Manage FPolicy persistent store configuration
Configure FPolicy Persistent Store settings to manage event notification retention within your storage virtual machine (SVM). These endpoints help define and adjust the volume attributes for an efficient setup. Use them to create, update, retrieve, and delete FPolicy Persistent Store configurations tailored to your SVM's requirements.
Overview
The FPolicy Persistent Store feature enables the configuration of a Persistent Store. This includes:
setting up a store to retain event notifications
specifying the volume created for FPolicy Persistent Store
defining the size of the volume
defining the autosize mode for the volume.
Each SVM can only have one Persistent Store. The same Persistent Store can be used by multiple policies within the same SVM. Once a Persistent Store is created, it can be utilized in the FPolicy policy configuration for the async and non-mandatory engine.
Creating an FPolicy Persistent Store with all required parameters
# The API:
POST /protocols/fpolicy/{svm.uuid}/persistent-stores
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/fpolicy/4f643fb4-fd21-11e8-ae49-0050568e2c1e/persistent-stores?return_records=true" -H "accept: application/json" -d "{\"name\": \"ps1\", \"volume\": \"psvol\", \"size\": 1073741824, \"autosize_mode\": \"off\"}"
# The response:
"num_records": 1,
"records": [
"name": "ps1",
"volume": "psvol",
"size": 1073741824,
"autosize_mode": "off"
Creating an FPolicy Persistent Store with the minimum required fields
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/fpolicy/4f643fb4-fd21-11e8-ae49-0050568e2c1e/persistent-stores?return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{\"name\": \"ps1\", \"volume\": \"psvol\", \"size\": 1073741824 }"
# The response:
"num_records": 1,
"records": [
"name": "ps1",
"volume": "psvol",
"size": 1073741824
Retrieving an FPolicy Persistent Store configuration for a specific SVM
# The API:
GET /protocols/fpolicy/{svm.uuid}/persistent-stores
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/fpolicy/4f643fb4-fd21-11e8-ae49-0050568e2c1e/persistent-stores/?return_records=true&return_timeout=15" -H "accept: application/json"
# The response:
"records": [
"name": "ps1"
"num_records": 1
Retrieving a specific FPolicy Persistent Store configuration for a specific SVM
# The API:
GET /protocols/fpolicy/{svm.uuid}/persistent-stores/{name}
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/fpolicy/4f643fb4-fd21-11e8-ae49-0050568e2c1e/persistent-stores/persistent_fpolicy?fields=*&return_records=true&return_timeout=15" -H "accept: application/json"
# The response:
"svm": {
"uuid": "4f643fb4-fd21-11e8-ae49-0050568e2c1e"
"name": "ps1",
"volume": "psvol",
"size": 1073741824,
Updating an FPolicy Persistent Store for an SVM
# The API:
PATCH /protocols/fpolicy/{svm.uuid}/persistent-stores/{name}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/protocols/fpolicy/4f643fb4-fd21-11e8-ae49-0050568e2c1e/persistent-stores/persistent_fpolicy" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"volume\": \"psvol\" , \"size\": 1073741824}"
Deleting a specific FPolicy Persistent Store configuration for a specific SVM
# The API:
DELETE /protocols/fpolicy/{svm.uuid}/persistent-stores/{name}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/fpolicy/4f643fb4-fd21-11e8-ae49-0050568e2c1e/persistent-stores/persistent_fpolicy" -H "accept: application/json"
