Retrieve the NFS configuration for SVMs
Retrieves the NFS configuration for SVMs to understand how your storage virtual machines are set up for NFS operations. This can help you manage and optimize your storage environment effectively.
HTTP method and endpoint
GET /protocols/nfs/services
Introduced in
ONTAP 9.6
Usage notes
Retrieves the NFS configuration of SVMs.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
statistics.* -
metric.*
Advanced properties
security.rpcsec_context_idle -
security.ntfs_unix_security -
security.chown_mode -
security.nt_acl_display_permission -
protocol.v3_features.ejukebox_enabled -
protocol.v3_features.connection_drop -
protocol.v3_features.fsid_change -
protocol.v3_features.mount_daemon_port -
protocol.v3_features.network_lock_manager_port -
protocol.v3_features.network_status_monitor_port -
protocol.v3_features.rquota_daemon_port -
protocol.v3_features.hide_snapshot_enabled -
protocol.v41_features.implementation_domain -
protocol.v41_features.implementation_name -
protocol.v40_features.acl_max_aces -
windows.map_unknown_uid_to_default_user -
exports.netgroup_trust_any_nsswitch_no_match -
credential_cache.negative_ttl -
transport.tcp_max_transfer_size -
root.* -
protocol.v41_features.trunking_enabled -
protocol.v42_features.seclabel_enabled -
protocol.v42_features.sparsefile_ops_enabled -
protocol.v42_features.xattrs_enabled -
protocol.v40_features.referrals_enabled -
protocol.v41_features.referrals_enabled -
protocol.v4_lease_seconds -
protocol.v4_session_slots -
protocol.v4_session_slot_reply_cache_size -
protocol.v4_fsid_change
Diagnostic properties
credential_cache.transient_error_ttl -
access_cache_config.ttl_failure
Related ONTAP commands
vserver nfs show -
vserver nfs status -
vserver export-policy check-access
Learn more
protocol_access_rules.volume |
string |
query |
False |
Volume on which access needs to be checked.
protocol_access_rules.client_ip |
string |
query |
False |
IP address for the client for which access needs to be checked.
protocol_access_rules.auth_type |
string |
query |
False |
Authentication method used to check the client's access to the volume.
exports.name_service_lookup_protocol |
string |
query |
False |
Filter by exports.name_service_lookup_protocol
exports.netgroup_trust_any_nsswitch_no_match |
boolean |
query |
False |
Filter by exports.netgroup_trust_any_nsswitch_no_match
qtree.validate_export |
boolean |
query |
False |
Filter by qtree.validate_export
qtree.export_enabled |
boolean |
query |
False |
Filter by qtree.export_enabled
vstorage_enabled |
boolean |
query |
False |
Filter by vstorage_enabled |
file_session_io_grouping_duration |
integer |
query |
False |
Filter by file_session_io_grouping_duration
state |
string |
query |
False |
Filter by state |
file_session_io_grouping_count |
integer |
query |
False |
Filter by file_session_io_grouping_count
access_cache_config.ttl_negative |
integer |
query |
False |
Filter by access_cache_config.ttl_negative
access_cache_config.isDnsTTLEnabled |
boolean |
query |
False |
Filter by access_cache_config.isDnsTTLEnabled
access_cache_config.harvest_timeout |
integer |
query |
False |
Filter by access_cache_config.harvest_timeout
access_cache_config.ttl_failure |
integer |
query |
False |
Filter by access_cache_config.ttl_failure
access_cache_config.ttl_positive |
integer |
query |
False |
Filter by access_cache_config.ttl_positive
rquota_enabled |
boolean |
query |
False |
Filter by rquota_enabled
showmount_enabled |
boolean |
query |
False |
Filter by showmount_enabled
metric.v41.iops.other |
integer |
query |
False |
Filter by metric.v41.iops.other
metric.v41.iops.total |
integer |
query |
False |
Filter by metric.v41.iops.total
metric.v41.iops.read |
integer |
query |
False |
Filter by metric.v41.iops.read
metric.v41.iops.write |
integer |
query |
False |
Filter by metric.v41.iops.write
metric.v41.status |
string |
query |
False |
Filter by metric.v41.status
metric.v41.latency.other |
integer |
query |
False |
Filter by metric.v41.latency.other
metric.v41.latency.total |
integer |
query |
False |
Filter by metric.v41.latency.total
metric.v41.latency.read |
integer |
query |
False |
Filter by metric.v41.latency.read
metric.v41.latency.write |
integer |
query |
False |
Filter by metric.v41.latency.write
metric.v41.duration |
string |
query |
False |
Filter by metric.v41.duration
metric.v41.timestamp |
string |
query |
False |
Filter by metric.v41.timestamp
metric.v41.throughput.read |
integer |
query |
False |
Filter by metric.v41.throughput.read
metric.v41.throughput.total |
integer |
query |
False |
Filter by metric.v41.throughput.total
metric.v41.throughput.write |
integer |
query |
False |
Filter by metric.v41.throughput.write
metric.v3.iops.other |
integer |
query |
False |
Filter by metric.v3.iops.other
metric.v3.iops.total |
integer |
query |
False |
Filter by metric.v3.iops.total
metric.v3.iops.read |
integer |
query |
False |
Filter by metric.v3.iops.read
metric.v3.iops.write |
integer |
query |
False |
Filter by metric.v3.iops.write
metric.v3.status |
string |
query |
False |
Filter by metric.v3.status
metric.v3.latency.other |
integer |
query |
False |
Filter by metric.v3.latency.other
metric.v3.latency.total |
integer |
query |
False |
Filter by metric.v3.latency.total
metric.v3.latency.read |
integer |
query |
False |
Filter by metric.v3.latency.read
metric.v3.latency.write |
integer |
query |
False |
Filter by metric.v3.latency.write
metric.v3.duration |
string |
query |
False |
Filter by metric.v3.duration
metric.v3.timestamp |
string |
query |
False |
Filter by metric.v3.timestamp
metric.v3.throughput.read |
integer |
query |
False |
Filter by metric.v3.throughput.read
metric.v3.throughput.total |
integer |
query |
False |
Filter by metric.v3.throughput.total
metric.v3.throughput.write |
integer |
query |
False |
Filter by metric.v3.throughput.write
metric.v4.iops.other |
integer |
query |
False |
Filter by metric.v4.iops.other
metric.v4.iops.total |
integer |
query |
False |
Filter by metric.v4.iops.total
metric.v4.iops.read |
integer |
query |
False |
Filter by metric.v4.iops.read
metric.v4.iops.write |
integer |
query |
False |
Filter by metric.v4.iops.write
metric.v4.status |
string |
query |
False |
Filter by metric.v4.status
metric.v4.latency.other |
integer |
query |
False |
Filter by metric.v4.latency.other
metric.v4.latency.total |
integer |
query |
False |
Filter by metric.v4.latency.total
metric.v4.latency.read |
integer |
query |
False |
Filter by metric.v4.latency.read
metric.v4.latency.write |
integer |
query |
False |
Filter by metric.v4.latency.write
metric.v4.duration |
string |
query |
False |
Filter by metric.v4.duration
metric.v4.timestamp |
string |
query |
False |
Filter by metric.v4.timestamp
metric.v4.throughput.read |
integer |
query |
False |
Filter by metric.v4.throughput.read
metric.v4.throughput.total |
integer |
query |
False |
Filter by metric.v4.throughput.total
metric.v4.throughput.write |
integer |
query |
False |
Filter by metric.v4.throughput.write
protocol.v4_fsid_change |
boolean |
query |
False |
Filter by protocol.v4_fsid_change
protocol.v4_session_slot_reply_cache_size |
integer |
query |
False |
Filter by protocol.v4_session_slot_reply_cache_size
protocol.v3_features.network_status_monitor_port |
integer |
query |
False |
Filter by protocol.v3_features.network_status_monitor_port
protocol.v3_features.network_lock_manager_port |
integer |
query |
False |
Filter by protocol.v3_features.network_lock_manager_port
protocol.v3_features.rquota_daemon_port |
integer |
query |
False |
Filter by protocol.v3_features.rquota_daemon_port
protocol.v3_features.mount_root_only |
boolean |
query |
False |
Filter by protocol.v3_features.mount_root_only
protocol.v3_features.connection_drop |
boolean |
query |
False |
Filter by protocol.v3_features.connection_drop
protocol.v3_features.ejukebox_enabled |
boolean |
query |
False |
Filter by protocol.v3_features.ejukebox_enabled
protocol.v3_features.fsid_change |
boolean |
query |
False |
Filter by protocol.v3_features.fsid_change
protocol.v3_features.hide_snapshot_enabled |
boolean |
query |
False |
Filter by protocol.v3_features.hide_snapshot_enabled
protocol.v3_features.mount_daemon_port |
integer |
query |
False |
Filter by protocol.v3_features.mount_daemon_port
protocol.v40_features.acl_max_aces |
integer |
query |
False |
Filter by protocol.v40_features.acl_max_aces
protocol.v40_features.read_delegation_enabled |
boolean |
query |
False |
Filter by protocol.v40_features.read_delegation_enabled |
protocol.v40_features.acl_enabled |
boolean |
query |
False |
Filter by protocol.v40_features.acl_enabled |
protocol.v40_features.referrals_enabled |
boolean |
query |
False |
Filter by protocol.v40_features.referrals_enabled
protocol.v40_features.acl_preserve |
boolean |
query |
False |
Filter by protocol.v40_features.acl_preserve
protocol.v40_features.write_delegation_enabled |
boolean |
query |
False |
Filter by protocol.v40_features.write_delegation_enabled |
protocol.v3_enabled |
boolean |
query |
False |
Filter by protocol.v3_enabled |
protocol.v4_grace_seconds |
integer |
query |
False |
Filter by protocol.v4_grace_seconds
protocol.v4_id_domain |
string |
query |
False |
Filter by protocol.v4_id_domain |
protocol.v42_features.seclabel_enabled |
boolean |
query |
False |
Filter by protocol.v42_features.seclabel_enabled
protocol.v42_features.xattrs_enabled |
boolean |
query |
False |
Filter by protocol.v42_features.xattrs_enabled
protocol.v42_features.sparsefile_ops_enabled |
boolean |
query |
False |
Filter by protocol.v42_features.sparsefile_ops_enabled
protocol.v4_session_slots |
integer |
query |
False |
Filter by protocol.v4_session_slots
protocol.v4_lease_seconds |
integer |
query |
False |
Filter by protocol.v4_lease_seconds
protocol.v4_64bit_identifiers_enabled |
boolean |
query |
False |
Filter by protocol.v4_64bit_identifiers_enabled
protocol.v41_enabled |
boolean |
query |
False |
Filter by protocol.v41_enabled |
protocol.v40_enabled |
boolean |
query |
False |
Filter by protocol.v40_enabled |
protocol.v3_64bit_identifiers_enabled |
boolean |
query |
False |
Filter by protocol.v3_64bit_identifiers_enabled
protocol.v41_features.read_delegation_enabled |
boolean |
query |
False |
Filter by protocol.v41_features.read_delegation_enabled |
protocol.v41_features.acl_enabled |
boolean |
query |
False |
Filter by protocol.v41_features.acl_enabled |
protocol.v41_features.referrals_enabled |
boolean |
query |
False |
Filter by protocol.v41_features.referrals_enabled
protocol.v41_features.write_delegation_enabled |
boolean |
query |
False |
Filter by protocol.v41_features.write_delegation_enabled |
protocol.v41_features.implementation_domain |
string |
query |
False |
Filter by protocol.v41_features.implementation_domain
protocol.v41_features.pnfs_enabled |
boolean |
query |
False |
Filter by protocol.v41_features.pnfs_enabled |
protocol.v41_features.trunking_enabled |
boolean |
query |
False |
Filter by protocol.v41_features.trunking_enabled
protocol.v41_features.implementation_name |
string |
query |
False |
Filter by protocol.v41_features.implementation_name
root.ignore_nt_acl |
boolean |
query |
False |
Filter by root.ignore_nt_acl
root.skip_write_permission_check |
boolean |
query |
False |
Filter by root.skip_write_permission_check
credential_cache.positive_ttl |
integer |
query |
False |
Filter by credential_cache.positive_ttl
credential_cache.transient_error_ttl |
integer |
query |
False |
Filter by credential_cache.transient_error_ttl
credential_cache.negative_ttl |
integer |
query |
False |
Filter by credential_cache.negative_ttl
protocol_access_rules.nfs4_access_type |
string |
query |
False |
Filter by protocol_access_rules.nfs4_access_type
protocol_access_rules.nfs3_access_type |
string |
query |
False |
Filter by protocol_access_rules.nfs3_access_type
protocol_access_rules.cifs_access_type |
string |
query |
False |
Filter by protocol_access_rules.cifs_access_type
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
auth_sys_extended_groups_enabled |
boolean |
query |
False |
Filter by auth_sys_extended_groups_enabled
extended_groups_limit |
integer |
query |
False |
Filter by extended_groups_limit
security.nt_acl_display_permission |
boolean |
query |
False |
Filter by security.nt_acl_display_permission
security.ntfs_unix_security |
string |
query |
False |
Filter by security.ntfs_unix_security
security.chown_mode |
string |
query |
False |
Filter by security.chown_mode
security.permitted_encryption_types |
string |
query |
False |
Filter by security.permitted_encryption_types
security.rpcsec_context_idle |
integer |
query |
False |
Filter by security.rpcsec_context_idle
transport.tcp_max_transfer_size |
integer |
query |
False |
Filter by transport.tcp_max_transfer_size
transport.tcp_enabled |
boolean |
query |
False |
Filter by transport.tcp_enabled |
transport.rdma_enabled |
boolean |
query |
False |
Filter by transport.rdma_enabled
transport.udp_enabled |
boolean |
query |
False |
Filter by transport.udp_enabled |
windows.default_user |
string |
query |
False |
Filter by windows.default_user
windows.map_unknown_uid_to_default_user |
boolean |
query |
False |
Filter by windows.map_unknown_uid_to_default_user
windows.v3_ms_dos_client_enabled |
boolean |
query |
False |
Filter by windows.v3_ms_dos_client_enabled
enabled |
boolean |
query |
False |
Filter by enabled |
statistics.v3.latency_raw.other |
integer |
query |
False |
Filter by statistics.v3.latency_raw.other
statistics.v3.latency_raw.total |
integer |
query |
False |
Filter by statistics.v3.latency_raw.total
statistics.v3.latency_raw.read |
integer |
query |
False |
Filter by statistics.v3.latency_raw.read
statistics.v3.latency_raw.write |
integer |
query |
False |
Filter by statistics.v3.latency_raw.write
statistics.v3.throughput_raw.read |
integer |
query |
False |
Filter by statistics.v3.throughput_raw.read
statistics.v3.throughput_raw.total |
integer |
query |
False |
Filter by statistics.v3.throughput_raw.total
statistics.v3.throughput_raw.write |
integer |
query |
False |
Filter by statistics.v3.throughput_raw.write
statistics.v3.iops_raw.other |
integer |
query |
False |
Filter by statistics.v3.iops_raw.other
statistics.v3.iops_raw.total |
integer |
query |
False |
Filter by statistics.v3.iops_raw.total
statistics.v3.iops_raw.read |
integer |
query |
False |
Filter by statistics.v3.iops_raw.read
statistics.v3.iops_raw.write |
integer |
query |
False |
Filter by statistics.v3.iops_raw.write
statistics.v3.status |
string |
query |
False |
Filter by statistics.v3.status
statistics.v3.timestamp |
string |
query |
False |
Filter by statistics.v3.timestamp
statistics.v41.latency_raw.other |
integer |
query |
False |
Filter by statistics.v41.latency_raw.other
statistics.v41.latency_raw.total |
integer |
query |
False |
Filter by statistics.v41.latency_raw.total
statistics.v41.latency_raw.read |
integer |
query |
False |
Filter by statistics.v41.latency_raw.read
statistics.v41.latency_raw.write |
integer |
query |
False |
Filter by statistics.v41.latency_raw.write
statistics.v41.throughput_raw.read |
integer |
query |
False |
Filter by statistics.v41.throughput_raw.read
statistics.v41.throughput_raw.total |
integer |
query |
False |
Filter by statistics.v41.throughput_raw.total
statistics.v41.throughput_raw.write |
integer |
query |
False |
Filter by statistics.v41.throughput_raw.write
statistics.v41.iops_raw.other |
integer |
query |
False |
Filter by statistics.v41.iops_raw.other
statistics.v41.iops_raw.total |
integer |
query |
False |
Filter by statistics.v41.iops_raw.total
statistics.v41.iops_raw.read |
integer |
query |
False |
Filter by statistics.v41.iops_raw.read
statistics.v41.iops_raw.write |
integer |
query |
False |
Filter by statistics.v41.iops_raw.write
statistics.v41.status |
string |
query |
False |
Filter by statistics.v41.status
statistics.v41.timestamp |
string |
query |
False |
Filter by statistics.v41.timestamp
statistics.v4.latency_raw.other |
integer |
query |
False |
Filter by statistics.v4.latency_raw.other
statistics.v4.latency_raw.total |
integer |
query |
False |
Filter by statistics.v4.latency_raw.total
statistics.v4.latency_raw.read |
integer |
query |
False |
Filter by statistics.v4.latency_raw.read
statistics.v4.latency_raw.write |
integer |
query |
False |
Filter by statistics.v4.latency_raw.write
statistics.v4.throughput_raw.read |
integer |
query |
False |
Filter by statistics.v4.throughput_raw.read
statistics.v4.throughput_raw.total |
integer |
query |
False |
Filter by statistics.v4.throughput_raw.total
statistics.v4.throughput_raw.write |
integer |
query |
False |
Filter by statistics.v4.throughput_raw.write
statistics.v4.iops_raw.other |
integer |
query |
False |
Filter by statistics.v4.iops_raw.other
statistics.v4.iops_raw.total |
integer |
query |
False |
Filter by statistics.v4.iops_raw.total
statistics.v4.iops_raw.read |
integer |
query |
False |
Filter by statistics.v4.iops_raw.read
statistics.v4.iops_raw.write |
integer |
query |
False |
Filter by statistics.v4.iops_raw.write
statistics.v4.status |
string |
query |
False |
Filter by statistics.v4.status
statistics.v4.timestamp |
string |
query |
False |
Filter by statistics.v4.timestamp
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of NFS Server Records |
records |
array[nfs_service] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"access_cache_config": {
"harvest_timeout": 3600,
"ttl_failure": 1,
"ttl_negative": 30,
"ttl_positive": 60
"credential_cache": {
"negative_ttl": 7200000,
"positive_ttl": 7200000,
"transient_error_ttl": 72000
"exports": {
"name_service_lookup_protocol": "string"
"extended_groups_limit": 32,
"file_session_io_grouping_count": 5000,
"file_session_io_grouping_duration": 120,
"metric": {
"v3": {
"duration": "PT15S",
"iops": {
"read": 200,
"total": 1000,
"write": 100
"latency": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"throughput": {
"read": 200,
"total": 1000,
"write": 100
"timestamp": "2017-01-25 06:20:13 -0500"
"v4": {
"iops": {
"read": 200,
"total": 1000,
"write": 100
"latency": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"throughput": {
"read": 200,
"total": 1000,
"write": 100
"v41": {
"iops": {
"read": 200,
"total": 1000,
"write": 100
"latency": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"throughput": {
"read": 200,
"total": 1000,
"write": 100
"protocol": {
"v40_features": {
"acl_max_aces": 500
"v41_features": {
"implementation_domain": "string",
"implementation_name": "string"
"v4_id_domain": "string"
"protocol_access_rules": {
"cifs_access_type": "string",
"nfs3_access_type": "string",
"nfs4_access_type": "string"
"security": {
"chown_mode": "string",
"ntfs_unix_security": "string",
"permitted_encryption_types": [
"string"
"state": "string",
"statistics": {
"v3": {
"iops_raw": {
"read": 200,
"total": 1000,
"write": 100
"latency_raw": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"throughput_raw": {
"read": 200,
"total": 1000,
"write": 100
"v4": {
"iops_raw": {
"read": 200,
"total": 1000,
"write": 100
"latency_raw": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"throughput_raw": {
"read": 200,
"total": 1000,
"write": 100
"v41": {
"iops_raw": {
"read": 200,
"total": 1000,
"write": 100
"latency_raw": {
"read": 200,
"total": 1000,
"write": 100
"status": "ok",
"throughput_raw": {
"read": 200,
"total": 1000,
"write": 100
"svm": {
"name": "svm1",
"transport": {
"tcp_max_transfer_size": 16384
"windows": {
"default_user": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
access_cache_config
harvest_timeout |
integer |
Specifies the time after which an entry is deleted from the access cache, if unused. |
isDnsTTLEnabled |
boolean |
Specifies whether Dns TTL is enabled. |
ttl_failure |
integer |
Specifies the time to live value for entries for which a failure was encountered, in seconds. |
ttl_negative |
integer |
Specifies the time to live value of a negative access cache, in seconds. |
ttl_positive |
integer |
Specifies the time to live value of a positive access cache, in seconds. |
credential_cache
negative_ttl |
integer |
Specifies the age in milliseconds, of the negative cached credentials after which they are cleared from the cache. |
positive_ttl |
integer |
Specifies the age in milliseconds, of the positive cached credentials after which they are cleared from the cache. |
integer |
Specifies the age in milliseconds, of the cached entries during a transient error situation. |
exports
string |
Specifies the protocol to use for doing name service lookups. |
boolean |
Specifies if you can consider a no-match result from any of the netgroup ns-switch sources to be authoritative. If this option is enabled, then a no-match response from any of the netgroup ns-switch sources is deemed conclusive even if other sources could not be searched. |
iops
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Performance metric for write I/O operations. |
latency
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput
read |
integer |
total |
integer |
write |
integer |
v3
The NFSv3 operations
_links |
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
iops |
The rate of I/O operations observed at the storage object. |
latency |
The round trip latency in microseconds observed at the storage object. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the storage object. |
timestamp |
string |
The timestamp of the performance data. |
v4
The NFSv4 operations
_links |
duration |
string |
iops |
latency |
status |
string |
throughput |
timestamp |
string |
v41
The NFSv4.1 operations
_links |
duration |
string |
iops |
latency |
status |
string |
throughput |
timestamp |
string |
metric
Historical performance numbers, such as IOPS latency and throughput, for SVM-NFS protocol.
v3 |
The NFSv3 operations |
v4 |
The NFSv4 operations |
v41 |
The NFSv4.1 operations |
v3_features
connection_drop |
boolean |
Specifies whether the dropping of a connection when an NFSv3 request is dropped is enabled. |
ejukebox_enabled |
boolean |
Specifies whether NFSv3 EJUKEBOX error is enabled. |
fsid_change |
boolean |
Specifies whether the change in FSID as NFSv3 clients traverse filesystems should be shown. |
boolean |
Specifies whether hiding a snapshot directory under a NFSv3 mount point is enabled. |
mount_daemon_port |
integer |
Specifies which port the NFS mount daemon (mountd) uses. |
mount_root_only |
boolean |
Specifies whether the SVM allows MOUNT protocol calls only from privileged ports (port numbers less than 1024). |
integer |
Specifies which port the Network lock manager uses. |
integer |
Specifies which port the Network status monitor port uses. |
integer |
Specifies which port the NFS quota daemon port uses. |
v40_features
acl_enabled |
boolean |
Specifies whether NFSv4.0 ACLs is enabled. |
acl_max_aces |
integer |
Specifies the maximum number of aces in a NFSv4.0 ACL. |
acl_preserve |
boolean |
Specifies if the NFSv4 ACL is preserved or dropped when chmod is performed. In unified security style, this parameter also specifies if NTFS file permissions are preserved or dropped when chmod, chgrp, or chown are performed. |
boolean |
Specifies whether NFSv4.0 Read Delegation is enabled. |
referrals_enabled |
boolean |
Specifies whether NFSv4.0 referrals is enabled. |
boolean |
Specifies whether NFSv4.0 Write Delegation is enabled. |
v41_features
acl_enabled |
boolean |
Specifies whether NFSv4.1 or later ACLs is enabled. |
string |
Specifies the NFSv4.1 or later implementation ID domain. |
string |
Specifies the NFSv4.1 or later implementation ID name. |
pnfs_enabled |
boolean |
Specifies whether NFSv4.1 or later Parallel NFS is enabled. |
boolean |
Specifies whether NFSv4.1 or later Read Delegation is enabled. |
referrals_enabled |
boolean |
Specifies whether NFSv4.1 referrals is enabled. |
trunking_enabled |
boolean |
Specifies whether NFSv4.1 or later trunking is enabled. |
boolean |
Specifies whether NFSv4.1 or later Write Delegation is enabled. |
v42_features
seclabel_enabled |
boolean |
Specifies whether NFSv4.2 or later security label is enabled. |
boolean |
Specifies whether NFSv4.2 or later sparsefile operation is enabled. |
xattrs_enabled |
boolean |
Specifies whether NFSv4.2 or later extended attributes is enabled. |
protocol
boolean |
Specifies whether 64-bit support for NFSv3 FSIDs and file IDs is enabled. |
v3_enabled |
boolean |
Specifies whether NFSv3 protocol is enabled. |
v3_features |
v40_enabled |
boolean |
Specifies whether NFSv4.0 protocol is enabled. |
v40_features |
v41_enabled |
boolean |
Specifies whether NFSv4.1 or later protocol is enabled. |
v41_features |
v42_features |
boolean |
Specifies whether 64-bit support for NFSv4.x FSIDs and file IDs is enabled. |
v4_fsid_change |
boolean |
Specifies whether the change in FSID when NFSv4 clients traverse file systems is displayed. |
v4_grace_seconds |
integer |
Specifies the grace period for clients to reclaim file locks after a server failure. |
v4_id_domain |
string |
Specifies the domain portion of the string form of user and group names as defined by the NFSv4 protocol. |
v4_lease_seconds |
integer |
Specifies the lease seconds of the NFSv4 clients. If it is inactive for more than the time displayed, all of the file lock states on a node might be lost. |
integer |
Specifies the number of bytes of the reply that is cached in each NFSv4.x session slot. |
v4_session_slots |
integer |
Specifies the number of entries in NFSv4.x session slot table. |
cifs_access_type |
string |
Access available for the CIFS protocol. |
nfs3_access_type |
string |
Access available for the NFSv3 protocol. |
nfs4_access_type |
string |
Access available for the NFSv4 protocol. |
qtree
export_enabled |
boolean |
Specifies whether qtree export is enabled. |
validate_export |
boolean |
Specifies whether qtree export validation is enabled. |
root
ignore_nt_acl |
boolean |
Specifies whether Windows ACLs affect root access from NFS. If this option is enabled, root access from NFS ignores the NT ACL set on the file or directory. |
boolean |
Specifies if permission checks are to be skipped for NFS WRITE calls from root/owner. For copying read-only files to a destination folder which has inheritable ACLs, this option must be enabled. |
security
chown_mode |
string |
Specifies whether file ownership can be changed only by the superuser, or if a non-root user can also change file ownership. If you set this parameter to restricted, file ownership can be changed only by the superuser, even though the on-disk permissions allow a non-root user to change file ownership. If you set this parameter to unrestricted, file ownership can be changed by the superuser and by the non-root user, depending upon the access granted by on-disk permissions. If you set this parameter to use_export_policy, file ownership can be changed in accordance with the relevant export rules. |
boolean |
Controls the permissions that are displayed to NFSv3 and NFSv4 clients on a file or directory that has an NT ACL set. When true, the displayed permissions are based on the maximum access granted by the NT ACL to any user. When false, the displayed permissions are based on the minimum access granted by the NT ACL to any user. |
string |
Specifies how NFSv3 security changes affect NTFS volumes. If you set this parameter to ignore, ONTAP ignores NFSv3 security changes. If you set this parameter to fail, this overrides the UNIX security options set in the relevant export rules. If you set this parameter to use_export_policy, ONTAP processes NFSv3 security changes in accordance with the relevant export rules.
array[string] |
Specifies the permitted encryption types for Kerberos over NFS. |
integer |
Specifies, in seconds, the amount of time a RPCSEC_GSS context is permitted to remain unused before it is deleted. |
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read |
integer |
total |
integer |
write |
integer |
v3
iops_raw |
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time. |
latency_raw |
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput_raw |
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
v4
iops_raw |
latency_raw |
status |
string |
throughput_raw |
timestamp |
string |
v41
iops_raw |
latency_raw |
status |
string |
throughput_raw |
timestamp |
string |
statistics
Realtime performance numbers, such as IOPS latency and throughput, for SVM-NFS protocol.
v3 |
v4 |
v41 |
svm
_links |
name |
string |
uuid |
string |
transport
rdma_enabled |
boolean |
Specifies whether RDMA transport is enabled for the NFS server. |
tcp_enabled |
boolean |
Specifies whether TCP transports are enabled on the server. |
integer |
Specifies the maximum transfer size in bytes, that the storage system negotiates with the client for TCP transport of data for NFSv3 and NFSv4.x protocols. The range is 8192 to 1048576. |
udp_enabled |
boolean |
Specifies whether UDP transports are enabled on the server. |
windows
default_user |
string |
Specifies the default Windows user for the NFS server. |
boolean |
Specifies whether or not the mapping of an unknown UID to the default Windows user is enabled. |
boolean |
Specifies whether NFSv3 MS-DOS client support is enabled. |
nfs_service
_links |
access_cache_config |
boolean |
Specifies whether or not extended groups support over AUTH_SYS is enabled. |
credential_cache |
enabled |
boolean |
Specifies if the NFS service is administratively enabled. |
exports |
integer |
Specifies the maximum auxiliary groups supported over AUTH_SYS and RPCSEC_GSS. |
integer |
Number of I/O operations on a file to be grouped and considered as one session for event generation applications, such as FPolicy. |
integer |
The duration for which I/O operations on a file will be grouped and considered as one session for event generation applications, such as FPolicy. |
metric |
Historical performance numbers, such as IOPS latency and throughput, for SVM-NFS protocol. |
protocol |
protocol_access_rules |
qtree |
root |
rquota_enabled |
boolean |
Specifies whether or not the remote quota feature is enabled. |
security |
showmount_enabled |
boolean |
Specifies whether or not the showmount feature is enabled. |
state |
string |
Specifies the state of the NFS service on the SVM. The following values are supported: * online - NFS server is ready to accept client requests. * offline - NFS server is not ready to accept client requests. |
statistics |
Realtime performance numbers, such as IOPS latency and throughput, for SVM-NFS protocol. |
svm |
transport |
vstorage_enabled |
boolean |
Specifies whether or not the VMware vstorage feature is enabled. |
windows |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
