REST API reference
Retrieve the AKV configuration for an SVM specified by the UUID
Retrieves the AKV configuration for a specific SVM to review the security settings associated with that SVM's key management.
HTTP method and endpoint
GET /security/azure-key-vaults/{uuid}
Introduced in
ONTAP 9.8
Usage notes
Retrieves the AKV configuration for the SVM specified by the UUID.
  • security key-manager external azure show
  • security key-manager external azure check
uuid
string
path
True
AKV UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
authentication_method
string
Authentication method for the AKV instance.
azure_reachability
azure_reachability
Indicates whether or not the AKV service is reachable from all the nodes in the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
client_id
string
Application client ID of the deployed Azure application with appropriate access to an AKV.
configuration
configuration
Security keystore object reference.
ekmip_reachability
array[ekmip_reachability]
enabled
boolean
Indicates whether the configuration is enabled.
key_id
string
Key Identifier of AKV key encryption key.
name
string
Name of the deployed AKV that will be used by ONTAP for storing keys.
oauth_host
string
Open authorization server host name.
port
integer
Authorization server and vault port number.
proxy_host
string
Proxy host.
proxy_port
integer
Proxy port.
proxy_type
string
Type of proxy.
proxy_username
string
Proxy username.
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
skip_verification
boolean
Set to true to skip the verification of the updated user credentials when updating credentials. The default value is false.
state
state
Indicates whether or not the AKV wrapped internal key is available cluster wide. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
svm
svm
tenant_id
string
Directory (tenant) ID of the deployed Azure application with appropriate access to an AKV.
uuid
string
A unique identifier for the Azure Key Vault (AKV).
vault_host
string
AKV host subdomain.
verify_host
boolean
Verify the identity of the AKV host name.
verify_ip
boolean
Verify the identity of the AKV IP address.
      "href": "/api/resourcelink"
  "authentication_method": "client_secret",
  "azure_reachability": {
    "code": "346758",
    "message": "AKV service is not reachable from all nodes - reason."
  "client_id": "aaaaaaaa-bbbb-aaaa-bbbb-aaaaaaaaaaaa",
  "configuration": {
    "name": "default",
    "uuid": "1cd8a442-86d1-11e0-ae1c-123478563434"
  "ekmip_reachability": [
      "code": "346758",
      "message": "embedded KMIP server status unavailable on node.",
      "node": {
        "name": "node1",
  "key_id": "https://keyvault1.vault.azure.net/keys/key1/12345678901234567890123456789012",
  "name": "https://kmip-akv-keyvault.vault.azure.net/",
  "oauth_host": "login.microsoftonline.com",
  "port": 443,
  "proxy_host": "proxy.eng.com",
  "proxy_port": 1234,
  "proxy_type": "http",
  "proxy_username": "proxyuser",
  "scope": "string",
  "skip_verification": "",
  "state": {
    "code": "346758",
    "message": "Top-level internal key protection key (KEK) is unavailable on the following nodes with the associated reasons: Node: node1. Reason: No volumes created yet for the SVM. Wrapped KEK status will be available after creating encrypted volumes."
  "svm": {
    "name": "svm1",
  "tenant_id": "zzzzzzzz-yyyy-zzzz-yyyy-zzzzzzzzzzzz",
  "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
  "vault_host": "vault.azure.net",
  "verify_host": "",
  "verify_ip": ""
Status: Default
ONTAP Error Response Codes
Error Code Description
65537549
The Azure Key Vault Key Management Service is unreachable from one or more nodes.
65537551
Top-level internal key protection key (KEK) unavailable on one or more nodes.
65537552
Embedded KMIP server status not available.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
azure_reachability
code
string
Code corresponding to the status message. Returns a 0 if AKV service is reachable from all nodes in the cluster.
message
string
Error message set when reachability is false.
reachable
boolean
Set to true when the AKV service is reachable from all nodes of the cluster.
configuration
_links
_links
name
string
Name of the configuration.
uuid
string
Keystore UUID.
node
_links
_links
name
string
uuid
string
ekmip_reachability
Provides the connectivity status for the given SVM on the given node to all EKMIP servers configured on all nodes of the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code
string
Code corresponding to the error message. Returns a 0 if a given SVM is able to communicate to the EKMIP servers of all of the nodes in the cluster.
message
string
Error message set when cluster-wide EKMIP server availability from the given SVM and node is false.
node
node
reachable
boolean
Set to true if the given SVM on the given node is able to communicate to all EKMIP servers configured on all nodes in the cluster.
state
available
boolean
Set to true when an AKV wrapped internal key is present on all nodes of the cluster.
code
string
Code corresponding to the status message. Returns a 0 if AKV wrapped key is available on all nodes in the cluster.
message
string
Error message set when top-level internal key protection key (KEK) availability on cluster is false.
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
