REST API reference
Retrieve all BGP peer group details for VIP
Obtains the details of all BGP peer groups associated with a VIP. Use this information to review and manage BGP configurations effectively within your network setup.
HTTP method and endpoint
GET /network/ip/bgp/peer-groups
Introduced in
ONTAP 9.7
Usage notes
Retrieves the details of all BGP peer groups for VIP.
  • network bgp peer-group show
state
string
query
False
Filter by state
peer.address
string
query
False
Filter by peer.address
peer.asn
integer
query
False
Filter by peer.asn
peer.md5_enabled
boolean
query
False
Filter by peer.md5_enabled
  • Introduced in: 9.16
peer.is_next_hop
boolean
query
False
Filter by peer.is_next_hop
  • Introduced in: 9.9
peer.md5_secret
string
query
False
Filter by peer.md5_secret
  • maxLength: 79
  • minLength: 1
local.interface.uuid
string
query
False
Filter by local.interface.uuid
local.interface.name
string
query
False
Filter by local.interface.name
local.interface.ip.address
string
query
False
Filter by local.interface.ip.address
local.port.node.name
string
query
False
Filter by local.port.node.name
local.port.name
string
query
False
Filter by local.port.name
local.port.uuid
string
query
False
Filter by local.port.uuid
ipspace.name
string
query
False
Filter by ipspace.name
ipspace.uuid
string
query
False
Filter by ipspace.uuid
uuid
string
query
False
Filter by uuid
name
string
query
False
Filter by name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[bgp_peer_group]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "ipspace": {
        "name": "Default",
      "local": {
        "interface": {
          "ip": {
            "address": "10.10.10.7"
          "name": "lif1",
        "port": {
          "name": "e1b",
          "node": {
            "name": "node1"
      "name": "bgpv4peer",
      "peer": {
        "address": "10.10.10.7",
        "md5_enabled": 1,
        "md5_secret": "SECRET_WORD"
      "state": "string",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
ipspace
Either the UUID or name is supplied on input.
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
ip
IP information
address
string
IPv4 or IPv6 address
interface
A network interface. Either UUID or name may be supplied on input.
_links
_links
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
ip
IP information to create a new interface.
address
string
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length.
node
name
string
Name of node on which the port is located.
port
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
_links
_links
name
string
node
node
uuid
string
local
Information describing the local interface that is being used to peer with a router using BGP. On a POST operation, an existing BGP interface is used by specifying the interface, or create a new one by specifying the port and IP address.
interface
interface
port
port
peer
Information describing the router to peer with
address
string
Peer router address
asn
integer
Autonomous system number of peer
is_next_hop
boolean
Use peer address as next hop.
md5_enabled
boolean
Enable or disable TCP MD5 signatures per RFC 2385.
md5_secret
string
The shared TCP MD5 secret key. This can either be given as a password or hexadecimal key.
bgp_peer_group
A BGP peer group between a local network interface and a router, for the purpose of announcing VIP interface locations for SVMs in this IPspace.
ipspace
ipspace
local
local
name
string
Name of the peer group
peer
peer
state
string
State of the peer group
uuid
string
UUID of the peer group
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
