Update configured group information
PATCH /security/groups/{owner.uuid}/{name}/{type}
Introduced In: 9.16
Updates configured group information.
Related ONTAP commands
security login group modify
owner.uuid |
string |
path |
True |
Group owner. Used to identify a cluster or an SVM. |
name |
string |
path |
True |
Group name. |
type |
string |
path |
True |
Group type. |
Request Body
| Name | Type | Description |
comment |
string |
Any comment regarding this group entry. |
create_time |
string |
Date and time indicating when this group entry was created. |
id |
integer |
Group ID which is unique per group across the system. It is a read-only field and it automatically assigns the next available unique number. |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
uuid |
string |
Group UUID from external Active Directory. |
Example request
"comment": "Azure Group",
"create_time": "string",
"id": 0,
"scope": "string",
"uuid": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5636235 |
Duplicate UUID. |
href |
string |
self_link
_links
owner
name |
string |
uuid |
string |
security_group
comment |
string |
create_time |
string |
id |
integer |
scope |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
