Retrieve Kerberos interfaces
Retrieves Kerberos interfaces to access information about existing Kerberos configurations associated with your network protocols.
HTTP method and endpoint
GET /protocols/nfs/kerberos/interfaces
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver nfs kerberos interface show
Learn more
interface.uuid |
string |
query |
False |
Filter by interface.uuid |
interface.name |
string |
query |
False |
Filter by interface.name |
interface.ip.address |
string |
query |
False |
Filter by interface.ip.address |
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
machine_account |
string |
query |
False |
Filter by machine_account
spn |
string |
query |
False |
Filter by spn |
enabled |
boolean |
query |
False |
Filter by enabled |
encryption_types |
string |
query |
False |
Filter by encryption_types |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[kerberos_interface] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"encryption_types": [
"string"
"force": true,
"interface": {
"ip": {
"address": "10.10.10.7"
"name": "lif1",
"machine_account": "string",
"spn": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
ip
IP information
address |
string |
IPv4 or IPv6 address |
interface
Network interface
_links |
ip |
IP information |
name |
string |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the interface. |
svm
_links |
name |
string |
uuid |
string |
kerberos_interface
_links |
enabled |
boolean |
Specifies if Kerberos is enabled. |
encryption_types |
array[string] |
interface |
Network interface |
machine_account |
string |
Specifies the machine account to create in Active Directory. |
spn |
string |
Service principal name. Valid in PATCH. |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
