REST API reference
Create a Duo group
POST /security/authentication/duo/groups
Introduced In: 9.14
Creates a Duo group.
Required properties
  • name - Group name
  • security login duo group create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
comment
string
Comment for the Duo group.
excluded_users
array[string]
List of excluded users.
name
string
Name of the group to be included in Duo authentication.
owner
owner
SVM name and UUID for which the Duo group profile is configured.
Example request
  "comment": "string",
  "excluded_users": [
    "user1",
    "user2"
  "name": "AD_Group",
  "owner": {
    "name": "svm1",
Status: 201, Created
num_records
integer
Number of records.
records
array[duogroup]
  "num_records": 1,
  "records": [
      "excluded_users": [
        "user1",
        "user2"
      "name": "AD_Group",
      "owner": {
        "name": "svm1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default, Error
string
owner
name
string
uuid
string
duogroup
Group profile to include in Duo authentication.
comment
string
excluded_users
array[string]
name
string
owner
owner
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
