Delete SVM peer permissions
Deletes SVM peer permissions to manage access controls between different storage virtual machines (SVMs). Use this operation to remove outdated or unnecessary permission settings.
HTTP method and endpoint
DELETE /svm/peer-permissions/{cluster_peer.uuid}/{svm.uuid}
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver peer permission delete
Example
Deletes an SVM peer permission.
DELETE "/api/svm/peer-permissions/d3268a74-ee76-11e8-a9bb-005056ac6dc9/8f467b93-f2f1-11e8-9027-005056ac81fc"
Learn more
cluster_peer.uuid |
string |
path |
True |
Peer cluster UUID
svm.uuid |
string |
path |
True |
SVM UUID |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error codes | Description |
26345574 |
Failed to find the SVM or volume name with UUID. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
