Retrieve netgroup cache settings
Retrieves netgroup cache settings to understand the current configuration for caching netgroup information. This is useful for managing name service performance in your network environment.
HTTP method and endpoint
GET /name-services/cache/netgroup/settings
Introduced in
ONTAP 9.11
Usage notes
Retrieves netgroups cache settings.
Related ONTAP commands
vserver services name-service cache netgroups settings show
Learn more
negative_ttl_byhost |
string |
query |
False |
Filter by negative_ttl_byhost |
ttl_for_members |
string |
query |
False |
Filter by ttl_for_members |
ttl_byhost |
string |
query |
False |
Filter by ttl_byhost |
enabled |
boolean |
query |
False |
Filter by enabled |
negative_cache_enabled_byhost |
boolean |
query |
False |
Filter by negative_cache_enabled_byhost |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[netgroups_settings] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"negative_ttl_byhost": "PT2M5S",
"svm": {
"name": "svm1",
"ttl_byhost": "PT24H",
"ttl_for_members": "PT2M"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
_links |
name |
string |
uuid |
string |
netgroups_settings
Netgroups cache setting.
_links |
enabled |
boolean |
Indicates whether or not the cache is enabled. |
boolean |
Indicates whether or not the negative cache is enabled. |
string |
Specifies negative Time to Live by host, in ISO 8601 format. |
svm |
ttl_byhost |
string |
Specifies Time to Live by host, in ISO 8601 format. |
ttl_for_members |
string |
Specifies Time to Live for netgroup members, in ISO 8601 format. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
