Security anti-ransomware endpoint overview
Overview
This API displays and manages the anti-ransomware version.
Retrieving the anti-ransomware versions of all nodes in the cluster.
The following example shows how to retrieve anti-ransomware versions.
# The API:
GET /security/anti-ransomware
# The call:
curl -X GET "https://<mgmt-ip>/api/security/anti-ransomware" -H "accept: application/hal+json"
# The response:
"nodes": [
"name": "sti11-vsim-ucs573i",
"version": "1.0"
"name": "sti11-vsim-ucs573j",
"version": "1.0"
"href": "/api/security/anti-ransomware/"
Updating the anti-ransomware package
The following example shows how to update the anti-ransomware package on the cluster.
# The API:
PATCH /security/anti-ransomware
# The call:
curl -X PATCH "https://<mgmt-ip>/api/security/anti-ransomware" -H "accept: application/hal+json" -d '{"uri": "http://server/package"}'
# The response:
"job": {
"uuid": "74d0faef-3e1a-11ef-af89-005056ac6d8a",
"href": "/api/cluster/jobs/74d0faef-3e1a-11ef-af89-005056ac6d8a"
The call to update the anti-ransomware package returns the job UUID, including a HAL link to retrieve details about the job. The job object includes a state field and a message to indicate the progress of the job. When the job is complete and the application is fully created, the message indicates success and the job state field is set to success.
# The API:
/api/cluster/jobs/{uuid}
# The call:
curl -X GET "https://<mgmt-ip>/api/cluster/jobs/74d0faef-3e1a-11ef-af89-005056ac6d8a" -H "accept: application/hal+json"
# The response:
"description": "PATCH /api/security/anti-ransomware",
"state": "success",
"message": "success",
"code": 0,
