Create a Duo group
Creates a Duo group to manage multi-factor authentication groups within your security framework.
HTTP method and endpoint
POST /security/authentication/duo/groups
Introduced in
ONTAP 9.14
Required properties
name- Group name
Related ONTAP commands
security login duo group create
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
comment |
string |
Comment for the Duo group. |
excluded_users |
array[string] |
List of excluded users. |
name |
string |
Name of the group to be included in Duo authentication. |
owner |
SVM name and UUID for which the Duo group profile is configured. |
Example request
"comment": "string",
"excluded_users": [
"user1",
"user2"
"name": "AD_Group",
"owner": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of records. |
records |
array[duogroup] |
"num_records": 1,
"records": [
"excluded_users": [
"user1",
"user2"
"name": "AD_Group",
"owner": {
"name": "svm1",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default, Error
href |
string |
_links
owner
name |
string |
uuid |
string |
duogroup
Group profile to include in Duo authentication.
comment |
string |
excluded_users |
array[string] |
name |
string |
owner |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
