Delete an SNMP traphost
Deletes an SNMP traphost when you need to remove an existing traphost configuration.
HTTP method and endpoint
DELETE /support/snmp/traphosts/{host}
Introduced in
ONTAP 9.7
Learn more
host |
string |
path |
True |
Fully Qualified Domain Name (FQDN), IPv4 address or IPv6 address of SNMP traphost. |
return_timeout |
integer |
query |
False |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
9043970 |
Traphost entry does not exist. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
