Update the properties of an NFS over TLS interface
Updates the properties of an NFS over TLS interface to configure its settings according to your requirements. This is typically used to modify interface attributes for secure communication in your network environment.
HTTP method and endpoint
PATCH /protocols/nfs/tls/interfaces/{interface.uuid}
Introduced in
ONTAP 9.15
Optional query parameter
skip-san-validation- Specifies whether the server should ignore validating the certificate for Subject Alternate Name.
Related ONTAP commands
vserver nfs tls interface modify -
vserver nfs tls interface enable -
vserver nfs tls interface disable
Learn more
interface.uuid |
string |
path |
True |
Network interface UUID. |
skip_san_validation |
boolean |
query |
False |
Indicates whether Subject Alternate Name (SAN) validation has to be skipped.
Request Body
| Name | Type | Description |
certificate |
Specifies the certificate that is used for creating NFS over TLS connections. |
enabled |
boolean |
Indicates whether NFS over TLS is enabled. |
interface |
Network interface. |
svm |
Example request
"certificate": {
"name": "string",
"interface": {
"name": "lif1",
"svm": {
"name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response codes
| Error codes | Description |
2 |
The value provided is an invalid value for field "interface.uuid". |
4 |
The entry doesn't exist |
3277204 |
TLS already enabled/disabled on this LIF. |
3277205 |
Cannot enable TLS because no certificate was provided. |
3277206 |
The "enabled" is a required field. |
3277210 |
The FQDN of the LIF IP address and the common name present in the certificate do not match. Update the certificate so that the common name and LIF FQDN match and retry the operation. |
3277217 |
Failed to enable TLS on LIF on vserver because the certificate does not have LIF as subject alternate name. |
92405900 |
Certificate not found for the SVM. |
92406020 |
Only certificates of type 'server' are supported on the SVM. |
href |
string |
_links
certificate
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
ip
IP information
interface
Network interface.
ip |
IP information |
name |
string |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the interface. |
svm
name |
string |
uuid |
string |
nfs_tls_interface
certificate |
enabled |
boolean |
interface |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
