REST API reference
Update a Duo profile configured for an SVM or cluster
PATCH /security/authentication/duo/profiles/{owner.uuid}
Introduced In: 9.14
Updates a configured Duo profile for a cluster or an SVM.
  • security login duo modify
owner.uuid
string
path
True
Account owner UUID
Request Body
Name Type Description
api_host
string
The URL at which the Duo API is hosted.
auto_push
boolean
Automatically sends a push notification for authentication when using Duo.
comment
string
Comment for the Duo profile.
fail_mode
string
Determines the behavior of the system when it cannot communicate with the Duo service.
fingerprint
string
The SHA fingerprint corresponding to the Duo secret key.
http_proxy
string
Specifies the HTTP proxy server to be used when connecting to the Duo service.
integration_key
string
The Integration Key associated with the Duo profile.
is_enabled
boolean
Indicates whether the Duo authentication feature is active or inactive.
max_prompts
integer
The maximum number of authentication attempts allowed for a user before the process is terminated.
owner
owner
SVM name and UUID for which the Duo profile is configured.
push_info
boolean
Additional information sent along with the push notification for Duo authentication.
secret_key
string
The Secret Key associated with the Duo profile.
status
string
Information on the reachability status of Duo.
Example request
  "api_host": "api-****.duo.com",
  "auto_push": 1,
  "comment": "string",
  "fail_mode": "safe",
  "fingerprint": "string",
  "http_proxy": "IPaddress:port",
  "integration_key": "string",
  "is_enabled": 1,
  "max_prompts": 1,
  "owner": {
    "name": "svm1",
  "push_info": 1,
  "secret_key": "string",
  "status": "OK"
Status: 200, Ok
Status: Default, Error
string
owner
name
string
uuid
string
duo
Duo profile for the SVM or cluster-management server (Cserver).
api_host
string
auto_push
boolean
comment
string
fail_mode
string
fingerprint
string
http_proxy
string
integration_key
string
is_enabled
boolean
max_prompts
integer
owner
owner
push_info
boolean
secret_key
string
status
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
