Modify the CIFS domain-related information for an SVM
Modifies the CIFS domain-related information for a specific SVM to update or reset domain configurations. Use this when you need to adjust domain settings or credentials associated with the SVM.
HTTP method and endpoint
PATCH /protocols/cifs/domains/{svm.uuid}
Introduced in
ONTAP 9.13
Usage notes
Modifies the CIFS domain-related information of the specified SVM.
Related ONTAP commands
vserver cifs domain password schedule modify -
vserver cifs domain discovered-servers discovery-mode modify -
vserver cifs domain password reset -
vserver cifs domain password change
Important notes
If the query is set to cifs_password_operation=reset and ad_domain_user and ad_domain_password is included in the body,a CIFS password reset is executed.
If the query is set to cifs_password_operation=reset and tenant_id, client_id and client_certificate is included in the body,a CIFS password reset is executed in Azure EntraId for hybrid user.
If the body is empty when the query is set to cifs_password_operation=reset, a CIFS password change is executed.
Learn more
cifs_password_operation |
string |
query |
False |
Specifies the operation to be performed on the domain password.
svm.uuid |
string |
path |
True |
Request Body
| Name | Type | Description |
ad_domain |
Specifies the credentials of a user with permissions to reset the password in the organizational unit for the machine account. |
client_certificate |
string |
PKCS12 certificate used by the application to prove its identity to AKV. |
client_id |
string |
Application client ID of the deployed Azure application with appropriate access to an AKV or EntraId. |
discovered_servers |
array[discovered_servers] |
Specifies the discovered servers records. |
name_mapping |
Specifies the name mapping search records. |
password_schedule |
Specifies the password schedule records. |
preferred_dcs |
array[preferred_dcs] |
Specifies the preferred DC records. |
server_discovery_mode |
string |
Specifies the mode of server discovery. |
svm |
tenant_id |
string |
Directory (tenant) ID of the deployed Azure application with appropriate access to an AKV or EntraId. |
trust_relationships |
array[trust_relationships] |
Specifies the trusted domain records. |
Example request
"ad_domain": {
"password": "string",
"user": "string"
"client_certificate": "PEM Cert",
"client_id": "e959d1b5-5a63-4284-9268-851e30e3eceb",
"discovered_servers": [
"domain": "test.com",
"node": {
"name": "node1",
"preference": "string",
"server_ip": "string",
"server_name": "string",
"server_type": "string",
"state": "string"
"name_mapping": {
"trusted_domains": [
"domain.com"
"password_schedule": {
"schedule_day_of_week": "Sunday",
"schedule_description": "string",
"schedule_last_changed_time": "string",
"schedule_time_of_day": 36900,
"schedule_warn_message": "string"
"preferred_dcs": [
"fqdn": "test.com",
"server_ip": "4.4.4.4"
"server_discovery_mode": "string",
"svm": {
"name": "svm1",
"tenant_id": "c9f32fcb-4ab7-40fe-af1b-1850d46cfbbe",
"trust_relationships": [
"home_domain": "string",
"node": {
"name": "node1",
"string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262278 |
Domain user and password are required fields. |
655513 |
Password update failed due to invalid credentials. |
656392 |
Preferred DC's need to be configured if CIFS discovery mode is set to none. |
656393 |
Default site needs to be configured if CIFS discovery mode is set to site. |
656487 |
Missing fields when doing CIFS operation with hybrid auth user type. |
ad_domain
password |
string |
The account password of the user with permissions to reset the password in the organizational unit for the machine account. |
user |
string |
The username of a user with permissions to reset the password in the organizational unit for the machine account. |
href |
string |
_links
node
name |
string |
uuid |
string |
discovered_servers
domain |
string |
Fully Qualified Domain Name. |
node |
preference |
string |
Server Preference |
server_ip |
string |
Server IP address |
server_name |
string |
Server Name |
server_type |
string |
Server Type |
state |
string |
Server status |
name_mapping
trusted_domains |
array[string] |
password_schedule
schedule_day_of_week |
string |
Day of the week for password change schedule. |
schedule_description |
string |
Schedule description. |
schedule_enabled |
boolean |
Is password schedule enabled. |
schedule_last_changed_time |
string |
Last successful password change time. |
schedule_randomized_minute |
integer |
Minutes within which schedule start can be randomized. |
schedule_time_of_day |
string |
Start time for password change schedule. |
schedule_warn_message |
string |
Warning message in case job is deleted. |
schedule_weekly_interval |
integer |
Interval in weeks for password change schedule. |
preferred_dcs
fqdn |
string |
server_ip |
string |
IP address of the preferred domain controller (DC). The address can be either an IPv4 or an IPv6 address. |
svm
name |
string |
uuid |
string |
trust_relationships
home_domain |
string |
Home Domain Name |
node |
trusted_domains |
array[string] |
Trusted Domain Name |
cifs_domain
ad_domain |
string |
client_id |
string |
name_mapping |
password_schedule |
preferred_dcs |
string |
svm |
tenant_id |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
