Create hostname mappings for an SVM
Creates hostname mappings for an SVM to define how names are translated within the storage virtual machine. This is typically used to control name resolution and ensure correct mapping of client requests.
HTTP method and endpoint
POST /name-services/name-mappings
Introduced in
ONTAP 9.6
Usage notes
Creates name mappings for an SVM.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the name mapping. -
index- Name mapping's position in the priority list. -
direction- Direction of the name mapping. -
pattern- Pattern to match to. Maximum length is 256 characters. -
replacement- Replacement pattern to match to. Maximum length is 256 characters.
Recommended optional properties
client_match- Hostname or IP address added to match the pattern to the client's workstation IP address.
Related ONTAP commands
vserver name-mapping create -
vserver name-mapping insert
Learn more
insert_name_map |
boolean |
query |
False |
Create a name mapping at a specified position
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
client_match |
string |
Client workstation IP Address which is matched when searching for the pattern. You can specify the value in any of the following formats:
direction |
string |
Direction in which the name mapping is applied. The possible values are:
index |
integer |
Position in the list of name mappings. |
pattern |
string |
Pattern used to match the name while searching for a name that can be used as a replacement. The pattern is a UNIX-style regular expression. Regular expressions are case-insensitive when mapping from Windows to UNIX, and they are case-sensitive for mappings from Kerberos to UNIX and UNIX to Windows. |
replacement |
string |
The name that is used as a replacement, if the pattern associated with this entry matches. |
svm |
Example request
"client_match": "10.254.101.111/28",
"direction": "win_unix",
"index": 1,
"pattern": "ENGCIFS_AD_USER",
"replacement": "unix_user1",
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[name_mapping] |
"num_records": 1,
"records": [
"index": 1,
"svm": {
"name": "svm1",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65798185 |
Failed to resolve the specified hostname |
65798173 |
The name mapping pattern already exists with a more generic IP qualifier |
65798149 |
Invalid index for the name mapping entry |
2621706 |
The specified svm.uuid and svm.name refer to different SVMs |
href |
string |
_links
svm
name |
string |
uuid |
string |
name_mapping
Name mapping is used to map CIFS identities to UNIX identities, Kerberos identities to UNIX identities, UNIX identities to CIFS identities, S3 to UNIX identities and S3 to CIFS identities. It needs this information to obtain user credentials and provide proper file access regardless of whether they are connecting from an NFS client, CIFS client or an S3 client.
client_match |
string |
direction |
string |
index |
integer |
pattern |
string |
replacement |
string |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
