REST API reference
Modify the CIFS domain-related information for an SVM
Modifies the CIFS domain-related information for a specific SVM to update or reset domain configurations. Use this when you need to adjust domain settings or credentials associated with the SVM.
HTTP method and endpoint
PATCH /protocols/cifs/domains/{svm.uuid}
Introduced in
ONTAP 9.13
Usage notes
Modifies the CIFS domain-related information of the specified SVM.
  • vserver cifs domain password schedule modify
  • vserver cifs domain discovered-servers discovery-mode modify
  • vserver cifs domain password reset
  • vserver cifs domain password change
Important notes
  • If the query is set to cifs_password_operation=reset and ad_domain_user and ad_domain_password is included in the body,a CIFS password reset is executed.
  • If the query is set to cifs_password_operation=reset and tenant_id, client_id and client_certificate is included in the body,a CIFS password reset is executed in Azure EntraId for hybrid user.
  • If the body is empty when the query is set to cifs_password_operation=reset, a CIFS password change is executed.
string
query
False
Specifies the operation to be performed on the domain password.
  • enum: ["reset"]
  • Introduced in: 9.14
svm.uuid
string
path
True
Request Body
Name Type Description
ad_domain
ad_domain
Specifies the credentials of a user with permissions to reset the password in the organizational unit for the machine account.
client_certificate
string
PKCS12 certificate used by the application to prove its identity to AKV.
client_id
string
Application client ID of the deployed Azure application with appropriate access to an AKV or EntraId.
discovered_servers
array[discovered_servers]
Specifies the discovered servers records.
name_mapping
name_mapping
Specifies the name mapping search records.
password_schedule
password_schedule
Specifies the password schedule records.
preferred_dcs
array[preferred_dcs]
Specifies the preferred DC records.
server_discovery_mode
string
Specifies the mode of server discovery.
svm
svm
tenant_id
string
Directory (tenant) ID of the deployed Azure application with appropriate access to an AKV or EntraId.
trust_relationships
array[trust_relationships]
Specifies the trusted domain records.
Example request
  "ad_domain": {
    "password": "string",
    "user": "string"
  "client_certificate": "PEM Cert",
  "client_id": "e959d1b5-5a63-4284-9268-851e30e3eceb",
  "discovered_servers": [
      "domain": "test.com",
      "node": {
        "name": "node1",
      "preference": "string",
      "server_ip": "string",
      "server_name": "string",
      "server_type": "string",
      "state": "string"
  "name_mapping": {
    "trusted_domains": [
      "domain.com"
  "password_schedule": {
    "schedule_day_of_week": "Sunday",
    "schedule_description": "string",
    "schedule_last_changed_time": "string",
    "schedule_time_of_day": 36900,
    "schedule_warn_message": "string"
  "preferred_dcs": [
      "fqdn": "test.com",
      "server_ip": "4.4.4.4"
  "server_discovery_mode": "string",
  "svm": {
    "name": "svm1",
  "tenant_id": "c9f32fcb-4ab7-40fe-af1b-1850d46cfbbe",
  "trust_relationships": [
      "home_domain": "string",
      "node": {
        "name": "node1",
        "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
262278
Domain user and password are required fields.
655513
Password update failed due to invalid credentials.
656392
Preferred DC's need to be configured if CIFS discovery mode is set to none.
656393
Default site needs to be configured if CIFS discovery mode is set to site.
656487
Missing fields when doing CIFS operation with hybrid auth user type.
ad_domain
password
string
The account password of the user with permissions to reset the password in the organizational unit for the machine account.
user
string
The username of a user with permissions to reset the password in the organizational unit for the machine account.
string
node
name
string
uuid
string
discovered_servers
domain
string
Fully Qualified Domain Name.
node
node
preference
string
Server Preference
server_ip
string
Server IP address
server_name
string
Server Name
server_type
string
Server Type
state
string
Server status
name_mapping
trusted_domains
array[string]
password_schedule
string
Day of the week for password change schedule.
string
Schedule description.
schedule_enabled
boolean
Is password schedule enabled.
string
Last successful password change time.
schedule_randomized_minute
integer
Minutes within which schedule start can be randomized.
string
Start time for password change schedule.
string
Warning message in case job is deleted.
schedule_weekly_interval
integer
Interval in weeks for password change schedule.
preferred_dcs
fqdn
string
server_ip
string
IP address of the preferred domain controller (DC). The address can be either an IPv4 or an IPv6 address.
svm
name
string
uuid
string
trust_relationships
home_domain
string
Home Domain Name
node
node
trusted_domains
array[string]
Trusted Domain Name
cifs_domain
ad_domain
ad_domain
client_certificate
string
client_id
string
discovered_servers
name_mapping
name_mapping
password_schedule
password_schedule
preferred_dcs
string
svm
svm
tenant_id
string
trust_relationships
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
