Update a port
Updates a network port's configuration to adjust its settings for connectivity or operational requirements.
HTTP method and endpoint
PATCH /network/ethernet/ports/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Updates a port.
Related ONTAP commands
network port broadcast-domain add-ports -
network port broadcast-domain remove-ports -
network port modify -
network port ifgrp add-port -
network port ifgrp remove-port -
network port reachability repair
uuid |
string |
path |
True |
Port UUID |
Request Body
| Name | Type | Description |
broadcast_domain |
Broadcast domain UUID along with a readable name. Either the UUID or both names may be provided on input. |
discovered_devices |
array[discovered_devices] |
Discovered devices |
enabled |
boolean |
interface_count |
integer |
Number of interfaces hosted. This field is only applicable for cluster administrators. No value is returned for SVM administrators. If the node hosting a port is not healthy no value will be returned. |
lag |
mac_address |
string |
mtu |
integer |
MTU of the port in bytes. Set by broadcast domain. |
name |
string |
Portname, such as e0a, e1b-100 (VLAN on Ethernet), a0c (LAG/ifgrp), a0d-200 (VLAN on LAG/ifgrp), e0a.pv1 (p-VLAN, in select environments only) |
rdma_protocols |
array[string] |
Supported RDMA offload protocols |
reachability |
string |
Reachability status of the port. Enum value "ok" is the only acceptable value for a PATCH request to repair a port. |
reachable_broadcast_domains |
array[reachable_broadcast_domains] |
Reachable broadcast domains. |
speed |
integer |
Link speed in Mbps |
state |
string |
Operational state of the port. The state is set to 'down' if the operational state of the port is down. The state is set to 'up' if the link state of the port is up and the port is healthy. The state is set to 'up' if the link state of the port is up and configured to ignore health status. The state is 'degraded' if the link state of the port is up, and the port is not healthy. |
uuid |
string |
Port UUID |
Example request
"broadcast_domain": {
"ipspace": {
"name": "ipspace1"
"name": "bd1",
"discovered_devices": [
"capabilities": [
"router",
"switch"
"chassis_id": "string",
"ip_addresses": [
"192.168.100.24",
"192.168.100.26"
"name": "ETY-R1S4-510Q13.datacenter.example.com",
"platform": "93180YC-EX",
"protocol": "cdp",
"remote_port": "FastEthernet0/12",
"system_name": "string",
"version": "Cisco Nexus Operating System (NX-OS) Software, Version 8.1"
"interface_count": 0,
"lag": {
"active_ports": [
"name": "e1b",
"node": {
"name": "node1"
"member_ports": [
"name": "e1b",
"node": {
"name": "node1"
"mac_address": "01:02:03:04:05:06",
"mtu": 1500,
"name": "e1b",
"rdma_protocols": [
"roce"
"reachability": "ok",
"reachable_broadcast_domains": [
"ipspace": {
"name": "ipspace1"
"name": "bd1",
"speed": 1000,
"state": "string",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1376361 |
Port is already a member of a LAG. |
1376488 |
Disabling the last operational cluster port on a node is not allowed. |
1377563 |
1377608 |
Port cannot be used because it is currently the home port or current port of an interface. |
1966288 |
Disabling the cluster ports can only be done on the local node. |
1967087 |
The specified broadcast domain UUID is not valid. |
1967088 |
The specified broadcast domain name does not exist in the specified IPspace. |
1967089 |
The specified broadcast domain UUID, name and IPspace name do not match. |
1967094 |
The specified LAG member port UUID is not valid. |
1967095 |
The specified LAG member port name and node name combination is not valid. |
1967096 |
The specified node does not match the specified LAG member port node. |
1967097 |
The specified LAG member ports UUID, name, and node name do not match. |
1967148 |
Failure to remove port from broadcast domain. |
1967149 |
Failure to add port to broadcast domain. |
1967184 |
The reachability parameter cannot be patched in the same request as other parameters that might affect the target port's reachability status. |
1967185 |
The port cannot be repaired because the port is deemed as non-repairable. |
1967186 |
Invalid value for the reachability parameter. |
1967580 |
This command is not supported as the effective cluster version is earlier than 9.8. |
1967582 |
The reachability parameter is not supported on this cluster. |
href |
string |
_links
ipspace
name |
string |
Name of the broadcast domain's IPspace |
broadcast_domain
ipspace |
name |
string |
Name of the broadcast domain, scoped to its IPspace |
uuid |
string |
Broadcast domain UUID |
discovered_devices
capabilities |
array[string] |
The list of the capabilities of the discovered device. |
chassis_id |
string |
Identifier associated with this specific discovered device, useful for locating the device in a data center. |
ip_addresses |
array[string] |
The IP addresses on the discovered device. |
name |
string |
Name of the discovered device. |
platform |
string |
Hardware platform of the discovered device. |
protocol |
string |
The protocol used to identify the discovered device. This can have a value of CDP or LLDP. |
remaining_hold_time |
integer |
The number of seconds until the discovered device entry expires and is removed. |
remote_port |
string |
The name of the remote port on the discovered device. The format is dependent on the reporting device. |
system_name |
string |
Additional name used to identify a specific piece of equipment. |
version |
string |
The version of the software running on the discovered device. |
node
name |
string |
Name of node on which the port is located. |
active_ports
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
name |
string |
node |
uuid |
string |
member_ports
name |
string |
node |
uuid |
string |
lag
active_ports |
array[active_ports] |
Active ports of a LAG (ifgrp). (Some member ports may be inactive.) |
member_ports |
array[member_ports] |
Array of ports belonging to the LAG, regardless of their state. |
throughput
The rate of throughput bytes per second observed at the interface.
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Peformance metric for write I/O operations. |
metric
The most recent sample of I/O metrics for the port.
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
status |
string |
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the interface. |
timestamp |
string |
The timestamp of the performance data. |
node
name |
string |
uuid |
string |
ipspace |
name |
string |
uuid |
string |
receive_raw
Packet receive counters for the Ethernet port.
discards |
integer |
Total number of discarded packets. |
errors |
integer |
Number of packet errors. |
packets |
integer |
Total packet count. |
transmit_raw
Packet transmit counters for the Ethernet port.
discards |
integer |
errors |
integer |
packets |
integer |
device
Device-related counters for the port object. These counters are applicable at the lowest layer of the networking stack. These values can be used to calculate both transmit and receive packet and error rates by comparing two samples taken at different times and calculating the increase in counter value divided by the elapsed time between the two samples.
link_down_count_raw |
integer |
The number of link state changes from up to down seen on the device. |
timestamp |
string |
The timestamp when the device specific counters were collected. |
throughput_raw
Throughput bytes observed at the port object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
read |
integer |
total |
integer |
write |
integer |
statistics
The real time I/O statistics for the port.
status |
string |
throughput_raw |
Throughput bytes observed at the port object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
The timestamp of the throughput_raw performance data. |
base_port
name |
string |
node |
uuid |
string |
vlan
base_port |
Port UUID along with readable names. Either the UUID or both names may be supplied on input. |
tag |
integer |
VLAN ID |
port
broadcast_domain |
enabled |
boolean |
interface_count |
integer |
lag |
mac_address |
string |
mtu |
integer |
name |
string |
rdma_protocols |
array[string] |
reachability |
string |
speed |
integer |
state |
string |
uuid |
string |
Port UUID |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
