REST API reference
Deletes the svm peer permissions
example
deletes an svm peer permission <br/>
delete "/api/svm/peer-permissions/d3268a74-ee76-11e8-a9bb-005056ac6dc9/8f467b93-f2f1-11e8-9027-005056ac81fc"
<br/> # learn more * [doc /svm/peer-permissions](#docs-svm-svm_peer-permissions)
DELETE /svm/peer-permissions/{cluster.uuid}/{svm.uuid}
Deletes the SVM peer permissions.
  • verver peer permission delete
Example
Deletes an SVM peer permission.
DELETE "/api/svm/peer-permissions/d3268a74-ee76-11e8-a9bb-005056ac6dc9/8f467b93-f2f1-11e8-9027-005056ac81fc"
cluster.uuid
string
path
True
svm.uuid
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error codes Description
26345574
Failed to find the SVM or volume name with UUID.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
