Delete SVM peer permissions
Deletes SVM peer permissions to manage access between storage virtual machines effectively.
HTTP method and endpoint
DELETE /svm/peer-permissions/{cluster_peer.uuid}/{svm.uuid}
Introduced in
ONTAP 9.6
Related ONTAP commands
verver peer permission delete
Example
Deletes an SVM peer permission.
DELETE "/api/svm/peer-permissions/d3268a74-ee76-11e8-a9bb-005056ac6dc9/8f467b93-f2f1-11e8-9027-005056ac81fc"
Learn more
cluster_peer.uuid |
string |
path |
True |
Peer cluster UUID
svm.uuid |
string |
path |
True |
SVM UUID |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error codes | Description |
26345574 |
Failed to find the SVM or volume name with UUID. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
