Retrieve data-entropy statistics for volumes
GET /security/anti-ransomware/volume/entropy-stats
Introduced In: 9.17
Retrieves the data-entropy statistics for the volumes.
timestamp |
string |
query |
False |
Filter by timestamp |
duration |
string |
query |
False |
Filter by duration |
data_written_in_bytes |
integer |
query |
False |
Filter by data_written_in_bytes |
entropy_stats_type |
string |
query |
False |
Filter by entropy_stats_type |
volume.uuid |
string |
query |
False |
Filter by volume.uuid |
volume.name |
string |
query |
False |
Filter by volume.name |
encryption_percentage |
integer |
query |
False |
Filter by encryption_percentage |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"data_written_in_bytes": 0,
"duration": "PT15M",
"encryption_percentage": 0,
"entropy_stats_type": "string",
"timestamp": "string",
"volume": {
"name": "volume1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
volume
_links |
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
records
Volume data-entropy statistics derived from block analysis.
_links |
integer |
The amount of data written. |
duration |
string |
The duration of the interval associated with this statistic. The duration is represented in ISO-8601 standard format. |
integer |
The percentage of data that is encrypted. |
string |
Volume metrics are retrieved based on this statistic type. |
timestamp |
string |
Start time in date-time format. |
volume |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
