Retrieve the nodes in a cluster
Retrieves information about the nodes present in your cluster. This endpoint is useful for understanding the current configuration and status of each node.
HTTP method and endpoint
GET /cluster/nodes
Introduced in
ONTAP 9.6
Usage notes
Retrieves the nodes in the cluster.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
statistics.* -
metric.*
Related ONTAP commands
system node show
snaplock.compliance_clock_time |
string |
query |
False |
Filter by snaplock.compliance_clock_time
nvlog.backing_type |
string |
query |
False |
Filter by nvlog.backing_type
nvlog.swap_mode |
string |
query |
False |
Filter by nvlog.swap_mode
external_cache_bypass.enabled |
boolean |
query |
False |
Filter by external_cache_bypass.enabled
external_cache_bypass.large_read_ops_allow_percent |
integer |
query |
False |
Filter by external_cache_bypass.large_read_ops_allow_percent
cluster_interfaces.uuid |
string |
query |
False |
Filter by cluster_interfaces.uuid |
cluster_interfaces.name |
string |
query |
False |
Filter by cluster_interfaces.name |
cluster_interfaces.ip.address |
string |
query |
False |
Filter by cluster_interfaces.ip.address |
date |
string |
query |
False |
Filter by date |
serial_number |
string |
query |
False |
Filter by serial_number |
statistics.processor_utilization_raw |
integer |
query |
False |
Filter by statistics.processor_utilization_raw
statistics.status |
string |
query |
False |
Filter by statistics.status
statistics.timestamp |
string |
query |
False |
Filter by statistics.timestamp
statistics.processor_utilization_base |
integer |
query |
False |
Filter by statistics.processor_utilization_base
membership |
string |
query |
False |
Filter by membership |
anti_ransomware_version |
string |
query |
False |
Filter by anti_ransomware_version
location |
string |
query |
False |
Filter by location |
system_id |
string |
query |
False |
Filter by system_id
model |
string |
query |
False |
Filter by model |
owner |
string |
query |
False |
Filter by owner
system_aggregate.uuid |
string |
query |
False |
Filter by system_aggregate.uuid
system_aggregate.name |
string |
query |
False |
Filter by system_aggregate.name
system_machine_type |
string |
query |
False |
Filter by system_machine_type
vm.provider_type |
string |
query |
False |
Filter by vm.provider_type
external_cache.pcs_size |
integer |
query |
False |
Filter by external_cache.pcs_size
external_cache.is_rewarm_enabled |
boolean |
query |
False |
Filter by external_cache.is_rewarm_enabled
external_cache.is_enabled |
boolean |
query |
False |
Filter by external_cache.is_enabled
external_cache.is_hya_enabled |
boolean |
query |
False |
Filter by external_cache.is_hya_enabled
storage_configuration |
string |
query |
False |
Filter by storage_configuration
name |
string |
query |
False |
Filter by name |
metrocluster.type |
string |
query |
False |
Filter by metrocluster.type
metrocluster.ports.name |
string |
query |
False |
Filter by metrocluster.ports.name
metrocluster.custom_vlan_capable |
boolean |
query |
False |
Filter by metrocluster.custom_vlan_capable
vendor_serial_number |
string |
query |
False |
Filter by vendor_serial_number
metric.uuid |
string |
query |
False |
Filter by metric.uuid
metric.processor_utilization |
integer |
query |
False |
Filter by metric.processor_utilization
metric.timestamp |
string |
query |
False |
Filter by metric.timestamp
metric.duration |
string |
query |
False |
Filter by metric.duration
metric.status |
string |
query |
False |
Filter by metric.status
state |
string |
query |
False |
Filter by state
version.generation |
integer |
query |
False |
Filter by version.generation |
version.major |
integer |
query |
False |
Filter by version.major |
version.minor |
integer |
query |
False |
Filter by version.minor |
version.full |
string |
query |
False |
Filter by version.full |
is_spares_low |
boolean |
query |
False |
Filter by is_spares_low
service_processor.ipv4_interface.enabled |
boolean |
query |
False |
Filter by service_processor.ipv4_interface.enabled
service_processor.ipv4_interface.netmask |
string |
query |
False |
Filter by service_processor.ipv4_interface.netmask |
service_processor.ipv4_interface.gateway |
string |
query |
False |
Filter by service_processor.ipv4_interface.gateway |
service_processor.ipv4_interface.address |
string |
query |
False |
Filter by service_processor.ipv4_interface.address |
service_processor.ipv4_interface.setup_state |
string |
query |
False |
Filter by service_processor.ipv4_interface.setup_state
service_processor.type |
string |
query |
False |
Filter by service_processor.type
service_processor.autoupdate_enabled |
boolean |
query |
False |
Filter by service_processor.autoupdate_enabled
service_processor.backup.state |
string |
query |
False |
Filter by service_processor.backup.state
service_processor.backup.version |
string |
query |
False |
Filter by service_processor.backup.version
service_processor.backup.is_current |
boolean |
query |
False |
Filter by service_processor.backup.is_current
service_processor.last_update_state |
string |
query |
False |
Filter by service_processor.last_update_state
service_processor.auto_config.ipv6_subnet |
string |
query |
False |
Filter by service_processor.auto_config.ipv6_subnet
service_processor.auto_config.ipv4_subnet |
string |
query |
False |
Filter by service_processor.auto_config.ipv4_subnet
service_processor.dhcp_enabled |
boolean |
query |
False |
Filter by service_processor.dhcp_enabled |
service_processor.link_status |
string |
query |
False |
Filter by service_processor.link_status |
service_processor.ssh_info.allowed_addresses |
string |
query |
False |
Filter by service_processor.ssh_info.allowed_addresses
service_processor.firmware_version |
string |
query |
False |
Filter by service_processor.firmware_version |
service_processor.web_service.enabled |
boolean |
query |
False |
Filter by service_processor.web_service.enabled
service_processor.web_service.limit_access |
boolean |
query |
False |
Filter by service_processor.web_service.limit_access
service_processor.state |
string |
query |
False |
Filter by service_processor.state |
service_processor.is_ip_configured |
boolean |
query |
False |
Filter by service_processor.is_ip_configured
service_processor.ipv6_interface.setup_state |
string |
query |
False |
Filter by service_processor.ipv6_interface.setup_state
service_processor.ipv6_interface.gateway |
string |
query |
False |
Filter by service_processor.ipv6_interface.gateway |
service_processor.ipv6_interface.router_ip |
string |
query |
False |
Filter by service_processor.ipv6_interface.router_ip
service_processor.ipv6_interface.link_local_ip |
string |
query |
False |
Filter by service_processor.ipv6_interface.link_local_ip
service_processor.ipv6_interface.address |
string |
query |
False |
Filter by service_processor.ipv6_interface.address |
service_processor.ipv6_interface.enabled |
boolean |
query |
False |
Filter by service_processor.ipv6_interface.enabled
service_processor.ipv6_interface.netmask |
integer |
query |
False |
Filter by service_processor.ipv6_interface.netmask |
service_processor.ipv6_interface.is_ipv6_ra_enabled |
boolean |
query |
False |
Filter by service_processor.ipv6_interface.is_ipv6_ra_enabled
service_processor.mac_address |
string |
query |
False |
Filter by service_processor.mac_address |
service_processor.primary.version |
string |
query |
False |
Filter by service_processor.primary.version
service_processor.primary.is_current |
boolean |
query |
False |
Filter by service_processor.primary.is_current
service_processor.primary.state |
string |
query |
False |
Filter by service_processor.primary.state
service_processor.api_service.limit_access |
boolean |
query |
False |
Filter by service_processor.api_service.limit_access
service_processor.api_service.enabled |
boolean |
query |
False |
Filter by service_processor.api_service.enabled
service_processor.api_service.port |
integer |
query |
False |
Filter by service_processor.api_service.port
uuid |
string |
query |
False |
Filter by uuid |
uptime |
integer |
query |
False |
Filter by uptime |
controller.memory_size |
integer |
query |
False |
Filter by controller.memory_size
controller.flash_cache.slot |
string |
query |
False |
Filter by controller.flash_cache.slot |
controller.flash_cache.firmware_file |
string |
query |
False |
Filter by controller.flash_cache.firmware_file
controller.flash_cache.model |
string |
query |
False |
Filter by controller.flash_cache.model |
controller.flash_cache.device_id |
integer |
query |
False |
Filter by controller.flash_cache.device_id
controller.flash_cache.capacity |
integer |
query |
False |
Filter by controller.flash_cache.capacity |
controller.flash_cache.state |
string |
query |
False |
Filter by controller.flash_cache.state |
controller.flash_cache.hardware_revision |
string |
query |
False |
Filter by controller.flash_cache.hardware_revision |
controller.flash_cache.part_number |
string |
query |
False |
Filter by controller.flash_cache.part_number |
controller.flash_cache.firmware_version |
string |
query |
False |
Filter by controller.flash_cache.firmware_version |
controller.flash_cache.serial_number |
string |
query |
False |
Filter by controller.flash_cache.serial_number |
controller.over_temperature |
string |
query |
False |
Filter by controller.over_temperature |
controller.failed_power_supply.message.message |
string |
query |
False |
Filter by controller.failed_power_supply.message.message
controller.failed_power_supply.message.code |
string |
query |
False |
Filter by controller.failed_power_supply.message.code
controller.failed_power_supply.count |
integer |
query |
False |
Filter by controller.failed_power_supply.count
controller.cpu.count |
integer |
query |
False |
Filter by controller.cpu.count
controller.cpu.processor |
string |
query |
False |
Filter by controller.cpu.processor
controller.cpu.firmware_release |
string |
query |
False |
Filter by controller.cpu.firmware_release
controller.failed_fan.message.message |
string |
query |
False |
Filter by controller.failed_fan.message.message
controller.failed_fan.message.code |
string |
query |
False |
Filter by controller.failed_fan.message.code
controller.failed_fan.count |
integer |
query |
False |
Filter by controller.failed_fan.count
controller.board |
string |
query |
False |
Filter by controller.board
controller.frus.state |
string |
query |
False |
Filter by controller.frus.state |
controller.frus.id |
string |
query |
False |
Filter by controller.frus.id |
controller.frus.type |
string |
query |
False |
Filter by controller.frus.type |
hw_assist.status.partner.port |
integer |
query |
False |
Filter by hw_assist.status.partner.port
hw_assist.status.partner.state |
string |
query |
False |
Filter by hw_assist.status.partner.state
hw_assist.status.partner.ip |
string |
query |
False |
Filter by hw_assist.status.partner.ip
hw_assist.status.local.port |
integer |
query |
False |
Filter by hw_assist.status.local.port
hw_assist.status.local.state |
string |
query |
False |
Filter by hw_assist.status.local.state
hw_assist.status.local.ip |
string |
query |
False |
Filter by hw_assist.status.local.ip
hw_assist.status.enabled |
boolean |
query |
False |
Filter by hw_assist.status.enabled
ha.takeover_check.reasons |
string |
query |
False |
Filter by ha.takeover_check.reasons
ha.takeover_check.takeover_possible |
boolean |
query |
False |
Filter by ha.takeover_check.takeover_possible
ha.type |
string |
query |
False |
Filter by ha.type
ha.interconnect.adapter |
string |
query |
False |
Filter by ha.interconnect.adapter
ha.interconnect.state |
string |
query |
False |
Filter by ha.interconnect.state
ha.auto_giveback |
boolean |
query |
False |
Filter by ha.auto_giveback |
ha.partners.uuid |
string |
query |
False |
Filter by ha.partners.uuid |
ha.partners.name |
string |
query |
False |
Filter by ha.partners.name |
ha.giveback.status.aggregate.uuid |
string |
query |
False |
Filter by ha.giveback.status.aggregate.uuid
ha.giveback.status.aggregate.name |
string |
query |
False |
Filter by ha.giveback.status.aggregate.name
ha.giveback.status.state |
string |
query |
False |
Filter by ha.giveback.status.state
ha.giveback.status.error.message |
string |
query |
False |
Filter by ha.giveback.status.error.message
ha.giveback.status.error.code |
string |
query |
False |
Filter by ha.giveback.status.error.code
ha.giveback.failure.message |
string |
query |
False |
Filter by ha.giveback.failure.message
ha.giveback.failure.code |
integer |
query |
False |
Filter by ha.giveback.failure.code
ha.giveback.state |
string |
query |
False |
Filter by ha.giveback.state
ha.ports.number |
integer |
query |
False |
Filter by ha.ports.number
ha.ports.state |
string |
query |
False |
Filter by ha.ports.state
ha.takeover.state |
string |
query |
False |
Filter by ha.takeover.state
ha.takeover.failure.code |
integer |
query |
False |
Filter by ha.takeover.failure.code
ha.takeover.failure.message |
string |
query |
False |
Filter by ha.takeover.failure.message
ha.enabled |
boolean |
query |
False |
Filter by ha.enabled |
management_interfaces.uuid |
string |
query |
False |
Filter by management_interfaces.uuid |
management_interfaces.name |
string |
query |
False |
Filter by management_interfaces.name |
management_interfaces.ip.address |
string |
query |
False |
Filter by management_interfaces.ip.address |
nvram.battery_state |
string |
query |
False |
Filter by nvram.battery_state
nvram.id |
integer |
query |
False |
Filter by nvram.id
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"anti_ransomware_version": "1.0",
"cluster_interfaces": [
"ip": {
"address": "10.10.10.7"
"name": "lif1",
"controller": {
"board": "System Board XXVIII",
"cpu": {
"count": 20,
"firmware_release": "string",
"processor": "string"
"failed_fan": {
"count": 1,
"message": {
"code": "111411207",
"message": "There are no failed fans."
"failed_power_supply": {
"count": 1,
"message": {
"code": "111411208",
"message": "There are no failed power supplies."
"flash_cache": [
"capacity": 1024000000000,
"device_id": 0,
"firmware_file": "X9170_O000Z6300NVM",
"firmware_version": "NA05",
"hardware_revision": "A1",
"model": "X1970A",
"part_number": "119-00207",
"serial_number": "A22P5061550000187",
"slot": "6-1",
"state": "string"
"frus": [
"id": "string",
"state": "string",
"type": "string"
"memory_size": 1024000000,
"over_temperature": "string"
"date": "2019-04-17 11:49:26 -0400",
"external_cache": {
"is_enabled": 1,
"is_hya_enabled": 1,
"is_rewarm_enabled": 1
"external_cache_bypass": {
"enabled": 1,
"large_read_ops_allow_percent": 100,
"reset": 1
"ha": {
"giveback": {
"failure": {
"code": 852126,
"message": "Failed to initiate giveback. Run the \"storage failover show-giveback\" command for more information."
"state": "failed",
"status": [
"aggregate": {
"name": "aggr1",
"error": {
"code": "852126",
"message": "string"
"state": "string"
"interconnect": {
"adapter": "MVIA-RDMA",
"state": "string"
"partners": [
"name": "node1",
"ports": [
"number": 0,
"state": "active"
"takeover": {
"failure": {
"code": 852130,
"message": "Failed to initiate takeover. Run the \"storage failover show-takeover\" command for more information."
"state": "failed"
"takeover_check": {
"reasons": [
"string"
"type": "string"
"hw_assist": {
"status": {
"local": {
"ip": "string",
"state": "string"
"partner": {
"ip": "string",
"state": "string"
"location": "rack 2 row 5",
"management_interfaces": [
"ip": {
"name": "lif1",
"membership": "string",
"metric": {
"duration": "PT15S",
"processor_utilization": 13,
"status": "ok",
"timestamp": "2017-01-25 06:20:13 -0500",
"metrocluster": {
"ports": [
"name": "e1b"
"type": "string"
"model": "FAS3070",
"name": "node-01",
"nvlog": {
"backing_type": "string",
"swap_mode": "string"
"nvram": {
"battery_state": "string",
"id": 0
"owner": "Example Corp",
"serial_number": "4048820-60-9",
"service_processor": {
"api_service": {
"port": 0
"auto_config": {
"ipv4_subnet": "ipv4_mgmt",
"ipv6_subnet": "ipv6_mgmt"
"backup": {
"state": "string",
"version": "11.6"
"firmware_version": "string",
"ipv4_interface": {
"address": "10.10.10.7",
"gateway": "10.1.1.1",
"netmask": "255.255.0.0",
"setup_state": "string"
"ipv6_interface": {
"address": "fd20:8b1e:b255:5011:10:141:4:97",
"gateway": "fd20:8b1e:b255:5011:10::1",
"link_local_ip": "FE80::/10",
"netmask": 64,
"router_ip": "2001:0db8:85a3:0000:0000:8a2e:0370:7334",
"last_update_state": "string",
"link_status": "string",
"mac_address": "string",
"primary": {
"state": "string",
"version": "11.6"
"ssh_info": {
"allowed_addresses": [
"10.10.10.7/24"
"state": "string",
"type": "string"
"snaplock": {
"compliance_clock_time": "2018-06-04 15:00:00 -0400"
"state": "string",
"statistics": {
"processor_utilization_base": 12345123,
"processor_utilization_raw": 13,
"status": "ok",
"storage_configuration": "string",
"system_aggregate": {
"name": "aggr1",
"system_id": 92027651,
"system_machine_type": "7Y56-CTOWW1",
"uptime": 300536,
"uuid": "4ea7a442-86d1-11e0-ae1c-123478563412",
"vendor_serial_number": 791603000068,
"version": {
"full": "NetApp Release 9.4.0: Sun Nov 05 18:20:57 UTC 2017",
"generation": 9,
"major": 4,
"minor": 0
"vm": {
"provider_type": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
node_setup_ip
The IP configuration for cluster setup.
address |
string |
IPv4 or IPv6 address |
cluster_interface
The cluster network IP address of the node to be added.
ip
IP information
address |
string |
cluster_interfaces
Network interface
_links |
ip |
IP information |
name |
string |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the interface. |
cpu
CPU information.
count |
integer |
Number of CPUs on the node. |
firmware_release |
string |
Firmware release number. Defined by the CPU manufacturer. |
processor |
string |
CPU type on the node. |
message
code |
string |
Error code describing the current condition of chassis fans. |
message |
string |
Message describing the current condition of chassis fans. It is only of use when |
failed_fan
count |
integer |
Specifies a count of the number of chassis fans that are not operating within the recommended RPM range. |
message |
message
code |
string |
Error code describing the current condition of power supply. |
message |
string |
Message describing the state of any power supplies that are currently degraded. It is only of use when |
failed_power_supply
count |
integer |
Number of failed power supply units. |
message |
flash_cache
capacity |
integer |
Size in bytes |
device_id |
integer |
firmware_file |
string |
firmware_version |
string |
hardware_revision |
string |
model |
string |
part_number |
string |
serial_number |
string |
slot |
string |
state |
string |
frus
id |
string |
state |
string |
type |
string |
controller
Controller information
board |
string |
Type of the system board. This is defined by vendor. |
cpu |
CPU information. |
failed_fan |
failed_power_supply |
flash_cache |
array[flash_cache] |
A list of Flash-Cache devices. Only returned when requested by name. |
frus |
array[frus] |
List of FRUs on the node. Only returned when requested by name. |
memory_size |
integer |
Memory available on the node, in bytes. |
over_temperature |
string |
Specifies whether the hardware is currently operating outside of its recommended temperature range. The hardware shuts down if the temperature exceeds critical thresholds. |
external_cache
Cache used for buffer management.
is_enabled |
boolean |
Indicates whether the external cache is enabled. |
is_hya_enabled |
boolean |
Indicates whether HyA caching is enabled. |
is_rewarm_enabled |
boolean |
Indicates whether rewarm is enabled. |
pcs_size |
integer |
PCS size in gigabytes. |
External cache bypass management.
enabled |
boolean |
Indicates whether external cache bypass is enabled. |
integer |
External cache bypass allowed operations percentage for large reads. |
reset |
boolean |
Initiates an external cache bypass threshold reset action. |
failure
Indicates the failure code and message. This property is not supported on the ASA r2 platform.
code |
integer |
Message code |
message |
string |
Detailed message based on the state. |
aggregate
Aggregate name and UUID.
_links |
name |
string |
uuid |
string |
error
Indicates the failed aggregate giveback code and message.
code |
string |
Message code. |
message |
string |
status
aggregate |
Aggregate name and UUID. |
error |
Indicates the failed aggregate giveback code and message. |
state |
string |
Giveback state of the aggregate. Possible values include no aggregates to giveback(nothing_to_giveback), failed to disable background disk firmware update(BDFU) on source node(failed_bdfu_source), giveback delayed as disk firmware update is in progress on source node(delayed_bdfu_source), performing veto checks(running_checks). |
giveback
Represents the state of the node that is giving storage back to its HA partner.
failure |
Indicates the failure code and message. This property is not supported on the ASA r2 platform. |
state |
string |
status |
array[status] |
Giveback status of each aggregate. This property is not supported on the ASA r2 platform. |
interconnect
adapter |
string |
HA interconnect device name. |
state |
string |
Indicates the HA interconnect status. |
partners
_links |
name |
string |
uuid |
string |
ports
number |
integer |
HA port number |
state |
string |
HA port state:
takeover
This represents the state of the node that is taking over storage from its HA partner.
failure |
state |
string |
takeover_check
The takeover check response.
reasons |
array[string] |
Reasons why the takeover is not possible. |
takeover_possible |
boolean |
Indicates whether the takeover is possible. |
ha
auto_giveback |
boolean |
Specifies whether giveback is automatically initiated when the node that owns the storage is ready. |
enabled |
boolean |
Specifies whether or not storage failover is enabled. |
giveback |
Represents the state of the node that is giving storage back to its HA partner. |
interconnect |
partners |
array[partners] |
Nodes in this node's High Availability (HA) group. |
ports |
array[ports] |
takeover |
This represents the state of the node that is taking over storage from its HA partner. |
takeover_check |
The takeover check response. |
type |
string |
Type of storage. |
local
ip |
string |
The hardware assist IP address. |
port |
integer |
The hardware assist port. |
state |
string |
The hardware assist monitor status. |
partner
ip |
string |
port |
integer |
state |
string |
status
enabled |
boolean |
Indicates whether hardware assist is enabled on the node. |
local |
partner |
hw_assist
The hardware assist information.
status |
The management interface of the node to be added. The subnet mask is set based on the management interface of the cluster or the management interfaces of other nodes.
Network interface
_links |
ip |
IP information |
name |
string |
uuid |
string |
metric
CPU performance for the nodes.
_links |
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
integer |
Average CPU Utilization for the node |
status |
string |
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
timestamp |
string |
The timestamp of the performance data. |
uuid |
string |
ports
name |
string |
metrocluster
Metrocluster
boolean |
Indicates whether the MetroCluster over IP platform supports custom VLAN IDs. |
ports |
array[ports] |
MetroCluster over IP ports. |
type |
string |
The Metrocluster configuration type |
nvlog
Non-volatile write log settings.
backing_type |
string |
Indicates the current NVLog journal backing type. |
swap_mode |
string |
Indicates the current NVLog journal swap mode. |
nvram
battery_state |
string |
Specifies status of the NVRAM battery. Possible values:
id |
integer |
Vendor specific NVRAM ID of the node. |
api_service
Provides the properties of the service processor (SP) or baseboard management controller (BMC) API service.
enabled |
boolean |
Indicates whether the SP API service of the SP or BMC is enabled or disabled. When the SP API service is disabled, features such as network-based firmware updates and network-based down node log collection are not available, and the slower serial-interface is used for firmware updates and down node log collection. |
limit_access |
boolean |
Restricts SP API service access to cluster nodes only. By default, limit_access is set to true. |
port |
integer |
Specifies the port number on the SP or BMC used for the SP API service. By default, port 50000 is used. |
auto_config
Provides the properties of the service processor auto configuration.
ipv4_subnet |
string |
Indicates the service processor auto configuration IPv4 subnet name. To enable IPv4 auto-config give the subnet name, give the value as null or an empty string "" to disable auto-config. |
ipv6_subnet |
string |
Indicates the service processor auto configuration IPv6 subnet name. To enable IPv6 auto-config give the subnet name, give the value as null or an empty string "" to disable auto-config. |
backup
Provides the properties of the service processor backup partition.
is_current |
boolean |
Indicates whether the service processor is currently booted from the backup partition. |
state |
string |
Status of the backup partition. |
version |
string |
Firmware version of the backup partition. |
ipv4_interface
Object to set up an interface along with its default router.
address |
string |
IPv4 address |
enabled |
boolean |
Indicates whether the IPv4 interfaces is enabled. It expects dhcp_enabled as "true" or values for address, netmask and gateway when set to "true". |
gateway |
string |
The IPv4 address of the default router. |
netmask |
string |
Input as IPv4 mask (255.255.0.0). Output is always the netmask length. |
setup_state |
string |
Indicates the setup state of the interface. |
ipv6_interface
Object to setup an interface along with its default router.
address |
string |
IPv6 address |
enabled |
boolean |
Indicates whether the IPv6 interfaces is enabled. It expects values for address, netmask and gateway when set to "true". |
gateway |
string |
The IPv6 address of the default router. |
boolean |
Indicates whether IPv6 RA is enabled. |
link_local_ip |
string |
Link local IP address. |
netmask |
integer |
The IPv6 netmask/prefix length. The default value is 64 with a valid range of 1 to 127. |
router_ip |
string |
Router assigned IP address. |
setup_state |
string |
primary
Provides the properties of the service processor primary partition.
is_current |
boolean |
Indicates whether the service processor is currently booted from the primary partition. |
state |
string |
Status of the primary partition. |
version |
string |
Firmware version of the primary partition. |
ssh_info
Service processor SSH allowed IP address configuration applied across the cluster.
allowed_addresses |
array[string] |
Allowed IP addresses |
web_service
Provides the properties of SP or BMC web service.
enabled |
boolean |
Indicates whether the web service of the SP or BMC is enabled or disabled. When the web service is disabled, features such as network-based firmware updates and network-based down node log collection are not available, and the slower serial-interface is used for firmware updates and down node log collection. |
limit_access |
boolean |
Restricts web service access to cluster nodes only. By default, limit_access is set to true. |
service_processor
api_service |
Provides the properties of the service processor (SP) or baseboard management controller (BMC) API service. |
auto_config |
Provides the properties of the service processor auto configuration. |
boolean |
Indicates whether the service processor can be automatically updated from ONTAP.
backup |
Provides the properties of the service processor backup partition. |
dhcp_enabled |
boolean |
Set to "true" to use DHCP to configure an IPv4 interface. Do not provide values for address, netmask and gateway when set to "true". |
firmware_version |
string |
The version of firmware installed. |
ipv4_interface |
Object to set up an interface along with its default router. |
ipv6_interface |
Object to setup an interface along with its default router. |
is_ip_configured |
boolean |
Indicates whether the service processor network is configured. |
last_update_state |
string |
Provides the "update status" of the last service processor update. |
link_status |
string |
mac_address |
string |
primary |
Provides the properties of the service processor primary partition. |
ssh_info |
Service processor SSH allowed IP address configuration applied across the cluster. |
state |
string |
type |
string |
web_service |
Provides the properties of SP or BMC web service. |
snaplock
SnapLock-related properties.
string |
SnapLock compliance clock time. |
statistics
Raw CPU performance for the nodes.
integer |
Base counter for CPU Utilization. |
integer |
Raw CPU utilization for the node. The change in this value over time should be divided by corresponding change in processor_utilization_base, then multiplied by 100 to calculate the percentage CPU utilization for the node. For example: processor_utilization_raw_t2 - processor_utilization_raw_t1) / (processor_utilization_base_t2 - processor_utilization_base_t1 * 100. |
status |
string |
timestamp |
string |
system_aggregate
Aggregate
_links |
name |
string |
uuid |
string |
version
This returns the cluster version information. When the cluster has more than one node, the cluster version is equivalent to the lowest of generation, major, and minor versions on all nodes.
full |
string |
The full cluster version string. |
generation |
integer |
The generation portion of the version. |
major |
integer |
The major portion of the version. |
minor |
integer |
The minor portion of the version. |
vm
provider_type |
string |
Cloud provider where the VM is hosted. |
records
Complete node information
_links |
string |
Anti ransomware version. |
cluster_interfaces |
array[cluster_interfaces] |
controller |
Controller information |
date |
string |
The current or "wall clock" time of the node in ISO-8601 date, time, and time zone format. The ISO-8601 date and time are localized based on the ONTAP cluster's timezone setting.
external_cache |
Cache used for buffer management. |
external_cache_bypass |
External cache bypass management. |
ha |
hw_assist |
The hardware assist information. |
is_spares_low |
boolean |
Specifies whether or not the node is in spares low condition. |
location |
string |
management_interfaces |
array[management_interfaces] |
membership |
string |
Possible values:
metric |
CPU performance for the nodes. |
metrocluster |
Metrocluster |
model |
string |
name |
string |
nvlog |
Non-volatile write log settings. |
nvram |
owner |
string |
Owner of the node. |
serial_number |
string |
service_processor |
snaplock |
SnapLock-related properties. |
state |
string |
State of the node:
statistics |
Raw CPU performance for the nodes. |
string |
The storage configuration in the system. Possible values:
system_aggregate |
Aggregate |
system_id |
string |
string |
OEM system machine type. |
uptime |
integer |
The total time, in seconds, that the node has been up. |
uuid |
string |
string |
OEM vendor serial number. |
version |
This returns the cluster version information. When the cluster has more than one node, the cluster version is equivalent to the lowest of generation, major, and minor versions on all nodes. |
vm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
