REST API reference
Update a port
Updates a network port to modify its configuration or manage its connectivity settings. This operation is typically used when adjusting network settings or integrating the port into different network configurations.
HTTP method and endpoint
PATCH /network/ethernet/ports/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Updates a port.
  • network port broadcast-domain add-ports
  • network port broadcast-domain remove-ports
  • network port modify
  • network port ifgrp add-port
  • network port ifgrp remove-port
  • network port reachability repair
uuid
string
path
True
Port UUID
Request Body
Name Type Description
broadcast_domain
broadcast_domain
Broadcast domain UUID along with a readable name. Either the UUID or both names may be provided on input.
discovered_devices
array[discovered_devices]
Discovered devices
enabled
boolean
flowcontrol_admin
string
Requested flow control
interface_count
integer
Number of interfaces hosted. This field is only applicable for cluster administrators. No value is returned for SVM administrators. If the node hosting a port is not healthy no value will be returned.
lag
lag
mac_address
string
mtu
integer
MTU of the port in bytes. Set by broadcast domain.
name
string
Portname, such as e0a, e1b-100 (VLAN on Ethernet), a0c (LAG/ifgrp), a0d-200 (VLAN on LAG/ifgrp), e0a.pv1 (p-VLAN, in select environments only)
pfc_queues_admin
array[integer]
List of PFC queues
rdma_protocols
array[string]
Supported RDMA offload protocols
reachability
string
Reachability status of the port. Enum value "ok" is the only acceptable value for a PATCH request to repair a port.
reachable_broadcast_domains
array[reachable_broadcast_domains]
Reachable broadcast domains.
speed
integer
Link speed in Mbps
state
string
Operational state of the port. The state is set to 'down' if the operational state of the port is down. The state is set to 'up' if the link state of the port is up and the port is healthy. The state is set to 'up' if the link state of the port is up and configured to ignore health status. The state is 'degraded' if the link state of the port is up, and the port is not healthy.
uuid
string
Port UUID
Example request
  "broadcast_domain": {
    "ipspace": {
      "name": "ipspace1"
    "name": "bd1",
  "discovered_devices": [
      "capabilities": [
        "router",
        "switch"
      "chassis_id": "string",
      "ip_addresses": [
        "192.168.100.24",
        "192.168.100.26"
      "name": "ETY-R1S4-510Q13.datacenter.example.com",
      "platform": "93180YC-EX",
      "protocol": "cdp",
      "remote_port": "FastEthernet0/12",
      "system_name": "string",
      "version": "Cisco Nexus Operating System (NX-OS) Software, Version 8.1"
  "flowcontrol_admin": "string",
  "interface_count": 0,
  "lag": {
    "active_ports": [
        "name": "e1b",
        "node": {
          "name": "node1"
    "member_ports": [
        "name": "e1b",
        "node": {
          "name": "node1"
  "mac_address": "01:02:03:04:05:06",
  "mtu": 1500,
  "name": "e1b",
  "pfc_queues_admin": [
    "integer"
  "rdma_protocols": [
    "roce"
  "reachability": "ok",
  "reachable_broadcast_domains": [
      "ipspace": {
        "name": "ipspace1"
      "name": "bd1",
  "speed": 1000,
  "state": "string",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1376361
Port is already a member of a LAG.
1376369
Cannot add port to the interface group because the port hosts one or more VLANs.
1376488
Disabling the last operational cluster port on a node is not allowed.
1376492
Cannot change the MTU of a VLAN to be greater than the MTU of the port hosting it.
1377563
1377608
Port cannot be used because it is currently the home port or current port of an interface.
1966288
Disabling the cluster ports can only be done on the local node.
1967087
The specified broadcast domain UUID is not valid.
1967088
The specified broadcast domain name does not exist in the specified IPspace.
1967089
The specified broadcast domain UUID, name and IPspace name do not match.
1967094
The specified LAG member port UUID is not valid.
1967095
The specified LAG member port name and node name combination is not valid.
1967096
The specified node does not match the specified LAG member port node.
1967097
The specified LAG member ports UUID, name, and node name do not match.
1967126
A LAG requires at least one member port.
1967148
Failure to remove port from broadcast domain.
1967149
Failure to add port to broadcast domain.
1967184
The reachability parameter cannot be patched in the same request as other parameters that might affect the target port's reachability status.
1967185
The port cannot be repaired because the port is deemed as non-repairable.
1967186
Invalid value for the reachability parameter.
1967195
Missing or incomplete name retrieval for specified port UUID.
1967580
This command is not supported as the effective cluster version is earlier than 9.8.
1967582
The reachability parameter is not supported on this cluster.
53216932
Failed to determine whether newly introduced PFC flow control is supported.
53280899
Not all nodes support enabling the PFC feature.
53280900
No PFC queues specified.
53280901
Failed to modify PFC.
53280902
Cluster ports does not support PFC flow control.
string
ipspace
name
string
Name of the broadcast domain's IPspace
broadcast_domain
ipspace
ipspace
name
string
Name of the broadcast domain, scoped to its IPspace
uuid
string
discovered_devices
capabilities
array[string]
The list of the capabilities of the discovered device.
chassis_id
string
Identifier associated with this specific discovered device, useful for locating the device in a data center.
ip_addresses
array[string]
The IP addresses on the discovered device.
name
string
Name of the discovered device.
platform
string
Hardware platform of the discovered device.
protocol
string
The protocol used to identify the discovered device. This can have a value of CDP or LLDP.
remaining_hold_time
integer
The number of seconds until the discovered device entry expires and is removed.
remote_port
string
The name of the remote port on the discovered device. The format is dependent on the reporting device.
system_name
string
Additional name used to identify a specific piece of equipment.
version
string
The version of the software running on the discovered device.
node
name
string
Name of node on which the port is located.
active_ports
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
name
string
node
node
uuid
string
member_ports
name
string
node
node
uuid
string
lag
active_ports
array[active_ports]
Active ports of a LAG (ifgrp). (Some member ports may be inactive.)
member_ports
array[member_ports]
Array of ports belonging to the LAG, regardless of their state.
throughput
The rate of throughput bytes per second observed at the interface.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Performance metric for write I/O operations.
metric
The most recent sample of I/O metrics for the port.
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
status
string
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
node
name
string
uuid
string
ipspace
ipspace
name
string
uuid
string
receive_raw
Packet receive counters for the Ethernet port.
discards
integer
Total number of discarded packets.
errors
integer
Number of packet errors.
packets
integer
Total packet count.
transmit_raw
Packet transmit counters for the Ethernet port.
discards
integer
errors
integer
packets
integer
Total packet count.
device
Device-related counters for the port object. These counters are applicable at the lowest layer of the networking stack. These values can be used to calculate both transmit and receive packet and error rates by comparing two samples taken at different times and calculating the increase in counter value divided by the elapsed time between the two samples.
link_down_count_raw
integer
The number of link state changes from up to down seen on the device.
timestamp
string
The timestamp when the device specific counters were collected.
throughput_raw
Throughput bytes observed at the port object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
read
integer
total
integer
write
integer
statistics
The real time I/O statistics for the port.
status
string
throughput_raw
throughput_raw
timestamp
string
The timestamp of the throughput_raw performance data.
base_port
name
string
node
node
uuid
string
vlan
base_port
base_port
tag
integer
VLAN ID
port
broadcast_domain
broadcast_domain
discovered_devices
Discovered devices
enabled
boolean
flowcontrol_admin
string
interface_count
integer
lag
lag
mac_address
string
mtu
integer
name
string
pfc_queues_admin
array[integer]
List of PFC queues
rdma_protocols
array[string]
reachability
string
speed
integer
Link speed in Mbps
state
string
uuid
string
Port UUID
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
