Security multi-admin-verify rules endpoint overview
Overview
Rules define the ONTAP commands (operations) that should be protected by multi-admin approval.
While the feature is turned on, any ONTAP operation that is defined with a rule will be enforced with multi-admin approval to execute the command (operation).
Creating a multi-admin-verify rule
Creates a rule for the specified ONTAP operation.
# The API: /api/security/multi-admin-verify/rules # The call: curl -X POST "https://<mgmt-ip>/api/security/multi-admin-verify/rules?return_records=true" -H "accept: application/hal+json" -d '{"operation": "volume delete", "query": "-vserver vs0", "required_approvers": 1}' # The response: { "num_records": 1, "records": [ { "owner": { "uuid": "c109634f-7011-11ec-a23d-005056a78fd5", "_links": { "self": { "href": "/api/svm/svms/c109634f-7011-11ec-a23d-005056a78fd5" } } }, "operation": "volume delete", "auto_request_create": true, "query": "-vserver vs0", "required_approvers": 1, "create_time": "2022-01-07T22:14:03-05:00", "system_defined": false, "_links": { "self": { "href": "/api/security/multi-admin-verify/rules/c109634f-7011-11ec-a23d-005056a78fd5/volume%20delete" } } } ] }
Retrieving multi-admin-verify rules
Displays information about multi admin verification rules.
# The API: /api/security/multi-admin-verify/rules # The call: curl -X GET "https://<cluster-ip>/api/security/multi-admin-verify/rules" # The response: { "records": [ { "owner": { "uuid": "52b75787-7011-11ec-a23d-005056a78fd5", "name": "cluster1", "_links": { "self": { "href": "/api/svm/svms/52b75787-7011-11ec-a23d-005056a78fd5" } } }, "operation": "security login password", "_links": { "self": { "href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20login%20password" } } }, { "owner": { "uuid": "52b75787-7011-11ec-a23d-005056a78fd5", "name": "cluster1", "_links": { "self": { "href": "/api/svm/svms/52b75787-7011-11ec-a23d-005056a78fd5" } } }, "operation": "security login unlock", "_links": { "self": { "href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20login%20unlock" } } }, { "owner": { "uuid": "52b75787-7011-11ec-a23d-005056a78fd5", "name": "cluster1", "_links": { "self": { "href": "/api/svm/svms/52b75787-7011-11ec-a23d-005056a78fd5" } } }, "operation": "security multi-admin-verify approval-group create", "_links": { "self": { "href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20approval-group%20create" } } }, { "owner": { "uuid": "52b75787-7011-11ec-a23d-005056a78fd5", "name": "cluster1", "_links": { "self": { "href": "/api/svm/svms/52b75787-7011-11ec-a23d-005056a78fd5" } } }, "operation": "security multi-admin-verify approval-group delete", "_links": { "self": { "href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20approval-group%20delete" } } }, { "owner": { "uuid": "52b75787-7011-11ec-a23d-005056a78fd5", "name": "cluster1", "_links": { "self": { "href": "/api/svm/svms/52b75787-7011-11ec-a23d-005056a78fd5" } } }, "operation": "security multi-admin-verify approval-group modify", "_links": { "self": { "href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20approval-group%20modify" } } }, { "owner": { "uuid": "52b75787-7011-11ec-a23d-005056a78fd5", "name": "cluster1", "_links": { "self": { "href": "/api/svm/svms/52b75787-7011-11ec-a23d-005056a78fd5" } } }, "operation": "security multi-admin-verify approval-group replace", "_links": { "self": { "href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20approval-group%20replace" } } }, { "owner": { "uuid": "52b75787-7011-11ec-a23d-005056a78fd5", "name": "cluster1", "_links": { "self": { "href": "/api/svm/svms/52b75787-7011-11ec-a23d-005056a78fd5" } } }, "operation": "security multi-admin-verify modify", "_links": { "self": { "href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20modify" } } }, { "owner": { "uuid": "52b75787-7011-11ec-a23d-005056a78fd5", "name": "cluster1", "_links": { "self": { "href": "/api/svm/svms/52b75787-7011-11ec-a23d-005056a78fd5" } } }, "operation": "security multi-admin-verify rule create", "_links": { "self": { "href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20rule%20create" } } }, { "owner": { "uuid": "52b75787-7011-11ec-a23d-005056a78fd5", "name": "cluster1", "_links": { "self": { "href": "/api/svm/svms/52b75787-7011-11ec-a23d-005056a78fd5" } } }, "operation": "security multi-admin-verify rule delete", "_links": { "self": { "href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20rule%20delete" } } }, { "owner": { "uuid": "52b75787-7011-11ec-a23d-005056a78fd5", "name": "cluster1", "_links": { "self": { "href": "/api/svm/svms/52b75787-7011-11ec-a23d-005056a78fd5" } } }, "operation": "security multi-admin-verify rule modify", "_links": { "self": { "href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/security%20multi-admin-verify%20rule%20modify" } } }, { "owner": { "uuid": "52b75787-7011-11ec-a23d-005056a78fd5", "name": "cluster1", "_links": { "self": { "href": "/api/svm/svms/52b75787-7011-11ec-a23d-005056a78fd5" } } }, "operation": "volume delete", "_links": { "self": { "href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/volume%20delete" } } } ], "num_records": 11, "_links": { "self": { "href": "/api/security/multi-admin-verify/rules" } } }
