REST API reference
Retrieve Kerberos interfaces
Retrieves Kerberos interfaces to provide details about the current configuration and status for secured network communications.
HTTP method and endpoint
GET /protocols/nfs/kerberos/interfaces
Introduced in
ONTAP 9.6
  • vserver nfs kerberos interface show
enabled
boolean
query
False
Filter by enabled
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
spn
string
query
False
Filter by spn
encryption_types
string
query
False
Filter by encryption_types
interface.ip.address
string
query
False
Filter by interface.ip.address
interface.name
string
query
False
Filter by interface.name
interface.uuid
string
query
False
Filter by interface.uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[kerberos_interface]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "encryption_types": [
        "string"
      "interface": {
        "ip": {
          "address": "10.10.10.7"
        "name": "lif1",
      "spn": "string",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
ip
IP information
address
string
IPv4 or IPv6 address
interface
Network interface
_links
_links
ip
ip
IP information
name
string
The name of the interface.
uuid
string
The UUID that uniquely identifies the interface.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
kerberos_interface
_links
_links
enabled
boolean
Specifies if Kerberos is enabled.
encryption_types
array[string]
interface
interface
Network interface
spn
string
Service principal name. Valid in PATCH.
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
