REST API reference
Delete a WebAuthn credentials entry
DELETE /security/webauthn/credentials/{owner.uuid}/{username}/{index}/{relying_party.id}
Introduced In: 9.16
Deletes a WebAuthn credentials entry.
Required properties
  • owner.uuid
  • username
  • index
  • relying_party.id
  • security webauthn credentials delete
owner.uuid
string
path
True
Used to identify a cluster or an SVM.
username
string
path
True
Username.
index
integer
path
True
Index.
relying_party.id
string
path
True
Relying Party ID.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Status: Default, Error
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
