REST API reference
Create hostname mappings for an SVM
Creates hostname mappings for an SVM to define how client names are translated within the storage virtual machine. This helps in managing name resolution and ensuring proper client access to resources.
HTTP method and endpoint
POST /name-services/name-mappings
Introduced in
ONTAP 9.6
Usage notes
Creates name mappings for an SVM.
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the name mapping.
  • index - Name mapping's position in the priority list.
  • direction - Direction of the name mapping.
  • pattern - Pattern to match to. Maximum length is 256 characters.
  • replacement - Replacement pattern to match to. Maximum length is 256 characters.
  • client_match - Hostname or IP address added to match the pattern to the client's workstation IP address.
  • vserver name-mapping create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
client_match
string
Client workstation IP Address which is matched when searching for the pattern. You can specify the value in any of the following formats:
  • As an IPv4 address with a subnet mask expressed as a number of bits; for instance, 10.1.12.0/24
  • As an IPv6 address with a subnet mask expressed as a number of bits; for instance, fd20:8b1e:b255:4071::/64
  • As an IPv4 address with a network mask; for instance, 10.1.16.0/255.255.255.0
  • As a hostname
direction
string
Direction in which the name mapping is applied. The possible values are:
  • krb_unix - Kerberos principal name to UNIX user name
  • win_unix - Windows user name to UNIX user name
  • unix_win - UNIX user name to Windows user name mapping
  • s3_unix - S3 user name to UNIX user name mapping
  • s3_win - S3 user name to Windows user name mapping
index
integer
Position in the list of name mappings.
pattern
string
Pattern used to match the name while searching for a name that can be used as a replacement. The pattern is a UNIX-style regular expression. Regular expressions are case-insensitive when mapping from Windows to UNIX, and they are case-sensitive for mappings from Kerberos to UNIX and UNIX to Windows.
replacement
string
The name that is used as a replacement, if the pattern associated with this entry matches.
svm
svm
Example request
  "client_match": "10.254.101.111/28",
  "direction": "win_unix",
  "index": 1,
  "pattern": "ENGCIFS_AD_USER",
  "replacement": "unix_user1",
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records
integer
Number of records
records
array[name_mapping]
  "num_records": 1,
  "records": [
      "index": 1,
      "svm": {
        "name": "svm1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
65798185
Failed to resolve the specified hostname
65798173
The name mapping pattern already exists with a more generic IP qualifier
65798149
Invalid index for the name mapping entry
2621706
The specified svm.uuid and svm.name refer to different SVMs
string
svm
name
string
uuid
string
name_mapping
Name mapping is used to map CIFS identities to UNIX identities, Kerberos identities to UNIX identities, UNIX identities to CIFS identities, S3 to UNIX identities and S3 to CIFS identities. It needs this information to obtain user credentials and provide proper file access regardless of whether they are connecting from an NFS client, CIFS client or an S3 client.
client_match
string
  • As a hostname
direction
string
index
integer
pattern
string
replacement
string
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
