Retrieve UNIX groups for all SVMs
Retrieves UNIX groups for all SVMs, including the group members, to manage and review user group configurations across your environment.
HTTP method and endpoint
GET /name-services/unix-groups
Introduced in
ONTAP 9.9
Usage notes
Retrieves the UNIX groups for all of the SVMs. UNIX users who are the members of the group are also displayed.
Related ONTAP commands
vserver services name-service unix-group show
Learn more
name |
string |
query |
False |
Filter by name |
users.name |
string |
query |
False |
Filter by users.name |
id |
integer |
query |
False |
Filter by id |
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
current_count |
integer |
Number of UNIX groups and members. |
num_records |
integer |
Number of UNIX group records. |
records |
array[unix_group] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"name": "group1",
"skip_name_validation": true,
"svm": {
"name": "svm1",
"users": [
"name": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
_links |
name |
string |
uuid |
string |
users
name |
string |
UNIX user who belongs to the specified UNIX group and the SVM. |
unix_group
_links |
id |
integer |
UNIX group ID of the specified user. |
name |
string |
UNIX group name to be added to the local database. |
svm |
users |
array[users] |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
