Retrieve all BGP peer group details for VIP
Retrieves the details of all BGP peer groups for VIP to understand the current configuration and status of these groups.
HTTP method and endpoint
GET /network/ip/bgp/peer-groups
Introduced in
ONTAP 9.7
Related ONTAP Commands
network bgp peer-group show
ipspace.name |
string |
query |
False |
Filter by ipspace.name |
ipspace.uuid |
string |
query |
False |
Filter by ipspace.uuid |
peer.is_next_hop |
boolean |
query |
False |
Filter by peer.is_next_hop
peer.md5_secret |
string |
query |
False |
Filter by peer.md5_secret
peer.asn |
integer |
query |
False |
Filter by peer.asn |
peer.md5_enabled |
boolean |
query |
False |
Filter by peer.md5_enabled
peer.address |
string |
query |
False |
Filter by peer.address |
state |
string |
query |
False |
Filter by state |
uuid |
string |
query |
False |
Filter by uuid |
local.port.name |
string |
query |
False |
Filter by local.port.name |
local.port.uuid |
string |
query |
False |
Filter by local.port.uuid |
local.port.node.name |
string |
query |
False |
Filter by local.port.node.name |
local.interface.uuid |
string |
query |
False |
Filter by local.interface.uuid |
local.interface.name |
string |
query |
False |
Filter by local.interface.name |
local.interface.ip.address |
string |
query |
False |
Filter by local.interface.ip.address |
name |
string |
query |
False |
Filter by name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[bgp_peer_group] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"ipspace": {
"name": "Default",
"local": {
"interface": {
"ip": {
"address": "10.10.10.7"
"name": "lif1",
"port": {
"name": "e1b",
"node": {
"name": "node1"
"name": "bgpv4peer",
"peer": {
"address": "10.10.10.7",
"md5_enabled": 1,
"md5_secret": "SECRET_WORD"
"state": "string",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
ipspace
Either the UUID or name is supplied on input.
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
ip
IP information
address |
string |
IPv4 or IPv6 address |
interface
A network interface. Either UUID or name may be supplied on input.
_links |
ip |
IP information |
name |
string |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the interface. |
ip
IP information to create a new interface.
address |
string |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length. |
node
name |
string |
Name of node on which the port is located. |
port
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
_links |
name |
string |
node |
uuid |
string |
local
Information describing the local interface that is being used to peer with a router using BGP. On a POST operation, an existing BGP interface is used by specifying the interface, or create a new one by specifying the port and IP address.
interface |
A network interface. Either UUID or name may be supplied on input. |
port |
Port UUID along with readable names. Either the UUID or both names may be supplied on input. |
peer
Information describing the router to peer with
address |
string |
Peer router address |
asn |
integer |
Autonomous system number of peer |
is_next_hop |
boolean |
Use peer address as next hop. |
md5_enabled |
boolean |
Enable or disable TCP MD5 signatures per RFC 2385. |
md5_secret |
string |
The shared TCP MD5 secret key. This can either be given as a password or hexadecimal key. |
bgp_peer_group
A BGP peer group between a local network interface and a router, for the purpose of announcing VIP interface locations for SVMs in this IPspace.
ipspace |
Either the UUID or name is supplied on input. |
local |
Information describing the local interface that is being used to peer with a router using BGP. On a POST operation, an existing BGP interface is used by specifying the interface, or create a new one by specifying the port and IP address. |
name |
string |
Name of the peer group |
peer |
Information describing the router to peer with |
state |
string |
State of the peer group |
uuid |
string |
UUID of the peer group |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
