Protocols CIFS domains svm.uuid preferred-domain-controllers endpoint overview
Overview
You can use this API to display a CIFS domain preferred DC configuration of an SVM.
Retrieving all CIFS domain preferred DC configurations of an SVM
The CIFS domain preferred DC GET endpoint retrieves all the configurations for a specific SVM.
Retrieving all the fields of all CIFS domain preferred DC configurations of an SVM
# The API: GET /api/protocols/cifs/domains/{svm.uuid}/preferred-domain-controllers # The call: curl -X GET "https://<mgmt-ip>/api/protocols/cifs/domains/1226670c-abc9-11eb-8de3-0050568eb0c4/preferred-domain-controllers/?fields=*" -H "accept: application/json" # The response: { "records": [ { "svm": { "uuid": "1226670c-abc9-11eb-8de3-0050568eb0c4", "name": "svm1" }, "fqdn": "host1", "server_ip": "4.4.4.4" }, { "svm": { "uuid": "1226670c-abc9-11eb-8de3-0050568eb0c4", "name": "svm1" }, "fqdn": "host2", "server_ip": "11.11.11.11" } ], "num_records": 2 }
Retrieving the CIFS domain preferred DC configuration of a specific SVM, "fqdn" and "server_ip"
# The API: GET /api/protocols/cifs/domains/{svm.uuid}/preferred-domain-controllers/{fqdn}/{server_ip} # The call: curl -X GET "https://<mgmt-ip>/api/protocols/cifs/domains/1226670c-abc9-11eb-8de3-0050568eb0c4/preferred-domain-controllers/host1/4.4.4.4" -H "accept: application/json" # The response: { "svm": { "uuid": "1226670c-abc9-11eb-8de3-0050568eb0c4", "name": "svm1" }, "fqdn": "host1", "server_ip": "4.4.4.4" }
Creating a new CIFS domain preferred DC configuration
The CIFS domain preferred DC POST endpoint creates a new configuration. Both bulk and instance POST is supported.
Creating a single CIFS domain preferred DC configuration
# The API: POST /api/protocols/cifs/domains/{svm.uuid}/preferred-domain-controllers # The call: curl -X POST "https://<mgmt-ip>/api/protocols/cifs/domains/1226670c-abc9-11eb-8de3-0050568eb0c4/preferred-domain-controllers?skip_config_validation=true&return_records=false" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"fqdn\": \"testing.com\", \"server_ip\": \"1.1.1.1\"}"
Deleting an existing CIFS domain preferred DC configuration
The CIFS domain preferred DC DELETE endpoint deletes an existing configuration. Both bulk and instance delete is supported.
Deleting the CIFS domain preferred DC configuration of a specific SVM, "fqdn" and "server_ip"
# The API: DELETE /api/protocols/cifs/domains/{svm.uuid}/preferred-domain-controllers/{fqdn}/{server_ip} # The call: curl -X DELETE "https://<mgmt-ip>/api/protocols/cifs/domains/1226670c-abc9-11eb-8de3-0050568eb0c4/preferred-domain-controllers/sample/4.4.4.4"
### Deleting the CIFS domain preferred DC configurations of a specific SVM and "fqdn"
# The API: DELETE /api/protocols/cifs/domains/{svm.uuid}/preferred-domain-controllers # The call: curl -X DELETE "https://<mgmt-ip>/api/protocols/cifs/domains/1226670c-abc9-11eb-8de3-0050568eb0c4/preferred-domain-controllers/?fqdn=sampl"
Deleting all CIFS domain preferred DC configurations of a specific SVM
# The API: DELETE /api/protocols/cifs/domains/{svm.uuid}/preferred-domain-controllers # The call: curl -X DELETE "https://<mgmt-ip>/api/protocols/cifs/domains/1226670c-abc9-11eb-8de3-0050568eb0c4/preferred-domain-controllers/?fqdn=*"
Deleting the CIFS domain preferred DC configurations of a specific SVM, "fqdn" and set of "server_ips"
# The API: DELETE /api/protocols/cifs/domains/{svm.uuid}/preferred-domain-controllers # The call: curl -X DELETE "https://<mgmt-ip>/api/protocols/cifs/domains/1226670c-abc9-11eb-8de3-0050568eb0c4/preferred-domain-controllers/?fqdn=sample&server_ip=3.3.3.3|4.4.4.4|1.1.1.1|2.2.2.2"
Deleting the CIFS domain preferred DC configurations of a specific SVM and set of "server_ips"
# The API: DELETE /api/protocols/cifs/domains/{svm.uuid}/preferred-domain-controllers # The call: curl -X DELETE "https://<mgmt-ip>/api/protocols/cifs/domains/1226670c-abc9-11eb-8de3-0050568eb0c4/preferred-domain-controllers/?server_ip=3.3.3.3|4.4.4.4|1.1.1.1|2.2.2.2"
