Security certificates endpoint overview
Overview
This API displays security certificate information and manages the certificates in ONTAP.
Installing certificates in ONTAP
The security certificates GET request retrieves all of the certificates in the cluster.
Retrieving all certificates installed in the cluster with their common-names
# The API: /api/security/certificates # The call: curl -X GET "https://<mgmt-ip>/api/security/certificates?fields=common_name" -H "accept: application/hal+json" # The response: { "records": [ { "svm": { "name": "vs0" }, "uuid": "dad2363b-8ac0-11e8-9058-005056b482fc", "common_name": "vs0", "_links": { "self": { "href": "/api/security/certificates/dad2363b-8ac0-11e8-9058-005056b482fc" } } }, { "uuid": "1941e048-8ac1-11e8-9058-005056b482fc", "common_name": "ROOT", "_links": { "self": { "href": "/api/security/certificates/1941e048-8ac1-11e8-9058-005056b482fc" } } }, { "uuid": "5a3a77a8-892d-11e8-b7da-005056b482fc", "common_name": "cert_name", "_links": { "self": { "href": "/api/security/certificates/5a3a77a8-892d-11e8-b7da-005056b482fc" } } } ], "num_records": 3, "_links": { "self": { "href": "/api/security/certificates?fields=common_name" } } }
Retrieving all certificates installed at cluster-scope with their common-names
# The API: /api/security/certificates # The call: curl -X GET "https://<mgmt-ip>/api/security/certificates?scope=cluster&fields=common_name" -H "accept: application/hal+json" # The response: { "records": [ { "uuid": "1941e048-8ac1-11e8-9058-005056b482fc", "scope": "cluster", "common_name": "ROOT", "_links": { "self": { "href": "/api/security/certificates/1941e048-8ac1-11e8-9058-005056b482fc" } } }, { "uuid": "5a3a77a8-892d-11e8-b7da-005056b482fc", "scope": "cluster", "common_name": "cert_name", "_links": { "self": { "href": "/api/security/certificates/5a3a77a8-892d-11e8-b7da-005056b482fc" } } } ], "num_records": 2, "_links": { "self": { "href": "/api/security/certificates?scope=cluster&fields=common_name" } } }
Retrieving all certificates installed on a specific SVM with their common-names
# The API: /api/security/certificates # The call: curl -X GET "https://<mgmt-ip>/api/security/certificates?svm.name=vs0&fields=common_name" -H "accept: application/hal+json" # The response: { "records": [ { "svm": { "name": "vs0" }, "uuid": "dad2363b-8ac0-11e8-9058-005056b482fc", "common_name": "vs0", "_links": { "self": { "href": "/api/security/certificates/dad2363b-8ac0-11e8-9058-005056b482fc" } } } ], "num_records": 1, "_links": { "self": { "href": "/api/security/certificates?svm.name=vs0&fields=common_name" } } }
Retrieving a certificate using its UUID for all fields
# The API: /api/security/certificates/{uuid} # The call: curl -X GET "https://<mgmt-ip>/api/security/certificates/dad2363b-8ac0-11e8-9058-005056b482fc?fields=*" -H "accept: application/hal+json" # The response: { "svm": { "uuid": "d817293c-8ac0-11e8-9058-005056b482fc", "name": "vs0" }, "uuid": "dad2363b-8ac0-11e8-9058-005056b482fc", "scope": "svm", "type": "server", "common_name": "vs0", "serial_number": "15428D45CF81CF56", "ca": "vs0", "hash_function": "sha256", "key_size": 2048, "expiry_time": "2019-07-18T15:29:14-04:00", "public_certificate": "-----BEGIN CERTIFICATE-----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\n9QAsTjTOF9PlAKgNxGoOJl2y0+48AA==\n-----END CERTIFICATE-----\n", "_links": { "self": { "href": "/api/security/certificates/dad2363b-8ac0-11e8-9058-005056b482fc" } } }
Creating a certificate in a cluster
These certificates can be used to help administrators enable certificate-based authentication and to enable SSL-based communication to the cluster.
# The API: /api/security/certificates # The call: curl -X POST "https://<mgmt-ip>/api/security/certificates" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "{ \"common_name\": \"TEST-SERVER\", \"type\": \"server\" }"
Installing a certificate in a cluster
These certificates can be used to help administrators enable certificate-based authentication and to enable-SSL based communication to the cluster.
# The API: /api/security/certificates # The call: curl -X POST "https://<mgmt-ip>/api/security/certificates" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"type\": \"server_ca\", \"public_certificate\": \"-----BEGIN CERTIFICATE-----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\ncGzM7vRX+Bi6hG6H\n-----END CERTIFICATE-----\n\" }"
Installing a certificate on a specific SVM
# The API: /api/security/certificates # The call: curl -X POST "https://<mgmt-ip>/api/security/certificates" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"svm\" : { \"name\" : \"vs0\" }, \"type\": \"server_ca\", \"public_certificate\": \"-----BEGIN CERTIFICATE-----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\ncGzM7vRX+Bi6hG6H\n-----END CERTIFICATE-----\n\" }"
Installing a CA-signed certificate on a specific SVM
# The API: /api/security/certificates # The call: curl -X POST "https://<mgmt-ip>/api/security/certificates" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"svm\" : { \"name\" : \"vs0\" }, \"type\": \"server\", \"public_certificate\": \"-----BEGIN CERTIFICATE-----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\nMoBBKg5TQ1r20GJ3XZ23sZTbUg==\n-----END CERTIFICATE-----\n\", \"private_key\": \"-----BEGIN PRIVATE KEY-----\n-----END PRIVATE KEY-----\n\", \"intermediate_certificates\": [\"-----BEGIN CERTIFICATE-----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\n+YmIPyvF2mFBxGdH7ORm3vPVX/TTFw==\n-----END CERTIFICATE-----\n\",\"-----BEGIN CERTIFICATE-----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\n-----END CERTIFICATE-----\n\"]}"
Deleting a certificate using its UUID
# The API: /api/security/certificates/{uuid} # The call: curl -X DELETE "https://<mgmt-ip>/api/security/certificates/dad2363b-8ac0-11e8-9058-005056b482fc?fields=*" -H "accept: application/hal+json"
Signing a new certificate signing request using an existing CA certificate UUID
Once you have created a certificate of type "root_ca", you can use that certificate to act as a local Certificate Authority to sign new certificate signing requests. The following example signs a new certificate signing request using an existing CA certificate UUID. If successful, the API returns a signed certificate.
# The API: /api/security/certificates/{ca.uuid}/sign # The call: curl -X POST "https://<mgmt-ip>/api/security/certificates/253add53-8ac9-11e8-9058-005056b482fc/sign" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"signing_request\": \"-----BEGIN CERTIFICATE REQUEST-----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Wsm8Ev727MziZ+0II9nxwkDKsdPvam+KLI9hLQ==\n-----END CERTIFICATE REQUEST-----\n\", \"hash_function\": \"sha256\"}" # The response: { "public_certificate": "-----BEGIN CERTIFICATE-----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\nR+dO6C0hcDKHFzA=\n-----END CERTIFICATE-----\n" }
Generate a new Certificate Signing Request (CSR)
# The API: /api/security/certificate-signing-request # The call: curl -X POST "https://<mgmt-ip>/api/security/certificate-signing-request" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"algorithm\": \"rsa\", \"extended_key_usage\": [\"serverauth\"], \"hash_function\": \"sha256\", \"key_usage\": [\"digitalsignature\"], \"security_strength\": \"112\", \"subject_alternatives\": { \"dns\": [ \"*.example.com\", \"*.example1.com\" ], \"email\": [\"abc@example.com\", \"abc@example1.com\"], \"ip\": [\"10.225.34.223\", \"10.225.34.224\"], \"uri\": [\"http://example.com\", \"http://example1.com\"] }, \"subject_name\": \"C=US,O=NTAP,CN=test.domain.com\"}" { "csr": "-----BEGIN CERTIFICATE REQUEST-----\n-----END CERTIFICATE REQUEST-----\n", "generated_private_key": "-----BEGIN PRIVATE KEY-----\n-----END PRIVATE KEY-----\n" }
### Download and install a certificate from the Azure Key Vault.
The API:
The call:
