REST API reference
Update the properties of an NFS over TLS interface
Updates the properties of an NFS over TLS interface to modify its configuration settings. This operation is useful when you need to change interface settings to meet security or connectivity requirements.
HTTP method and endpoint
PATCH /protocols/nfs/tls/interfaces/{interface.uuid}
Introduced in
ONTAP 9.15
  • vserver nfs tls interface modify
  • vserver nfs tls interface enable
  • vserver nfs tls interface disable
interface.uuid
string
path
True
Network interface UUID.
Request Body
Name Type Description
certificate
certificate
Specifies the certificate that is used for creating NFS over TLS connections.
enabled
boolean
Indicates whether NFS over TLS is enabled.
interface
interface
Network interface.
svm
svm
Example request
  "certificate": {
    "name": "string",
  "interface": {
    "name": "lif1",
  "svm": {
    "name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response codes
Error codes Description
2
The value provided is an invalid value for field "interface.uuid".
4
The entry doesn't exist
3277204
TLS already enabled/disabled on this LIF.
3277205
Cannot enable TLS because no certificate was provided.
3277206
The "enabled" is a required field.
3277210
The FQDN of the LIF IP address and the common name present in the certificate do not match. Update the certificate so that the common name and LIF FQDN match and retry the operation.
3277217
Failed to enable TLS on LIF on vserver because the certificate does not have LIF as subject alternate name.
92405900
Certificate not found for the SVM.
92406020
Only certificates of type 'server' are supported on the SVM.
string
certificate
name
string
Certificate name
uuid
string
Certificate UUID
ip
IP information
interface
Network interface.
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
svm
name
string
uuid
string
nfs_tls_interface
certificate
certificate
enabled
boolean
interface
interface
Network interface.
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
