Update an FC port
Updates an FC port to change its configuration or settings as needed.
HTTP method and endpoint
PATCH /network/fc/ports/{uuid}
Introduced in
ONTAP 9.6
Related ONTAP commands
network fcp adapter modify
Learn more
uuid |
string |
path |
True |
The unique identifier for the FC port. |
Request Body
| Name | Type | Description |
description |
string |
A description of the FC port. |
enabled |
boolean |
The administrative state of the FC port. If this property is set to false, all FC connectivity to FC interfaces are blocked. Optional in PATCH. |
fabric |
Properties of the fabric to which the FC port is attached. |
interface_count |
integer |
The number of FC interfaces currently provisioned on this port. This property is not supported in an SVM context. |
name |
string |
The FC port name. |
node |
physical_protocol |
string |
The physical network protocol of the FC port. |
speed |
The physical device speed related properties of the FC port. |
state |
string |
The operational state of the FC port.
supported_protocols |
array[string] |
The network protocols supported by the FC port. |
transceiver |
Properties of the transceiver connected to the FC port. |
uuid |
string |
The unique identifier of the FC port. |
wwnn |
string |
The base world wide node name (WWNN) for the FC port. |
wwpn |
string |
The base world wide port name (WWPN) for the FC port. |
Example request
"description": "Fibre Channel Target Adapter 0a (ACME Fibre Channel Adapter, rev. 1.0.0, 8G)",
"fabric": {
"connected_speed": 16,
"name": "string",
"port_address": "52100A",
"switch_port": "ssan-g620-03:33"
"interface_count": 0,
"name": "0a",
"node": {
"name": "node1",
"physical_protocol": "string",
"speed": {
"configured": "auto",
"maximum": "32"
"state": "online",
"supported_protocols": [
"string"
"transceiver": {
"capabilities": [
16
"form_factor": "string",
"manufacturer": "Acme, Inc.",
"part_number": "string"
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
"wwnn": "20:00:00:50:56:b4:13:a8",
"wwpn": "20:00:00:50:56:b4:13:a8"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5374085 |
The node where the Fibre Channel port is located is offline. |
5374087 |
The Fibre Channel port has active Fibre Channel interfaces and cannot be disabled. |
href |
string |
_links
fabric
connected |
boolean |
Reports if the physical port has established a connection with the FC fabric. |
connected_speed |
integer |
The negotiated data rate between the target FC port and the fabric in gigabits per second. |
name |
string |
The name of the fabric to which the port is connected. This is only available when the FC port is connected to a fabric. There is an added computational cost to retrieving this property's value. It is not populated for a GET request unless it is explicitly requested using the |
port_address |
string |
The FC port address of the host bus adapter (HBA) physical port. Each FC port in an FC switched fabric has its own unique FC port address for routing purposes. The FC port address is assigned by a switch in the fabric when that port logs in to the fabric. This property refers to the FC port address given to the physical host bus adapter (HBA) port when the port performs a fabric login (FLOGI). This is useful for obtaining statistics and diagnostic information from FC switches. This is a six-digit hexadecimal encoded numeric value. |
switch_port |
string |
The switch port to which the FC port is connected. |
iops
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Performance metric for write I/O operations. |
latency
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput
read |
integer |
total |
integer |
write |
integer |
metric
Performance numbers, such as IOPS latency and throughput
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
iops |
The rate of I/O operations observed at the storage object. |
latency |
The round trip latency in microseconds observed at the storage object. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the storage object. |
timestamp |
string |
The timestamp of the performance data. |
node
name |
string |
uuid |
string |
speed
configured |
string |
The configured speed of the FC port in gigabits per second. |
maximum |
string |
The maximum speed supported by the FC port in gigabits per second. |
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read |
integer |
total |
integer |
write |
integer |
statistics
These are raw performance numbers, such as IOPS latency and throughput. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
iops_raw |
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time. |
latency_raw |
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput_raw |
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
transceiver
capabilities |
array[integer] |
The speeds of which the transceiver is capable in gigabits per second. |
form_factor |
string |
The form factor of the transceiver. Possible values are:
manufacturer |
string |
The manufacturer of the transceiver. |
part_number |
string |
The part number of the transceiver. |
fc_port
A Fibre Channel (FC) port is the physical port of an FC adapter on an ONTAP cluster node that can be connected to an FC network to provide FC network connectivity. An FC port defines the location of an FC interface within the ONTAP cluster.
description |
string |
enabled |
boolean |
fabric |
interface_count |
integer |
name |
string |
The FC port name. |
node |
physical_protocol |
string |
speed |
state |
string |
array[string] |
transceiver |
uuid |
string |
wwnn |
string |
wwpn |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
