Update a port
PATCH /network/ethernet/ports/{uuid}
Updates a port.
Related ONTAP commands
network port broadcast-domain add-ports -
network port broadcast-domain remove-ports -
network port ifgrp modify -
network port modify -
network port vlan modify
Learn more
uuid |
string |
path |
True |
Port UUID |
Request Body
| Name | Type | Description |
_links |
broadcast_domain |
Broadcast domain UUID along with a readable name. Either the UUID or both names may be provided on input. |
enabled |
boolean |
lag |
mac_address |
string |
mtu |
integer |
MTU of the port in bytes. Set by broadcast domain. |
name |
string |
Portname, such as e0a, e1b-100 (VLAN on ethernet), a0c (LAG/ifgrp), a0d-200 (vlan on LAG/ifgrp) |
speed |
integer |
Link speed in Mbps |
state |
string |
Operational state of the port. |
uuid |
string |
Port UUID |
Example request
"href": "/api/resourcelink"
"broadcast_domain": {
"ipspace": {
"name": "ipspace1"
"name": "bd1",
"lag": {
"active_ports": [
"name": "e1b",
"node": {
"name": "node1"
"member_ports": [
"name": "e1b",
"node": {
"name": "node1"
"mac_address": "01:02:03:04:05:06",
"mtu": 1500,
"name": "e1b",
"speed": 1000,
"state": "string",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1376361 |
Port is already a member of a LAG. |
1377562 |
Port cannot be used because it is currently the home port or current port of an interface. |
1377563 |
1967087 |
The specified broadcast domain UUID is not valid. |
1967088 |
The specified broadcast domain name does not exist in the specified IPspace. |
1967089 |
The specified broadcast domain UUID, name and IPspace name do not match. |
1967094 |
The specified LAG member port UUID is not valid. |
1967095 |
The specified LAG member port name and node name combination is not valid. |
1967096 |
The specified node does not match the specified LAG member port node. |
1967097 |
The specified LAG member ports UUID, name, and node name do not match. |
1967148 |
Failure to remove port from broadcast domain. |
1967149 |
Failure to add port to broadcast domain. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
ipspace
name |
string |
Name of the broadcast domain's IPspace |
broadcast_domain
_links |
ipspace |
name |
string |
Name of the broadcast domain, scoped to its IPspace |
uuid |
string |
Broadcast domain UUID |
node
name |
string |
Name of node on which the port is located. |
active_ports
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
_links |
name |
string |
node |
uuid |
string |
member_ports
_links |
name |
string |
node |
uuid |
string |
lag
active_ports |
array[active_ports] |
Active ports of a LAG (ifgrp). (Some member ports may be inactive.) |
member_ports |
array[member_ports] |
node
_links |
name |
string |
uuid |
string |
base_port
_links |
name |
string |
node |
uuid |
string |
vlan
base_port |
Port UUID along with readable names. Either the UUID or both names may be supplied on input. |
tag |
integer |
VLAN ID |
port
_links |
broadcast_domain |
enabled |
boolean |
lag |
mac_address |
string |
mtu |
integer |
name |
string |
speed |
integer |
state |
string |
uuid |
string |
Port UUID |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
