Delete a WebAuthn credentials entry
Removes a WebAuthn credentials entry when it is no longer needed for authentication. This helps manage and maintain security by ensuring only valid credentials are retained.
HTTP method and endpoint
DELETE /security/webauthn/credentials/{owner.uuid}/{username}/{index}/{relying_party.id}
Introduced in
ONTAP 9.16
Usage notes
Deletes a WebAuthn credentials entry.
Required properties
owner.uuid -
username -
index -
relying_party.id
Related ONTAP commands
security webauthn credentials delete
owner.uuid |
string |
path |
True |
Used to identify a cluster or an SVM. |
username |
string |
path |
True |
Username. |
index |
integer |
path |
True |
Index. |
relying_party.id |
string |
path |
True |
Relying Party ID. |
fields |
array[string] |
query |
False |
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
