REST API reference
Retrieve UNIX groups for all SVMs
GET /name-services/unix-groups
Introduced In: 9.9
Retrieves the UNIX groups for all of the SVMs. UNIX users who are the members of the group are also displayed.
  • vserver services name-service unix-group show
users.name
string
query
False
Filter by users.name
id
integer
query
False
Filter by id
name
string
query
False
Filter by name
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
current_count
integer
Number of UNIX groups and members.
num_records
integer
Number of UNIX group records.
records
array[unix_group]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "name": "group1",
      "skip_name_validation": true,
      "svm": {
        "name": "svm1",
      "users": [
          "name": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
_links
_links
name
string
uuid
string
users
name
string
UNIX user who belongs to the specified UNIX group and the SVM.
unix_group
_links
_links
id
integer
UNIX group ID of the specified user.
name
string
UNIX group name to be added to the local database.
svm
svm
users
array[users]
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
