
string |
query |
False |
Filter by flash_pool.cache_eligibility
snaplock.autocommit_period |
string |
query |
False |
Filter by snaplock.autocommit_period |
snaplock.type |
string |
query |
False |
Filter by snaplock.type |
snaplock.compliance_clock_time |
string |
query |
False |
Filter by snaplock.compliance_clock_time |
snaplock.expiry_time |
string |
query |
False |
Filter by snaplock.expiry_time |
snaplock.litigation_count |
integer |
query |
False |
Filter by snaplock.litigation_count |
snaplock.unspecified_retention_file_count |
integer |
query |
False |
Filter by snaplock.unspecified_retention_file_count
snaplock.privileged_delete |
string |
query |
False |
Filter by snaplock.privileged_delete |
snaplock.is_audit_log |
boolean |
query |
False |
Filter by snaplock.is_audit_log |
snaplock.retention.minimum |
string |
query |
False |
Filter by snaplock.retention.minimum |
snaplock.retention.maximum |
string |
query |
False |
Filter by snaplock.retention.maximum |
snaplock.retention.default |
string |
query |
False |
Filter by snaplock.retention.default |
snaplock.append_mode_enabled |
boolean |
query |
False |
Filter by snaplock.append_mode_enabled |
guarantee.honored |
boolean |
query |
False |
Filter by guarantee.honored |
guarantee.type |
string |
query |
False |
Filter by guarantee.type |
clone.parent_snapshot.uuid |
string |
query |
False |
Filter by clone.parent_snapshot.uuid |
clone.parent_snapshot.name |
string |
query |
False |
Filter by clone.parent_snapshot.name |
clone.parent_svm.uuid |
string |
query |
False |
Filter by clone.parent_svm.uuid |
clone.parent_svm.name |
string |
query |
False |
Filter by clone.parent_svm.name |
clone.split_estimate |
integer |
query |
False |
Filter by clone.split_estimate |
clone.split_complete_percent |
integer |
query |
False |
Filter by clone.split_complete_percent |
clone.is_flexclone |
boolean |
query |
False |
Filter by clone.is_flexclone |
clone.parent_volume.name |
string |
query |
False |
Filter by clone.parent_volume.name |
clone.parent_volume.uuid |
string |
query |
False |
Filter by clone.parent_volume.uuid |
clone.qtree_name |
string |
query |
False |
Filter by clone.qtree_name
clone.split_initiated |
boolean |
query |
False |
Filter by clone.split_initiated |
clone.inherited_savings |
integer |
query |
False |
Filter by clone.inherited_savings
clone.inherited_physical_used |
integer |
query |
False |
Filter by clone.inherited_physical_used
clone.lun_name |
string |
query |
False |
Filter by clone.lun_name
clone.has_flexclone |
boolean |
query |
False |
Filter by clone.has_flexclone
error_state.has_bad_blocks |
boolean |
query |
False |
Filter by error_state.has_bad_blocks |
error_state.is_inconsistent |
boolean |
query |
False |
Filter by error_state.is_inconsistent |
msid |
integer |
query |
False |
Filter by msid
activity_tracking.notices.code |
string |
query |
False |
Filter by activity_tracking.notices.code
activity_tracking.notices.message |
string |
query |
False |
Filter by activity_tracking.notices.message
activity_tracking.unsupported_reason.message |
string |
query |
False |
Filter by activity_tracking.unsupported_reason.message
activity_tracking.unsupported_reason.code |
string |
query |
False |
Filter by activity_tracking.unsupported_reason.code
activity_tracking.state |
string |
query |
False |
Filter by activity_tracking.state
activity_tracking.supported |
boolean |
query |
False |
Filter by activity_tracking.supported
is_object_store |
boolean |
query |
False |
Filter by is_object_store
access_time_enabled |
boolean |
query |
False |
Filter by access_time_enabled
svm_dr_protection |
string |
query |
False |
Filter by svm_dr_protection
qos.policy.uuid |
string |
query |
False |
Filter by qos.policy.uuid |
qos.policy.min_throughput_mbps |
integer |
query |
False |
Filter by qos.policy.min_throughput_mbps
qos.policy.max_throughput_mbps |
integer |
query |
False |
Filter by qos.policy.max_throughput_mbps
qos.policy.min_throughput_iops |
integer |
query |
False |
Filter by qos.policy.min_throughput_iops
qos.policy.min_throughput |
string |
query |
False |
qos.policy.name |
string |
query |
False |
Filter by qos.policy.name |
qos.policy.max_throughput_iops |
integer |
query |
False |
Filter by qos.policy.max_throughput_iops
qos.policy.max_throughput |
string |
query |
False |
asynchronous_directory_delete.enabled |
boolean |
query |
False |
Filter by asynchronous_directory_delete.enabled
asynchronous_directory_delete.trash_bin |
string |
query |
False |
Filter by asynchronous_directory_delete.trash_bin
status |
string |
query |
False |
Filter by status
analytics.files_scanned |
integer |
query |
False |
Filter by analytics.files_scanned
analytics.by_accessed_time.bytes_used.newest_label |
string |
query |
False |
Filter by analytics.by_accessed_time.bytes_used.newest_label
analytics.by_accessed_time.bytes_used.labels |
string |
query |
False |
Filter by analytics.by_accessed_time.bytes_used.labels
analytics.by_accessed_time.bytes_used.oldest_label |
string |
query |
False |
Filter by analytics.by_accessed_time.bytes_used.oldest_label
analytics.by_accessed_time.bytes_used.percentages |
number |
query |
False |
Filter by analytics.by_accessed_time.bytes_used.percentages
analytics.by_accessed_time.bytes_used.values |
integer |
query |
False |
Filter by analytics.by_accessed_time.bytes_used.values
analytics.by_accessed_time.bytes_used.aged_data_metric |
number |
query |
False |
Filter by analytics.by_accessed_time.bytes_used.aged_data_metric
analytics.incomplete_data |
boolean |
query |
False |
Filter by analytics.incomplete_data
analytics.supported |
boolean |
query |
False |
Filter by analytics.supported
analytics.scan_throttle_reason.code |
string |
query |
False |
Filter by analytics.scan_throttle_reason.code
analytics.scan_throttle_reason.arguments |
string |
query |
False |
Filter by analytics.scan_throttle_reason.arguments
analytics.scan_throttle_reason.message |
string |
query |
False |
Filter by analytics.scan_throttle_reason.message
analytics.report_time |
string |
query |
False |
Filter by analytics.report_time
analytics.by_modified_time.bytes_used.newest_label |
string |
query |
False |
Filter by analytics.by_modified_time.bytes_used.newest_label
analytics.by_modified_time.bytes_used.labels |
string |
query |
False |
Filter by analytics.by_modified_time.bytes_used.labels
analytics.by_modified_time.bytes_used.oldest_label |
string |
query |
False |
Filter by analytics.by_modified_time.bytes_used.oldest_label
analytics.by_modified_time.bytes_used.percentages |
number |
query |
False |
Filter by analytics.by_modified_time.bytes_used.percentages
analytics.by_modified_time.bytes_used.values |
integer |
query |
False |
Filter by analytics.by_modified_time.bytes_used.values
analytics.by_modified_time.bytes_used.aged_data_metric |
number |
query |
False |
Filter by analytics.by_modified_time.bytes_used.aged_data_metric
analytics.scan_progress |
integer |
query |
False |
Filter by analytics.scan_progress
analytics.total_files |
integer |
query |
False |
Filter by analytics.total_files
analytics.subdir_count |
integer |
query |
False |
Filter by analytics.subdir_count
analytics.bytes_used |
integer |
query |
False |
Filter by analytics.bytes_used
analytics.initialization.state |
string |
query |
False |
Filter by analytics.initialization.state
analytics.file_count |
integer |
query |
False |
Filter by analytics.file_count
analytics.unsupported_reason.code |
string |
query |
False |
Filter by analytics.unsupported_reason.code
analytics.unsupported_reason.message |
string |
query |
False |
Filter by analytics.unsupported_reason.message
analytics.state |
string |
query |
False |
Filter by analytics.state
efficiency.storage_efficiency_mode |
string |
query |
False |
Filter by efficiency.storage_efficiency_mode
efficiency.last_op_begin |
string |
query |
False |
Filter by efficiency.last_op_begin
efficiency.idcs_scanner.threshold_inactive_time |
string |
query |
False |
Filter by efficiency.idcs_scanner.threshold_inactive_time
efficiency.idcs_scanner.operation_state |
string |
query |
False |
Filter by efficiency.idcs_scanner.operation_state
efficiency.idcs_scanner.mode |
string |
query |
False |
Filter by efficiency.idcs_scanner.mode
efficiency.idcs_scanner.enabled |
boolean |
query |
False |
Filter by efficiency.idcs_scanner.enabled
efficiency.idcs_scanner.status |
string |
query |
False |
Filter by efficiency.idcs_scanner.status
efficiency.progress |
string |
query |
False |
Filter by efficiency.progress
efficiency.dedupe |
string |
query |
False |
Filter by efficiency.dedupe |
efficiency.auto_state |
string |
query |
False |
Filter by efficiency.auto_state
efficiency.application_io_size |
string |
query |
False |
Filter by efficiency.application_io_size
efficiency.schedule |
string |
query |
False |
Filter by efficiency.schedule
efficiency.last_op_end |
string |
query |
False |
Filter by efficiency.last_op_end
efficiency.volume_path |
string |
query |
False |
Filter by efficiency.volume_path
efficiency.cross_volume_dedupe |
string |
query |
False |
Filter by efficiency.cross_volume_dedupe |
efficiency.space_savings.total |
integer |
query |
False |
Filter by efficiency.space_savings.total
efficiency.space_savings.compression_percent |
integer |
query |
False |
Filter by efficiency.space_savings.compression_percent
efficiency.space_savings.dedupe_sharing |
integer |
query |
False |
Filter by efficiency.space_savings.dedupe_sharing
efficiency.space_savings.dedupe_percent |
integer |
query |
False |
Filter by efficiency.space_savings.dedupe_percent
efficiency.space_savings.total_percent |
integer |
query |
False |
Filter by efficiency.space_savings.total_percent
efficiency.space_savings.compression |
integer |
query |
False |
efficiency.space_savings.dedupe |
integer |
query |
False |
efficiency.last_op_size |
integer |
query |
False |
Filter by efficiency.last_op_size
efficiency.policy.name |
string |
query |
False |
Filter by efficiency.policy.name
efficiency.compression_type |
string |
query |
False |
Filter by efficiency.compression_type
efficiency.state |
string |
query |
False |
Filter by efficiency.state
efficiency.type |
string |
query |
False |
Filter by efficiency.type
efficiency.ratio |
number |
query |
False |
Filter by efficiency.ratio
efficiency.logging_enabled |
boolean |
query |
False |
Filter by efficiency.logging_enabled
efficiency.last_op_state |
string |
query |
False |
Filter by efficiency.last_op_state
efficiency.compaction |
string |
query |
False |
Filter by efficiency.compaction |
efficiency.last_op_err |
string |
query |
False |
Filter by efficiency.last_op_err
efficiency.scanner.scan_old_data |
boolean |
query |
False |
Filter by efficiency.scanner.scan_old_data
efficiency.scanner.compression |
boolean |
query |
False |
Filter by efficiency.scanner.compression
efficiency.scanner.state |
string |
query |
False |
Filter by efficiency.scanner.state
efficiency.scanner.dedupe |
boolean |
query |
False |
Filter by efficiency.scanner.dedupe
efficiency.compression |
string |
query |
False |
Filter by efficiency.compression |
efficiency.op_state |
string |
query |
False |
Filter by efficiency.op_state
efficiency.has_savings |
boolean |
query |
False |
Filter by efficiency.has_savings
language |
string |
query |
False |
Filter by language |
consistency_group.uuid |
string |
query |
False |
Filter by consistency_group.uuid
consistency_group.name |
string |
query |
False |
Filter by consistency_group.name
is_dir_index_transfer_enabled |
boolean |
query |
False |
Filter by is_dir_index_transfer_enabled
cloud_write_enabled |
boolean |
query |
False |
Filter by cloud_write_enabled
type |
string |
query |
False |
Filter by type |
aggressive_readahead_mode |
string |
query |
False |
Filter by aggressive_readahead_mode
aggregates.uuid |
string |
query |
False |
Filter by aggregates.uuid |
aggregates.name |
string |
query |
False |
Filter by aggregates.name |
encryption.status.message |
string |
query |
False |
Filter by encryption.status.message |
encryption.status.code |
string |
query |
False |
Filter by encryption.status.code |
encryption.key_create_time |
string |
query |
False |
Filter by encryption.key_create_time
encryption.type |
string |
query |
False |
Filter by encryption.type |
encryption.rekey |
boolean |
query |
False |
Filter by encryption.rekey |
encryption.state |
string |
query |
False |
Filter by encryption.state |
encryption.key_id |
string |
query |
False |
Filter by encryption.key_id |
encryption.enabled |
boolean |
query |
False |
Filter by encryption.enabled |
encryption.action |
string |
query |
False |
Filter by encryption.action
tiering.policy |
string |
query |
False |
Filter by tiering.policy |
tiering.object_tags |
string |
query |
False |
Filter by tiering.object_tags
tiering.min_cooling_days |
integer |
query |
False |
Filter by tiering.min_cooling_days
snapshot_directory_access_enabled |
boolean |
query |
False |
Filter by snapshot_directory_access_enabled
is_large_dir_enabled |
boolean |
query |
False |
Filter by is_large_dir_enabled
autosize.maximum |
integer |
query |
False |
Filter by autosize.maximum |
autosize.minimum |
integer |
query |
False |
Filter by autosize.minimum |
autosize.shrink_threshold |
integer |
query |
False |
Filter by autosize.shrink_threshold |
autosize.mode |
string |
query |
False |
Filter by autosize.mode |
autosize.grow_threshold |
integer |
query |
False |
Filter by autosize.grow_threshold |
movement.capacity_tier_optimized |
boolean |
query |
False |
Filter by movement.capacity_tier_optimized
movement.percent_complete |
integer |
query |
False |
Filter by movement.percent_complete |
movement.cutover_window |
integer |
query |
False |
Filter by movement.cutover_window |
movement.start_time |
string |
query |
False |
Filter by movement.start_time
movement.destination_aggregate.uuid |
string |
query |
False |
Filter by movement.destination_aggregate.uuid |
movement.destination_aggregate.name |
string |
query |
False |
Filter by movement.destination_aggregate.name |
movement.state |
string |
query |
False |
Filter by movement.state |
movement.tiering_policy |
string |
query |
False |
Filter by movement.tiering_policy
has_large_dir |
boolean |
query |
False |
Filter by has_large_dir
constituents.aggregates.name |
string |
query |
False |
Filter by constituents.aggregates.name
constituents.aggregates.uuid |
string |
query |
False |
Filter by constituents.aggregates.uuid
constituents.movement.cutover_window |
integer |
query |
False |
Filter by constituents.movement.cutover_window
constituents.movement.destination_aggregate.uuid |
string |
query |
False |
Filter by constituents.movement.destination_aggregate.uuid
constituents.movement.destination_aggregate.name |
string |
query |
False |
Filter by constituents.movement.destination_aggregate.name
constituents.movement.state |
string |
query |
False |
Filter by constituents.movement.state
constituents.movement.percent_complete |
integer |
query |
False |
Filter by constituents.movement.percent_complete
constituents.name |
string |
query |
False |
Filter by constituents.name
constituents.node.name |
string |
query |
False |
Filter by constituents.node.name
constituents.node.uuid |
string |
query |
False |
Filter by constituents.node.uuid
constituents.space.max_size |
string |
query |
False |
Filter by constituents.space.max_size
constituents.space.local_tier_footprint |
integer |
query |
False |
Filter by constituents.space.local_tier_footprint
constituents.space.available |
integer |
query |
False |
Filter by constituents.space.available
constituents.space.used |
integer |
query |
False |
Filter by constituents.space.used
constituents.space.snapshot.reserve_percent |
integer |
query |
False |
Filter by constituents.space.snapshot.reserve_percent
constituents.space.snapshot.used |
integer |
query |
False |
Filter by constituents.space.snapshot.used
constituents.space.available_percent |
integer |
query |
False |
Filter by constituents.space.available_percent
constituents.space.used_by_afs |
integer |
query |
False |
Filter by constituents.space.used_by_afs
constituents.space.total_metadata |
integer |
query |
False |
Filter by constituents.space.total_metadata
constituents.space.total_metadata_footprint |
integer |
query |
False |
Filter by constituents.space.total_metadata_footprint
constituents.space.logical_space.reporting |
boolean |
query |
False |
Filter by constituents.space.logical_space.reporting
constituents.space.logical_space.enforcement |
boolean |
query |
False |
Filter by constituents.space.logical_space.enforcement
constituents.space.logical_space.available |
integer |
query |
False |
Filter by constituents.space.logical_space.available
constituents.space.logical_space.used_by_afs |
integer |
query |
False |
Filter by constituents.space.logical_space.used_by_afs
constituents.space.performance_tier_footprint |
integer |
query |
False |
Filter by constituents.space.performance_tier_footprint
constituents.space.afs_total |
integer |
query |
False |
Filter by constituents.space.afs_total
constituents.space.metadata |
integer |
query |
False |
Filter by constituents.space.metadata
constituents.space.block_storage_inactive_user_data |
integer |
query |
False |
Filter by constituents.space.block_storage_inactive_user_data
constituents.space.size |
integer |
query |
False |
Filter by constituents.space.size
constituents.space.large_size_enabled |
boolean |
query |
False |
Filter by constituents.space.large_size_enabled
constituents.space.over_provisioned |
integer |
query |
False |
Filter by constituents.space.over_provisioned
constituents.space.total_footprint |
integer |
query |
False |
Filter by constituents.space.total_footprint
constituents.space.used_percent |
integer |
query |
False |
Filter by constituents.space.used_percent
constituents.space.capacity_tier_footprint |
integer |
query |
False |
Filter by constituents.space.capacity_tier_footprint
constituents.space.footprint |
integer |
query |
False |
Filter by constituents.space.footprint
flexcache_endpoint_type |
string |
query |
False |
Filter by flexcache_endpoint_type |
anti_ransomware.attack_reports.time |
string |
query |
False |
Filter by anti_ransomware.attack_reports.time
anti_ransomware.block_device_detection_start_time |
string |
query |
False |
Filter by anti_ransomware.block_device_detection_start_time
anti_ransomware.workload.surge_statistics.time |
string |
query |
False |
Filter by anti_ransomware.workload.surge_statistics.time
anti_ransomware.workload.surge_statistics.file_create_peak_rate_per_minute |
integer |
query |
False |
Filter by anti_ransomware.workload.surge_statistics.file_create_peak_rate_per_minute
anti_ransomware.workload.surge_statistics.high_entropy_data_write_peak_percent |
integer |
query |
False |
Filter by anti_ransomware.workload.surge_statistics.high_entropy_data_write_peak_percent
anti_ransomware.workload.surge_statistics.high_entropy_data_write_peak_rate_kb_per_minute |
integer |
query |
False |
Filter by anti_ransomware.workload.surge_statistics.high_entropy_data_write_peak_rate_kb_per_minute
anti_ransomware.workload.surge_statistics.file_rename_peak_rate_per_minute |
integer |
query |
False |
Filter by anti_ransomware.workload.surge_statistics.file_rename_peak_rate_per_minute
anti_ransomware.workload.surge_statistics.file_delete_peak_rate_per_minute |
integer |
query |
False |
Filter by anti_ransomware.workload.surge_statistics.file_delete_peak_rate_per_minute
anti_ransomware.workload.typical_usage.file_delete_peak_rate_per_minute |
integer |
query |
False |
Filter by anti_ransomware.workload.typical_usage.file_delete_peak_rate_per_minute
anti_ransomware.workload.typical_usage.high_entropy_data_write_peak_rate_kb_per_minute |
integer |
query |
False |
Filter by anti_ransomware.workload.typical_usage.high_entropy_data_write_peak_rate_kb_per_minute
anti_ransomware.workload.typical_usage.file_rename_peak_rate_per_minute |
integer |
query |
False |
Filter by anti_ransomware.workload.typical_usage.file_rename_peak_rate_per_minute
anti_ransomware.workload.typical_usage.file_create_peak_rate_per_minute |
integer |
query |
False |
Filter by anti_ransomware.workload.typical_usage.file_create_peak_rate_per_minute
anti_ransomware.workload.typical_usage.high_entropy_data_write_peak_percent |
integer |
query |
False |
Filter by anti_ransomware.workload.typical_usage.high_entropy_data_write_peak_percent
anti_ransomware.workload.file_extensions_observed |
string |
query |
False |
Filter by anti_ransomware.workload.file_extensions_observed
anti_ransomware.workload.historical_statistics.file_delete_peak_rate_per_minute |
integer |
query |
False |
Filter by anti_ransomware.workload.historical_statistics.file_delete_peak_rate_per_minute
anti_ransomware.workload.historical_statistics.high_entropy_data_write_peak_percent |
integer |
query |
False |
Filter by anti_ransomware.workload.historical_statistics.high_entropy_data_write_peak_percent
anti_ransomware.workload.historical_statistics.file_create_peak_rate_per_minute |
integer |
query |
False |
Filter by anti_ransomware.workload.historical_statistics.file_create_peak_rate_per_minute
anti_ransomware.workload.historical_statistics.high_entropy_data_write_peak_rate_kb_per_minute |
integer |
query |
False |
Filter by anti_ransomware.workload.historical_statistics.high_entropy_data_write_peak_rate_kb_per_minute
anti_ransomware.workload.historical_statistics.file_rename_peak_rate_per_minute |
integer |
query |
False |
Filter by anti_ransomware.workload.historical_statistics.file_rename_peak_rate_per_minute
anti_ransomware.workload.surge_usage.newly_observed_file_extensions.count |
integer |
query |
False |
Filter by anti_ransomware.workload.surge_usage.newly_observed_file_extensions.count
anti_ransomware.workload.surge_usage.newly_observed_file_extensions.name |
string |
query |
False |
Filter by anti_ransomware.workload.surge_usage.newly_observed_file_extensions.name
anti_ransomware.workload.surge_usage.file_delete_peak_rate_per_minute |
integer |
query |
False |
Filter by anti_ransomware.workload.surge_usage.file_delete_peak_rate_per_minute
anti_ransomware.workload.surge_usage.file_create_peak_rate_per_minute |
integer |
query |
False |
Filter by anti_ransomware.workload.surge_usage.file_create_peak_rate_per_minute
anti_ransomware.workload.surge_usage.time |
string |
query |
False |
Filter by anti_ransomware.workload.surge_usage.time
anti_ransomware.workload.surge_usage.high_entropy_data_write_peak_percent |
integer |
query |
False |
Filter by anti_ransomware.workload.surge_usage.high_entropy_data_write_peak_percent
anti_ransomware.workload.surge_usage.high_entropy_data_write_peak_rate_kb_per_minute |
integer |
query |
False |
Filter by anti_ransomware.workload.surge_usage.high_entropy_data_write_peak_rate_kb_per_minute
anti_ransomware.workload.surge_usage.file_rename_peak_rate_per_minute |
integer |
query |
False |
Filter by anti_ransomware.workload.surge_usage.file_rename_peak_rate_per_minute
anti_ransomware.workload.file_extension_types_count |
integer |
query |
False |
Filter by anti_ransomware.workload.file_extension_types_count
anti_ransomware.workload.newly_observed_file_extensions.name |
string |
query |
False |
Filter by anti_ransomware.workload.newly_observed_file_extensions.name
anti_ransomware.workload.newly_observed_file_extensions.count |
integer |
query |
False |
Filter by anti_ransomware.workload.newly_observed_file_extensions.count
anti_ransomware.attack_detection_parameters.block_device_auto_learned_encryption_threshold |
integer |
query |
False |
Filter by anti_ransomware.attack_detection_parameters.block_device_auto_learned_encryption_threshold
anti_ransomware.attack_detection_parameters.never_seen_before_file_extension_duration_in_hours |
integer |
query |
False |
Filter by anti_ransomware.attack_detection_parameters.never_seen_before_file_extension_duration_in_hours
anti_ransomware.attack_detection_parameters.based_on_file_delete_op_rate |
boolean |
query |
False |
Filter by anti_ransomware.attack_detection_parameters.based_on_file_delete_op_rate
anti_ransomware.attack_detection_parameters.file_delete_op_rate_surge_notify_percent |
integer |
query |
False |
Filter by anti_ransomware.attack_detection_parameters.file_delete_op_rate_surge_notify_percent
anti_ransomware.attack_detection_parameters.based_on_never_seen_before_file_extension |
boolean |
query |
False |
Filter by anti_ransomware.attack_detection_parameters.based_on_never_seen_before_file_extension
anti_ransomware.attack_detection_parameters.file_create_op_rate_surge_notify_percent |
integer |
query |
False |
Filter by anti_ransomware.attack_detection_parameters.file_create_op_rate_surge_notify_percent
anti_ransomware.attack_detection_parameters.high_entropy_data_surge_notify_percent |
integer |
query |
False |
Filter by anti_ransomware.attack_detection_parameters.high_entropy_data_surge_notify_percent
anti_ransomware.attack_detection_parameters.relaxing_popular_file_extensions |
boolean |
query |
False |
Filter by anti_ransomware.attack_detection_parameters.relaxing_popular_file_extensions
anti_ransomware.attack_detection_parameters.based_on_file_rename_op_rate |
boolean |
query |
False |
Filter by anti_ransomware.attack_detection_parameters.based_on_file_rename_op_rate
anti_ransomware.attack_detection_parameters.file_rename_op_rate_surge_notify_percent |
integer |
query |
False |
Filter by anti_ransomware.attack_detection_parameters.file_rename_op_rate_surge_notify_percent
anti_ransomware.attack_detection_parameters.based_on_high_entropy_data_rate |
boolean |
query |
False |
Filter by anti_ransomware.attack_detection_parameters.based_on_high_entropy_data_rate
anti_ransomware.attack_detection_parameters.never_seen_before_file_extension_count_notify_threshold |
integer |
query |
False |
Filter by anti_ransomware.attack_detection_parameters.never_seen_before_file_extension_count_notify_threshold
anti_ransomware.attack_detection_parameters.based_on_file_create_op_rate |
boolean |
query |
False |
Filter by anti_ransomware.attack_detection_parameters.based_on_file_create_op_rate
anti_ransomware.surge_usage.high_entropy_data_write_peak_percent |
integer |
query |
False |
Filter by anti_ransomware.surge_usage.high_entropy_data_write_peak_percent
anti_ransomware.surge_usage.time |
string |
query |
False |
Filter by anti_ransomware.surge_usage.time
anti_ransomware.surge_usage.file_create_peak_rate_per_minute |
integer |
query |
False |
Filter by anti_ransomware.surge_usage.file_create_peak_rate_per_minute
anti_ransomware.surge_usage.high_entropy_data_write_peak_rate_kb_per_minute |
integer |
query |
False |
Filter by anti_ransomware.surge_usage.high_entropy_data_write_peak_rate_kb_per_minute
anti_ransomware.surge_usage.file_rename_peak_rate_per_minute |
integer |
query |
False |
Filter by anti_ransomware.surge_usage.file_rename_peak_rate_per_minute
anti_ransomware.surge_usage.file_delete_peak_rate_per_minute |
integer |
query |
False |
Filter by anti_ransomware.surge_usage.file_delete_peak_rate_per_minute
anti_ransomware.block_device_detection_state |
string |
query |
False |
Filter by anti_ransomware.block_device_detection_state
anti_ransomware.clear_suspect.phase |
string |
query |
False |
Filter by anti_ransomware.clear_suspect.phase
anti_ransomware.clear_suspect.start_time |
string |
query |
False |
Filter by anti_ransomware.clear_suspect.start_time
anti_ransomware.attack_probability |
string |
query |
False |
Filter by anti_ransomware.attack_probability
anti_ransomware.state |
string |
query |
False |
Filter by anti_ransomware.state
anti_ransomware.space.used_by_logs |
integer |
query |
False |
Filter by anti_ransomware.space.used_by_logs
anti_ransomware.space.used_by_snapshots |
integer |
query |
False |
Filter by anti_ransomware.space.used_by_snapshots
anti_ransomware.space.used |
integer |
query |
False |
anti_ransomware.space.snapshot_count |
integer |
query |
False |
Filter by anti_ransomware.space.snapshot_count
anti_ransomware.update_baseline_from_surge |
boolean |
query |
False |
Filter by anti_ransomware.update_baseline_from_surge
anti_ransomware.typical_usage.file_delete_peak_rate_per_minute |
integer |
query |
False |
Filter by anti_ransomware.typical_usage.file_delete_peak_rate_per_minute
anti_ransomware.typical_usage.high_entropy_data_write_peak_percent |
integer |
query |
False |
Filter by anti_ransomware.typical_usage.high_entropy_data_write_peak_percent
anti_ransomware.typical_usage.file_create_peak_rate_per_minute |
integer |
query |
False |
Filter by anti_ransomware.typical_usage.file_create_peak_rate_per_minute
anti_ransomware.typical_usage.high_entropy_data_write_peak_rate_kb_per_minute |
integer |
query |
False |
Filter by anti_ransomware.typical_usage.high_entropy_data_write_peak_rate_kb_per_minute
anti_ransomware.typical_usage.file_rename_peak_rate_per_minute |
integer |
query |
False |
Filter by anti_ransomware.typical_usage.file_rename_peak_rate_per_minute
anti_ransomware.dry_run_start_time |
string |
query |
False |
Filter by anti_ransomware.dry_run_start_time
anti_ransomware.suspect_files.format |
string |
query |
False |
Filter by anti_ransomware.suspect_files.format
anti_ransomware.suspect_files.count |
integer |
query |
False |
Filter by anti_ransomware.suspect_files.count
anti_ransomware.suspect_files.entropy |
string |
query |
False |
Filter by anti_ransomware.suspect_files.entropy
anti_ransomware.event_log.is_enabled_on_snapshot_copy_creation |
boolean |
query |
False |
Filter by anti_ransomware.event_log.is_enabled_on_snapshot_copy_creation
anti_ransomware.event_log.is_enabled_on_new_file_extension_seen |
boolean |
query |
False |
Filter by anti_ransomware.event_log.is_enabled_on_new_file_extension_seen
anti_ransomware.surge_as_normal |
boolean |
query |
False |
Filter by anti_ransomware.surge_as_normal
anti_ransomware.attack_detected_by |
string |
query |
False |
Filter by anti_ransomware.attack_detected_by
scheduled_snapshot_naming_scheme |
string |
query |
False |
Filter by scheduled_snapshot_naming_scheme
state |
string |
query |
False |
Filter by state |
nodes.name |
string |
query |
False |
Filter by nodes.name
nodes.uuid |
string |
query |
False |
Filter by nodes.uuid
metric.status |
string |
query |
False |
Filter by metric.status |
metric.duration |
string |
query |
False |
Filter by metric.duration |
metric.iops.read |
integer |
query |
False |
Filter by metric.iops.read |
metric.iops.other |
integer |
query |
False |
Filter by metric.iops.other |
metric.iops.total |
integer |
query |
False |
Filter by metric.iops.total |
metric.iops.write |
integer |
query |
False |
Filter by metric.iops.write |
metric.throughput.read |
integer |
query |
False |
Filter by metric.throughput.read |
metric.throughput.other |
integer |
query |
False |
Filter by metric.throughput.other |
metric.throughput.total |
integer |
query |
False |
Filter by metric.throughput.total |
metric.throughput.write |
integer |
query |
False |
Filter by metric.throughput.write |
metric.timestamp |
string |
query |
False |
Filter by metric.timestamp |
metric.latency.read |
integer |
query |
False |
Filter by metric.latency.read |
metric.latency.other |
integer |
query |
False |
Filter by metric.latency.other |
metric.latency.total |
integer |
query |
False |
Filter by metric.latency.total |
metric.latency.write |
integer |
query |
False |
Filter by metric.latency.write |
metric.cloud.timestamp |
string |
query |
False |
Filter by metric.cloud.timestamp
metric.cloud.status |
string |
query |
False |
Filter by metric.cloud.status
metric.cloud.latency.read |
integer |
query |
False |
Filter by metric.cloud.latency.read
metric.cloud.latency.other |
integer |
query |
False |
Filter by metric.cloud.latency.other
metric.cloud.latency.total |
integer |
query |
False |
Filter by metric.cloud.latency.total
metric.cloud.latency.write |
integer |
query |
False |
Filter by metric.cloud.latency.write
metric.cloud.duration |
string |
query |
False |
Filter by metric.cloud.duration
metric.cloud.iops.read |
integer |
query |
False |
Filter by metric.cloud.iops.read
metric.cloud.iops.other |
integer |
query |
False |
Filter by metric.cloud.iops.other
metric.cloud.iops.total |
integer |
query |
False |
Filter by metric.cloud.iops.total
metric.cloud.iops.write |
integer |
query |
False |
Filter by metric.cloud.iops.write
metric.flexcache.timestamp |
string |
query |
False |
Filter by metric.flexcache.timestamp
metric.flexcache.status |
string |
query |
False |
Filter by metric.flexcache.status
metric.flexcache.duration |
string |
query |
False |
Filter by metric.flexcache.duration
metric.flexcache.cache_miss_percent |
integer |
query |
False |
Filter by metric.flexcache.cache_miss_percent
metric.flexcache.bandwidth_savings |
integer |
query |
False |
Filter by metric.flexcache.bandwidth_savings
snapshot_locking_enabled |
boolean |
query |
False |
Filter by snapshot_locking_enabled
granular_data |
boolean |
query |
False |
queue_for_encryption |
boolean |
query |
False |
Filter by queue_for_encryption
flexgroup.name |
string |
query |
False |
Filter by flexgroup.name
flexgroup.uuid |
string |
query |
False |
Filter by flexgroup.uuid
rebalancing.stop_time |
string |
query |
False |
Filter by rebalancing.stop_time
rebalancing.max_threshold |
integer |
query |
False |
Filter by rebalancing.max_threshold
rebalancing.target_used |
integer |
query |
False |
Filter by rebalancing.target_used
rebalancing.start_time |
string |
query |
False |
Filter by rebalancing.start_time
rebalancing.used_for_imbalance |
integer |
query |
False |
Filter by rebalancing.used_for_imbalance
rebalancing.exclude_snapshots |
boolean |
query |
False |
Filter by rebalancing.exclude_snapshots
rebalancing.max_runtime |
string |
query |
False |
Filter by rebalancing.max_runtime
rebalancing.engine.movement.file_moves_started |
integer |
query |
False |
Filter by rebalancing.engine.movement.file_moves_started
rebalancing.engine.movement.most_recent_start_time |
string |
query |
False |
Filter by rebalancing.engine.movement.most_recent_start_time
rebalancing.engine.movement.last_error.destination |
integer |
query |
False |
Filter by rebalancing.engine.movement.last_error.destination
rebalancing.engine.movement.last_error.time |
string |
query |
False |
Filter by rebalancing.engine.movement.last_error.time
rebalancing.engine.movement.last_error.file_id |
integer |
query |
False |
Filter by rebalancing.engine.movement.last_error.file_id
rebalancing.engine.movement.last_error.code |
integer |
query |
False |
Filter by rebalancing.engine.movement.last_error.code
rebalancing.engine.scanner.files_skipped.in_snapshot |
integer |
query |
False |
Filter by rebalancing.engine.scanner.files_skipped.in_snapshot
rebalancing.engine.scanner.files_skipped.fast_truncate |
integer |
query |
False |
Filter by rebalancing.engine.scanner.files_skipped.fast_truncate
rebalancing.engine.scanner.files_skipped.footprint_invalid |
integer |
query |
False |
Filter by rebalancing.engine.scanner.files_skipped.footprint_invalid
rebalancing.engine.scanner.files_skipped.metadata |
integer |
query |
False |
Filter by rebalancing.engine.scanner.files_skipped.metadata
rebalancing.engine.scanner.files_skipped.on_demand_destination |
integer |
query |
False |
Filter by rebalancing.engine.scanner.files_skipped.on_demand_destination
rebalancing.engine.scanner.files_skipped.remote_cache |
integer |
query |
False |
Filter by rebalancing.engine.scanner.files_skipped.remote_cache
rebalancing.engine.scanner.files_skipped.too_small |
integer |
query |
False |
Filter by rebalancing.engine.scanner.files_skipped.too_small
rebalancing.engine.scanner.files_skipped.other |
integer |
query |
False |
Filter by rebalancing.engine.scanner.files_skipped.other
rebalancing.engine.scanner.files_skipped.efficiency_blocks |
integer |
query |
False |
Filter by rebalancing.engine.scanner.files_skipped.efficiency_blocks
rebalancing.engine.scanner.files_skipped.too_large |
integer |
query |
False |
Filter by rebalancing.engine.scanner.files_skipped.too_large
rebalancing.engine.scanner.files_skipped.write_fenced |
integer |
query |
False |
Filter by rebalancing.engine.scanner.files_skipped.write_fenced
rebalancing.engine.scanner.files_skipped.incompatible |
integer |
query |
False |
Filter by rebalancing.engine.scanner.files_skipped.incompatible
rebalancing.engine.scanner.files_skipped.efficiency_percent |
integer |
query |
False |
Filter by rebalancing.engine.scanner.files_skipped.efficiency_percent
rebalancing.engine.scanner.files_scanned |
integer |
query |
False |
Filter by rebalancing.engine.scanner.files_scanned
rebalancing.engine.scanner.blocks_scanned |
integer |
query |
False |
Filter by rebalancing.engine.scanner.blocks_scanned
rebalancing.engine.scanner.blocks_skipped.in_snapshot |
integer |
query |
False |
Filter by rebalancing.engine.scanner.blocks_skipped.in_snapshot
rebalancing.engine.scanner.blocks_skipped.fast_truncate |
integer |
query |
False |
Filter by rebalancing.engine.scanner.blocks_skipped.fast_truncate
rebalancing.engine.scanner.blocks_skipped.metadata |
integer |
query |
False |
Filter by rebalancing.engine.scanner.blocks_skipped.metadata
rebalancing.engine.scanner.blocks_skipped.footprint_invalid |
integer |
query |
False |
Filter by rebalancing.engine.scanner.blocks_skipped.footprint_invalid
rebalancing.engine.scanner.blocks_skipped.on_demand_destination |
integer |
query |
False |
Filter by rebalancing.engine.scanner.blocks_skipped.on_demand_destination
rebalancing.engine.scanner.blocks_skipped.other |
integer |
query |
False |
Filter by rebalancing.engine.scanner.blocks_skipped.other
rebalancing.engine.scanner.blocks_skipped.too_small |
integer |
query |
False |
Filter by rebalancing.engine.scanner.blocks_skipped.too_small
rebalancing.engine.scanner.blocks_skipped.remote_cache |
integer |
query |
False |
Filter by rebalancing.engine.scanner.blocks_skipped.remote_cache
rebalancing.engine.scanner.blocks_skipped.efficiency_blocks |
integer |
query |
False |
Filter by rebalancing.engine.scanner.blocks_skipped.efficiency_blocks
rebalancing.engine.scanner.blocks_skipped.too_large |
integer |
query |
False |
Filter by rebalancing.engine.scanner.blocks_skipped.too_large
rebalancing.engine.scanner.blocks_skipped.write_fenced |
integer |
query |
False |
Filter by rebalancing.engine.scanner.blocks_skipped.write_fenced
rebalancing.engine.scanner.blocks_skipped.incompatible |
integer |
query |
False |
Filter by rebalancing.engine.scanner.blocks_skipped.incompatible
rebalancing.engine.scanner.blocks_skipped.efficiency_percent |
integer |
query |
False |
Filter by rebalancing.engine.scanner.blocks_skipped.efficiency_percent
rebalancing.imbalance_percent |
integer |
query |
False |
Filter by rebalancing.imbalance_percent
rebalancing.imbalance_size |
integer |
query |
False |
Filter by rebalancing.imbalance_size
rebalancing.runtime |
string |
query |
False |
Filter by rebalancing.runtime
rebalancing.min_threshold |
integer |
query |
False |
Filter by rebalancing.min_threshold
rebalancing.max_constituent_imbalance_percent |
integer |
query |
False |
Filter by rebalancing.max_constituent_imbalance_percent
rebalancing.state |
string |
query |
False |
Filter by rebalancing.state
rebalancing.data_moved |
integer |
query |
False |
Filter by rebalancing.data_moved
rebalancing.notices.code |
string |
query |
False |
Filter by rebalancing.notices.code
rebalancing.notices.arguments.message |
string |
query |
False |
Filter by rebalancing.notices.arguments.message
rebalancing.notices.arguments.code |
string |
query |
False |
Filter by rebalancing.notices.arguments.code
rebalancing.notices.message |
string |
query |
False |
Filter by rebalancing.notices.message
rebalancing.max_file_moves |
integer |
query |
False |
Filter by rebalancing.max_file_moves
rebalancing.min_file_size |
integer |
query |
False |
Filter by rebalancing.min_file_size
snapmirror.destinations.is_ontap |
boolean |
query |
False |
Filter by snapmirror.destinations.is_ontap
snapmirror.destinations.is_cloud |
boolean |
query |
False |
Filter by snapmirror.destinations.is_cloud
snapmirror.is_protected |
boolean |
query |
False |
Filter by snapmirror.is_protected
size |
integer |
query |
False |
Filter by size |
snapshot_count |
integer |
query |
False |
Filter by snapshot_count
validate_only |
boolean |
query |
False |
Filter by validate_only
has_dir_index_public |
boolean |
query |
False |
Filter by has_dir_index_public
integer |
query |
False |
Filter by space.total_metadata
space.snapshot_reserve_unusable |
integer |
query |
False |
Filter by space.snapshot_reserve_unusable
space.used_by_afs |
integer |
query |
False |
Filter by space.used_by_afs
space.dedupe_metafiles_footprint |
integer |
query |
False |
Filter by space.dedupe_metafiles_footprint
integer |
query |
False |
Filter by space.performance_tier_footprint
space.logical_space.used_percent |
integer |
query |
False |
Filter by space.logical_space.used_percent
integer |
query |
False |
Filter by space.logical_space.used_by_afs |
boolean |
query |
False |
Filter by space.logical_space.enforcement |
space.logical_space.used_by_snapshots |
integer |
query |
False |
Filter by space.logical_space.used_by_snapshots
boolean |
query |
False |
Filter by space.logical_space.reporting |
space.logical_space.used |
integer |
query |
False |
integer |
query |
False |
Filter by space.logical_space.available |
space.percent_used |
integer |
query |
False |
Filter by space.percent_used
integer |
query |
False |
Filter by space.total_metadata_footprint
space.filesystem_size_fixed |
boolean |
query |
False |
Filter by space.filesystem_size_fixed
space.max_size |
string |
query |
False |
Filter by space.max_size
integer |
query |
False |
Filter by space.local_tier_footprint
space.used |
integer |
query |
False |
Filter by space.used |
integer |
query |
False |
Filter by space.available_percent
space.filesystem_size |
integer |
query |
False |
space.delayed_free_footprint |
integer |
query |
False |
Filter by space.delayed_free_footprint
space.block_storage_inactive_user_data_percent |
integer |
query |
False |
Filter by space.block_storage_inactive_user_data_percent
space.fractional_reserve |
integer |
query |
False |
Filter by space.fractional_reserve
space.footprint |
integer |
query |
False |
Filter by space.footprint |
space.user_data |
integer |
query |
False |
Filter by space.user_data
space.full_threshold_percent |
integer |
query |
False |
Filter by space.full_threshold_percent
space.expected_available |
integer |
query |
False |
Filter by space.expected_available
space.file_operation_metadata |
integer |
query |
False |
Filter by space.file_operation_metadata
space.size |
integer |
query |
False |
Filter by space.size |
integer |
query |
False |
Filter by space.block_storage_inactive_user_data |
space.cross_volume_dedupe_metafiles_temporary_footprint |
integer |
query |
False |
Filter by space.cross_volume_dedupe_metafiles_temporary_footprint
space.size_available_for_snapshots |
integer |
query |
False |
Filter by space.size_available_for_snapshots
space.snapmirror_destination_footprint |
integer |
query |
False |
Filter by space.snapmirror_destination_footprint
space.metadata |
integer |
query |
False |
Filter by space.metadata |
space.afs_total |
integer |
query |
False |
Filter by space.afs_total
space.volume_guarantee_footprint |
integer |
query |
False |
Filter by space.volume_guarantee_footprint
space.overwrite_reserve |
integer |
query |
False |
Filter by space.overwrite_reserve
space.overwrite_reserve_used |
integer |
query |
False |
Filter by space.overwrite_reserve_used
space.physical_used |
integer |
query |
False |
Filter by space.physical_used
space.auto_adaptive_compression_footprint_data_reduction |
integer |
query |
False |
Filter by space.auto_adaptive_compression_footprint_data_reduction
space.effective_total_footprint |
integer |
query |
False |
Filter by space.effective_total_footprint
space.capacity_tier_footprint_data_reduction |
integer |
query |
False |
Filter by space.capacity_tier_footprint_data_reduction
space.snapshot.autodelete_trigger |
string |
query |
False |
Filter by space.snapshot.autodelete_trigger
integer |
query |
False |
Filter by space.snapshot.used |
space.snapshot.space_used_percent |
integer |
query |
False |
Filter by space.snapshot.space_used_percent
space.snapshot.reserve_size |
integer |
query |
False |
Filter by space.snapshot.reserve_size
integer |
query |
False |
Filter by space.snapshot.reserve_percent |
space.snapshot.autodelete.trigger |
string |
query |
False |
Filter by space.snapshot.autodelete.trigger
space.snapshot.autodelete.prefix |
string |
query |
False |
Filter by space.snapshot.autodelete.prefix
space.snapshot.autodelete.defer_delete |
string |
query |
False |
Filter by space.snapshot.autodelete.defer_delete
space.snapshot.autodelete.delete_order |
string |
query |
False |
Filter by space.snapshot.autodelete.delete_order
space.snapshot.autodelete.target_free_space |
integer |
query |
False |
Filter by space.snapshot.autodelete.target_free_space
space.snapshot.autodelete.commitment |
string |
query |
False |
Filter by space.snapshot.autodelete.commitment
space.snapshot.reserve_available |
integer |
query |
False |
Filter by space.snapshot.reserve_available
space.is_used_stale |
boolean |
query |
False |
Filter by space.is_used_stale
space.available |
integer |
query |
False |
Filter by space.available |
space.compaction_footprint_data_reduction |
integer |
query |
False |
Filter by space.compaction_footprint_data_reduction
space.nearly_full_threshold_percent |
integer |
query |
False |
Filter by space.nearly_full_threshold_percent
integer |
query |
False |
Filter by space.total_footprint
integer |
query |
False |
Filter by space.capacity_tier_footprint |
space.snapshot_spill |
integer |
query |
False |
Filter by space.snapshot_spill
space.cross_volume_dedupe_metafiles_footprint |
integer |
query |
False |
Filter by space.cross_volume_dedupe_metafiles_footprint
space.physical_used_percent |
integer |
query |
False |
Filter by space.physical_used_percent
space.dedupe_metafiles_temporary_footprint |
integer |
query |
False |
Filter by space.dedupe_metafiles_temporary_footprint
boolean |
query |
False |
Filter by space.large_size_enabled
integer |
query |
False |
Filter by space.over_provisioned |
application.name |
string |
query |
False |
Filter by application.name |
application.uuid |
string |
query |
False |
Filter by application.uuid |
files.inodefile_capacity |
integer |
query |
False |
Filter by files.inodefile_capacity
files.used |
integer |
query |
False |
Filter by files.used |
files.maximum |
integer |
query |
False |
Filter by files.maximum |
smas_protection |
string |
query |
False |
Filter by smas_protection
style |
string |
query |
False |
Filter by style |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
analytics |
Additional file system analytics information that is non-modifiable amongst all elements in the collection. This property is only populated if file system analytics is enabled on the containing volume. This analytics object captures properties that are non-modifiable amongst all elements included in the |
num_records |
integer |
Number of records |
records |
array[volume] |
"next": {
"href": "/api/resourcelink"
"analytics": {
"by_accessed_time": {
"bytes_used": {
"labels": [
"2019-07",
"2019-06",
"2019-05",
"2019",
"2018",
"--2017",
"unknown"
"by_modified_time": {
"bytes_used": {
"labels": [
"2019-07",
"2019-06",
"2019-05",
"2019",
"2018",
"--2017",
"unknown"
"num_records": 1,
"records": [
"_tags": [
"team:csi",
"environment:test"
"activity_tracking": {
"notices": [
"code": "124518424",
"message": "The top metrics report contains partial data for read operations because NFSv4 reads using Multi-Processor I/O (MPIO) are not tracked."
"state": "string",
"unsupported_reason": {
"code": "124518405",
"message": "Volume activity tracking cannot be enabled on volumes that contain LUNs."
"aggregates": [
"name": "aggr1",
"aggressive_readahead_mode": "string",
"analytics": {
"bytes_used": {
"aged_data_metric": 15.23,
"labels": [
"2019-07",
"2019-06",
"2019-05",
"2019",
"2018",
"--2017",
"unknown"
"newest_label": "2019-07",
"oldest_label": "2019-07",
"percentages": [
0.1,
11.24,
0.18,
15.75,
0.75,
83.5,
0
"values": [
15925248,
1735569408,
27672576,
2430595072,
116105216,
12889948160,
0
"bytes_used": {
"labels": [
"2019-07",
"2019-06",
"2019-05",
"2019",
"2018",
"--2017",
"unknown"
"percentages": [
0.1,
11.24,
0.18,
15.75,
0.75,
83.5,
0
"values": [
15925248,
1735569408,
27672576,
2430595072,
116105216,
12889948160,
0
"bytes_used": 15436648448,
"file_count": 21134,
"files_scanned": 43002,
"initialization": {
"state": "string"
"report_time": "2024-11-06 13:57:15 -0500",
"scan_progress": 17,
"scan_throttle_reason": {
"arguments": [
"string"
"code": "6739881",
"message": "The file system analytics scan running on volume \"fsavol2\" in SVM \"vs2\" has slowed down on node \"my_node\". Reason: Computing resources are being used by higher priority workloads."
"state": "string",
"subdir_count": 35,
"total_files": 101890,
"code": "111411207",
"message": "File system analytics cannot be enabled on volumes that contain LUNs."
"anti_ransomware": {
"attack_detected_by": "string",
"attack_detection_parameters": {
"file_create_op_rate_surge_notify_percent": 100
"attack_probability": "string",
"attack_reports": [
"suspects": {
"time": "2021-06-01 20:36:41 +0530"
"block_device_detection_start_time": "string",
"block_device_detection_state": "string",
"clear_suspect": {
"phase": "string",
"start_time": "string"
"dry_run_start_time": "string",
"space": {
"snapshot_count": 0,
"used": 0,
"used_by_logs": 0,
"used_by_snapshots": 0
"state": "string",
"surge_usage": {
"file_create_peak_rate_per_minute": 10,
"file_delete_peak_rate_per_minute": 50,
"file_rename_peak_rate_per_minute": 30,
"high_entropy_data_write_peak_percent": 30,
"high_entropy_data_write_peak_rate_kb_per_minute": 2500,
"time": "2021-12-01 23:16:20 +0530"
"suspect_files": [
"count": 0,
"entropy": "string",
"format": "string"
"typical_usage": {
"file_create_peak_rate_per_minute": 50,
"file_delete_peak_rate_per_minute": 10,
"file_rename_peak_rate_per_minute": 5,
"high_entropy_data_write_peak_percent": 10,
"high_entropy_data_write_peak_rate_kb_per_minute": 1200
"workload": {
"file_extension_types_count": 3,
"file_extensions_observed": [
"pdf",
"jpeg",
"txt"
"historical_statistics": {
"newly_observed_file_extensions": [
"count": [
20
"name": [
"lockile"
"surge_statistics": {
"surge_usage": {
"count": [
20
"name": [
"lockile"
"typical_usage": {
"application": {
"name": "string",
"uuid": "1cd8a442-86d1-11e0-ae1d-123478563412"
"asynchronous_directory_delete": {
"trash_bin": "string"
"autosize": {
"mode": "string"
"clone": {
"inherited_physical_used": 0,
"inherited_savings": 0,
"lun_name": "string",
"parent_snapshot": {
"name": "this_snapshot",
"parent_svm": {
"name": "svm1",
"parent_volume": {
"name": "volume1",
"qtree_name": "string",
"split_complete_percent": 0,
"split_estimate": 0
"cloud_retrieval_policy": "string",
"comment": "string",
"consistency_group": {
"name": "consistency_group_1",
"constituents": [
"aggregates": {
"name": "string",
"movement": {
"cutover_window": 30,
"destination_aggregate": {
"name": "aggr1",
"percent_complete": 0,
"state": "replicating",
"tiering_policy": "string"
"name": "string",
"node": {
"name": "string",
"uuid": "string"
"space": {
"available": 0,
"block_storage_inactive_user_data": 0,
"capacity_tier_footprint": 0,
"footprint": 0,
"local_tier_footprint": 0,
"logical_space": {
"available": 0,
"used_by_afs": 0
"max_size": "string",
"metadata": 0,
"over_provisioned": 0,
"performance_tier_footprint": 0,
"snapshot": {
"used": 0
"total_footprint": 0,
"total_metadata": 0,
"total_metadata_footprint": 0,
"used": 0
"create_time": "2018-06-04 19:00:00 +0000",
"efficiency": {
"application_io_size": "string",
"auto_state": "string",
"compaction": "string",
"compression": "string",
"compression_type": "string",
"cross_volume_dedupe": "string",
"dedupe": "string",
"idcs_scanner": {
"mode": "string",
"operation_state": "string",
"status": "string",
"threshold_inactive_time": "P14D"
"last_op_begin": "string",
"last_op_end": "string",
"last_op_err": "string",
"last_op_size": 0,
"last_op_state": "string",
"op_state": "string",
"policy": {
"name": "string"
"progress": "string",
"ratio": 0,
"scanner": {
"state": "string"
"schedule": "string",
"space_savings": {
"compression": 0,
"compression_percent": 0,
"dedupe": 0,
"dedupe_percent": 0,
"dedupe_sharing": 0,
"total": 0,
"total_percent": 0
"state": "string",
"storage_efficiency_mode": "string",
"type": "string",
"volume_path": "string"
"encryption": {
"action": "string",
"key_create_time": "2022-01-01 19:00:00 +0000",
"key_id": "string",
"state": "string",
"status": {
"code": "string",
"message": "string"
"type": "string"
"files": {
"inodefile_capacity": 0,
"used": 0
"flash_pool": {
"cache_eligibility": "string",
"cache_retention_priority": "string",
"caching_policy": "string"
"flexcache_endpoint_type": "string",
"flexgroup": {
"name": "my_flexgroup",
"uuid": "75c9cfb0-3eb4-11eb-9fb4-005056bb088a"
"granular_data_mode": "string",
"guarantee": {
"type": "string"
"language": "string",
"metric": {
"cloud": {
"duration": "PT15S",
"iops": {
"read": 200,
"total": 1000,
"write": 100
"latency": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"timestamp": "2017-01-25 11:20:13 +0000"
"flexcache": {
"bandwidth_savings": 4096,
"cache_miss_percent": 20,
"duration": "PT1D",
"status": "ok",
"iops": {
"read": 200,
"total": 1000,
"write": 100
"latency": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"throughput": {
"read": 200,
"total": 1000,
"write": 100
"movement": {
"name": "aggr1",
"start_time": "2020-12-07 03:45:12 -0500",
"name": "vol_cs_dept",
"nas": {
"export_policy": {
"id": 100,
"name": "default"
"junction_parent": {
"name": "vs1_root",
"path": "/user/my_volume",
"security_style": "string",
"unix_permissions": 493
"nodes": [
"name": "string",
"uuid": "string"
"optimize_aggregates": true,
"qos": {
"policy": {
"max_throughput": [
"900KB/s",
"500MB/s",
"120GB/s",
"5000IOPS",
"5000IOPS,500KB/s",
"2500IOPS,100MB/s",
"1000IOPS,25MB/s"
"max_throughput_iops": 10000,
"max_throughput_mbps": 500,
"min_throughput": [
"900KB/s",
"500MB/s",
"120GB/s",
"5000IOPS",
"5000IOPS,500KB/s",
"2500IOPS,100MB/s",
"1000IOPS,25MB/s"
"min_throughput_iops": 2000,
"min_throughput_mbps": 500,
"name": "performance",
"quota": {
"state": "string"
"rebalancing": {
"data_moved": 0,
"engine": {
"movement": {
"file_moves_started": 0,
"last_error": {
"code": 0,
"destination": 0,
"file_id": 0,
"time": "2018-06-04 19:00:00 +0000"
"most_recent_start_time": "2018-06-04 19:00:00 +0000"
"scanner": {
"blocks_scanned": 0,
"blocks_skipped": {
"efficiency_blocks": 0,
"efficiency_percent": 0,
"fast_truncate": 0,
"footprint_invalid": 0,
"in_snapshot": 0,
"incompatible": 0,
"metadata": 0,
"on_demand_destination": 0,
"other": 0,
"remote_cache": 0,
"too_large": 0,
"too_small": 0,
"write_fenced": 0
"files_scanned": 0,
"files_skipped": {
"fast_truncate": 0,
"in_snapshot": 0,
"incompatible": 0,
"metadata": 0,
"other": 0,
"remote_cache": 0,
"too_large": 0,
"too_small": 0,
"write_fenced": 0
"imbalance_percent": 0,
"imbalance_size": 0,
"max_constituent_imbalance_percent": 0,
"max_runtime": "string",
"notices": [
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"message": "entry doesn't exist"
"runtime": "string",
"start_time": "string",
"state": "rebalancing",
"stop_time": "string",
"target_used": 0,
"used_for_imbalance": 0
"scheduled_snapshot_naming_scheme": "string",
"sizing_method": "string",
"smas_protection": "string",
"snaplock": {
"append_mode_enabled": "",
"autocommit_period": "P30M",
"compliance_clock_time": "2018-06-04 19:00:00 +0000",
"expiry_time": "Wed Sep 5 11:02:42 GMT 2018",
"is_audit_log": 1,
"litigation_count": 10,
"privileged_delete": "enabled",
"retention": {
"default": "P30Y",
"maximum": "P30Y",
"minimum": "P30Y"
"type": "enterprise",
"unspecified_retention_file_count": 10
"snapshot_policy": {
"name": "default",
"space": {
"auto_adaptive_compression_footprint_data_reduction": 0,
"available": 0,
"block_storage_inactive_user_data_percent": 0,
"capacity_tier_footprint_data_reduction": 0,
"compaction_footprint_data_reduction": 0,
"cross_volume_dedupe_metafiles_footprint": 0,
"cross_volume_dedupe_metafiles_temporary_footprint": 0,
"dedupe_metafiles_footprint": 0,
"dedupe_metafiles_temporary_footprint": 0,
"delayed_free_footprint": 0,
"effective_total_footprint": 0,
"file_operation_metadata": 0,
"filesystem_size": 0,
"footprint": 0,
"logical_space": {
"available": 0,
"used": 0,
"used_by_afs": 0,
"used_by_snapshots": 0,
"used_percent": 0
"metadata": 0,
"overwrite_reserve": 0,
"overwrite_reserve_used": 0,
"percent_used": 0,
"size_available_for_snapshots": 0,
"snapmirror_destination_footprint": 0,
"snapshot": {
"autodelete": {
"commitment": "string",
"defer_delete": "string",
"delete_order": "string",
"prefix": "string",
"trigger": "string"
"autodelete_trigger": "string",
"reserve_available": 0,
"reserve_size": 0,
"space_used_percent": 0,
"used": 0
"snapshot_reserve_unusable": 0,
"snapshot_spill": 0,
"used": 0,
"user_data": 0,
"volume_guarantee_footprint": 0
"state": "string",
"statistics": {
"cifs_ops_raw": {
"access": {
"count": 1000,
"total_time": 200
"audit": {
"count": 1000,
"total_time": 200
"create": {
"dir": {
"count": 1000,
"total_time": 200
"file": {
"count": 1000,
"total_time": 200
"other": {
"count": 1000,
"total_time": 200
"symlink": {
"count": 1000,
"total_time": 200
"getattr": {
"count": 1000,
"total_time": 200
"link": {
"count": 1000,
"total_time": 200
"lock": {
"count": 1000,
"total_time": 200
"lookup": {
"count": 1000,
"total_time": 200
"open": {
"count": 1000,
"total_time": 200
"read": {
"count": 1000,
"total_time": 200,
"volume_protocol_latency_histogram_counts": [
0,
0,
0,
0,
0,
15,
35,
100,
200,
200,
300,
500,
500,
500,
1000,
1000,
800,
500,
500,
300,
200,
50,
40,
15,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0
"volume_protocol_latency_histogram_labels": [
"<2us",
"<6us",
"<10us",
"<14us",
"<20us",
"<40us",
"<60us",
"<80us",
"<100us",
"<200us",
"<400us",
"<600us",
"<800us",
"<1ms",
"<2ms",
"<4ms",
"<6ms",
"<8ms",
"<10ms",
"<12ms",
"<14ms",
"<16ms",
"<18ms",
"<20ms",
"<40ms",
"<60ms",
"<80ms",
"<100ms",
"<200ms",
"<400ms",
"<600ms",
"<800ms",
"<1s",
"<2s",
"<4s",
"<6s",
"<8s",
"<10s",
"<20s",
">20s"
"volume_protocol_size_histogram_counts": [
2400,
1055,
1100,
700,
500,
300,
200,
100,
100,
50,
50,
75,
25,
0,
0
"volume_protocol_size_histogram_labels": [
"< 4KB",
"= 4KB",
"< 8KB",
"= 8KB",
"< 16KB",
"= 16KB",
"< 32KB",
"= 32KB",
"< 64KB",
"= 64KB",
"< 256KB",
"= 256KB",
"< 1024KB",
"= 1024KB",
"> 1024KB"
"readdir": {
"count": 1000,
"total_time": 200
"readlink": {
"count": 1000,
"total_time": 200
"rename": {
"count": 1000,
"total_time": 200
"setattr": {
"count": 1000,
"total_time": 200
"unlink": {
"count": 1000,
"total_time": 200
"watch": {
"count": 1000,
"total_time": 200
"write": {
"count": 1000,
"total_time": 200,
0,
0,
0,
0,
0,
15,
35,
100,
200,
200,
300,
500,
500,
500,
1000,
1000,
800,
500,
500,
300,
200,
50,
40,
15,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0
"<2us",
"<6us",
"<10us",
"<14us",
"<20us",
"<40us",
"<60us",
"<80us",
"<100us",
"<200us",
"<400us",
"<600us",
"<800us",
"<1ms",
"<2ms",
"<4ms",
"<6ms",
"<8ms",
"<10ms",
"<12ms",
"<14ms",
"<16ms",
"<18ms",
"<20ms",
"<40ms",
"<60ms",
"<80ms",
"<100ms",
"<200ms",
"<400ms",
"<600ms",
"<800ms",
"<1s",
"<2s",
"<4s",
"<6s",
"<8s",
"<10s",
"<20s",
">20s"
2400,
1055,
1100,
700,
500,
300,
200,
100,
100,
50,
50,
75,
25,
0,
0
"< 4KB",
"= 4KB",
"< 8KB",
"= 8KB",
"< 16KB",
"= 16KB",
"< 32KB",
"= 32KB",
"< 64KB",
"= 64KB",
"< 256KB",
"= 256KB",
"< 1024KB",
"= 1024KB",
"> 1024KB"
"cloud": {
"iops_raw": {
"read": 200,
"total": 1000,
"write": 100
"latency_raw": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"flexcache_raw": {
"cache_miss_blocks": 10,
"client_requested_blocks": 500,
"status": "ok",
"iops_raw": {
"read": 200,
"total": 1000,
"write": 100
"latency_raw": {
"read": 200,
"total": 1000,
"write": 100
"nfs_ops_raw": {
"access": {
"count": 1000,
"total_time": 200
"audit": {
"count": 1000,
"total_time": 200
"create": {
"dir": {
"count": 1000,
"total_time": 200
"file": {
"count": 1000,
"total_time": 200
"other": {
"count": 1000,
"total_time": 200
"symlink": {
"count": 1000,
"total_time": 200
"getattr": {
"count": 1000,
"total_time": 200
"link": {
"count": 1000,
"total_time": 200
"lock": {
"count": 1000,
"total_time": 200
"lookup": {
"count": 1000,
"total_time": 200
"open": {
"count": 1000,
"total_time": 200
"read": {
"count": 1000,
"total_time": 200,
0,
0,
0,
0,
0,
15,
35,
100,
200,
200,
300,
500,
500,
500,
1000,
1000,
800,
500,
500,
300,
200,
50,
40,
15,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0
"<2us",
"<6us",
"<10us",
"<14us",
"<20us",
"<40us",
"<60us",
"<80us",
"<100us",
"<200us",
"<400us",
"<600us",
"<800us",
"<1ms",
"<2ms",
"<4ms",
"<6ms",
"<8ms",
"<10ms",
"<12ms",
"<14ms",
"<16ms",
"<18ms",
"<20ms",
"<40ms",
"<60ms",
"<80ms",
"<100ms",
"<200ms",
"<400ms",
"<600ms",
"<800ms",
"<1s",
"<2s",
"<4s",
"<6s",
"<8s",
"<10s",
"<20s",
">20s"
2400,
1055,
1100,
700,
500,
300,
200,
100,
100,
50,
50,
75,
25,
0,
0
"< 4KB",
"= 4KB",
"< 8KB",
"= 8KB",
"< 16KB",
"= 16KB",
"< 32KB",
"= 32KB",
"< 64KB",
"= 64KB",
"< 256KB",
"= 256KB",
"< 1024KB",
"= 1024KB",
"> 1024KB"
"readdir": {
"count": 1000,
"total_time": 200
"readlink": {
"count": 1000,
"total_time": 200
"rename": {
"count": 1000,
"total_time": 200
"setattr": {
"count": 1000,
"total_time": 200
"unlink": {
"count": 1000,
"total_time": 200
"watch": {
"count": 1000,
"total_time": 200
"write": {
"count": 1000,
"total_time": 200,
0,
0,
0,
0,
0,
15,
35,
100,
200,
200,
300,
500,
500,
500,
1000,
1000,
800,
500,
500,
300,
200,
50,
40,
15,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0
"<2us",
"<6us",
"<10us",
"<14us",
"<20us",
"<40us",
"<60us",
"<80us",
"<100us",
"<200us",
"<400us",
"<600us",
"<800us",
"<1ms",
"<2ms",
"<4ms",
"<6ms",
"<8ms",
"<10ms",
"<12ms",
"<14ms",
"<16ms",
"<18ms",
"<20ms",
"<40ms",
"<60ms",
"<80ms",
"<100ms",
"<200ms",
"<400ms",
"<600ms",
"<800ms",
"<1s",
"<2s",
"<4s",
"<6s",
"<8s",
"<10s",
"<20s",
">20s"
2400,
1055,
1100,
700,
500,
300,
200,
100,
100,
50,
50,
75,
25,
0,
0
"< 4KB",
"= 4KB",
"< 8KB",
"= 8KB",
"< 16KB",
"= 16KB",
"< 32KB",
"= 32KB",
"< 64KB",
"= 64KB",
"< 256KB",
"= 256KB",
"< 1024KB",
"= 1024KB",
"> 1024KB"
"status": "ok",
"throughput_raw": {
"read": 200,
"total": 1000,
"write": 100
"status": [
"string"
"style": "string",
"svm": {
"name": "svm1",
"svm_dr_protection": "string",
"tiering": {
"object_tags": [
"string"
"policy": "string",
"supported": true
"type": "string",
"use_mirrored_aggregates": true,
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
bytes_used
Number of bytes used on-disk, broken down by date of last access.
labels |
array[string] |
Labels for this histogram |
by_accessed_time
File system analytics information, broken down by date of last access.
bytes_used |
Number of bytes used on-disk, broken down by date of last access. |
bytes_used
Number of bytes used on-disk, broken down by date of last modification.
labels |
array[string] |
by_modified_time
File system analytics information, broken down by date of last modification.
bytes_used |
Number of bytes used on-disk, broken down by date of last modification. |
analytics
This analytics object captures properties that are non-modifiable amongst all elements included in the records array. The non-modifiable properties are included here, rather than within the information for each element, to avoid returning an excessive amount of duplicated information when the collection is large.
by_accessed_time |
File system analytics information, broken down by date of last access. |
by_modified_time |
File system analytics information, broken down by date of last modification. |
_links
self |
notices
code |
string |
An error code related to activity tracking. |
message |
string |
A notice message related to activity tracking. |
unsupported_reason
code |
string |
If volume activity tracking is not supported on the volume, this field provides an appropriate error code. |
message |
string |
If volume activity tracking is not supported on the volume, this field provides an error message detailing why this is the case. |
activity_tracking
notices |
array[notices] |
List of activity-tracking notices. |
state |
string |
Activity tracking state of the volume. If this value is "on", ONTAP collects top metrics information for the volume in real time. There is a slight impact to I/O performance in order to collect this information. If this value is "off", no activity tracking information is collected or available to view.
supported |
boolean |
This field indicates whether or not volume activity tracking is supported on the volume. If volume activity tracking is not supported, the reason why is provided in the "activity_tracking.unsupported_reason" field. |
unsupported_reason |
aggregates
Aggregate
_links |
name |
string |
uuid |
string |
bytes_used
aged_data_metric |
number |
A score summarizing how old the data is. A higher value means the data is older. |
labels |
array[string] |
newest_label |
string |
Each label indicates the period of time the corresponding data is associated with. A label can take one of the following forms:<ul> a partial date in an extended ISO8601 representation an interval between partial dates in an extended ISO8601 representation, where "--" is used to separate the beginning and end of the interval the string literal "unknown" </ul>For partial dates and partial date intervals where components of a date are unspecified, the label allows for any valid normalized values the unspecified components might take. For example, the label "2017" allows for any time within the year 2017. Essentially, this is the fully specified interval 2017-01-01T00:00:00—2017-12-31T23:59:59. Similarly, the interval "2018-05—2018-07" allows for any time within the months of May, June, and July in 2018, corresponding to the fully specified interval 2018-05-01T00:00:00—2018-07-31T23:59:59. The following extensions to ISO8601 are used:<ul> Quarters may be specified. The form yyyy-Qq is used to represent the qth quarter of the year yyyy. Q1 consists of the months January, February, and March; Q2 consists of April, May, and June; Q3 consists of July, August, and September; Q4 consists of October, November, and December. For example, the label "2019-Q2" represents the second quarter of the year 2019, which corresponds to the interval 2019-04-01T00:00:00—2019-06-30T23:59:59. Either the beginning or end of an interval may be omitted. When the beginning is omitted, the interval includes points in time arbitrarily far in the past. When the end is omitted, the interval includes points in time through the end of the current week. </ul>The "unknown" label tracks data that could not be associated with any other time period. This usually occurs when the data was at some point associated with a time in the future. |
oldest_label |
string |
percentages |
array[number] |
Percentages for this histogram |
values |
array[integer] |
Values for this histogram |
bytes_used
aged_data_metric |
number |
labels |
array[string] |
newest_label |
string |
oldest_label |
string |
percentages |
array[number] |
values |
array[integer] |
initialization
state |
string |
State of the analytics file system scan. |
arguments |
array[string] |
Arguments present in the warning message encountered. |
code |
string |
Warning code indicating why scanner throttling is reported. |
message |
string |
A message that provides details for scan throttling. |
unsupported_reason
code |
string |
If file system analytics is not supported on the volume, this field provides the error code explaining why. |
message |
string |
If file system analytics is not supported on the volume, this field provides the error message explaining why. |
analytics
by_accessed_time |
by_modified_time |
bytes_used |
integer |
Number of bytes used on-disk. |
file_count |
integer |
Number of descendants. |
files_scanned |
integer |
Number of files in the volume that the file system analytics initialization scan has processed. Only returned when the state is |
incomplete_data |
boolean |
Returns true if data collection is incomplete for this directory tree. |
initialization |
report_time |
string |
Time of data collection. |
scan_progress |
integer |
Percentage of files in the volume that the file system analytics initialization scan has processed. Only returned when the state is |
scan_throttle_reason |
state |
string |
File system analytics state of the volume. If this value is "on", ONTAP collects extra file system analytics information for all directories on the volume. There will be a slight impact to I/O performance to collect this information. If this value is "off", file system analytics information is not collected and not available to be viewed. If this value is "initializing", that means file system analytics was recently turned on, and the initialization scan to gather information for all existing files and directories is currently running. If this value is "initialization_paused", this means that the initialization scan is currently paused. If this value is 'unknown', this means that there was an internal error when determining the file system analytics state for the volume.
subdir_count |
integer |
Number of sub-directories. |
supported |
boolean |
This field indicates whether or not file system analytics is supported on the volume. If file system analytics is not supported, the reason will be specified in the "analytics.unsupported_reason" field. |
total_files |
integer |
Total number of files in the volume that the file system analytics initialization scan will process. Only returned when the state is |
anti_ransomware_volume_attack_detection_parameters
boolean |
Specifies whether attack detection is based on the file create operations rate. This parameter is valid only for NAS volumes. |
boolean |
Specifies whether attack detection is based on the file delete operations rate. This parameter is valid only for NAS volumes. |
boolean |
Specifies whether attack detection is based on the file rename operations rate. This parameter is valid only for NAS volumes. |
boolean |
Specifies whether a high entropy data rate should be considered for attack detection. |
boolean |
Specifies whether file extensions never seen before should be considered for attack detection. |
integer |
Specifies the block device auto learned encryption threshold. |
integer |
Specifies the percentage of surge in the file create rate up to which it is considered normal behavior. |
integer |
Specifies the percentage of surge in the file delete rate up to which it is considered normal behavior. |
integer |
Specifies the percent of surge in the file rename rate up to which it is considered normal behavior. |
integer |
Specifies the percentage of surge in high entropy data up to which it is considered as normal behavior. For example, if the usual high entropy data rate in the volume is 5% and if this parameter is set to 100%, it will be considered as an unusual surge if the high entropy data rate of the volume exceeds 10% at any time. Similarly, if this parameter is set to 400%, it will be considered as an unusual surge if the high entropy data rate of the volume exceeds 25%, and so on. |
integer |
Specifies the number of files found with a never seen before file extension up to which it is considered normal behavior. |
integer |
Specifies the duration within which the specified number of files found with never seen before file extensions is considered normal behavior. |
boolean |
Specifies whether popular file extensions should be relaxed from being treated as a suspect for the attack. Some popular file extensions are .txt, .pdf, and so on. |
_links
suspects |
anti_ransomware_attack_report
_links |
time |
string |
Timestamp at which ransomware attack is observed. |
clear_suspect
Clear suspect status.
phase |
string |
Clear suspect phase. |
start_time |
string |
Clear suspect start time. |
event_log
boolean |
Specifies whether to send an EMS when a new file extension is discovered. |
boolean |
Specifies whether to send an EMS when a snapshot is created. |
space
snapshot_count |
integer |
Total number of Anti-ransomware backup snapshots. |
used |
integer |
Total space in bytes used by the Anti-ransomware feature. |
used_by_logs |
integer |
Space in bytes used by the Anti-ransomware analytics logs. |
used_by_snapshots |
integer |
Space in bytes used by the Anti-ransomware backup snapshots. |
surge_usage
Usage values of the volume's workload during surge. This object is no longer supported use surge_statistics instead.
integer |
Peak rate of file creates per minute in the workload of the volume during surge. |
integer |
Peak rate of file deletes per minute in the workload of the volume during surge. |
integer |
Peak rate of file renames per minute in the workload of the volume during surge. |
integer |
Peak percentage of high entropy data writes in the volume during surge. |
integer |
Peak high entropy data write rate in the volume during surge, in KBs per minute. |
time |
string |
Timestamp at which the first surge in the volume's workload is observed. |
suspect_files
count |
integer |
Total number of |
entropy |
string |
Indicates the entropy level of this file type. |
format |
string |
File formats observed by the Anti-ransomware analytics engine on the volume. |
typical_usage
Typical usage values of volume workload. This object is no longer supported use historical_statistics instead.
integer |
Typical peak rate of file creates per minute in the workload of the volume. |
integer |
Typical peak rate of file deletes per minute in the workload of the volume. |
integer |
Typical peak rate of file renames per minute in the workload of the volume. |
integer |
Typical peak percentage of high entropy data writes in the volume. |
integer |
Typical peak high entropy data write rate in the volume, in KBs per minute. |
integer |
integer |
integer |
integer |
integer |
count |
integer |
Count of newly observed file extensions. |
name |
string |
Name of the newly observed file extension. |
surge_statistics
integer |
integer |
integer |
integer |
integer |
time |
string |
surge_usage
integer |
integer |
integer |
integer |
integer |
newly_observed_file_extensions |
New file extensions observed in the volume during surge. |
time |
string |
anti_ransomware_volume_workload
integer |
Count of types of file extensions observed in the volume. |
array[string] |
File extensions observed in the volume. |
historical_statistics |
Typical usage values of volume workload. |
surge_statistics |
Usage values of the volume's workload during surge. |
surge_usage |
Usage values of the volume's workload during surge. This object is no longer supported use surge_statistics instead. |
typical_usage |
Typical usage values of volume workload. This object is no longer supported use historical_statistics instead. |
anti_ransomware
Anti-ransomware related information of the volume.
string |
This field specifies whether the attack was reported by |
attack_detection_parameters |
string |
Probability of a ransomware attack.
attack_reports |
string |
This field specifies the block device evaluation start time. |
string |
This field specifies the block device attack detection status.
clear_suspect |
Clear suspect status. |
string |
Time when anti-ransomware monitoring |
event_log |
space |
state |
string |
Anti-ransomware state.
surge_as_normal |
boolean |
Indicates whether or not to set the surge values as historical values. This field is no longer supported. Use update_baseline_from_surge instead. |
surge_usage |
suspect_files |
array[suspect_files] |
typical_usage |
boolean |
Sets the observed surge value as the new baseline on a volume. |
workload |
application
name |
string |
Name of the application to which the volume belongs. Available only when the volume is part of an application. |
uuid |
string |
UUID of the application to which the volume belongs. Available only when the volume is part of an application. |
Configuration for asynchronous directory delete from the client. This is only supported on Flexible volumes and FlexGroup volumes.
enabled |
boolean |
Specifies whether asynchronous directory delete from the client is enabled on the volume. |
trash_bin |
string |
Name of the trash bin directory. If no "trash_bin" property is specified when enabling, the default trash bin name, "._ontaptrashbin", is used. |
autosize
grow_threshold |
integer |
Used space threshold size, in percentage, for the automatic growth of the volume. When the amount of used space in the volume becomes greater than this threshold, the volume automatically grows unless it has reached the maximum size. The volume grows when 'space.used' is greater than this percent of 'space.size'. The 'grow_threshold' size cannot be less than or equal to the 'shrink_threshold' size.. |
maximum |
integer |
Maximum size in bytes up to which a volume grows automatically. This size cannot be less than the current volume size, or less than or equal to the minimum size of volume. |
minimum |
integer |
Minimum size in bytes up to which the volume shrinks automatically. This size cannot be greater than or equal to the maximum size of volume. |
mode |
string |
Autosize mode for the volume. grow ‐ Volume automatically grows when the amount of used space is above the 'grow_threshold' value. grow_shrink ‐ Volume grows or shrinks in response to the amount of space used. off ‐ Autosizing of the volume is disabled. |
shrink_threshold |
integer |
Used space threshold size, in percentage, for the automatic shrinkage of the volume. When the amount of used space in the volume drops below this threshold, the volume automatically shrinks unless it has reached the minimum size. The volume shrinks when the 'space.used' is less than the 'shrink_threshold' percent of 'space.size'. The 'shrink_threshold' size cannot be greater than or equal to the 'grow_threshold' size. |
snapshot_reference
_links |
name |
string |
uuid |
string |
parent_svm
_links |
name |
string |
uuid |
string |
parent_volume
_links |
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
clone
has_flexclone |
boolean |
Specifies whether this volume is a parent of any FlexClone volume. |
inherited_physical_used |
integer |
Inherited physical used from the clone's base snapshot. |
inherited_savings |
integer |
Inherited savings from the clone's base snapshot. |
is_flexclone |
boolean |
Specifies if this volume is a normal FlexVol volume or FlexClone volume. This field needs to be set when creating a FlexClone volume. Valid in POST. |
lun_name |
string |
This optional parameter specifies the name of a LUN that will be non-disruptively migrated to the newly created FlexClone volume. If not specified, no LUNs are migrated. |
parent_snapshot |
parent_svm |
parent_volume |
qtree_name |
string |
This optional parameter specifies the name of the qtree containing the LUN that will be non-disruptively migrated to the newly created FlexClone volume. |
split_complete_percent |
integer |
Percentage of FlexClone volume blocks split from its parent volume. |
split_estimate |
integer |
Space required by the containing-aggregate to split the FlexClone volume. |
split_initiated |
boolean |
This field is set when a split is executed on any FlexClone volume, that is when the FlexClone volume is split from its parent FlexVol volume. Setting this field initiates a split of a FlexClone volume from a FlexVol volume. Valid in PATCH. |
consistency_group
Consistency group the volume is part of.
name |
string |
The name of the consistency group to which the volume belongs. Available only when the volume is part of a consistency group. If this volume belongs to a child consistency group, then this will be the UUID of the parent consistency group. |
uuid |
string |
The UUID of the consistency group to which the volume belongs. Available only when the volume is part of a consistency group. If this volume belongs to a child consistency group, then this will be the UUID of the parent consistency group. |
aggregates
name |
string |
Name of the aggregate hosting the FlexGroup volume constituent. |
uuid |
string |
Unique identifier for the aggregate. |
Aggregate
_links |
name |
string |
uuid |
string |
movement
Volume movement. All attributes are modify, that is, not writable through POST. Set PATCH state to destination_aggregate to initiate a volume move operation.
cutover_window |
integer |
Time window in seconds for cutover. The allowed range is between 30 to 300 seconds. |
destination_aggregate |
Aggregate |
percent_complete |
integer |
Completion percentage |
state |
string |
State of volume move operation. PATCH the state to "aborted" to abort the move operation. PATCH the state to "cutover" to trigger cutover. PATCH the state to "paused" to pause the volume move operation in progress. PATCH the state to "replicating" to resume the paused volume move operation. PATCH the state to "cutover_wait" to go into cutover manually. When volume move operation is waiting to go into "cutover" state, this is indicated by the "cutover_pending" state. A change of state is only supported if volume movement is in progress. |
tiering_policy |
string |
Tiering policy for FabricPool |
node
name |
string |
List of the node names hosting the FlexGroup volume constituent. |
uuid |
string |
List of the node UUIDs hosting the FlexGroup volume constituent. |
logical_space
available |
integer |
The amount of space available in this volume with storage efficiency space considered used, in bytes. |
enforcement |
boolean |
Specifies whether space accounting for operations on the volume is done along with storage efficiency. |
reporting |
boolean |
Specifies whether space reporting on the volume is done along with storage efficiency. |
used_by_afs |
integer |
The virtual space used by AFS alone (includes volume reserves) and along with storage efficiency, in bytes. |
snapshot
autodelete_enabled |
boolean |
Specifies whether snapshot autodelete is currently enabled on this volume. |
reserve_percent |
integer |
The space that has been set aside as a reserve for snapshot usage, in percent. |
used |
integer |
The total space used by snapshots in the volume, in bytes. |
space
afs_total |
integer |
Total size of AFS, excluding snap-reserve, in bytes. |
available |
integer |
The available space, in bytes. |
available_percent |
integer |
The space available, as a percent. |
integer |
The size that is physically used in the block storage of the volume and has a cold temperature. In bytes. This parameter is only supported if the volume is in an aggregate that is either attached to a cloud store or could be attached to a cloud store. |
integer |
Space used by capacity tier for this volume in the FabricPool aggregate, in bytes. |
footprint |
integer |
Data used for this volume in the aggregate, in bytes. |
large_size_enabled |
boolean |
Specifies whether the support for large volumes and large files is enabled on the volume. |
local_tier_footprint |
integer |
Space used by the local tier for this volume in the aggregate, in bytes. |
logical_space |
max_size |
string |
Indicates the maximum size supported for each constituent of the FlexGroup volume. |
metadata |
integer |
Space used by the volume metadata in the aggregate, in bytes. |
over_provisioned |
integer |
The amount of space not available for this volume in the aggregate, in bytes. |
performance_tier_footprint |
integer |
Space used by the performance tier for this volume in the FabricPool aggregate, in bytes. |
size |
integer |
Total provisioned size. The default size is equal to the minimum size of 20MB, in bytes. |
snapshot |
total_footprint |
integer |
Data and metadata used for this volume in the aggregate, in bytes. |
total_metadata |
integer |
Space used by the total metadata in the volume, in bytes. |
total_metadata_footprint |
integer |
Space used by the volume metadata footprint in the aggregate, in bytes. |
used |
integer |
The virtual space used (includes volume reserves) before storage efficiency, in bytes. |
used_by_afs |
integer |
The space used by Active Filesystem, in bytes. |
used_percent |
integer |
The virtual space used (includes volume reserves) before storage efficiency, as a percent. |
constituents
aggregates |
movement |
Volume movement. All attributes are modify, that is, not writable through POST. Set PATCH state to destination_aggregate to initiate a volume move operation. |
name |
string |
FlexGroup volume constituent name. |
node |
space |
idcs_scanner
Inactive data compression scan looks and picks up blocks that have not been read for a certain amount of time(threshold_inactive_days). These blocks are then compressed in 32K chunks. All attributes are valid for GET only, except for 'operation_state' which is valid for PATCH and GET, and is used to start/stop the scanner.
enabled |
boolean |
Specifies the administrative state of the inactive data compression scanner. Disabling inactive data compression is not allowed on Capacity optimized Flash with QAT supported platforms. |
inactive_days |
integer |
Data blocks older than, or equal to, 'inactive_days' are picked up by the inactive data compression scanner. Valid for PATCH only. Only applicable when 'operation_state' set to 'active'. |
mode |
string |
Specifies the mode of inactive data compression scanner. Valid for PATCH and GET. |
operation_state |
string |
Specifies the operational state of the inactive data compression scanner. VALID for PATCH and GET. Valid options for PATCH are "idle" and "active". |
status |
string |
Status of last inactive data compression scan on the volume. |
threshold_inactive_time |
string |
Time interval after which inactive data compression is automatically triggered. The value is in days and is represented in the ISO-8601 format "P |
policy
name |
string |
Specifies the name of the efficiency policy. The "inline-only" and "none" policies are not supported on Capacity optimized Flash with QAT supported platform. |
scanner
compression |
boolean |
Start compression if scanning old data. Valid for PATCH and GET. This option is not supported for FSX/CVO platforms. |
dedupe |
boolean |
Start deduplication if scanning old data. Valid for PATCH and GET. |
scan_old_data |
boolean |
Indicates whether or not to scan old data. Valid for PATCH and GET. |
state |
string |
State of the volume efficiency scanner. Valid for PATCH and GET. Valid options for PATCH are "idle" and "active". |
space_savings
compression |
integer |
Total disk space that is saved by compressing blocks on the referenced file system, in bytes. |
compression_percent |
integer |
Percentage of total disk space that is saved by compressing blocks on the referenced file system. |
dedupe |
integer |
Total disk space that is saved by deduplication and file cloning, in bytes. |
dedupe_percent |
integer |
Percentage of total disk space that is saved by deduplication and file cloning. |
dedupe_sharing |
integer |
Total disk space that is shared due to deduplication and file cloning. |
total |
integer |
Total disk space saved in the volume due to deduplication, compression and file cloning, in bytes. |
total_percent |
integer |
Percentage of total disk space saved in the volume due to deduplication, compression and file cloning. |
efficiency
| Name | Type | Description | ||
application_io_size |
string |
Block size to use by compression. 8k and auto are only allowed for POST. Only auto is supported on QAT supported platforms. |
auto_state |
string |
Automatic deduplication schedule volume state. auto ‐ Volumes with auto_state set to auto start post-process deduplication automatically. deprioritized ‐ Volumes with auto_state set to deprioritized do not start post-process deduplication automatically. |
compaction |
string |
The system can be enabled/disabled compaction. inline ‐ Data will be compacted first and written to the volume. none ‐ None mixed ‐ Read only field for FlexGroup volumes, where some of the constituent volumes are compaction enabled and some are disabled. |
compression |
string |
The system can be enabled/disabled compression. Disabling compression is not allowed on Capacity optimized Flash with QAT supported platforms. inline ‐ Data will be compressed first and written to the volume. background ‐ Data will be written to the volume and compressed later. both ‐ Inline compression compresses the data and write to the volume, background compression compresses only the blocks on which inline compression is not run. none ‐ None mixed ‐ Read only field for FlexGroup volumes, where some of the constituent volumes are compression enabled and some are disabled.
compression_type |
string |
Compression type to use by compression. Valid for PATCH and GET. |
cross_volume_dedupe |
string |
The system can be enabled/disabled cross volume dedupe. it can be enabled only when dedupe is enabled. Disabling cross volume dedupe is not allowed on Capacity optimized Flash with QAT supported platforms. inline ‐ Data will be cross volume deduped first and written to the volume. background ‐ Data will be written to the volume and cross volume deduped later. both ‐ Inline cross volume dedupe dedupes the data and write to the volume, background cross volume dedupe dedupes only the blocks on which inline dedupe is not run. none ‐ None mixed ‐ Read only field for FlexGroup volumes, where some of the constituent volumes are cross volume dedupe enabled and some are disabled. |
dedupe |
string |
The system can be enabled/disabled dedupe. Disabling dedupe is not allowed on Capacity optimized Flash with QAT supported platforms. inline ‐ Data will be deduped first and written to the volume. background ‐ Data will be written to the volume and deduped later. both ‐ Inline dedupe dedupes the data and write to the volume, background dedupe dedupes only the blocks on which inline dedupe is not run. none ‐ None mixed ‐ Read only field for FlexGroup volumes, where some of the constituent volumes are dedupe enabled and some are disabled. |
has_savings |
boolean |
When true, indicates that the volume contains shared(deduplication, file clones) or compressed data. |
idcs_scanner |
Inactive data compression scan looks and picks up blocks that have not been read for a certain amount of time(threshold_inactive_days). These blocks are then compressed in 32K chunks. All attributes are valid for GET only, except for 'operation_state' which is valid for PATCH and GET, and is used to start/stop the scanner. |
last_op_begin |
string |
Last sis operation begin timestamp. |
last_op_end |
string |
Last sis operation end timestamp. |
last_op_err |
string |
Last sis operation error text. |
last_op_size |
integer |
Last sis operation size. |
last_op_state |
string |
Last sis operation state. |
logging_enabled |
boolean |
When true, indicates that space savings for any newly-written data are being logged. |
op_state |
string |
Sis status of the volume. |
policy |
progress |
string |
Sis progress of the volume. |
ratio |
number |
Storage efficiency that does not include the savings provided by snapshots. |
scanner |
schedule |
string |
Schedule associated with volume. |
space_savings |
state |
string |
Storage efficiency state of the volume. Currently, this field supports POST/PATCH only for RW (Read-Write) volumes on FSx for ONTAP and Cloud Volumes ONTAP. disabled ‐ All storage efficiency features are disabled. mixed ‐ Read-only field for FlexGroup volumes, storage efficiency is enabled on certain constituents and disabled on others. On FSx for ONTAP and Cloud Volumes ONTAP ‐ enabled ‐ All supported storage efficiency features for the volume are enabled. custom ‐ Read-only field currently only supported for the FSx for ONTAP and Cloud Volumes ONTAP, user-defined storage efficiency features are enabled. For other platforms ‐ enabled ‐ At least one storage efficiency feature for the volume is enabled.
storage_efficiency_mode |
string |
Storage efficiency mode used by volume. This parameter is supported only on AFF platforms. There is no difference between default and efficient modes on QAT supported platforms and auto adaptive compression is set irrespective of the modes. |
type |
string |
Sis Type of the volume. |
volume_path |
string |
Absolute volume path of the volume. |
status
code |
string |
Encryption progress message code. |
message |
string |
Encryption progress message. |
encryption
action |
string |
This field can be used to pause an ongoing rekey or conversion operation or resume a paused rekey or conversion operation. Valid in PATCH. The following actions are supported for this field: conversion_pause ‐ Pause an encryption conversion operation currently in progress. conversion_resume ‐ Resume a paused encryption conversion operation. rekey_pause ‐ Pause an encryption rekey operation currently in progress. rekey_resume ‐ Resume a paused encryption rekey operation. |
enabled |
boolean |
Creates an encrypted or an unencrypted volume. For POST, when set to 'true', a new key is generated and used to encrypt the given volume. In that case, the underlying SVM must be configured with the key manager. When set to 'false', the volume created will be unencrypted. For PATCH, when set to 'true', it encrypts an unencrypted volume. Specifying the parameter as 'false' in a PATCH operation for an encrypted volume is only supported when moving the volume to another aggregate. |
key_create_time |
string |
Encryption key creation time of the volume. |
key_id |
string |
The key ID used for creating encrypted volume. A new key-id is generated for creating an encrypted volume. This key-id is associated with the generated key. |
rekey |
boolean |
If set to 'true', re-encrypts the volume with a new key. Valid in PATCH. |
state |
string |
Volume encryption state. encrypted ‐ The volume is completely encrypted. encrypting ‐ Encryption operation is in progress. partial ‐ Some constituents are encrypted and some are not. Applicable only for FlexGroup volume. rekeying. Encryption of volume with a new key is in progress. unencrypted ‐ The volume is a plain-text one. |
status |
type |
string |
Volume encryption type. none ‐ The volume is a plain-text one. volume ‐ The volume is encrypted with NVE (NetApp Volume Encryption). aggregate ‐ The volume is encrypted with NAE (NetApp Aggregate Encryption). |
error_state
has_bad_blocks |
boolean |
Indicates whether the volume has any corrupt data blocks. If the damaged data block is accessed, an IO error, such as EIO for NFS or STATUS_FILE_CORRUPT for CIFS, is returned. |
is_inconsistent |
boolean |
Indicates whether the file system has any inconsistencies. true ‐ File system is inconsistent. false ‐ File system in not inconsistent. |
files
integer |
Number of inodes that can currently be stored on the volume for user-visible files. This number dynamically increases as more user-visible files are created. |
maximum |
integer |
The maximum number of files (inodes) for user-visible data allowed on the volume. This value can be increased or decreased. Increasing the maximum number of files does not immediately cause additional disk space to be used to track files. Instead, as more files are created on the volume, the system dynamically increases the number of disk blocks that are used to track files. The space assigned to track files is never freed, and this value cannot be decreased below the current number of files that can be tracked within the assigned space for the volume. Valid in PATCH. |
used |
integer |
Number of files (inodes) used for user-visible data permitted on the volume. This field is valid only when the volume is online. |
flash_pool
cache_eligibility |
string |
If this parameter is specified, the command displays information only about the volume or volumes with the specified Flash Pool caching attributes. |
cache_retention_priority |
string |
If this parameter is specified, the command displays the volumes that match the specified cache retention priority policy. A cache retention priority defines how long the blocks of a volume will be cached in the Flash Pool once they become cold. |
caching_policy |
string |
This optionally specifies the caching policy to apply to the volume. A caching policy defines how the system caches a volume's data in Flash Cache modules. If a caching policy is not assigned to a volume, the system uses the caching policy that is assigned to the containing SVM. If a caching policy is not assigned to the containing SVM, the system uses the default cluster-wide policy. |
flexgroup
name |
string |
Name of the FlexGroup volume that the constituent is part of. |
uuid |
string |
Unique identifier for the FlexGroup volume that the constituent is part of. |
guarantee
honored |
boolean |
Is the space guarantee of this volume honored in the aggregate? |
type |
string |
The type of space guarantee of this volume in the aggregate. |
iops
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Performance metric for write I/O operations. |
latency
other |
integer |
read |
integer |
total |
integer |
write |
integer |
cloud
Performance numbers (IOPS and latency) for cloud store. These numbers are relevant only for volumes hosted on FabricPools.
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
iops |
The rate of I/O operations observed at the storage object. |
latency |
The round trip latency in microseconds observed at the storage object. |
status |
string |
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
timestamp |
string |
The timestamp of the performance data. |
flexcache
Performance number for FlexCache used to measure cache effectiveness.
bandwidth_savings |
integer |
Bandwidth savings denoting the amount of data served locally by the cache, in bytes. |
cache_miss_percent |
integer |
Cache miss percentage. |
duration |
string |
status |
string |
timestamp |
string |
throughput
other |
integer |
read |
integer |
total |
integer |
write |
integer |
metric
Performance numbers, such as IOPS, latency and throughput.
_links |
cloud |
Performance numbers (IOPS and latency) for cloud store. These numbers are relevant only for volumes hosted on FabricPools. |
duration |
string |
flexcache |
Performance number for FlexCache used to measure cache effectiveness. |
iops |
latency |
status |
string |
throughput |
The rate of throughput bytes per second observed at the storage object. |
timestamp |
string |
movement
capacity_tier_optimized |
boolean |
Specifies whether this move should perform optimized volume move for the capacity tier, in which data in the capacity tier does not need to be copied over. |
cutover_window |
integer |
Aggregate |
percent_complete |
integer |
start_time |
string |
Start time of volume move. |
state |
string |
tiering_policy |
string |
export_policy
Export Policy
_links |
id |
integer |
name |
string |
junction_parent
_links |
name |
string |
The name of the parent volume that contains the junction inode of this volume. The junction parent volume must belong to the same SVM that owns this volume. |
uuid |
string |
Unique identifier for the parent volume. |
nas
export_policy |
Export Policy |
gid |
integer |
The UNIX group ID of the volume. Valid in POST or PATCH. |
junction_parent |
path |
string |
The fully-qualified path in the owning SVM's namespace at which the volume is mounted. The path is case insensitive and must be unique within a SVM's namespace. Path must begin with '/' and must not end with '/'. Only one volume can be mounted at any given junction path. An empty path in POST creates an unmounted volume. An empty path in PATCH deactivates and unmounts the volume. Taking a volume offline or restricted state removes its junction path. This attribute is reported in GET only when the volume is mounted. |
security_style |
string |
Security style associated with the volume. Valid in POST or PATCH. mixed ‐ Mixed-style security ntfs ‐ NTFS/WIndows-style security unified ‐ Unified-style security, unified UNIX, NFS and CIFS permissions unix ‐ Unix-style security. |
uid |
integer |
The UNIX user ID of the volume. Valid in POST or PATCH. |
unix_permissions |
integer |
UNIX permissions to be viewed as an octal number. It consists of 4 digits derived by adding up bits 4 (read), 2 (write) and 1 (execute). First digit selects the set user ID(4), set group ID (2) and sticky (1) attributes. The second digit selects permission for the owner of the file; the third selects permissions for other users in the same group; the fourth for other users not in the group. Valid in POST or PATCH. For security style "mixed" or "unix", the default setting is 0755 in octal (493 in decimal) and for security style "ntfs", the default setting is 0000. In cases where only owner, group and other permissions are given (as in 755, representing the second, third and fourth dight), first digit is assumed to be zero. |
nodes
name |
string |
List of the node names hosting the volume. |
uuid |
string |
List of the node UUIDs hosting the volume. |
policy
When "min_throughput_iops", "min_throughput_mbps", "min_throughput", "max_throughput_iops", "max_throughput_mbps" or "max_throughput" attributes are specified, the storage object is assigned to an auto-generated QoS policy group. If the attributes are later modified, the auto-generated QoS policy-group attributes are modified. Attributes can be removed by specifying "0" and policy group by specifying "none". Upon deletion of the storage object or if the attributes are removed, then the QoS policy-group is also removed.
_links |
max_throughput |
string |
Specifies the maximum throughput in Kilobytes per sec, Megabytes per sec or Gigabytes per sec along with or without IOPS. 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when either max_throughput_mbps or max_throughput_iops are set during POST or PATCH. During GET, the returned value is rounded to the largest unit with a value greater than 1. |
max_throughput_iops |
integer |
Specifies the maximum throughput in IOPS, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when max_throughput is set during POST or PATCH. |
max_throughput_mbps |
integer |
Specifies the maximum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when max_throughput is set during POST or PATCH. |
min_throughput |
string |
Specifies the minimum throughput in Kilobytes per sec, Megabytes per sec or Gigabytes per sec along with or without IOPS. 0 means none.Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when either min_throughput_mbps or min_throughput_iops are set during POST or PATCH. During GET, the returned value is rounded to the largest unit with a value greater than 1. |
min_throughput_iops |
integer |
Specifies the minimum throughput in IOPS, 0 means none. Setting "min_throughput" is supported on AFF platforms only, unless FabricPool tiering policies are set. This is mutually exclusive with name and UUID during POST and PATCH. This cannot be set when min_throughput is set during POST or PATCH. |
min_throughput_mbps |
integer |
Specifies the minimum throughput in Megabytes per sec, 0 means none. This is mutually exclusive with name and UUID during POST and PATCH.This cannot be set when min_throughput is set during POST or PATCH. |
name |
string |
The QoS policy group name. This is mutually exclusive with UUID and other QoS attributes during POST and PATCH. |
uuid |
string |
The QoS policy group UUID. This is mutually exclusive with name and other QoS attributes during POST and PATCH. |
qos
QoS information
policy |
When "min_throughput_iops", "min_throughput_mbps", "min_throughput", "max_throughput_iops", "max_throughput_mbps" or "max_throughput" attributes are specified, the storage object is assigned to an auto-generated QoS policy group. If the attributes are later modified, the auto-generated QoS policy-group attributes are modified. Attributes can be removed by specifying "0" and policy group by specifying "none". Upon deletion of the storage object or if the attributes are removed, then the QoS policy-group is also removed. |
quota
Quotas track the space or file usage of a user, group, or qtree in a FlexVol volume or a FlexGroup volume.
enabled |
boolean |
This option is used to enable or disable the quota for the volume. This option is valid only in PATCH. Quotas are enabled for FlexVol volumes or FlexGroup volumes when the quota state is "on". Quotas are disabled for FlexVol volumes or FlexGroup volumes when the quota state is "off". |
state |
string |
Quota state of the volume |
last_error
Error information for the last failed file move on the constituent.
code |
integer |
Error code of the last file move error on the constituent. |
destination |
integer |
DSID of the destination constituent of the last file move error on the constituent. |
file_id |
integer |
File ID of the last file move error on the constituent. |
time |
string |
Time of the last file move error on the constituent. |
movement
Properties on this constituent related to file movement.
file_moves_started |
integer |
Number of file moves started on this constituent. |
last_error |
Error information for the last failed file move on the constituent. |
most_recent_start_time |
string |
Start time of the most recent file move on the constituent. |
blocks_skipped
Number of blocks skipped by the scanner on this constituent due to various reasons.
efficiency_blocks |
integer |
Number of blocks skipped by the scanner on this constituent because storage efficiency lost, in blocks, would be too high. |
efficiency_percent |
integer |
Number of blocks skipped by the scanner on this constituent because storage efficiency lost, in percent, would be too high. |
fast_truncate |
integer |
Number of blocks skipped by the scanner on this constituent because fast truncate is currently running on files. |
footprint_invalid |
integer |
Number of blocks skipped by the scanner on this constituent because of files with invalid space footprints. |
in_snapshot |
integer |
Number of blocks skipped by the scanner on this constituent because of files in snapshots. |
incompatible |
integer |
Number of blocks skipped by the scanner on this constituent because of incompatible files. |
metadata |
integer |
Number of blocks skipped by the scanner on this constituent because of metadata files. |
on_demand_destination |
integer |
Number of blocks skipped by the scanner on this constituent because of on demand destination files. |
other |
integer |
Number of blocks skipped by the scanner on this constituent for all other reasons. |
remote_cache |
integer |
Number of blocks skipped by the scanner on this constituent because of remote caches. |
too_large |
integer |
Number of blocks skipped by the scanner on this constituent because of files that are larger than rebalancing.max_file_size. |
too_small |
integer |
Number of blocks skipped by the scanner on this constituent because of files that are smaller than rebalancing.min_file_size. |
write_fenced |
integer |
Number of blocks skipped by the scanner on this constituent because of files fenced for write operations. |
files_skipped
Number of files skipped by the scanner on this constituent due to various reasons.
efficiency_blocks |
integer |
Number of files skipped by the scanner on this constituent because storage efficiency lost, in blocks, would be too high. |
integer |
Number of files skipped by the scanner on this constituent because storage efficiency lost, in percent, would be too high. |
fast_truncate |
integer |
Number of files skipped by the scanner on this constituent because fast truncate is currently running on the file. |
footprint_invalid |
integer |
Number of files skipped by the scanner on this constituent because their space footprints are invalid. |
in_snapshot |
integer |
Number of files skipped by the scanner on this constituent because they are trapped in snapshots. |
incompatible |
integer |
Number of files skipped by the scanner on this constituent because they are incompatible. |
metadata |
integer |
Number of files skipped by the scanner on this constituent because they metadata files. |
integer |
Number of files skipped by the scanner on this constituent because they are on demand destinations. |
other |
integer |
Number of files skipped by the scanner on this constituent for all other reasons. |
remote_cache |
integer |
Number of files skipped by the scanner on this constituent because they are remote caches. |
too_large |
integer |
Number of files skipped by the scanner on this constituent because they are larger than rebalancing.max_file_size. |
too_small |
integer |
Number of files skipped by the scanner on this constituent because they are smaller than rebalancing.min_file_size. |
write_fenced |
integer |
Number of files skipped by the scanner on this constituent because they are fenced for write operations. |
scanner
Properties related to determining which files to move and where to move them to.
blocks_scanned |
integer |
Number of blocks scanned on this constituent. |
blocks_skipped |
Number of blocks skipped by the scanner on this constituent due to various reasons. |
files_scanned |
integer |
Number of files scanned on this constituent. |
files_skipped |
Number of files skipped by the scanner on this constituent due to various reasons. |
engine
Each constituent has one rebalancing engine that co-ordinates scanning constituents for free space and files to move, as well as moving files between constituents. The engine properties must be explicitly requested, are meant for helping diagnose why the volume rebalancer is making decisions.
movement |
Properties on this constituent related to file movement. |
scanner |
Properties related to determining which files to move and where to move them to. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
rebalancing
Configuration and runtime properties involving non-disruptive volume capacity rebalancing for a FlexGroup volume.
_links |
data_moved |
integer |
The amount of data that has been moved in or out of a constituent. A positive value represents data moving into the constituent while a negative value is data moving out of the constituent. |
engine |
Each constituent has one rebalancing engine that co-ordinates scanning constituents for free space and files to move, as well as moving files between constituents. The engine properties must be explicitly requested, are meant for helping diagnose why the volume rebalancer is making decisions. |
exclude_snapshots |
boolean |
Specifies whether or not to exclude files that are stuck in snapshots during rebalancing operation. When a new capacity rebalancing operation is started on a FlexGroup volume, it uses the current "exclude_snapshots" value. Once the operation is started, any changes to the "exclude_snapshots" value do not affect the currently running capacity rebalancing operation. Only future capacity rebalancing operations will use the new "exclude_snapshots" value. |
imbalance_percent |
integer |
Represents the percentage the volume is out of balance. |
imbalance_size |
integer |
Represents how much the volume is out of balance, in bytes. |
max_constituent_imbalance_percent |
integer |
Absolute percentage of the constituent that is most out of balance. This value will update every 30 seconds when rebalancing is not active and every 10 seconds when rebalancing is active. |
max_file_moves |
integer |
Specifies the maximum number of concurrent file moves in a volume capacity rebalancing operation on a constituent of the FlexGroup volume. When a new capacity rebalancing operation is started on a FlexGroup volume, it uses the current "max_file_moves" value. Once the operation is started, any changes to the "max_file_moves" value do not affect the currently running capacity rebalancing operation. Only future capacity rebalancing operations will use the new "max_file_moves" value. |
max_runtime |
string |
This optional field specifies the maximum time a capacity rebalancing operation runs for. Once the maximum runtime has passed, the capacity rebalancing operation stops. If it is not set, the default value is 6 hours. This value cannot be updated while a capacity rebalancing operation is running. The maximum runtime can be in years, months, days, hours, and minutes. A period specified for years, months, and days is represented in the ISO-8601 format as "P |
max_threshold |
integer |
Specifies the maximum imbalance percentage for FlexGroup volume constituents. When a constituent's imbalance percentage is larger than this value, files are moved from the constituent. When a new capacity rebalancing operation is started on a FlexGroup volume, it uses the current "max_threshold" value. Once the operation is started, any changes to the "max_threshold" value do not affect the currently running capacity rebalancing operation. Only future capacity rebalancing operations will use the new "max_threshold" value. |
min_file_size |
integer |
Specifies the minimum file size to consider for a volume capacity rebalancing operation. When a new capacity rebalancing operation is started on a FlexGroup volume, it uses the current "min_file_size" value. Once the operation is started, any changes to the "min_file_size" value do not affect the currently running capacity rebalancing operation. Only future capacity rebalancing operations will use the new "min_file_size" value. The value must be a multiple of 4KB. If it is not set, the default value is 100MB. Setting "min-file-size" to less than the default value leads to more files being moved. Moved files use granular data, which may impact read/write I/O performance. |
min_threshold |
integer |
Specifies the minimum imbalance percentage for FlexGroup volume constituents. When a constituent's imbalance percentage is smaller than this value, files are not moved from the constituent. When a new capacity rebalancing operation is started on a FlexGroup volume, it will use the current "min_threshold" value. Once the operation is started, any changes to the "min_threshold" value do not affect the currently running capacity rebalancing operation. Only future capacity rebalancing operations will use the new "min_threshold" value. |
notices |
array[error] |
Capacity rebalancing notice messages. |
runtime |
string |
Duration the capacity rebalancing operation has been running. |
start_time |
string |
Time when the current capacity rebalancing operation started, or when a future scheduled rebalancing operation begins. |
state |
string |
State of the volume capacity rebalancing operation. PATCH the state to "starting" to trigger the capacity rebalance operation, and include start_time to schedule rebalancing. PATCH the state to "stopping" to stop the capacity rebalance operation, or cancel a scheduled rebalancing operation. PATCH without the state with a valid start_time to modify the start_time of an existing scheduled rebalance operation. While a FlexGroup volume is rebalancing, every constituent will have a rebalancing engine that can either be scanning the filesystem for space usage and files to move, actively moving files or temporarily doing neither. If one or more constituents has a state of "rebalancing_source" or "rebalancing_dest", then files are being moved to rebalance the FlexGroup volume. If no files are being moved, more information about what the rebalancing engine is doing for each constituent is available using the "rebalancing.engine" property. The following values apply to FlexGroup volumes. not_running ‐ capacity rebalancing is not running on the volume. starting ‐ used in a PATCH operation to start a capacity rebalancing operation. rebalancing ‐ capacity rebalancing is running on the volume. paused ‐ volume capacity rebalancing is paused on the volume. stopping ‐ used in a PATCH operation to stop a capacity rebalancing operation. unknown ‐ the system was unable to determine the rebalancing state for the volume. The following values apply to FlexGroup volume constituents. idle ‐ capacity rebalancing is running on the constituent, however, no active scanning or file movement is currently occurring. scanning ‐ the constituent's file system is being scanned to find files to move and determine free space. rebalancing_source ‐ a file is being moved off of the constituent. rebalancing_dest ‐ a file is being moved to the constituent. not_running ‐ capacity rebalancing is not running on the constituent. unknown ‐ the system was unable to determine the rebalancing state for the constituent. |
stop_time |
string |
Time when the capacity rebalancing operation stopped. |
target_used |
integer |
Represents the ideal used size of each constituent. Calculated by dividing the total FlexGroup volume used size by the number of constituents. |
used_for_imbalance |
integer |
Represents the used size of each constituent, as determined by the rebalancing engine. Calculated by subtracting the size used by snapshots, the size of files pending deletion and the size of filesystem metadata from the volume used size. |
retention
default |
string |
Specifies the default retention period that is applied to files while committing them to the WORM state without an associated retention period. The retention value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A duration specified for years, months, and days is represented in the ISO-8601 format as "P |
maximum |
string |
Specifies the maximum allowed retention period for files committed to the WORM state on the volume. The retention value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A duration specified for years, months, and days is represented in the ISO-8601 format as "P |
minimum |
string |
Specifies the minimum allowed retention period for files committed to the WORM state on the volume. The retention value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A duration specified for years, month,s and days is represented in the ISO-8601 format as "P |
snaplock
append_mode_enabled |
boolean |
Specifies if the volume append mode is enabled or disabled. When it is enabled, all the files created with write permissions on the volume are, by default, WORM appendable files. The user can append the data to a WORM appendable file but cannot modify the existing contents of the file nor delete the file until it expires. |
autocommit_period |
string |
Specifies the autocommit period for SnapLock volume. All files which are not modified for a period greater than the autocommit period of the volume are committed to the WORM state. The autocommit period value represents a duration and must be specified in the ISO-8601 duration format. The autocommit period can be in years, months, days, hours, and minutes. A period specified for years, months, and days is represented in the ISO-8601 format as "P |
compliance_clock_time |
string |
This is the volume compliance clock time which is used to manage the SnapLock objects in the volume. |
expiry_time |
string |
Expiry time of the volume. For volumes with an infinite, indefinite or unspecified SnapLock expiry time, "9999-12-31T23:59:59" is used to denote the time. |
is_audit_log |
boolean |
Indicates if this volume has been configured as SnapLock audit log volume for the SVM . |
litigation_count |
integer |
Litigation count indicates the number of active legal-holds on the volume. |
privileged_delete |
string |
Specifies the privileged-delete attribute of a SnapLock volume. On a SnapLock Enterprise (SLE) volume, a designated privileged user can selectively delete files irrespective of the retention time of the file. SLE volumes can have privileged delete as disabled, enabled or permanently_disabled and for SnapLock Compliance (SLC) volumes it is always permanently_disabled. |
retention |
type |
string |
The SnapLock type of the volume. compliance ‐ A SnapLock Compliance(SLC) volume provides the highest level of WORM protection and an administrator cannot destroy a SLC volume if it contains unexpired WORM files. enterprise ‐ An administrator can delete a SnapLock Enterprise(SLE) volume. non_snaplock ‐ Indicates the volume is non-snaplock. |
unspecified_retention_file_count |
integer |
Indicates the number of files with an unspecified retention time in the volume. |
destinations
is_cloud |
boolean |
Specifies whether a volume is a SnapMirror source volume, using SnapMirror to protect its data to a cloud destination. |
is_ontap |
boolean |
Specifies whether a volume is a SnapMirror source volume, using SnapMirror to protect its data to an ONTAP destination.
snapmirror
Specifies attributes for SnapMirror protection.
destinations |
is_protected |
boolean |
Specifies whether a volume is a SnapMirror source volume, using SnapMirror to protect its data. |
snapshot_policy
This is a reference to the snapshot policy.
_links |
name |
string |
uuid |
string |
logical_space
available |
integer |
enforcement |
boolean |
reporting |
boolean |
used |
integer |
SUM of (physical-used, shared_refs, compression_saved_in_plane0, vbn_zero, future_blk_cnt), in bytes. |
used_by_afs |
integer |
used_by_snapshots |
integer |
Size that is logically used across all snapshots in the volume, in bytes. |
used_percent |
integer |
SUM of (physical-used, shared_refs, compression_saved_in_plane0, vbn_zero, future_blk_cnt), as a percentage. |
autodelete
commitment |
string |
By default, snapshot autodelete does not delete snapshots locked by Snapmirror, clones of a volume, a LUN, an NVMe namespace, or a file. Deletion of snapshots locked by these applications is specified using this option. The default value is try. |
defer_delete |
string |
Allows the user to inform snapshot autodelete to defer the deletion of a specified snapshot until the end. The default value is user_created. |
delete_order |
string |
Specifies the order in which snapshot autodelete occurs. Ordering is done using the date and time the snapshot is created. The default value is oldest_first. |
enabled |
boolean |
prefix |
string |
Specifies the prefix of the snapshot which if matched, is deleted last. Used with autodelete_defer_delete when used with a prefix value. |
target_free_space |
integer |
Snapshots are deleted, one at a time, until the used volume space reaches the value specified. The default is 20% free space or 80% utilized. |
trigger |
string |
Specifies when the system should trigger an autodelete of snapshots. When set to volume, autodelete is triggered based on volume fullness. When set to snap_reserve, autodelete is triggered based on snapshot reserve fullness. The default value is volume. |
snapshot
autodelete |
boolean |
Specifies whether snapshot autodelete is currently enabled on this volume. This field will no longer be supported in a future release. Use autodelete.enabled instead. |
autodelete_trigger |
string |
Specifies when the system should trigger an autodelete of snapshots. When set to volume, autodelete is triggered based on volume fullness. When set to snap_reserve, autodelete is triggered based on snapshot reserve fullness. The default value is volume. This field will no longer be supported in a future release. Use autodelete.trigger instead. |
reserve_available |
integer |
Size available for snapshots within the snapshot reserve, in bytes. |
reserve_percent |
integer |
reserve_size |
integer |
Size in the volume that has been set aside as a reserve for snapshot usage, in bytes. |
space_used_percent |
integer |
Percentage of snapshot reserve size that has been used. |
used |
integer |
space
afs_total |
integer |
auto_adaptive_compression_footprint_data_reduction |
integer |
Savings achieved due to Auto Adaptive Compression, in bytes. |
available |
integer |
available_percent |
integer |
block_storage_inactive_user_data |
integer |
block_storage_inactive_user_data_percent |
integer |
Percentage of size that is physically used in the performance tier of the volume. |
capacity_tier_footprint |
integer |
capacity_tier_footprint_data_reduction |
integer |
Savings achieved in the space used by the capacity tier for this volume in the FabricPool aggregate, in bytes. |
compaction_footprint_data_reduction |
integer |
Savings achieved due to Data Compaction, in bytes. |
cross_volume_dedupe_metafiles_footprint |
integer |
Cross volume deduplication metadata footprint, in bytes. |
cross_volume_dedupe_metafiles_temporary_footprint |
integer |
Cross volume temporary deduplication metadata footprint, in bytes. |
integer |
Deduplication metadata footprint, in bytes. |
integer |
Temporary deduplication metadata footprint, in bytes. |
delayed_free_footprint |
integer |
Delayed free blocks footprint, in bytes. |
effective_total_footprint |
integer |
Volume footprint after efficiency savings, in bytes. effective total footprint represents total footprint after deducting auto adaptive compression and compaction savings. effective-footprint includes aggregate metadata used by volume. |
expected_available |
integer |
Size that should be available for the volume, irrespective of available size in the aggregate, in bytes. |
file_operation_metadata |
integer |
File operation metadata footprint, in bytes. |
filesystem_size |
integer |
Total usable size of the volume, in bytes. |
filesystem_size_fixed |
boolean |
Specifies whether the file system is to remain of the same size when set to true or to grow when set to false. This option is automatically set to true when a volume becomes SnapMirrored. |
footprint |
integer |
fractional_reserve |
integer |
Used to change the amount of space reserved for overwrites of reserved objects in a volume. |
full_threshold_percent |
integer |
Volume full threshold percentage at which EMS warnings can be sent. |
is_used_stale |
boolean |
Specifies if the virtual space used is stale. |
boolean |
Indicates if the support for large FlexVol volumes and large files is enabled on this volume. When configured to true, FlexVol volume size can reach up to 300TB and single file size can reach 128TB. |
integer |
logical_space |
max_size |
string |
Indicates the maximum size supported for the FlexVol volume or for each constituent of the FlexGroup volume. |
metadata |
integer |
nearly_full_threshold_percent |
integer |
Volume nearly full threshold percentage at which EMS warnings can be sent. |
over_provisioned |
integer |
overwrite_reserve |
integer |
Reserved space for overwrites, in bytes. |
overwrite_reserve_used |
integer |
Overwrite logical reserve space used, in bytes. |
percent_used |
integer |
Percentage of the volume size that is used. |
integer |
physical_used |
integer |
Size that is physically used in the volume, in bytes. Physical used is effective total footprint which is equivalent to total footprint after deducting auto adaptive compression and compaction savings. Physical-used also includes aggregate metadata used by volume. |
physical_used_percent |
integer |
Size that is physically used in the volume, as a percentage. |
size |
integer |
size_available_for_snapshots |
integer |
Available space for snapshots from snap-reserve, in bytes. |
snapmirror_destination_footprint |
integer |
SnapMirror destination footprint, in bytes. |
snapshot |
snapshot_reserve_unusable |
integer |
Snapshot reserve that is not available for snapshot creation, in bytes. |
snapshot_spill |
integer |
Space used by the snapshot copies beyond the snap-reserve, in bytes. |
total_footprint |
integer |
total_metadata |
integer |
integer |
used |
integer |
used_by_afs |
integer |
user_data |
integer |
User data, in bytes. |
volume_guarantee_footprint |
integer |
Space reserved for future writes in the volume, in bytes. |
access
Raw count and latency data for access operations.
count |
integer |
Number of operations of the given type performed on this volume. |
total_time |
integer |
The raw data component latency in microseconds measured within ONTAP for all operations of the given type.
audit
Raw count and latency data for audit operations. These statistics are only applicable for CIFS protocol operations.
count |
integer |
total_time |
integer |
dir
Raw count and latency data for directory-create operations.
count |
integer |
total_time |
integer |
file
Raw count and latency data for file-create operations.
count |
integer |
total_time |
integer |
other
Raw count and latency data for create operations on objects other than files, directories and symlinks.
count |
integer |
total_time |
integer |
symlink
Raw count and latency data for symlink-create operations.
count |
integer |
total_time |
integer |
create
Raw count and latency data for create operations.
dir |
Raw count and latency data for directory-create operations. |
file |
Raw count and latency data for file-create operations. |
other |
Raw count and latency data for create operations on objects other than files, directories and symlinks. |
symlink |
Raw count and latency data for symlink-create operations. |
getattr
Raw count and latency data for getattr operations.
count |
integer |
total_time |
integer |
link
Raw count and latency data for link operations.
count |
integer |
total_time |
integer |
lock
Raw count and latency data for lock operations.
count |
integer |
total_time |
integer |
lookup
Raw count and latency data for lookup operations.
count |
integer |
total_time |
integer |
open
Raw count and latency data for open operations.
count |
integer |
total_time |
integer |
read
Raw count and latency data for read operations, including histograms categorizing operations by size and latency.
count |
integer |
total_time |
integer |
volume_protocol_latency_histogram_counts |
array[integer] |
volume_protocol_latency_histogram_labels |
array[string] |
Labels for the latency histogram, ranging from <2us to >20s. |
volume_protocol_size_histogram_counts |
array[integer] |
volume_protocol_size_histogram_labels |
array[string] |
Labels for the size histogram, ranging from <4KB to >1024KB. |
readdir
Raw count and latency data for readdir operations.
count |
integer |
total_time |
integer |
readlink
Raw count and latency data for readlink operations.
count |
integer |
total_time |
integer |
rename
Raw count and latency data for rename operations.
count |
integer |
total_time |
integer |
setattr
Raw count and latency data for setattr operations.
count |
integer |
total_time |
integer |
unlink
Raw count and latency data for unlink operations.
count |
integer |
total_time |
integer |
watch
Raw count and latency data for watch operations. These statistics are only applicable for CIFS protocol operations.
count |
integer |
total_time |
integer |
write
Raw count and latency data for write operations, including histograms categorizing operations by size and latency.
count |
integer |
total_time |
integer |
array[integer] |
array[string] |
array[integer] |
array[string] |
cifs_ops_raw
Raw data component performance values for CIFS operations on this volume, including number of operations and raw latency, in microseconds for each operation. The values are cumulative and increase while the volume is online.
access |
Raw count and latency data for access operations. |
audit |
Raw count and latency data for audit operations. These statistics are only applicable for CIFS protocol operations. |
create |
Raw count and latency data for create operations. |
getattr |
Raw count and latency data for getattr operations. |
link |
Raw count and latency data for link operations. |
lock |
Raw count and latency data for lock operations. |
lookup |
Raw count and latency data for lookup operations. |
open |
Raw count and latency data for open operations. |
read |
Raw count and latency data for read operations, including histograms categorizing operations by size and latency. |
readdir |
Raw count and latency data for readdir operations. |
readlink |
Raw count and latency data for readlink operations. |
rename |
Raw count and latency data for rename operations. |
setattr |
Raw count and latency data for setattr operations. |
unlink |
Raw count and latency data for unlink operations. |
watch |
Raw count and latency data for watch operations. These statistics are only applicable for CIFS protocol operations. |
write |
Raw count and latency data for write operations, including histograms categorizing operations by size and latency. |
iops_raw
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
latency_raw
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
cloud
These are raw performance numbers (IOPS and latency) for the cloud store. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster. These numbers are relevant only for volumes hosted on FabricPools.
iops_raw |
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time. |
latency_raw |
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation. |
status |
string |
timestamp |
string |
flexcache_raw
Performance numbers for FlexCache used to measure cache effectiveness.
cache_miss_blocks |
integer |
Blocks retrieved from origin in case of a cache miss. This can be divided by the raw client_requested_blocks and multiplied by 100 to calculate the cache miss percentage. |
client_requested_blocks |
integer |
Total blocks requested by the client. |
status |
string |
timestamp |
string |
nfs_ops_raw
Raw data component performance values for NFS operations on this volume, including number of operations and raw latency, in microseconds for each operation. The values are cumulative and increase while the volume is online.
access |
audit |
create |
getattr |
link |
lock |
lookup |
open |
read |
readdir |
readlink |
rename |
setattr |
unlink |
watch |
write |
throughput_raw
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
statistics
These are raw performance numbers, such as IOPS latency and throughput. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
cifs_ops_raw |
Raw data component performance values for CIFS operations on this volume, including number of operations and raw latency, in microseconds for each operation. The values are cumulative and increase while the volume is online. |
cloud |
These are raw performance numbers (IOPS and latency) for the cloud store. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster. These numbers are relevant only for volumes hosted on FabricPools. |
flexcache_raw |
Performance numbers for FlexCache used to measure cache effectiveness. |
iops_raw |
latency_raw |
nfs_ops_raw |
Raw data component performance values for NFS operations on this volume, including number of operations and raw latency, in microseconds for each operation. The values are cumulative and increase while the volume is online. |
status |
string |
throughput_raw |
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
svm
SVM containing the volume. Required on POST.
_links |
name |
string |
uuid |
string |
tiering
min_cooling_days |
integer |
This parameter specifies the minimum number of days that user data blocks of the volume must be cooled before they can be considered cold and tiered out to the cloud tier. Note that this parameter is only used for tiering purposes and does not affect the reporting of inactive data. The value specified should be greater than the frequency with which applications in the volume shift between different sets of data. This parameter cannot be set when volume tiering policy is either "none" or "all". The default value of this parameter depends on the volume's tiering policy. See the tiering policy section of this documentation for corresponding default values. If the tiering policy on the volume gets changed, then this parameter will be reset to the default value corresponding to the new tiering policy. |
object_tags |
array[string] |
This parameter specifies tags of a volume for objects stored on a FabricPool-enabled aggregate. Each tag is a key,value pair and should be in the format "key=value". |
policy |
string |
Policy that determines whether the user data blocks of a volume in a FabricPool will be tiered to the cloud store when they become cold. FabricPool combines flash (performance tier) with a cloud store into a single aggregate. Temperature of a volume block increases if it is accessed frequently and decreases when it is not. Valid in POST or PATCH. all ‐ This policy allows tiering of both snapshots and active file system user data to the cloud store as soon as possible by ignoring the temperature on the volume blocks. auto ‐ This policy allows tiering of both snapshot and active file system user data to the cloud store none ‐ Volume blocks will not be tiered to the cloud store. snapshot_only ‐ This policy allows tiering of only the volume snapshots not associated with the active file system. The default tiering policy is "snapshot-only" for a FlexVol volume and "none" for a FlexGroup volume. The default minimum cooling period for the "snapshot-only" tiering policy is 2 days and for the "auto" tiering policy is 31 days. |
volume
_links |
_tags |
array[string] |
Tags are an optional way to track the uses of a resource. Tag values must be formatted as key:value strings. |
access_time_enabled |
boolean |
Indicates whether or not access time updates are enabled on the volume. |
activity_tracking |
aggregates |
array[aggregates] |
Aggregate(s) hosting the volume. Optional. |
aggressive_readahead_mode |
string |
Specifies the
analytics |
anti_ransomware |
Anti-ransomware related information of the volume. |
application |
asynchronous_directory_delete |
Configuration for asynchronous directory delete from the client. This is only supported on Flexible volumes and FlexGroup volumes. |
autosize |
clone |
cloud_retrieval_policy |
string |
This parameter specifies the cloud retrieval policy for the volume. This policy determines which tiered out blocks to retrieve from the capacity tier to the performance tier. The available cloud retrieval policies are "default" policy retrieves tiered data based on the underlying tiering policy. If the tiering policy is 'auto', tiered data is retrieved only for random client driven data reads. If the tiering policy is 'none' or 'snapshot_only', tiered data is retrieved for random and sequential client driven data reads. If the tiering policy is 'all', tiered data is not retrieved. "on_read" policy retrieves tiered data for all client driven data reads. "never" policy never retrieves tiered data. "promote" policy retrieves all eligible tiered data automatically during the next scheduled scan. It is only supported when the tiering policy is 'none' or 'snapshot_only'. If the tiering policy is 'snapshot_only', the only data brought back is the data in the AFS. Data that is only in a snapshot copy stays in the cloud and if tiering policy is 'none' then all data is retrieved. |
cloud_write_enabled |
boolean |
Indicates whether or not cloud writes are enabled on the volume. NFS writes to this volume are sent to the cloud directly instead of the local performance tier. This feature is only available on volumes in FabricPools. |
comment |
string |
A comment for the volume. Valid in POST or PATCH. |
consistency_group |
Consistency group the volume is part of. |
constituents |
array[constituents] |
FlexGroup volume constituents. FlexGroup volume constituents can be retrieved more efficiently by specifying "is_constituent=true" or "is_constituent=true&flexgroup.uuid= |
convert_unicode |
boolean |
Specifies whether directory Unicode format conversion is enabled when directories are accessed by NFS clients. |
create_time |
string |
Creation time of the volume. This field is generated when the volume is created. |
efficiency |
encryption |
error_state |
files |
flash_pool |
flexcache_endpoint_type |
string |
FlexCache endpoint type. none ‐ The volume is neither a FlexCache nor origin of any FlexCache. cache ‐ The volume is a FlexCache volume. origin ‐ The volume is origin of a FlexCache volume. |
flexgroup |
granular_data |
boolean |
State of granular data on the volume. This setting is
granular_data_mode |
string |
Mode of granular data on the volume. This setting defaults to
guarantee |
has_dir_index_public |
boolean |
Specifies whether the volume has directories with public index files. |
has_large_dir |
boolean |
Specifies whether the volume has directories bigger than 4GB. |
is_dir_index_transfer_enabled |
boolean |
When set to true, this field enables support for directory index transfer. |
is_large_dir_enabled |
boolean |
When set to true, this field enables the large directory feature on a volume. |
is_object_store |
boolean |
Specifies whether the volume is provisioned for an object store server. |
is_s3_arbitrary_part_size_enabled |
boolean |
Specifies that the volume should allow Amazon S3 multipart uploads with arbitrary part lengths. This is only supported for FlexGroup volumes with |
is_svm_root |
boolean |
Specifies whether the volume is a root volume of the SVM it belongs to. |
language |
string |
Language encoding setting for volume. If no language is specified, the volume inherits its SVM language encoding setting. |
max_dir_size |
integer |
Maximum directory size. This value sets maximum size, in bytes, to which a directory can grow. The default maximum directory size for FlexVol volumes is model-dependent, and optimized for the size of system memory. Before increasing the maximum directory size, involve technical support. |
metric |
Performance numbers, such as IOPS, latency and throughput. |
movement |
Volume movement. All attributes are modify, that is, not writable through POST. Set PATCH state to destination_aggregate to initiate a volume move operation. |
msid |
integer |
The volume's Master Set ID. |
name |
string |
Volume name. The name of volume must start with an alphabetic character (a to z or A to Z) or an underscore (_). The name must be 197 or fewer characters in length for FlexGroup volumes, and 203 or fewer characters in length for all other types of volumes. Volume names must be unique within an SVM. Required on POST. |
nas |
nodes |
array[nodes] |
List of the nodes hosting the volume. |
qos |
QoS information |
queue_for_encryption |
boolean |
Specifies whether the volume is queued for encryption. |
quota |
Quotas track the space or file usage of a user, group, or qtree in a FlexVol volume or a FlexGroup volume. |
rebalancing |
Configuration and runtime properties involving non-disruptive volume capacity rebalancing for a FlexGroup volume. |
scheduled_snapshot_naming_scheme |
string |
Naming Scheme for automatic snapshots:
size |
integer |
Physical size of the volume, in bytes. The minimum size for a FlexVol volume is 20MB and the minimum size for a FlexGroup volume is 200MB per constituent. The recommended size for a FlexGroup volume is a minimum of 100GB per constituent. For all volumes, the default size is equal to the minimum size. |
sizing_method |
string |
When expanding a FlexGroup volume, this specifies whether to add new constituents, or to resize the current constituents. |
smas_protection |
string |
Specifies the volume should be protected by SnapMirror Active Sync NAS or not |
snaplock |
snapmirror |
Specifies attributes for SnapMirror protection. |
snapshot_count |
integer |
Number of snapshots in the volume. |
snapshot_directory_access_enabled |
boolean |
This field, if true, enables the visible ".snapshot" directory from the client. The ".snapshot" directory will be available in every directory on the volume. |
snapshot_locking_enabled |
boolean |
Specifies whether or not snapshot copy locking is enabled on the volume. |
snapshot_policy |
This is a reference to the snapshot policy. |
space |
state |
string |
Volume state. Client access is supported only when volume is online and junctioned. Taking volume to offline or restricted state removes its junction path and blocks client access. When volume is in restricted state some operations like parity reconstruction and iron on commit are allowed. The 'mixed' state applies to FlexGroup volumes only and cannot be specified as a target state. An 'error' state implies that the volume is not in a state to serve data. |
statistics |
These are raw performance numbers, such as IOPS latency and throughput. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster. |
status |
array[string] |
Describes the current status of a volume. |
style |
string |
The style of the volume. If "style" is not specified, the volume type is determined based on the specified aggregates. Specifying a single aggregate, without "constituents_per_aggregate", creates a flexible volume. Specifying multiple aggregates, or a single aggregate with "constituents_per_aggregate", creates a FlexGroup volume. When the UDO License is installed, and no aggregates are specified, the system automatically provisions a FlexGroup volume on system selected aggregates. Specifying a volume "style" creates a volume of that type. For example, if the style is "flexvol", you must specify a single aggregate. If the style is "flexgroup", the system either uses the specified aggregates or automatically provisions aggregates if there are no specified aggregates. The style "flexgroup_constituent" is not supported when creating a volume. flexvol ‐ flexible volumes and FlexClone volumes flexgroup ‐ FlexGroup volumes flexgroup_constituent ‐ FlexGroup volume constituents. |
svm |
SVM containing the volume. Required on POST. |
svm_dr_protection |
string |
Specifies the volume should be protected by Vserver level SnapMirror or not |
tiering |
type |
string |
Type of the volume.
rw ‐ read-write volume.
dp ‐ data-protection volume.
ls ‐ load-sharing |
uuid |
string |
validate_only |
boolean |
Validate the volume move or volume conversion operations and their parameters, without actually performing the operation. |
returned_error
| Name | Type | Description |
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
