REST API reference
Delete an SNMP traphost
Deletes an SNMP traphost to remove it from the list of configured traphosts. This action is typically used when a traphost is no longer needed or requires reconfiguration.
HTTP method and endpoint
DELETE /support/snmp/traphosts/{host}
Introduced in
ONTAP 9.7
host
string
path
True
Fully Qualified Domain Name (FQDN), IPv4 address or IPv6 address of SNMP traphost.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
8847365
Unknown host.
9043970
Traphost entry does not exist.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
