REST API reference
Manage FPolicy persistent store configuration
Overview
  • The FPolicy Persistent Store feature enables the configuration of a Persistent Store. This includes:
  • setting up a store to retain event notifications
  • specifying the volume created for FPolicy Persistent Store
  • defining the size of the volume
  • defining the autosize mode for the volume.
  • Each SVM can only have one Persistent Store. The same Persistent Store can be used by multiple policies within the same SVM. Once a Persistent Store is created, it can be utilized in the FPolicy policy configuration for the async and non-mandatory engine.
Creating an FPolicy Persistent Store with all required parameters
# The API:
POST /protocols/fpolicy/{svm.uuid}/persistent-stores
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/fpolicy/4f643fb4-fd21-11e8-ae49-0050568e2c1e/persistent-stores?return_records=true" -H "accept: application/json" -d "{\"name\": \"ps1\", \"volume\": \"psvol\", \"size\": 1073741824, \"autosize_mode\": \"off\"}"
# The response:
"num_records": 1,
"records": [
    "name": "ps1",
    "volume": "psvol",
    "size": 1073741824,
    "autosize_mode": "off"
Creating an FPolicy Persistent Store with the minimum required fields
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/protocols/fpolicy/4f643fb4-fd21-11e8-ae49-0050568e2c1e/persistent-stores?return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{\"name\": \"ps1\", \"volume\": \"psvol\", \"size\": 1073741824 }"
# The response:
"num_records": 1,
"records": [
    "name": "ps1",
    "volume": "psvol",
    "size": 1073741824
Retrieving an FPolicy Persistent Store configuration for a specific SVM
# The API:
GET /protocols/fpolicy/{svm.uuid}/persistent-stores
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/fpolicy/4f643fb4-fd21-11e8-ae49-0050568e2c1e/persistent-stores/?return_records=true&return_timeout=15" -H "accept: application/json"
# The response:
"records": [
    "name": "ps1"
"num_records": 1
Retrieving a specific FPolicy Persistent Store configuration for a specific SVM
# The API:
GET /protocols/fpolicy/{svm.uuid}/persistent-stores/{name}
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/fpolicy/4f643fb4-fd21-11e8-ae49-0050568e2c1e/persistent-stores/persistent_fpolicy?fields=*&return_records=true&return_timeout=15" -H "accept: application/json"
# The response:
"svm": {
  "uuid": "4f643fb4-fd21-11e8-ae49-0050568e2c1e"
"name": "ps1",
"volume": "psvol",
"size": 1073741824,
Updating an FPolicy Persistent Store for an SVM
# The API:
PATCH /protocols/fpolicy/{svm.uuid}/persistent-stores/{name}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/protocols/fpolicy/4f643fb4-fd21-11e8-ae49-0050568e2c1e/persistent-stores/persistent_fpolicy" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"volume\": \"psvol\" , \"size\": 1073741824}"
Deleting a specific FPolicy Persistent Store configuration for a specific SVM
# The API:
DELETE /protocols/fpolicy/{svm.uuid}/persistent-stores/{name}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/fpolicy/4f643fb4-fd21-11e8-ae49-0050568e2c1e/persistent-stores/persistent_fpolicy" -H "accept: application/json"
