REST API reference
Update an FC port
Updates an FC port to change its configuration or settings as needed.
HTTP method and endpoint
PATCH /network/fc/ports/{uuid}
Introduced in
ONTAP 9.6
  • network fcp adapter modify
uuid
string
path
True
The unique identifier for the FC port.
Request Body
Name Type Description
description
string
A description of the FC port.
enabled
boolean
The administrative state of the FC port. If this property is set to false, all FC connectivity to FC interfaces are blocked. Optional in PATCH.
fabric
fabric
Properties of the fabric to which the FC port is attached.
interface_count
integer
The number of FC interfaces currently provisioned on this port. This property is not supported in an SVM context.
name
string
The FC port name.
node
node
physical_protocol
string
The physical network protocol of the FC port.
speed
speed
The physical device speed related properties of the FC port.
state
string
The operational state of the FC port.
  • startup - The port is booting up.
  • link_not_connected - The port has finished initialization, but a link with the fabric is not established.
  • online - The port is initialized and a link with the fabric has been established.
  • link_disconnected - The link was present at one point on this port but is currently not established.
  • offlined_by_user - The port is administratively disabled.
  • offlined_by_system - The port is set to offline by the system. This happens when the port encounters too many errors.
  • node_offline - The state information for the port cannot be retrieved. The node is offline or inaccessible.
supported_protocols
array[string]
The network protocols supported by the FC port.
transceiver
transceiver
Properties of the transceiver connected to the FC port.
uuid
string
The unique identifier of the FC port.
wwnn
string
The base world wide node name (WWNN) for the FC port.
wwpn
string
The base world wide port name (WWPN) for the FC port.
Example request
  "description": "Fibre Channel Target Adapter 0a (ACME Fibre Channel Adapter, rev. 1.0.0, 8G)",
  "fabric": {
    "connected_speed": 16,
    "name": "string",
    "port_address": "52100A",
    "switch_port": "ssan-g620-03:33"
  "interface_count": 0,
  "name": "0a",
  "node": {
    "name": "node1",
  "physical_protocol": "string",
  "speed": {
    "configured": "auto",
    "maximum": "32"
  "state": "online",
  "supported_protocols": [
    "string"
  "transceiver": {
    "capabilities": [
      16
    "form_factor": "string",
    "manufacturer": "Acme, Inc.",
    "part_number": "string"
  "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
  "wwnn": "20:00:00:50:56:b4:13:a8",
  "wwpn": "20:00:00:50:56:b4:13:a8"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
5374085
The node where the Fibre Channel port is located is offline.
5374087
The Fibre Channel port has active Fibre Channel interfaces and cannot be disabled.
string
fabric
connected
boolean
Reports if the physical port has established a connection with the FC fabric.
connected_speed
integer
The negotiated data rate between the target FC port and the fabric in gigabits per second.
name
string
The name of the fabric to which the port is connected. This is only available when the FC port is connected to a fabric.
There is an added computational cost to retrieving this property's value. It is not populated for a GET request unless it is explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
port_address
string
The FC port address of the host bus adapter (HBA) physical port.
Each FC port in an FC switched fabric has its own unique FC port address for routing purposes. The FC port address is assigned by a switch in the fabric when that port logs in to the fabric. This property refers to the FC port address given to the physical host bus adapter (HBA) port when the port performs a fabric login (FLOGI).
This is useful for obtaining statistics and diagnostic information from FC switches.
This is a six-digit hexadecimal encoded numeric value.
switch_port
string
The switch port to which the FC port is connected.
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Performance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
read
integer
total
integer
write
integer
metric
Performance numbers, such as IOPS latency and throughput
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
node
name
string
uuid
string
speed
configured
string
The configured speed of the FC port in gigabits per second.
maximum
string
The maximum speed supported by the FC port in gigabits per second.
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read
integer
total
integer
write
integer
statistics
These are raw performance numbers, such as IOPS latency and throughput. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
iops_raw
iops_raw
latency_raw
latency_raw
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput_raw
throughput_raw
timestamp
string
transceiver
capabilities
array[integer]
The speeds of which the transceiver is capable in gigabits per second.
form_factor
string
The form factor of the transceiver. Possible values are:
  • sfp - Small Form Factor - Pluggable
  • sff - Small Form Factor
  • unknown - Unknown
manufacturer
string
The manufacturer of the transceiver.
part_number
string
The part number of the transceiver.
fc_port
A Fibre Channel (FC) port is the physical port of an FC adapter on an ONTAP cluster node that can be connected to an FC network to provide FC network connectivity. An FC port defines the location of an FC interface within the ONTAP cluster.
description
string
enabled
boolean
fabric
fabric
interface_count
integer
name
string
The FC port name.
node
node
physical_protocol
string
speed
speed
state
string
supported_protocols
array[string]
transceiver
transceiver
uuid
string
wwnn
string
wwpn
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
