REST API reference
Retrieve data-entropy statistics for volumes
GET /security/anti-ransomware/volume/entropy-stats
Introduced In: 9.17
Retrieves the data-entropy statistics for the volumes.
volume.name
string
query
False
Filter by volume.name
volume.uuid
string
query
False
Filter by volume.uuid
timestamp
string
query
False
Filter by timestamp
data_written_in_bytes
integer
query
False
Filter by data_written_in_bytes
encryption_percentage
integer
query
False
Filter by encryption_percentage
duration
string
query
False
Filter by duration
entropy_stats_type
string
query
False
Filter by entropy_stats_type
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[records]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "data_written_in_bytes": 0,
      "duration": "PT15M",
      "encryption_percentage": 0,
      "entropy_stats_type": "string",
      "timestamp": "string",
      "volume": {
        "name": "volume1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
volume
_links
_links
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
records
Volume data-entropy statistics derived from block analysis.
_links
_links
integer
The amount of data written.
duration
string
The duration of the interval associated with this statistic. The duration is represented in ISO-8601 standard format.
integer
The percentage of data that is encrypted.
entropy_stats_type
string
Volume metrics are retrieved based on this statistic type.
timestamp
string
Start time in date-time format.
volume
volume
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
