REST API reference
Update configured group information
PATCH /security/groups/{owner.uuid}/{name}/{type}
Introduced In: 9.16
Updates configured group information.
  • security login group modify
owner.uuid
string
path
True
Group owner. Used to identify a cluster or an SVM.
name
string
path
True
Group name.
type
string
path
True
Group type.
Request Body
Name Type Description
comment
string
Any comment regarding this group entry.
create_time
string
Date and time indicating when this group entry was created.
id
integer
Group ID which is unique per group across the system. It is a read-only field and it automatically assigns the next available unique number.
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
uuid
string
Group UUID from external Active Directory.
Example request
  "comment": "Azure Group",
  "create_time": "string",
  "id": 0,
  "scope": "string",
  "uuid": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
5636235
Duplicate UUID.
string
owner
name
string
uuid
string
security_group
comment
string
create_time
string
id
integer
scope
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
