Retrieves the nodes in the cluster
statistics* -
metric*# related ontap commands -
system node show
GET /cluster/nodes
Introduced In: 9.6
Retrieves the nodes in the cluster.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
statistics.* -
metric.*
Related ONTAP commands
system node show
vm.provider_type |
string |
query |
False |
Filter by vm.provider_type
storage_configuration |
string |
query |
False |
Filter by storage_configuration
statistics.timestamp |
string |
query |
False |
Filter by statistics.timestamp
statistics.processor_utilization_base |
integer |
query |
False |
Filter by statistics.processor_utilization_base
statistics.processor_utilization_raw |
integer |
query |
False |
Filter by statistics.processor_utilization_raw
statistics.status |
string |
query |
False |
Filter by statistics.status
date |
string |
query |
False |
Filter by date |
owner |
string |
query |
False |
Filter by owner
system_id |
string |
query |
False |
Filter by system_id
vendor_serial_number |
string |
query |
False |
Filter by vendor_serial_number
membership |
string |
query |
False |
Filter by membership |
controller.over_temperature |
string |
query |
False |
Filter by controller.over_temperature |
controller.failed_power_supply.message.code |
string |
query |
False |
Filter by controller.failed_power_supply.message.code
controller.failed_power_supply.message.message |
string |
query |
False |
Filter by controller.failed_power_supply.message.message
controller.failed_power_supply.count |
integer |
query |
False |
Filter by controller.failed_power_supply.count
controller.memory_size |
integer |
query |
False |
Filter by controller.memory_size
controller.cpu.processor |
string |
query |
False |
Filter by controller.cpu.processor
controller.cpu.count |
integer |
query |
False |
Filter by controller.cpu.count
controller.cpu.firmware_release |
string |
query |
False |
Filter by controller.cpu.firmware_release
controller.board |
string |
query |
False |
Filter by controller.board
controller.failed_fan.message.code |
string |
query |
False |
Filter by controller.failed_fan.message.code
controller.failed_fan.message.message |
string |
query |
False |
Filter by controller.failed_fan.message.message
controller.failed_fan.count |
integer |
query |
False |
Filter by controller.failed_fan.count
controller.frus.state |
string |
query |
False |
Filter by controller.frus.state |
controller.frus.id |
string |
query |
False |
Filter by controller.frus.id |
controller.frus.type |
string |
query |
False |
Filter by controller.frus.type |
controller.flash_cache.serial_number |
string |
query |
False |
Filter by controller.flash_cache.serial_number |
controller.flash_cache.part_number |
string |
query |
False |
Filter by controller.flash_cache.part_number |
controller.flash_cache.firmware_file |
string |
query |
False |
Filter by controller.flash_cache.firmware_file
controller.flash_cache.hardware_revision |
string |
query |
False |
Filter by controller.flash_cache.hardware_revision |
controller.flash_cache.capacity |
integer |
query |
False |
Filter by controller.flash_cache.capacity |
controller.flash_cache.firmware_version |
string |
query |
False |
Filter by controller.flash_cache.firmware_version |
controller.flash_cache.device_id |
integer |
query |
False |
Filter by controller.flash_cache.device_id
controller.flash_cache.state |
string |
query |
False |
Filter by controller.flash_cache.state |
controller.flash_cache.slot |
string |
query |
False |
Filter by controller.flash_cache.slot |
controller.flash_cache.model |
string |
query |
False |
Filter by controller.flash_cache.model |
location |
string |
query |
False |
Filter by location |
ha.ports.number |
integer |
query |
False |
Filter by ha.ports.number
ha.ports.state |
string |
query |
False |
Filter by ha.ports.state
ha.auto_giveback |
boolean |
query |
False |
Filter by ha.auto_giveback |
ha.giveback.state |
string |
query |
False |
Filter by ha.giveback.state
ha.giveback.failure.message |
string |
query |
False |
Filter by ha.giveback.failure.message
ha.giveback.failure.code |
integer |
query |
False |
Filter by ha.giveback.failure.code
ha.enabled |
boolean |
query |
False |
Filter by ha.enabled |
ha.partners.name |
string |
query |
False |
Filter by ha.partners.name |
ha.partners.uuid |
string |
query |
False |
Filter by ha.partners.uuid |
ha.takeover.state |
string |
query |
False |
Filter by ha.takeover.state
ha.takeover.failure.code |
integer |
query |
False |
Filter by ha.takeover.failure.code
ha.takeover.failure.message |
string |
query |
False |
Filter by ha.takeover.failure.message
service_processor.firmware_version |
string |
query |
False |
Filter by service_processor.firmware_version |
service_processor.link_status |
string |
query |
False |
Filter by service_processor.link_status |
service_processor.ipv4_interface.netmask |
string |
query |
False |
Filter by service_processor.ipv4_interface.netmask |
service_processor.ipv4_interface.address |
string |
query |
False |
Filter by service_processor.ipv4_interface.address |
service_processor.ipv4_interface.gateway |
string |
query |
False |
Filter by service_processor.ipv4_interface.gateway |
service_processor.state |
string |
query |
False |
Filter by service_processor.state |
service_processor.mac_address |
string |
query |
False |
Filter by service_processor.mac_address |
service_processor.ipv6_interface.address |
string |
query |
False |
Filter by service_processor.ipv6_interface.address |
service_processor.ipv6_interface.netmask |
integer |
query |
False |
Filter by service_processor.ipv6_interface.netmask |
service_processor.ipv6_interface.gateway |
string |
query |
False |
Filter by service_processor.ipv6_interface.gateway |
service_processor.dhcp_enabled |
boolean |
query |
False |
Filter by service_processor.dhcp_enabled |
uuid |
string |
query |
False |
Filter by uuid |
name |
string |
query |
False |
Filter by name |
metrocluster.type |
string |
query |
False |
Filter by metrocluster.type
metrocluster.ports.name |
string |
query |
False |
Filter by metrocluster.ports.name
metrocluster.custom_vlan_capable |
boolean |
query |
False |
Filter by metrocluster.custom_vlan_capable
state |
string |
query |
False |
Filter by state
system_machine_type |
string |
query |
False |
Filter by system_machine_type
model |
string |
query |
False |
Filter by model |
cluster_interfaces.ip.address |
string |
query |
False |
Filter by cluster_interfaces.ip.address |
cluster_interfaces.name |
string |
query |
False |
Filter by cluster_interfaces.name |
cluster_interfaces.uuid |
string |
query |
False |
Filter by cluster_interfaces.uuid |
management_interfaces.ip.address |
string |
query |
False |
Filter by management_interfaces.ip.address |
management_interfaces.name |
string |
query |
False |
Filter by management_interfaces.name |
management_interfaces.uuid |
string |
query |
False |
Filter by management_interfaces.uuid |
nvram.id |
integer |
query |
False |
Filter by nvram.id
nvram.battery_state |
string |
query |
False |
Filter by nvram.battery_state
version.major |
integer |
query |
False |
Filter by version.major |
version.minor |
integer |
query |
False |
Filter by version.minor |
version.generation |
integer |
query |
False |
Filter by version.generation |
version.full |
string |
query |
False |
Filter by version.full |
metric.duration |
string |
query |
False |
Filter by metric.duration
metric.processor_utilization |
integer |
query |
False |
Filter by metric.processor_utilization
metric.timestamp |
string |
query |
False |
Filter by metric.timestamp
metric.status |
string |
query |
False |
Filter by metric.status
serial_number |
string |
query |
False |
Filter by serial_number |
uptime |
integer |
query |
False |
Filter by uptime |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"records": [
"cluster_interfaces": [
"ip": {
"address": "10.10.10.7"
"name": "lif1",
"controller": {
"board": "System Board XXVIII",
"cpu": {
"count": "20",
"firmware_release": "string",
"processor": "string"
"failed_fan": {
"count": "1",
"message": {
"code": "111411207",
"message": "There are no failed fans."
"failed_power_supply": {
"count": "1",
"message": {
"code": "111411208",
"message": "There are no failed power supplies."
"flash_cache": [
"capacity": "1024000000000",
"device_id": "0",
"firmware_file": "X9170_O000Z6300NVM",
"firmware_version": "NA05",
"hardware_revision": "A1",
"model": "X1970A",
"part_number": "119-00207",
"serial_number": "A22P5061550000187",
"slot": "6-1",
"state": "string"
"frus": [
"id": "string",
"state": "string",
"type": "string"
"memory_size": "1024000000",
"over_temperature": "string"
"date": "2019-04-17T11:49:26-04:00",
"ha": {
"giveback": {
"failure": {
"code": "852126",
"message": "Failed to initiate giveback. Run the \"storage failover show-giveback\" command for more information."
"state": "failed"
"partners": [
"name": "node1",
"ports": [
"number": "0",
"state": "active"
"takeover": {
"failure": {
"code": "852130",
"message": "Failed to initiate takeover. Run the \"storage failover show-takeover\" command for more information."
"state": "failed"
"location": "rack 2 row 5",
"management_interfaces": [
"ip": {
"name": "lif1",
"membership": "string",
"metric": {
"duration": "PT15S",
"processor_utilization": "13",
"status": "ok",
"timestamp": "2017-01-25T11:20:13Z"
"metrocluster": {
"ports": [
"name": "e1b"
"type": "string"
"model": "FAS3070",
"name": "node-01",
"nvram": {
"battery_state": "string",
"id": 0
"owner": "Example Corp",
"serial_number": "4048820-60-9",
"service_processor": {
"firmware_version": "string",
"ipv4_interface": {
"address": "10.10.10.7",
"gateway": "10.1.1.1",
"netmask": "24"
"ipv6_interface": {
"address": "fd20:8b1e:b255:5011:10:141:4:97",
"gateway": "fd20:8b1e:b255:5011:10::1",
"netmask": "64"
"link_status": "string",
"mac_address": "string",
"state": "string"
"state": "string",
"statistics": {
"processor_utilization_base": "12345123",
"processor_utilization_raw": "13",
"status": "ok",
"storage_configuration": "string",
"system_id": "0537035403",
"system_machine_type": "7Y56-CTOWW1",
"uptime": "300536",
"uuid": "4ea7a442-86d1-11e0-ae1c-123478563412",
"vendor_serial_number": "791603000068",
"version": {
"full": "NetApp Release 9.4.0: Sun Nov 05 18:20:57 UTC 2017",
"generation": "9",
"major": "4",
"minor": "0"
"vm": {
"provider_type": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
node_setup_ip
The IP configuration for cluster setup.
address |
string |
IPv4 or IPv6 address |
cluster_interface
The cluster network IP address of the node to be added.
ip
IP information
address |
string |
cluster_interfaces
Network interface
_links |
ip |
IP information |
name |
string |
The name of the interface. |
uuid |
string |
The UUID that uniquely identifies the interface. |
cpu
CPU information.
count |
integer |
Number of CPUs on the node. |
firmware_release |
string |
Firmware release number. Defined by the CPU manufacturer. |
processor |
string |
CPU type on the node. |
message
code |
string |
Error code describing the current condition of chassis fans. |
message |
string |
Message describing the current condition of chassis fans. It is only of use when |
failed_fan
count |
integer |
Specifies a count of the number of chassis fans that are not operating within the recommended RPM range. |
message |
message
code |
string |
Error code describing the current condition of power supply. |
message |
string |
Message describing the state of any power supplies that are currently degraded. It is only of use when |
failed_power_supply
count |
integer |
Number of failed power supply units. |
message |
flash_cache
capacity |
integer |
Size in bytes |
device_id |
integer |
firmware_file |
string |
firmware_version |
string |
hardware_revision |
string |
model |
string |
part_number |
string |
serial_number |
string |
slot |
string |
state |
string |
frus
id |
string |
state |
string |
type |
string |
controller
Controller information
board |
string |
Type of the system board. This is defined by vendor. |
cpu |
CPU information. |
failed_fan |
failed_power_supply |
flash_cache |
array[flash_cache] |
A list of Flash-Cache devices. Only returned when requested by name. |
frus |
array[frus] |
List of FRUs on the node. Only returned when requested by name. |
memory_size |
integer |
Memory available on the node, in bytes. |
over_temperature |
string |
Specifies whether the hardware is currently operating outside of its recommended temperature range. The hardware shuts down if the temperature exceeds critical thresholds. |
failure
Indicates the failure code and message.
code |
integer |
Message code |
message |
string |
Detailed message based on the state. |
giveback
Represents the state of the node that is giving storage back to its HA partner.
failure |
Indicates the failure code and message. |
state |
string |
partners
_links |
name |
string |
uuid |
string |
ports
number |
integer |
HA port number |
state |
string |
HA port state:
takeover
This represents the state of the node that is taking over storage from its HA partner.
failure |
state |
string |
ha
auto_giveback |
boolean |
Specifies whether giveback is automatically initiated when the node that owns the storage is ready. |
enabled |
boolean |
Specifies whether or not storage failover is enabled. |
giveback |
Represents the state of the node that is giving storage back to its HA partner. |
partners |
array[partners] |
Nodes in this node's High Availability (HA) group. |
ports |
array[ports] |
takeover |
This represents the state of the node that is taking over storage from its HA partner. |
The management interface of the node to be added. The subnet mask is set based on the management interface of the cluster or the managment interfaces of other nodes.
Network interface
_links |
ip |
IP information |
name |
string |
uuid |
string |
metric
CPU performance for the nodes.
_links |
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
integer |
Average CPU Utilization for the node |
status |
string |
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
timestamp |
string |
The timestamp of the performance data. |
ports
name |
string |
metrocluster
Metrocluster
boolean |
Indicates whether the MetroCluster over IP platform supports custom VLAN IDs. |
ports |
array[ports] |
MetroCluster over IP ports. |
type |
string |
The Metrocluster configuration type |
nvram
battery_state |
string |
Specifies status of the NVRAM battery. Possible values:
id |
integer |
Vendor specific NVRAM ID of the node. |
ipv4_interface
Object to setup an interface along with its default router.
address |
string |
gateway |
string |
The IPv4 or IPv6 address of the default router. |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length. |
ipv6_interface
address |
string |
IPv6 address |
gateway |
string |
The IPv6 address of the default router. |
netmask |
integer |
The IPv6 netmask/prefix length. The default value is 64 with a valid range of 1 to 127. |
service_processor
dhcp_enabled |
boolean |
Set to "true" to use DHCP to configure an IPv4 interface. |
firmware_version |
string |
The version of firmware installed. |
ipv4_interface |
Object to setup an interface along with its default router. |
ipv6_interface |
link_status |
string |
mac_address |
string |
state |
string |
statistics
Raw CPU performance for the nodes.
integer |
Base counter for CPU Utilization. |
integer |
Raw CPU Utilization for the node. This should be divided by the processor_utilization_base to calculate the percentage CPU utilization for the node. |
status |
string |
timestamp |
string |
version
This returns the cluster version information. When the cluster has more than one node, the cluster version is equivalent to the lowest of generation, major, and minor versions on all nodes.
full |
string |
The full cluster version string. |
generation |
integer |
The generation portion of the version. |
major |
integer |
The major portion of the version. |
minor |
integer |
The minor portion of the version. |
vm
provider_type |
string |
Cloud provider where the VM is hosted. |
records
Complete node information
_links |
cluster_interfaces |
array[cluster_interfaces] |
controller |
Controller information |
date |
string |
The current or "wall clock" time of the node in ISO-8601 date, time, and time zone format. The ISO-8601 date and time are localized based on the ONTAP cluster's timezone setting.
ha |
location |
string |
management_interfaces |
array[management_interfaces] |
membership |
string |
Possible values:
metric |
CPU performance for the nodes. |
metrocluster |
Metrocluster |
model |
string |
name |
string |
nvram |
owner |
string |
Owner of the node. |
serial_number |
string |
service_processor |
state |
string |
State of the node:
statistics |
Raw CPU performance for the nodes. |
string |
The storage configuration in the system. Possible values:
system_id |
string |
string |
OEM system machine type. |
uptime |
integer |
The total time, in seconds, that the node has been up. |
uuid |
string |
string |
OEM vendor serial number. |
version |
This returns the cluster version information. When the cluster has more than one node, the cluster version is equivalent to the lowest of generation, major, and minor versions on all nodes. |
vm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
