Storage qtrees endpoint overview
Overview
A qtree is a logically defined file system that can exist as a special subdirectory of the root directory within a FlexVol volume or a FlexGroup volume.
Qtree QoS policy
Qtree QoS policy and settings enforce Service Level Objectives (SLOs) on a qtree. SLOs can be set by specifying "qos_policy.max_throughput_iops" and/or "qos_policy.max_throughput_mbps" or "qos_policy.min_throughput_iops" and/or "qos_policy.min_throughput_mbps". Specifying "min_throughput_iops" or "min_throughput_mbps" is only supported on volumes hosted on a node that is flash optimized. A pre-created QoS policy can also be used by specifying "qos_policy.name" or "qos_policy.uuid" properties. Setting or assigning a QoS policy to a qtree is not supported if its containing volume or SVM has a QoS policy attached, or a file or LUN in its containing volume already has a QoS policy attached.
Performance monitoring
Performance of a qtree can be monitored by observing the statistics.* properties. These properties show the performance of the qtree in terms of IOPS and throughput. The statistics.* properties denote a real-time monotonically increasing value aggregated across all nodes.
Extended performance monitoring
Extended performance monitoring enables the collection of latency statistics and the archival of statistics samples for a qtree. When extended performance monitoring is enabled for a qtree, its performance can be monitored by observing the metric.* and statistics.* properties. These properties show the performance of the qtree in terms of IOPS, latency and throughput. The metric.* properties denote an average whereas statistics.* properties denote a real-time monotonically increasing value aggregated across all nodes.
Extended performance monitoring can be enabled for a qtree using the ext_performance_monitoring.enabled property. A maximum of 50,000 qtrees can have extended performance monitoring enabled on a cluster. If extended performance monitoring is enabled for an existing qtree, the prior statistics.* properties showing the IOPS and throughput performance of the qtree will be cleared.
When extended performance monitoring is enabled for a qtree for the first time in an SVM, existing NFS clients might not be accounted for until their NFS shares associated with the SVM are remounted.
Qtree APIs
The following APIs are used to create, retrieve, modify, and delete qtrees.
– POST /api/storage/qtrees
– GET /api/storage/qtrees
– GET /api/storage/qtrees/{volume-uuid}/{qtree-id}
– PATCH /api/storage/qtrees/{volume-uuid}/{qtree-id}
– DELETE /api/storage/qtrees/{volume-uuid}/{qtree-id}
Creating a qtree inside a volume for an SVM
This API is used to create a qtree inside a volume for an SVM.
The following example shows how to create a qtree in a FlexVol volume with a given security style, user, group, UNIX permissions, an export policy, and a QoS policy.
# The API:
# The call:
curl -X POST 'https://<mgmt-ip>/api/storage/qtrees?return_records=true' -H 'accept: application/hal+json' -d @test_qtree_post.txt
test_qtree_post.txt(body):
"svm": {
"name": "svm1"
"volume": {
"name": "fv"
"name": "qt1",
"security_style": "unix",
"user": {
"name": "unix_user1"
"group": {
"name": "unix_group1"
"unix_permissions": 744,
"export_policy": {
"name": "default"
"qos_policy": {
"max_throughput_iops": 1000
# The response:
"num_records": 1,
"records": [
"svm": {
"name": "svm1"
"volume": {
"name": "fv"
"name": "qt1",
"user": {
"group": {
"export_policy": {
"name": "default"
"qos_policy": {
"min_throughput_iops": 0,
"min_throughput_mbps": 0,
"max_throughput_iops": 1000,
"max_throughput_mbps": 0,
"uuid": "39ac471f-ff35-11e9-b0f9-005056a7ab52",
"name": "vs0_auto_gen_policy_39a9522f_ff35_11e9_b0f9_005056a7ab52"
"href": "/api/storage/qtrees/?volume.name=fv&name=qt1"
"job": {
"uuid": "84edef3c-4f6d-11e9-9a71-005056a7f717",
"href": "/api/cluster/jobs/84edef3c-4f6d-11e9-9a71-005056a7f717"
Retrieving qtrees
This API is used to retrieve qtrees.
The following example shows how to retrieve qtrees belonging to SVM svm1 and volume fv. The svm.name and volume.name query parameters are used to find the required qtrees.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/qtrees/?svm.name=svm1&volume.name=fv" -H 'accept: application/hal+json'
# The response
"records": [
"svm": {
"uuid": "b68f961b-4cee-11e9-930a-005056a7f717",
"name": "svm1",
"href": "/api/svm/svms/b68f961b-4cee-11e9-930a-005056a7f717"
"volume": {
"uuid": "cb20da45-4f6b-11e9-9a71-005056a7f717",
"name": "fv",
"href": "/api/storage/volumes/cb20da45-4f6b-11e9-9a71-005056a7f717"
"id": 0,
"name": "",
"href": "/api/storage/qtrees/cb20da45-4f6b-11e9-9a71-005056a7f717/0"
"svm": {
"name": "svm1",
"volume": {
"name": "fv",
"id": 1,
"name": "qt1",
"href": "/api/storage/qtrees/cb20da45-4f6b-11e9-9a71-005056a7f717/1"
"svm": {
"name": "svm1",
"volume": {
"name": "fv",
"id": 2,
"name": "qt2",
"href": "/api/storage/qtrees/cb20da45-4f6b-11e9-9a71-005056a7f717/2"
"num_records": 3,
"href": "/api/storage/qtrees/?svm.name=svm1&volume.name=fv"
Retrieving properties of a specific qtree using a qtree identifier
This API is used to retrieve properties of a specific qtree using qtree.id.
The following example shows how to use the qtree identifier to retrieve all properties of the qtree using the fields query parameter.
# The API:
GET /api/storage/qtrees/{volume.uuid}/{id}
# The call:
curl -X GET 'https://<mgmt-ip>/api/storage/qtrees/cb20da45-4f6b-11e9-9a71-005056a7f717/2?fields=*' -H 'accept: application/hal+json'
"svm": {
"name": "svm1",
"volume": {
"name": "fv",
"id": 2,
"name": "qt2",
"user": {
"group": {
"export_policy": {
"name": "default",
"id": 12884901889,
"href": "/api/protocols/nfs/export-policies/12884901889"
"qos_policy": {
"name": "vs0_auto_gen_policy_39a9522f_ff35_11e9_b0f9_005056a7ab52",
"href": "/api/storage/qos/policies/39ac471f-ff35-11e9-b0f9-005056a7ab52"
"ext_performance_monitoring": {
"enabled": false
"statistics": {
"timestamp": "2019-04-09T05:50:42Z",
"status": "ok",
"iops_raw": {
"read": 0,
"write": 0,
"other": 3,
"total": 3
"throughput_raw": {
"read": 0,
"write": 0,
"other": 0,
"total": 0
"path": "/fv/qt2",
"nas": {
"path": "/fv/qt2",
Retrieving properties of a specific qtree using the qtree name
This API is used to retrieve properties of a specific qtree using "qtree.name".
The following example shows how to retrieve all of the properties belonging to qtree "qt2". The svm.name and volume.name query parameters are used here along with the qtree name.
# The API:
# The call:
curl -X GET 'https://<mgmt-ip>/api/storage/qtrees/?svm.name=svm1&volume.name=fv&name=qt2&fields=*' -H 'accept: application/hal+json'
"svm": {
"name": "svm1",
"volume": {
"name": "fv",
"id": 2,
"name": "qt2",
"user": {
"group": {
"export_policy": {
"name": "default",
"id": 12884901889,
"qos_policy": {
"enabled": false
"statistics": {
"status": "ok",
"iops_raw": {
"read": 0,
"write": 0,
"other": 3,
"total": 3
"throughput_raw": {
"read": 0,
"write": 0,
"other": 0,
"total": 0
Updating a qtree
This API is used to update a qtree.
The following example shows how to update properties in a qtree.
# The API:
PATCH /api/storage/qtrees/{volume.uuid}/{id}
# The call:
curl -X PATCH 'https://<mgmt-ip>/api/storage/qtrees/cb20da45-4f6b-11e9-9a71-005056a7f717/2' -H 'accept: application/hal+json' -d '@test_qtree_patch.txt'
test_qtree_patch.txt(body):
"security_style": "mixed",
"user": {
"group": {
"unix_permissions": 777,
"export_policy": {
"id": "9",
"name": "exp1"
"qos_policy": {
"uuid": "39ac471f-ff35-11e9-b0f9-005056a7ab53"
Renaming a qtree
This API is used to rename a qtree.
The following example below shows how to rename a qtree with a new name.
# The API:
# The call:
curl -X PATCH 'https://<mgmt-ip>/api/storage/qtrees/cb20da45-4f6b-11e9-9a71-005056a7f717/1' -H 'accept: application/hal+json' -d '{ "name": "new_qt1" }'
Deleting a qtree inside a volume of an SVM
This API is used to delete a qtree inside a volume of an SVM.
The following example shows how to delete a qtree.
# The API:
DELETE /api/storage/qtrees/{volume.uuid}/{id}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/storage/qtrees/cb20da45-4f6b-11e9-9a71-005056a7f717/2" -H 'accept: application/hal+json'
Enabling extended performance monitoring on a qtree using PATCH
This API is used to enable extended performance monitoring on a qtree.
The following example shows how to enable extended performance monitoring on a qtree.
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/qtrees/cb20da45-4f6b-11e9-9a71-005056a7f717/1" -H 'accept: application/hal+json' -d '{ "ext_performance_monitoring": { "enabled": "true" }}'
Disabling extended performance monitoring on a qtree using PATCH
This API is used to disable extended performance monitoring on a qtree.
The following example shows how to disable extended performance monitoring on a qtree.
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/storage/qtrees/cb20da45-4f6b-11e9-9a71-005056a7f717/1" -H 'accept: application/hal+json' -d '{ "ext_performance_monitoring": { "enabled": "false" }}'
Retrieving performance properties for a qtree which has extended performance monitoring enabled
The following example shows how to use a GET request to retrieve performance properties for a qtree which has extended performance monitoring enabled.
# The API:
# The call:
curl -X GET 'https://<mgmt-ip>/api/storage/qtrees/cb20da45-4f6b-11e9-9a71-005056a7f717/3?fields=ext_performance_monitoring,statistics,metric' -H 'accept: application/hal+json'
"volume": {
"name": "fv",
"id": 3,
"name": "qt3",
"enabled": true
"statistics": {
"status": "ok",
"iops_raw": {
"read": 0,
"write": 0,
"other": 0,
"total": 0
"throughput_raw": {
"read": 0,
"write": 0,
"other": 0,
"total": 0
"latency_raw": {
"read": 0,
"write": 0,
"other": 0,
"total": 0
"metric": {
"timestamp": "2019-04-09T05:50:00Z",
"duration": "PT5M",
"status": "ok",
"iops": {
"read": 0,
"write": 0,
"other": 0,
"total": 0
"throughput": {
"read": 0,
"write": 0,
"other": 0,
"total": 0
"latency": {
"read": 0,
"write": 0,
"other": 0,
"total": 0
"href": "/api/storage/qtrees/cb20da45-4f6b-11e9-9a71-005056a7f717/3"
