REST API reference
Retrieve netgroup cache settings
Accesses the netgroup cache settings, which provide details on the current configuration for managing cached netgroup entries. This information is useful when you need to review or adjust the cache settings for netgroups.
HTTP method and endpoint
GET /name-services/cache/netgroup/settings
Introduced in
ONTAP 9.11
Usage notes
Retrieves netgroups cache settings.
  • vserver services name-service cache netgroups settings show
ttl_for_members
string
query
False
Filter by ttl_for_members
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
negative_cache_enabled_byhost
boolean
query
False
Filter by negative_cache_enabled_byhost
ttl_byhost
string
query
False
Filter by ttl_byhost
negative_ttl_byhost
string
query
False
Filter by negative_ttl_byhost
enabled
boolean
query
False
Filter by enabled
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records.
records
array[netgroups_settings]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "negative_ttl_byhost": "PT2M5S",
      "svm": {
        "name": "svm1",
      "ttl_byhost": "PT24H",
      "ttl_for_members": "PT2M"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
_links
_links
name
string
uuid
string
netgroups_settings
Netgroups cache setting.
_links
_links
enabled
boolean
Indicates whether or not the cache is enabled.
boolean
Indicates whether or not the negative cache is enabled.
negative_ttl_byhost
string
Specifies negative Time to Live by host, in ISO 8601 format.
svm
svm
ttl_byhost
string
Specifies Time to Live by host, in ISO 8601 format.
ttl_for_members
string
Specifies Time to Live for netgroup members, in ISO 8601 format.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
