Update a Duo profile configured for an SVM or cluster
PATCH /security/authentication/duo/profiles/{owner.uuid}
Introduced In: 9.14
Updates a configured Duo profile for a cluster or an SVM.
Related ONTAP commands
security login duo modify
owner.uuid  |
string  |
path  |
True  |
Account owner UUID  |
Request Body
| Name | Type | Description |
api_host  |
string  |
The URL at which the Duo API is hosted.  |
auto_push  |
boolean  |
Automatically sends a push notification for authentication when using Duo.  |
comment  |
string  |
Comment for the Duo profile.  |
fail_mode  |
string  |
Determines the behavior of the system when it cannot communicate with the Duo service.  |
fingerprint  |
string  |
The SHA fingerprint corresponding to the Duo secret key.  |
http_proxy  |
string  |
Specifies the HTTP proxy server to be used when connecting to the Duo service.  |
integration_key  |
string  |
The Integration Key associated with the Duo profile.  |
is_enabled  |
boolean  |
Indicates whether the Duo authentication feature is active or inactive.  |
max_prompts  |
integer  |
The maximum number of authentication attempts allowed for a user before the process is terminated.  |
owner  |
SVM name and UUID for which the Duo profile is configured.  |
push_info  |
boolean  |
Additional information sent along with the push notification for Duo authentication.  |
secret_key  |
string  |
The Secret Key associated with the Duo profile.  |
status  |
string  |
Information on the reachability status of Duo.  |
Example request
  "api_host": "api-****.duo.com",
  "auto_push": 1,
  "comment": "string",
  "fail_mode": "safe",
  "fingerprint": "string",
  "http_proxy": "IPaddress:port",
  "integration_key": "string",
  "is_enabled": 1,
  "max_prompts": 1,
  "owner": {
    "name": "svm1",
  "push_info": 1,
  "secret_key": "string",
  "status": "OK"
Status: 200, Ok
Status: Default, Error
href  |
string  |
_links
owner
name  |
string  |
The name of the SVM. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
duo
Duo profile for the SVM or cluster-management server (Cserver).
api_host  |
string  |
auto_push  |
boolean  |
comment  |
string  |
fail_mode  |
string  |
fingerprint  |
string  |
http_proxy  |
string  |
integration_key  |
string  |
is_enabled  |
boolean  |
max_prompts  |
integer  |
owner  |
push_info  |
boolean  |
secret_key  |
string  |
status  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
