REST API reference
Retrieve the anti-ransomware version of the nodes in the cluster
Obtains the anti-ransomware package version of the nodes in your cluster. This information helps you verify the current protection level against ransomware attacks.
HTTP method and endpoint
GET /security/anti-ransomware
Introduced in
ONTAP 9.16
Usage notes
Retrieves the anti-ransomware package version of the nodes in the cluster.
  • security anti-ransomware show
fields
array[string]
query
False
Specify the fields to return.
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Name Type Description
nodes
array[anti_ransomware_node]
uri
string
URI of the anti-ransomware package through a server
  "nodes": [
      "name": "node1",
      "version": "1.0"
  "uri": "http://server/package"
Status: Default
ONTAP Error Response Codes
Error Code Description
917775
Operation is not supported on offline volumes.
203161606
Failed to check the "anti-ransomware-state" of the volume.
203162108
Operation is not supported on volumes that contain LUNs or namespaces.
203162109
Operation is not supported on an anti-ransomware disable-in-progress volume.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
name
string
Name of the node.
version
string
Anti-ransomware version.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
