REST API reference
Retrieve NFS configuration for SVMs
Retrieves the NFS configuration for storage virtual machines (SVMs) to understand their current settings and optimize network file sharing.
HTTP method and endpoint
GET /protocols/nfs/services
Introduced in
ONTAP 9.6
Usage notes
Retrieves the NFS configuration of SVMs.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • statistics.*
  • metric.*
  • vserver nfs show
  • vserver nfs status
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
positive_cached_credential_ttl
integer
query
False
Filter by positive_cached_credential_ttl
  • Introduced in: 9.8
transport.tcp_enabled
boolean
query
False
Filter by transport.tcp_enabled
transport.udp_enabled
boolean
query
False
Filter by transport.udp_enabled
enabled
boolean
query
False
Filter by enabled
statistics.v4.timestamp
string
query
False
Filter by statistics.v4.timestamp
statistics.v4.iops_raw.total
integer
query
False
Filter by statistics.v4.iops_raw.total
statistics.v4.iops_raw.other
integer
query
False
Filter by statistics.v4.iops_raw.other
statistics.v4.iops_raw.read
integer
query
False
Filter by statistics.v4.iops_raw.read
statistics.v4.iops_raw.write
integer
query
False
Filter by statistics.v4.iops_raw.write
statistics.v4.latency_raw.total
integer
query
False
Filter by statistics.v4.latency_raw.total
statistics.v4.latency_raw.other
integer
query
False
Filter by statistics.v4.latency_raw.other
statistics.v4.latency_raw.read
integer
query
False
Filter by statistics.v4.latency_raw.read
statistics.v4.latency_raw.write
integer
query
False
Filter by statistics.v4.latency_raw.write
statistics.v4.status
string
query
False
Filter by statistics.v4.status
statistics.v4.throughput_raw.total
integer
query
False
Filter by statistics.v4.throughput_raw.total
statistics.v4.throughput_raw.read
integer
query
False
Filter by statistics.v4.throughput_raw.read
statistics.v4.throughput_raw.write
integer
query
False
Filter by statistics.v4.throughput_raw.write
statistics.v3.timestamp
string
query
False
Filter by statistics.v3.timestamp
  • Introduced in: 9.7
statistics.v3.iops_raw.total
integer
query
False
Filter by statistics.v3.iops_raw.total
statistics.v3.iops_raw.other
integer
query
False
Filter by statistics.v3.iops_raw.other
statistics.v3.iops_raw.read
integer
query
False
Filter by statistics.v3.iops_raw.read
statistics.v3.iops_raw.write
integer
query
False
Filter by statistics.v3.iops_raw.write
statistics.v3.latency_raw.total
integer
query
False
Filter by statistics.v3.latency_raw.total
statistics.v3.latency_raw.other
integer
query
False
Filter by statistics.v3.latency_raw.other
statistics.v3.latency_raw.read
integer
query
False
Filter by statistics.v3.latency_raw.read
statistics.v3.latency_raw.write
integer
query
False
Filter by statistics.v3.latency_raw.write
statistics.v3.status
string
query
False
Filter by statistics.v3.status
statistics.v3.throughput_raw.total
integer
query
False
Filter by statistics.v3.throughput_raw.total
statistics.v3.throughput_raw.read
integer
query
False
Filter by statistics.v3.throughput_raw.read
statistics.v3.throughput_raw.write
integer
query
False
Filter by statistics.v3.throughput_raw.write
statistics.v41.timestamp
string
query
False
Filter by statistics.v41.timestamp
statistics.v41.iops_raw.total
integer
query
False
Filter by statistics.v41.iops_raw.total
statistics.v41.iops_raw.other
integer
query
False
Filter by statistics.v41.iops_raw.other
statistics.v41.iops_raw.read
integer
query
False
Filter by statistics.v41.iops_raw.read
statistics.v41.iops_raw.write
integer
query
False
Filter by statistics.v41.iops_raw.write
statistics.v41.latency_raw.total
integer
query
False
Filter by statistics.v41.latency_raw.total
statistics.v41.latency_raw.other
integer
query
False
Filter by statistics.v41.latency_raw.other
statistics.v41.latency_raw.read
integer
query
False
Filter by statistics.v41.latency_raw.read
statistics.v41.latency_raw.write
integer
query
False
Filter by statistics.v41.latency_raw.write
statistics.v41.status
string
query
False
Filter by statistics.v41.status
statistics.v41.throughput_raw.total
integer
query
False
Filter by statistics.v41.throughput_raw.total
statistics.v41.throughput_raw.read
integer
query
False
Filter by statistics.v41.throughput_raw.read
statistics.v41.throughput_raw.write
integer
query
False
Filter by statistics.v41.throughput_raw.write
protocol.v40_features.acl_enabled
boolean
query
False
Filter by protocol.v40_features.acl_enabled
protocol.v40_features.write_delegation_enabled
boolean
query
False
Filter by protocol.v40_features.write_delegation_enabled
protocol.v40_features.read_delegation_enabled
boolean
query
False
Filter by protocol.v40_features.read_delegation_enabled
protocol.v4_id_domain
string
query
False
Filter by protocol.v4_id_domain
protocol.v4_64bit_identifiers_enabled
boolean
query
False
Filter by protocol.v4_64bit_identifiers_enabled
protocol.v41_features.acl_enabled
boolean
query
False
Filter by protocol.v41_features.acl_enabled
protocol.v41_features.pnfs_enabled
boolean
query
False
Filter by protocol.v41_features.pnfs_enabled
protocol.v41_features.write_delegation_enabled
boolean
query
False
Filter by protocol.v41_features.write_delegation_enabled
protocol.v41_features.read_delegation_enabled
boolean
query
False
Filter by protocol.v41_features.read_delegation_enabled
protocol.v41_enabled
boolean
query
False
Filter by protocol.v41_enabled
protocol.v3_enabled
boolean
query
False
Filter by protocol.v3_enabled
protocol.v3_64bit_identifiers_enabled
boolean
query
False
Filter by protocol.v3_64bit_identifiers_enabled
protocol.v40_enabled
boolean
query
False
Filter by protocol.v40_enabled
auth_sys_extended_groups_enabled
boolean
query
False
Filter by auth_sys_extended_groups_enabled
showmount_enabled
boolean
query
False
Filter by showmount_enabled
state
string
query
False
Filter by state
metric.v41.timestamp
string
query
False
Filter by metric.v41.timestamp
metric.v41.throughput.total
integer
query
False
Filter by metric.v41.throughput.total
metric.v41.throughput.read
integer
query
False
Filter by metric.v41.throughput.read
metric.v41.throughput.write
integer
query
False
Filter by metric.v41.throughput.write
metric.v41.latency.total
integer
query
False
Filter by metric.v41.latency.total
metric.v41.latency.other
integer
query
False
Filter by metric.v41.latency.other
metric.v41.latency.read
integer
query
False
Filter by metric.v41.latency.read
metric.v41.latency.write
integer
query
False
Filter by metric.v41.latency.write
metric.v41.iops.total
integer
query
False
Filter by metric.v41.iops.total
metric.v41.iops.other
integer
query
False
Filter by metric.v41.iops.other
metric.v41.iops.read
integer
query
False
Filter by metric.v41.iops.read
metric.v41.iops.write
integer
query
False
Filter by metric.v41.iops.write
metric.v41.duration
string
query
False
Filter by metric.v41.duration
metric.v41.status
string
query
False
Filter by metric.v41.status
metric.v3.timestamp
string
query
False
Filter by metric.v3.timestamp
metric.v3.throughput.total
integer
query
False
Filter by metric.v3.throughput.total
metric.v3.throughput.read
integer
query
False
Filter by metric.v3.throughput.read
metric.v3.throughput.write
integer
query
False
Filter by metric.v3.throughput.write
metric.v3.latency.total
integer
query
False
Filter by metric.v3.latency.total
metric.v3.latency.other
integer
query
False
Filter by metric.v3.latency.other
metric.v3.latency.read
integer
query
False
Filter by metric.v3.latency.read
metric.v3.latency.write
integer
query
False
Filter by metric.v3.latency.write
metric.v3.iops.total
integer
query
False
Filter by metric.v3.iops.total
metric.v3.iops.other
integer
query
False
Filter by metric.v3.iops.other
metric.v3.iops.read
integer
query
False
Filter by metric.v3.iops.read
metric.v3.iops.write
integer
query
False
Filter by metric.v3.iops.write
metric.v3.duration
string
query
False
Filter by metric.v3.duration
metric.v3.status
string
query
False
Filter by metric.v3.status
metric.v4.timestamp
string
query
False
Filter by metric.v4.timestamp
metric.v4.throughput.total
integer
query
False
Filter by metric.v4.throughput.total
metric.v4.throughput.read
integer
query
False
Filter by metric.v4.throughput.read
metric.v4.throughput.write
integer
query
False
Filter by metric.v4.throughput.write
metric.v4.latency.total
integer
query
False
Filter by metric.v4.latency.total
metric.v4.latency.other
integer
query
False
Filter by metric.v4.latency.other
metric.v4.latency.read
integer
query
False
Filter by metric.v4.latency.read
metric.v4.latency.write
integer
query
False
Filter by metric.v4.latency.write
metric.v4.iops.total
integer
query
False
Filter by metric.v4.iops.total
metric.v4.iops.other
integer
query
False
Filter by metric.v4.iops.other
metric.v4.iops.read
integer
query
False
Filter by metric.v4.iops.read
metric.v4.iops.write
integer
query
False
Filter by metric.v4.iops.write
metric.v4.duration
string
query
False
Filter by metric.v4.duration
metric.v4.status
string
query
False
Filter by metric.v4.status
extended_groups_limit
integer
query
False
Filter by extended_groups_limit
vstorage_enabled
boolean
query
False
Filter by vstorage_enabled
rquota_enabled
boolean
query
False
Filter by rquota_enabled
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of NFS Server Records
records
array[nfs_service]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "extended_groups_limit": "32",
      "metric": {
        "v3": {
          "duration": "PT15S",
          "iops": {
            "read": "200",
            "total": "1000",
            "write": "100"
          "latency": {
            "read": "200",
            "total": "1000",
            "write": "100"
          "status": "ok",
          "throughput": {
            "read": "200",
            "total": "1000",
            "write": "100"
          "timestamp": "2017-01-25T11:20:13Z"
        "v4": {
          "iops": {
            "read": "200",
            "total": "1000",
            "write": "100"
          "latency": {
            "read": "200",
            "total": "1000",
            "write": "100"
          "status": "ok",
          "throughput": {
            "read": "200",
            "total": "1000",
            "write": "100"
        "v41": {
          "iops": {
            "read": "200",
            "total": "1000",
            "write": "100"
          "latency": {
            "read": "200",
            "total": "1000",
            "write": "100"
          "status": "ok",
          "throughput": {
            "read": "200",
            "total": "1000",
            "write": "100"
      "positive_cached_credential_ttl": "7200000",
      "protocol": {
        "v4_id_domain": "string"
      "state": "string",
      "statistics": {
        "v3": {
          "iops_raw": {
            "read": "200",
            "total": "1000",
            "write": "100"
          "latency_raw": {
            "read": "200",
            "total": "1000",
            "write": "100"
          "status": "ok",
          "throughput_raw": {
            "read": "200",
            "total": "1000",
            "write": "100"
        "v4": {
          "iops_raw": {
            "read": "200",
            "total": "1000",
            "write": "100"
          "latency_raw": {
            "read": "200",
            "total": "1000",
            "write": "100"
          "status": "ok",
          "throughput_raw": {
            "read": "200",
            "total": "1000",
            "write": "100"
        "v41": {
          "iops_raw": {
            "read": "200",
            "total": "1000",
            "write": "100"
          "latency_raw": {
            "read": "200",
            "total": "1000",
            "write": "100"
          "status": "ok",
          "throughput_raw": {
            "read": "200",
            "total": "1000",
            "write": "100"
      "svm": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
read
integer
total
integer
write
integer
v3
The NFSv3 operations
_links
_links
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
v4
The NFSv4 operations
_links
_links
duration
string
iops
iops
latency
latency
status
string
throughput
throughput
timestamp
string
v41
The NFSv4.1 operations
_links
_links
duration
string
iops
iops
latency
latency
status
string
throughput
throughput
timestamp
string
metric
Historical performance numbers, such as IOPS latency and throughput, for SVM-NFS protocol.
v3
v3
v4
v4
v41
v41
v40_features
acl_enabled
boolean
Specifies whether NFSv4.0 ACLs is enabled.
boolean
Specifies whether NFSv4.0 Read Delegation is enabled.
boolean
Specifies whether NFSv4.0 Write Delegation is enabled.
v41_features
acl_enabled
boolean
Specifies whether NFSv4.1 or later ACLs is enabled.
pnfs_enabled
boolean
Specifies whether NFSv4.1 or later Parallel NFS is enabled.
boolean
Specifies whether NFSv4.1 or later Read Delegation is enabled.
boolean
Specifies whether NFSv4.1 or later Write Delegation is enabled.
protocol
boolean
Specifies whether 64-bit support for NFSv3 FSIDs and file IDs is enabled.
v3_enabled
boolean
Specifies whether NFSv3 protocol is enabled.
v40_enabled
boolean
Specifies whether NFSv4.0 protocol is enabled.
v40_features
v40_features
v41_enabled
boolean
Specifies whether NFSv4.1 or later protocol is enabled.
v41_features
v41_features
boolean
Specifies whether 64-bit support for NFSv4.x FSIDs and file IDs is enabled.
v4_id_domain
string
Specifies the domain portion of the string form of user and group names as defined by the NFSv4 protocol.
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read
integer
total
integer
write
integer
v3
iops_raw
iops_raw
latency_raw
latency_raw
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput_raw
throughput_raw
timestamp
string
v4
iops_raw
iops_raw
latency_raw
latency_raw
status
string
throughput_raw
throughput_raw
timestamp
string
v41
iops_raw
iops_raw
latency_raw
latency_raw
status
string
throughput_raw
throughput_raw
timestamp
string
statistics
Realtime performance numbers, such as IOPS latency and throughput, for SVM-NFS protocol.
v3
v3
v4
v4
v41
v41
svm
_links
_links
name
string
The name of the SVM.
uuid
string
transport
tcp_enabled
boolean
Specifies whether TCP transports are enabled on the server.
udp_enabled
boolean
Specifies whether UDP transports are enabled on the server.
nfs_service
_links
_links
boolean
Specifies whether or not extended groups support over AUTH_SYS is enabled.
enabled
boolean
Specifies if the NFS service is administratively enabled.
integer
Specifies the maximum auxillary groups supported over AUTH_SYS and RPCSEC_GSS.
metric
metric
integer
Specifies the time to live value (in msecs) of a positive cached credential
protocol
protocol
rquota_enabled
boolean
Specifies whether or not the remote quota feature is enabled.
showmount_enabled
boolean
Specifies whether or not the showmount feature is enabled.
state
string
Specifies the state of the NFS service on the SVM. The following values are supported: * online - NFS server is ready to accept client requests. * offline - NFS server is not ready to accept client requests.
statistics
statistics
svm
svm
transport
transport
vstorage_enabled
boolean
Specifies whether or not the VMware vstorage feature is enabled.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
